MBR0540T1G
MBR0540T1G
    JSMICRO(杰盛微)
    SOD123
    肖特基二极管 40V 500mA 620mV@1A SOD123
MBR0540T1G 数据手册
MBR0520/30/40T1G Schottky Barrier Diode FEATURES   Low forward voltage drop. Guard ring construction for transient Protection.  High conductance.  MSL 1 to r SOD-123 APPLICATIONS 0.5A surface mount schottky barrier rectifier. nd uc  MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol RMS Reverse Voltage MBR0530 MBR0540 Unit VRRM VRWM 20 30 40 V Se mi Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Reverse Voltage MBR0520 co Characteristic 14 21 28 V VR VR(RMS) Average Rectified Output Current @ TL = 100℃ CR O Non-Repetitive Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load 0.5 A IFSM 5.5 A Pd 410 410 mW RθjA 182 244 ℃/W Operating and Storage Temperature Range Tj,Tstg -65 to +100 -65 to +125 ℃ JS Power Dissipation IO dv/dt MI Typical Thermal Resistance Junction to Ambient Voltage Rate of Change www.jsmsemi.com 1000 V/μs 第1页,共4页 MBR0520/30/40T1G Schottky Barrier Diode ELECTRICAL CHARACTERISTICS @ Ta=25℃ Maximum Leakage Current V(BR)R 20 - 30 - 40 VFM 0.300 0.385 0.220 0.330 - 0.375 0.430 - 0.510 0.620 0.460 0.610 75 250 - 20 130 - 10 20 μA VR=10V,Tj=25℃ VR=15V,Tj=25℃ VR=20V,Tj=25℃ VR=30V,Tj=25℃ VR=40V,Tj=25℃ 5.0 13 mA VR=10V,Tj=100℃ VR=20V,Tj=100℃ VR=40V,Tj=100℃ IRM CJ 170 Unit IR= 250μA IR= 130μA IR= 20μA IF=0.1A, Tj =25℃ IF=0.5A, Tj =25℃ IF=1.0A, Tj =25℃ IF=0.1A, Tj =100℃ IF=0.5A, Tj =100℃ IF=1.0A, Tj =100℃ to r V Test Conditions V pF f=1MHz,VR=0V DC JS MI CR O Junction Capacitance - Se mi 5.0 8.0 - MBR0530 MBR0540 uc Maximum Forward Voltage Drop MBR0520 nd Minimum Reverse Breakdown Voltage Symbol co Characteristic unless otherwise specified www.jsmsemi.com 第2页,共4页 MBR0520/30/40T1G Schottky Barrier Diode JS MI CR O Se mi co nd uc to r TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.jsmsemi.com 第3页,共4页 MBR0520/30/40T1G Schottky Barrier Diode PACKAGE OUTLINE Plastic surface mounted package SOD-123 SOD-123 K C Dim Min Max A 1.45 1.75 B A 2.55 2.85 1.00 1.30 0.50 0.60 E 0.25 0.45 H 0.02 0.10 J 0.05 0.15 K 3.55 3.85 C D uc D H nd E All Dimensions in mm Se mi co J to r B SOLDERING FOOTPRINT O 0.91 MI CR 1.22 JS 2.36 4.19 Unit:mm PACKAGE INFORMATION Device MBR0520/30/40T1G Package Shipping SOD-123 3000pcs / Tape & Reel www.jsmsemi.com 第4页,共4页
MBR0540T1G 价格&库存
很抱歉,暂时无法提供与“MBR0540T1G”相匹配的价格&库存,您可以联系我们找货
