Crystal Unit
YSX321SL
Applications
Features
‧Smart Wearable
‧Dimensions: 3.20 x 2.50 x 0.70 mm..
‧High precision and high frequency stability.
IOT Communication
‧Standard Frequency: 8~54MHz
‧Extremely good for reducing EMI effect.
Specifications(规格参数)
Item
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Symbol
Specifications
f_nom
8~64MHz
AT Fundamental
CL
10pF, 20pF, or specify
f_tol
±10ppm, ±20ppm, or specify
f_tem
±20ppm, or specify
T_use
-40~+85℃ or specify
T_stg
-55~+125℃
C0
7pF Max.
DL
1~200μW Max.(100μW typical)
f_age
±3ppm/year Max.
Equivalent Series Resistance(等效串联电阻(ESR))
YST321SL
8 ~ 11.2892MHz
150 Ω Max.
12 ~ 16MHz
80 Ω Max.
17 ~ 64MHz
50 Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XL2OI-111-32M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27285
- 100+0.25466
- 300+0.23647
- 500+0.21828
- 2000+0.20919
- 5000+0.20373
