Crystal Unit
32.768KHZ
YT-26 DIP
Applications Features
‧RTC
‧Dimensions: 2.0 x 6.0mm..
‧Standard Frequency: 32.768KHz
‧Resistance welded type crystal units.
‧Low impedance performance.
Specifications(规格参数)
Item
Symbol
Specifications
f_nom
32.768KHz
Frequency Tolerance(频率偏差) (at 25℃ )
CL
12.5pF, or specify
f_tol
±5ppm, ±10ppm, or specify
Operating Temperature(工作温度)
B
( - 0.036 ± 0.01 ) * 10-6/ ℃2
T_use
-20~+70℃, 40~+85℃, or specify
T_stg
-55~+125℃
C0
2.0pF Max.
C1
3.0fF
DL
1.0μW Typ.
f_age
±3ppm/year Max.
Nominal Frequency(额定频率范围)
Load Capacitance(负载电容)
Parabolic Coefficient(频率温度系数)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Motional Capacitance(动态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Equivalent Series Resistance(等效串联电阻(ESR))
YT-26
40K Ω Max.
Dimensions(外观尺寸)
Dimensions (Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“Y6OGC-STU-32.768K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27000
- 100+0.25200
- 300+0.23400
- 500+0.21600
- 2000+0.20700
- 5000+0.20160
