承
認
書
SPECIFICATION FOR APPROVAL
*客戶名稱
Customer name
*產品名稱
Product Description
*產品型號
Product part number
*客戶料號
Customer's material number
*數量
Quantity
*日期
Date
: 电源插座
DC-005Aφ2.0-PU
供應商負責人簽名
客戶負責人確認簽回
製作人
莫丽琴
承認人
審核
郭远维
審核
批准
王瑞宝
批准
皓宇(香港)有限公司
HAOYU (HONG KONG) LIMITED
东莞市弘皓电子有限公司
DONGGUAN HOOYA ELECTRONICS CO.LTD
東莞市石碣鎮四村第一工業區
Sicun 1st Industrial park, Sicun,
Shijie Town, Dongguan
電 話
Tel No
: (86)769-82310511-867
傳 真
Fax No
: (86)769-82310510
郵 箱
E - mail
: hooya89@hooya.hk
核 准
Approved
版本號* Issue No:HYMD-Z201204Y
Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร1
SERIES ขߓ٨
DC POWER JACK (DIP) ऴ༺ ڤDC ሽᄭ༺ஆ
TYPE ขীᇆ
DC-005A
DRAWN
LI JIAN
APVD ᐉ
ޕᏦ
ૠ
1ΗRATINGΰᠰࡳଖαΚDC24V 3.5A
Apply to the appended drawing.
ዌ֡՚
ฤףॵٽቹ
ᖙ܂ᄵ৫ᒤ
ႈؾ
CONSTRUCTION DIMENSION
2ΗOPERATING TEMPERATURE RANGE
ITEM
ޅ
٥3
-20к~70к
PRESERVATIVE TEMPERATURE RANGE
15к~35к
ᚏژᄵ৫ᒤ
TEST CONDITIONS ྒྷᇢයٙ
SPECIFICATIONS
3ΗELECTRICAL PERFORMANCEΰሽࢤ౨αΚ
MEASURED BY THE CONTACT RESISTANCE APPARATUS OR mӨ
CONTACT
3A
RESISTANCE
൷ᤛሽॴ
METER AT 0.1A DC5V .THE RESULT IS THE AVERAGE OF5
SUCCESSIVE MEASUREMENTS.
ڇሽᚘ 5VΔऴੌሽੌ 0.1A ழΔش൷ᤛሽॴྒྷၦᏚࢨශᑛ।ྒྷၦΖ
50mӨ
max
50 ශᑛאՀ
࣠࠷ྒྷၦ 5 ڻ৵ऱؓ݁ଖΖ
A VOLTAGE OF 250V DC SHALL BE APPLIED
FOR 1 MIN. AFTER WHICH MEASUREMENT SHALL BE MADE.
3B
INSULATION
BETWEEN TERMINALS
RESISTANCE
BETWEEN INDIVIDUAL TERMINALS AND FRAME
100MӨ min
ᙁԵ 250V DC ሽᚘ 1 ։ᤪ,ਊאՀ൷ᤛֱऄྒྷᇢ
100 ٢ᑛאՂ.
ᒴॴݼ
(1) ൷ᤛጤհၴ
(2) ༺ஆ᧯ءፖጤհၴ
A VOLTAGE OF250V AC SHALL BE APPLIED
DIELECTRIC
3C
STRENGTH
રሽᚘ
BETWEEN TERMINALS
ᙁԵ 250V AC ሽᚘ 1 ։ᤪ,ਊאՀ൷ᤛֱऄྒྷᇢ
(3) ൷ᤛጤհၴ
WITHOUT DAMAGE
TO PARTS ARCING
OR BREAKDOWN ETC
ڶჾ႞ ᧢ݮᒴధᡏฆൄ.
(4) ༺ஆ᧯ءፖጤհၴ
4.MECHANICAL PERFORMANCE(ᖲඳࢤ౨)
4A
INSERTION
AND
WITHDRAW
FORCE ༺ࢸԺ
Being measure at across spring piece and across matching plug for
ergometer
ྒྷشԺૠ༺ڇᙰፖᐘׂհၴၞ۩ྒྷၦΗ(़༺Կڻ৵ྒྷᇢ)
Insertion and extraction force
3-30N
༺ࢸԺ
3-30 ׄቅ
ELECTRICAL
SHALL
4B
BE
CHARACTERISTICS
SATISFIED.WITHOUT
TERMINAL
A STATIC LOAD OF 10 N(1000gf) SHALL BE APPLIED TO THE TIP
DAMAGE OR EXCESSIVE LOOSEN-ESS
STRENGTH
OF THE TERMINALS FOR 60 SEC. IN ANY DIRECTION
OF ACTUATOR
ڇٚრԫଡֱٻऱ٣ጤՂףԺ৫ 10N(1000gf)60 ઞᤪ
ڇጤխڶါၲ\ᠾ೯ฆൄ
ጤൎ৫
የߩ࣍ሽᕴࢤ౨.
UNLESS OTHERWISE SPECIFIED. THE STANDRD RANGE
STANDARD
4C
ATMOSPHEIC
CONDITIONS
ࠌشᑑᄷणኪ
OF ATMOSPHERIC CONDITIONS FOR MAKING MEASUREMENTS
ڶڇਐࡳऱൣउՀྒྷᇢᄵ৫ᛘ
AND TESTS ARE AS FOLLOWS:
৫ΕᚘڕՀΚ
AMDIENT TEMPERATURE: 15к TO 35к
˄1˅ ᄵ৫ 15к~35к
RELATIVE HUMIDITY
˄2˅ ᛘ৫ 25%~ 85%RH
AIR PRESSURE
:25%TO 85%RH
:80Kpa TO 106Kpa
˄3˅ ᚘ 80Kpa ~106Kpa
Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร2
٥3
5ΗDURABILITY ΰરՆࢤα
THE TOP OF THE TERMINALS SHALL BEDIPPED 2mm
IN THE SOLDER BATH OF220 ̈́ 5 к
5A
FOR 3 ̈́ 0.5
SOLDERABILITY
SECONDS. THE PLASTIC BODY IS 1.6mm ABOVE THE
TEST
TIN LIGUID.
ጤືຝ௦Ե෬ᙔۃխ 2mm Δᄵ৫ 220̈́5кΔழၴ
3̈́ 0.5 ઞ. ֫ՠ෬൷ᄵ৫ 350̈́5кΔழၴ 2̈́0.5 ઞΖ
ᓄߪ၏ᠦᙔ 1.6mmΖ
ࣹΚءขᔞ֫شٽ෬Εं෬Ζ
ױ෬ࢤᇢ᧭
˄1˅ SOLDER WETTING TIME
SHALL BE 3 SEC OR LESS
෬൷ழၴᚨ֟࣍ 3 ઞ
˄2˅
THE AREA
OF SOLDERABILITY
SHOULD BE OVER 90%
෬൷૿ᗨ ڶ90%אՂ
WITHOUT DEFORMATION OF CASE
RESISTANCE
TO
5B
SOLDERING
HEATʳ TEST
ર෬ࢤᇢ᧭
OR
THE TOP OF THE TERMINALS SHALL BEDIPPED 2mm .
THE PLASTIC BODY IS 1.6mm ABOVE THE TIN LIGUID.
ጤືຝ௦Ե෬ᙔۃխ 2mm , ᓄߪ၏ᠦᙔ 1.6mmΖ
Wave-soldering is to be performed within 3seconds at 260 +/-5
к ं෬൷ᄵ৫ 260 +/-5к ழၴ 3 ઞΖ
Hand weilding to be performed within 3 seconds at 380к or
below. ֫ՠ෬൷ᄵ৫ 380кࢨאփΔழၴ 3̈́0.5 ઞΖ
ࣹΚءขᔞ֫شٽ෬Εं෬Ζ
EXCESSIVE
LOOSENESS
OF
TERMINALS
ELECTRICAL
CHARACTERISTICS
SHALL
BE SATISFIED.
ݮ᧢ྤ᧯ءΔ ౨የߩ࣍ᖲඳΕሽࢤ
౨Ζ
5C
LIFE TEST.
ኂࡎᇢ᧭
WITHOUT LOAD ΰ IT IS TESTED BY MACHINE Δ
ACTING FORCE MUST BE PARALLED TO THE WAY OF
PUSHINGαΚ
AN ACTUATOR SHALL BE SUBIECT TO 5000 CYCLES
AT A SPEED OF30 CYCLES FOR 1 MIN
ྤ๛ΰ࣍ૻᖲᕴྒྷᇢΔش܂Ժؓ۩࣍༺ࢸֱٻαΚ
ᖙޢאृ܂։ᤪ 30 ڻऱ᙮ ܂5000 ڃհྤ๛ྒྷᇢΖ
˄1˅ CONTACT
RESISTANCE
SHALLBE 200mӨmax
˄2˅ MECHANICAL
AND
ELECTRICAL
CHARACTERISTICS SHALL
BESATISFIEDΖ
˄1˅ ൷ᤛሽॴլ౨၌࣍ 200mӨ
˄2˅ ࠡהየߩ࣍ᖲඳሽᕴࢤ౨Ζ
85̈́2к FOR 48 HOURS AFTER TEST KEEP IN NORMAL
5D
HEAT TEST.
રᑷᇢ᧭
CONDITION FOR 30 MINUTES.
ڇ85̈́2кᛩቼխ࣋ 48 ՛ழ,٦࣋إڇൄᛩቼխ 30 ։ᤪ৵ၞ
۩ྒྷᇢΖ
40 ̈́ 2 к
5E
HUMIDITY TEST.
રᛘᇢ᧭
THERE SHALL BE NO DAMAGE ON
90-96%RH FOR 48 HOURS, TEST AFTER
MECHANICAL AND ELECTRICAL
ڇ40̈́2к 90Ё96иRH ᛩቼխ࣋ 48 ՛ழΔ٦࣋إڇൄᛩ
CHARACTERISTICS
ቼխΔ30 ։ᤪ৵ၞ۩ྒྷᇢΖ
SATISFIED
AT –40 ̈́ 2 к FOR 48 HRS. AFTER TEST KEEP IN
5F
COLD TEST.
રܐᇢ᧭
APPEARANCEΖ
KEEPING IN NORMAL CONDITION FOR 30 MIN.
SHALL
BE
؆ᨠྤฆൄΔየߩ࣍ᖲඳΔሽᕴࢤ౨Ζ
ڇ-40̈́2кᛩቼխ࣋ 48 ՛ழ,٦ᆜ࣍إൄᛩቼխ 30 ։ᤪ৵ၞ
۩ྒྷᇢΖ
SALT SPRAY TEST
5G
Ᏼᣆᇢ᧭
AT 5% NACL LIQUOR FOR 24HOURS, AFTER WASHING,
KEEP IN NORMAL CONDITION FOR 30 MIN.
5%ऱ Nacl ᄫխᏴᣆ 24 ՛ழΔֽش堚ੑࠀ
ڇᄵՀ࣋ᆜ 30 ։ᤪ
WITHOUT EXCESSIVE CORROSION
OR CRACK IN APPEARANCE
।૿ྤࣔ᧩ፍ፱ࢨᝳᐋๅᆵွ
Ⱨᅛ(佭␃)᳝䰤݀ৌ
֮ٙᒳᇆ
HY-WI-32
࿇۩ֲཚ
2008-07-23
SPECIFICATION
ࢭᎁ
ร B-2 ठ
ร3
٥3
6ΗࣹრࠃႈΰAPPLICATION NOTES:α
Εڇર෬൷መ࿓խ,լ࣪ނଉᒴΕڶፍ፱ࢤढᔆ௦ԵขփΖ
ΰROSIN AND OTHER INSULATING AND CAUSTIC MATERIAL CAN NOT BE DIPPED INTO THE ROCKET DURING
SOLDERING.α
2Εข෬൷৵լ౨شዓشࢨܬᄫᕪޱੑΖ
ΰPRODUCTS CAN NOT BE BLOWN WITH AIR GUN OR CLEANED WITH A SOLVENT AFTER SOLDERING.)
3Εข෬൷ছٺሿٙլ౨ᄫ֏Ζ
ΰALL PARTS OF THE PRODUCTS CAN NOT BE DISSOLVED BEFORE SOLDERING.α
4Εᝩ܍ᚏ៲࣍ᄵΕᑪᛘ֗ፍ፱ऱࢬΖ
ΰAVOID STORING THE PRODUCTS IN A PLACE AT HIGH TEMPERATURE, HIGH HUMIDITY AND
IN CORROSIVE GASES.)
5Εဿژཚૻ:۞࿇ຄհֲದ,ဿژཚլ၌መ 180 ֚.ૉ၌נဿژཚૻ,ขسլߜ,ءֆᄗլຂΖ
ΰSHELF LIFE IS LESS THAN 180 DAYS SINCE THE GOODS WARE SENT OUT FROM OUR FACTORY. OUR COMPANY
DOESN’T ACCEPT RESPONSIBILITY FOR REJECTS IF THE SHELF LIFE OF GOODS EXCEEDS 180 DAYS.α
6ΕءขڶڕլߜࠃٙΔඨᐗ୮֗ழڃ墅Δ֗ঁאழಖᙕΕுΕޏΕᇿ᠋Ζ
ΰPLEASE FEEL FREE TO REPORT TO US IF YOU DISCOVER THE INFERIOR GOODS, SO THAT WE CAN TAKE NOTE,
CHECK, TRACK AND IMPROVE THEM. THANKS.α
Ⱨᅛ(佭␃)᳝䰤݀ৌ
很抱歉,暂时无法提供与“DC-005A∅2.0-PU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39000
- 10+0.36000
- 30+0.35400
- 100+0.33600
