SY8388ARHC
SY8388ARHC
    SILERGY(矽力杰)
    QFN16_2.5X2.5MM_EP
    高效快速响应,8A,24V输入同步降压调节器
SY8388ARHC 数据手册
Application Note: AN_ SY8388A High Efficiency Fast Response, 8A, 24V Input Synchronous Step Down Regulator General Description Features SY8388A develops a high efficiency synchronous stepdown DC/DC regulator capable of delivering 8A current over a wide input voltage range of 4V to 24V. Ordering Information SY8388 □(□□)□ dF rep are     .C Package type QFN2.5×2.5-16 Note -- LCD-TV/Net-TV/3DTV Set Top Box Notebook High Power AP orp Ordering Number SY8388ARHC Applications on fi Temperature Code Package Code Optional Spec Code de nti a lP Internal 20mΩ power and 10mΩ synchronous rectifier switches provide excellent efficiency over a range of applications, especially for low output voltages and low duty cycles. SY8388A also integrates a bypass switch which allows the IC to be powered by external DC source. Cycle-by-cycle current limit, input under voltage lock-out, internal soft-start, output under voltage protection and over voltage protection and thermal shutdown provide safe operation in all operating conditions. The SY8388A is available in a compact QFN2.5×2.5-16 package. or wo ok oo Silergy’s proprietary Instant-PWM™ fast-response, constant-on-time (COT) PWM control method supports high input/output voltage ratios (low duty cycles), and fast transient response while maintaining a near constant operating frequency over line, load and output voltage ranges. This control method provides stable operation without complex compensation and even with low ESR ceramic capacitors.  Low RDS(ON) for Internal Switches (Top/Bottom): 20/10 mΩ  Wide Input Voltage Range: 4~24V  Integrated Bypass Switch: 1.5Ω  Instant PWM Architecture to Achieve Fast Transient Responses  Internal Soft-Start Limits the Inrush Current  Pseudo-Constant Frequency: 600kHz  Adjustable Output Voltage Application  8A Output Current Capability  ±1% Internal Reference Voltage  PFM/FCCM Selectable Light Load Operation Mode  Power Good Indicator  Output Discharge Function  Cycle-by-cycle Valley and Peak Current Limit Protection  Programmable Valley Current Limit Threshold by ILMT Pin  Hic-cup Mode Output Under Voltage Protection  Auto-recovery Mode Output Over Voltage Protection  Auto-recovery Mode Over Temperature Protection  Input UVLO  RoHS Compliant and Halogen Free  Compact Package: QFN2.5×2.5-16 ON/OFF PG GND BS MODE LX Sil High/Low IN High/Floating/Low 3.3V External Voltage (opt.) EN Efficiency vs. Output Current 100 95 CBS=0.1µF L1=1.5µH VOUT=3.3V COUT=22µF×3 RFF=1kΩ SY8388A CFF=220pF ILMT FB BYP VCC R1=100kΩ 90 85 80 75 VIN=5V, VOUT=3.3V VIN=12V, VOUT=3.3V VIN=19V, VOUT=3.3V VIN=24V, VOUT=3.3V 70 R2=22.1kΩ CVCC=2.2µF CBYP=1.0µF (VBYP=3.3V, PFM, L=1.5μH/PCMB104T-1R5MS) PG (Open Drain Output) Efficiency (%) CIN=10µF CIN=0.1µF erg VIN=4~24V yC Typical Applications 65 60 0.001 0.01 0.1 1 8 Output Current (A) Figure1. Schematic Diagram AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Figure2. Efficiency vs. Output Current Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SY8388A 3 IN 4 LX GND VCC Exposed Pad (GND) 12 BYP 11 FB 10 ILMT 9 5 6 7 8 (QFN2.5×2.5-16) EN or wo ok oo IN 13 MODE 2 14 PG IN 15 GND 1 16 LX BS LX Pinout (top view) Top Mark: B3xyz, (Device code: B3, x=year code, y=week code, z= lot number code) IN 2, 3, 4 LX GND 5, 15, 16 6, 14, EP PG 7 MODE 8 EN 9 ILMT FB 10 11 BYP 12 VCC 13 dF 1 rep are BS Pin Description Boot-strap pin. Supply high side gate driver. Connect a 0.1µF ceramic capacitor between the BS and the LX pin. Input pin. Decouple this pin to the GND pin with at least a 10µF ceramic capacitor. A 0.1μF input ceramic capacitor is recommended to reduce the input noise. Inductor pin. Connect this pin to the switching node of the inductor. Ground pin. Power good Indicator. Open drain output when the output voltage is within 90% to 120% of regulation point. Operating mode selection under light load. Pull this pin low for PFM operating and pull this pin high for FCCM operation. Do not leave this pin floating. Enable control of the IC. Pull high to turn on the IC and pull low to turn off the IC. Valley current limit threshold selection pin. See Table1 to find more details. Output feedback pin. Connect to the center point of resistor divider. External 3.3V bypass power supply input. Decouple this pin to GND with a 1µF ceramic capacitor. Leave this pin floating or connect this pin to the GND if it is not used. Internal 3.3V LDO output. Power supply for internal analog circuits and driving circuit. Decouple this pin to GND with a 2.2µF ceramic capacitor. lP Pin Number Sil erg yC orp .C on fi de nti a Pin Name AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SY8388A Block Diagram IN Input UVLO Current Sense PG VCC Bootstrap Charge MODE BS or wo ok oo EN ILMT Internal SST OTP OVP PWM Control & Protection Logic LX Current Sense VCC UVP dF 0.6V rep are FB IN 3.1V BYP GND VCC lP 3.3V LDO de nti a Figure3. Block Diagram Absolute Maximum Ratings (Note 1) Sil erg yC orp .C on fi Supply Input Voltage ------------------------------------------------------------------------------------------------- -0.3V to 26V IN-LX, LX, PG, MODE, EN Voltage------------------------------------------------------------------------ -0.3V to IN+0.3V BS-LX, ILMT, VCC Voltage----------------------------------------------------------------------------------------- -0.3V to 4V FB, BYP Voltage ------------------------------------------------------------------------------------------------------- -0.3V to 6V Maximum Power Dissipation, PD,MAX @ TA = 25°C QFN2.5×2.5-16 ---------------------------------------------------- 3W Package Thermal Resistance (Note 2) θ JA, QFN2.5×2.5-16 ------------------------------------------------------------------------------------------- 33°C/W θ JC, QFN2.5×2.5-16 ------------------------------------------------------------------------------------------- 5.5°C/W Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C Dynamic LX Voltage in 10ns Duration -------------------------------------------------------------------- GND-5V to IN+3V Dynamic LX Voltage in 20ns Duration -------------------------------------------------------------------- GND-1V to IN+2V Recommended Operating Conditions (Note 3) Supply Input Voltage ---------------------------------------------------------------------------------------------------- 4V to 24V Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range -------------------------------------------------------------------------------------- -40°C to 85°C AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. SY8388A Electrical Characteristics Min 4 Typ Max 24 3.9 Unit V V V 140 170 µA 4 0.600 9 0.606 50 20 10 100 22 µA V nA mΩ mΩ mA A A A A 4.8 A 0.5 0.594 -50 8 12 16 3 1.2 Sil AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. 1.98 1 0.4 0.4 VIN 1 0 1 2.5 510 3.15 115 55 80 erg yC orp .C on fi de nti a lP rep are dF or wo ok oo (VIN= 12V, COUT= 66µF, TA= 25°C, IOUT= 1A unless otherwise specified) Parameter Symbol Test Conditions Input Voltage Range VIN Input UVLO Threshold VIN rising VUVLO UVLO Hysteresis VHYS PFM, IOUT=0A, Quiescent Current IQ VOUT=VSET×105% Shutdown Current ISHDN EN=0 Feedback Reference Voltage VREF FB Input Current IFB VFB=1V Top FET RDS(ON) RDS(ON)1 Bottom FET RDS(ON) RDS(ON)2 Output Discharge Current IDIS VOUT=5V Top FET Current Limit ILMT,TOP ILMT=Low Bottom FET Current Limit ILMT,BOT ILMT=Floating ILMT=High Bottom FET Reverse Current ILMT,RVS FCCM mode Limit VFB from 0% to100VREF Soft-start Time tSS (Note 4) EN Input Voltage High VEN, H EN Input Voltage Low VEN, L MODE Voltage for PFM Mode VMODE,PFM MODE Voltage for FCCM Mode VMODE,FCCM EN/MODE Input Current IEN/MODE VEN/VMODE=3.3V ILMT Input Voltage High VILMT, H ILMT Input Voltage Low VILMT, L Switching Frequency fSW VOUT=5V, CCM Min ON Time tON,MIN VIN=VIN,MAX (Note 4) Min OFF Time tOFF,MIN VCC Output Voltage VCC VCC adds 1mA load Output Over Voltage Threshold VOVP VFB rising Output Over Voltage Hysteresis VOVP,HYS Output Under Voltage Protection VUVP Threshold Output UVP Delay tUVP,DLY (Note 4) Power Good Threshold VPG,F VFB falling(not good) Power Good Hysteresis VPG,HYS VFB rising (good) tPG,R Low to high (Note 4) Power Good Delay tPG,F High to low (Note 4) Power Good Low Voltage VPG,LOW VFB=0V, IPG=5mA Bypass Switch RDS(ON) RDS(ON),BYP Bypass Switch Turn-on Voltage VBYP Bypass Switch Switchover VBYP,HYS Hysteresis Bypass Switch OVP Threshold VBYP,OVP Thermal Shutdown Temperature TOTP TJ rising (Note 4) Thermal Shutdown Hysteresis TOTP,HYS (Note 4) 600 50 150 3.3 120 5 60 200 83 7 200 30 0.4 690 3.45 125 65 V V V V μA V V kHz ns ns V %VREF %VREF %VREF 1.5 3.1 µs %VREF %VREF µs µs V Ω V 0.2 V 120 150 15 %VLDO °C °C 86 0.45 2.97 ms Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SY8388A Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability Note 2: Package thermal resistance is measured in the natural convection at TA = 25°C on a 8.5cm×8.5cm size, four-layer Silergy Evaluation Board with 2-oz copper. Note 3: The device is not guaranteed to function outside its operating conditions. Sil erg yC orp .C on fi de nti a lP rep are dF or wo ok oo Note4:Guaranteed by design. AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. SY8388A Typical Performance Characteristics (TA=25°C, VIN=12V, VOUT=3.3V, L=1.5μH, COUT=66μF, unless otherwise noted) Efficiency vs. Output Current Efficiency vs. Output Current (VBYP=3.3V, PFM, L=1.0μH/PCMB104T-1R0MT) (VBYP=3.3V, FCCM, L=1.0μH/PCMB104T-1R0MT) 90 80 80 70 70 60 50 40 VIN=5V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=19V, VOUT=1.2V VIN=24V, VOUT=1.2V 30 20 50 40 VIN=5V, VOUT=1.2V VIN=12V, VOUT=1.2V VIN=19V, VOUT=1.2V VIN=24V, VOUT=1.2V 30 20 10 10 0 0.001 60 0 0.01 0.1 1 0.001 8 0.1 1 8 Output Current (A) rep are Efficiency vs. Output Current (VBYP=3.3V, PFM, L=1.0μH/PCMB104T-1R0MT) Efficiency vs. Output Current (VBYP=3.3V, FCCM, L=1.0μH/PCMB104T-1R0MT) 100 100 90 90 lP 70 Efficiency (%) 80 80 50 40 VIN=5V, VOUT=1.8V VIN=12V, VOUT=1.8V VIN=19V, VOUT=1.8V VIN=24V, VOUT=1.8V 30 20 10 0.01 0.1 1 70 60 50 40 30 VIN=5V, VOUT=1.8V VIN=12V, VOUT=1.8V VIN=19V, VOUT=1.8V VIN=24V, VOUT=1.8V 20 10 0 0.001 8 0.01 0.1 1 8 Output Current (A) orp .C Output Current (A) de nti a 60 on fi Efficiency (%) 0.01 dF Output Current (A) 0 0.001 or wo ok oo Efficiency (%) 100 90 Efficiency (%) 100 Efficiency vs. Output Current Efficiency vs. Output Current (VBYP=3.3V, PFM, L=1.5μH/PCMB104T-1R5MS) VIN=5V, VOUT=3.3V VIN=12V, VOUT=3.3V VIN=19V, VOUT=3.3V VIN=24V, VOUT=3.3V 70 65 60 0.001 Efficiency (%) 85 75 80 erg 90 Sil Efficiency (%) 95 80 90 yC 100 (VBYP=3.3V, FCCM, L=1.5μH/PCMB104T-1R5MS) 100 0.01 0.1 1 Output Current (A) AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. 70 60 50 40 VIN=5V, VOUT=3.3V VIN=12V, VOUT=3.3V VIN=19V, VOUT=3.3V VIN=24V, VOUT=3.3V 30 20 10 8 0 0.001 0.01 0.1 1 8 Output Current (A) Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. SY8388A Efficiency vs. Output Current Efficiency vs. Output Current (VBYP=3.3V, PFM, L=1.5μH/PCMB104T-1R5MS) (VBYP=3.3V, FCCM, L=1.5μH/PCMB104T-1R5MS) 100 100 90 95 80 85 80 75 VIN=7.4V, VOUT=5.0V VIN=12V, VOUT=5.0V VIN=19V, VOUT=5.0V VIN=24V, VOUT=5.0V 70 65 60 0.001 0.01 0.1 1 10 0 0.001 8 IL 10A/div de nti a 10V/div on fi VLX Startup from EN .C Time (4ms/div) IL yC erg 10V/div Sil VLX orp (VIN=12V, VOUT=3.3V, IOUT=8A) 5V/div 0.1 1 10A/div Time (4ms/div) AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. 8 Shutdown from VIN (VIN=12V, VOUT=3.3V, IOUT=8A) VIN 10V/div VOUT 5V/div VLX 10V/div IL 10A/div lP 5V/div VOUT 0.01 dF rep are 10V/div 2V/div VIN=7.4V, VOUT=5.0V VIN=12V, VOUT=5.0V VIN=19V, VOUT=5.0V VIN=24V, VOUT=5.0V Output Current (A) Startup from VIN EN 40 20 (VIN=12V, VOUT=3.3V, IOUT=8A) VOUT 60 50 30 Output Current (A) VIN 70 or wo ok oo Efficiency (%) Efficiency (%) 90 Time (4ms/div) Shutdown from EN (VIN=12V, VOUT=3.3V, IOUT=8A) EN 2V/div VOUT 5V/div VLX 10V/div IL 10A/div Time (4ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. SY8388A Output Short Circuit Protection Output Short Circuit Protection (VIN=12V, VOUT=3.3V, IOUT=0A~Short, ILMT=Low, PFM) (VIN=12V, VOUT=3.3V, IOUT=8A~Short, ILMT=Low) 2V/div IL 10A/div VOUT IL Time (4ms/div) Output Short Circuit Protection Output Short Circuit Protection lP .C Time (4ms/div) de nti a 10A/div on fi IL (VIN=12V, VOUT=3.3V, IOUT=8A~Short, ILMT=Floating) rep are (VIN=12V, VOUT=3.3V, IOUT=0A~Short, ILMT=Floating, PFM) 2V/div 10A/div dF Time (4ms/div) VOUT 2V/div or wo ok oo VOUT VOUT 2V/div IL 10A/div Time (4ms/div) Output Short Circuit Protection (VIN=12V, VOUT=3.3V, IOUT=8A~Short, ILMT=High) yC orp Output Short Circuit Protection (VIN=12V, VOUT=3.3V, IOUT=0A~Short, ILMT=High, PFM) 2V/div VOUT 2V/div Sil erg VOUT IL 10A/div Time (4ms/div) AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. IL 10A/div Time (4ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. SY8388A Output Ripple Output Ripple (VIN=12V, VOUT=3.3V, IOUT=0A, PFM) (VIN=12V, VOUT=3.3V, IOUT=0A, FCCM) 50mV/div ∆VOUT 50mV/div VLX 10V/div VLX 10V/div IL 5A/div or wo ok oo ∆VOUT IL Time (2μs/div) 5A/div dF Time (2μs/div) Output Ripple 50mV/div VLX 10V/div IL 10A/div Output Ripple (VIN=12V, VOUT=3.3V, IOUT=8A) ∆VOUT 50mV/div VLX 10V/div IL 10A/div on fi de nti a lP ∆VOUT rep are (VIN=12V, VOUT=3.3V, IOUT=4A) Load Transient .C Time (2μs/div) 200mV/div Load Transient (VIN=12V, VOUT=3.3V, IOUT=0~4A, FCCM) ΔVOUT 200mV/div erg yC ΔVOUT orp (VIN=12V, VOUT=3.3V, IOUT=0~4A, PFM) Time (2μs/div) Sil IL 5A/div Time (200μs/div) AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. IL 5A/div Time (200μs/div) Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. SY8388A Load Transient Load Transient (VIN=12V, VOUT=3.3V, IOUT=0.8~8A, PFM) (VIN=12V, VOUT=3.3V, IOUT=0.8~8A, FCCM) 200mV/div ΔVOUT 200mV/div 5A/div IL 5A/div IL or wo ok oo ΔVOUT Time (200μs/div) Time (200μs/div) dF Switching Frequency vs. Output Voltage (VIN=12V, IOUT=0A, FCCM) rep are 700 650 600 550 fSW, MIN fSW, TYP fSW, MAX 400 350 300 2 3 4 Sil erg yC orp .C Output Voltage (V) 5 on fi 1 lP 500 450 de nti a Switching Frequency (kHz) 750 AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved. SY8388A Instant-PWM Operation Detailed Description L1 VIN General Features R2 Ramp Generator on fi .C orp yC Sil erg Minimum Duty Cycle and Maximum Duty Cycle In the COT architecture, there is no limitation for small duty cycle, since at very low duty cycle operation, once the on-time is close to the minimum on time, the switching frequency can be reduced as needed to always ensure a proper operation. The device can support ~75% maximum duty cycle operation under TJ=-40℃~125℃ condition. VRAMP VFB S Q R or wo ok oo PWM signal VREF tON Generator dF Silergy’s instant-PWM control method adds several proprietary improvements to the traditional COT architecture. Whereas most legacy based on COT implementations require a dedicated connection to the output voltage terminal to calculate the tON duration, instant-PWM control method derives this signal internally. Another improvement optimizes operation with low ESR ceramic output capacitors. In many applications it is desirable to utilize very low ESR ceramic output capacitors, but legacy COT regulators may become unstable in these cases because the beneficial ramp signal that results from the inductor current flowing into the output capacitor maybe become too small to maintain smooth operation. For this reason, instant-PWM synthesizes a virtual replica of this signal internally. This internal virtual ramp and the feedback voltage are combined and compared to the reference voltage. When the sum is lower than the reference voltage, the tON pulse is triggered as long as the minimum tOFF has been satisfied and the inductor current as measured in the low-side synchronous rectifier is lower than the bottom FET current limit. As the t ON pulse is triggered, the low-side synchronous rectifier turns off and the high-side power switch turns on. Then the inductor current ramps up linearly during the t ON period. At the conclusion of the tON period, the highside power switch turns off, the low-side synchronous rectifier turns on and the inductor current ramps down linearly. This action also initiates the minimum tOFF timer to ensure sufficient time for stabilizing any transient conditions and settling the feedback comparator before the next cycle is initiated. This minimum tOFF is relatively short so that during high speed load transient tON can be retriggered with minimal delay, allowing the inductor current to ramp quickly to provide sufficient energy to the load side. rep are de nti a In a COT architecture, there is no fixed clock, so the high-side power switch can turn on almost immediately after a load transient and subsequent switching pulses can be quickly initiated, ramping the inductor current up to meet load requirements with minimal delays. Traditional current mode or voltage mode control methods must simultaneously monitor the feedback voltage, current feedback and internal ramps and compensation signals to determine when to turn off the high-side power switch and turn on the low-side synchronous rectifier. Considering these small signals in a switching environment are difficult to be noise-free after switching large currents, making those architectures difficult to apply in noisy environments and at low duty cycles. R1 COUT CIN lP Constant-on-time Architecture Fundamental to any constant-on-time (COT) architecture is the one-shot circuit or on-time generator, which determines how long to turn on the high-side power switch. Each on-time (tON) is a “fixed” period internally calculated to operate the step down regulator at the desired switching frequency considering the input and output voltage ration, tON = (VOUT/VIN)×(1/fSW). For example, considering that a hypothetical converter targets 3.3V output from a 12V input at 600kHz, the target ontime is (3.3V/12V)×(1/600kHz) = 458ns. Each tON pulse is triggered by the feedback comparator when the output voltage as measured at FB drops below the target value. After one tON period, a minimum offtime (tOFF,MIN) is imposed before any further switching is initiated, even if the output voltage is less than the target. This approach avoids the making any switching decisions during the noisy periods just after switching events and while the switching node (LX) is rapidly rising or falling. VOUT In order to avoid shoot-through, a dead time (tDEAD) is generated internally between the high-side power AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 11 All Rights Reserved. SY8388A switch off and the low-side synchronous rectifier on period or the low-side synchronous rectifier off and the high-side power switch on period. VUVLO less than the input UVLO hysteresis, switching actions will again be suppressed. If the input UVLO threshold is low for some high input UVLO threshold requirement applications, use EN to adjust the input UVLO by adopting two external divided resistors. Light Load Operation Mode Selection PFM or FCCM light load operation is selected by MODE pin. Pull MODE pin low for PFM operation, and pull this pin high for FCCM operation. on fi .C erg yC orp If FCCM light load operation is selected, under light load conditions, the low-side synchronous rectifier still turns on even when the inductor current crosses zero. Current flow will continue until the next tON cycle. The device always operates under continuous conditions mode and keeps fairly constant switching frequency over all the output current range. or wo ok oo EN RL GND rep are dF Enable Control The EN input is a high-voltage capable input with logic-compatible threshold. When EN is driven above 1V normal device operation will be enabled. When driven < 0.4V the device will be shut down, reducing input current to < 10µA. It is not recommended to connect EN and IN directly. A resistor in a range of 1kΩ to 1MΩ should be used if EN is pulled high by IN. Sil lP Startup and Shutdown The SY8388A incorporates an internal soft-start circuit to smoothly ramp the output to the desired voltage whenever the device is enabled. Internally, the soft-start circuit clamps the output at a low voltage and then allows the output to rise to the desired voltage over approximately 1.2ms, which avoids high current flow and transients during startup. The startup and shutdown sequence is shown below. VUVLO VIN EN tDLY1 VCC 125µs tDLY2 275µs VREF VSS(internal signal) Input Under Voltage Lock-out (UVLO) To prevent operation before all internal circuitry is ready and to ensure that the power and synchronous rectifier switches can be sufficiently enhanced, the instant-PWM incorporates one input under-voltage lockout protections. The device remains in a low current state and all switching actions are inhibited until VIN exceeds their own UVLO (rising) threshold. At that time, if EN is enabled, the device will start-up by initiating a soft-start ramp. If VIN falls below AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. IN RH de nti a If PFM light load operation is selected, under light load conditions, typically IOUT < 1/2×ΔIL, the current through the low-side synchronous rectifier will ramp to near zero before the next tON time. When this occurs, the low-side synchronous rectifier turns off, preventing recirculation current that can seriously reduce efficiency under these light load conditions. As load current is further reduced, and the combined feedback and ramp signals remain much greater than the reference voltage, the instant-PWM control loop will not trigger another tON until needed, so the apparent operating switching frequency will correspondingly drop, further enhancing efficiency. The switching frequency can be lower than audible frequency area under deep light load or null load conditions. Continuous conduction mode (CCM) resumes smoothly as soon as the load current increases sufficiently for the inductor current to remain above zero at the time of the next tON cycle. The device enters CCM once the load current exceeds the critical level. After that, the switching frequency stays fairly constant over the output current range. The critical level of the load current is determined with V  (1  D) I IOUT_CTL  L  OUT 2 2  fSW  L1 VIN VPG,R VPG, F VUVP VFB tSS VOUT tPG,R tPG,F PG After the input voltage exceeds its own UVLO (rising) threshold, VCC is turned on after EN is Silergy Corp. Confidential- Prepared for Customer Use Only 12 All Rights Reserved. SY8388A enabled for one delay time tDLY1, the buck regulator is turned on after another delay time tDLY2 after VCC voltage is set up. When the output voltage is 90% of the regulation point, PG becomes high-impedance after one delay time tPG,R. BS CBS 0.1µF LX If the output is pre-biased to a certain voltage before start-up, the device disables the switching of both the high-side power switch and the low-side synchronous rectifier until the voltage on the internal soft start circuit voltage VSS exceeds the sensed output voltage at the FB node. or wo ok oo CVCC 2.2µF yC orp .C on fi PG should be connected to VIN or another voltage source through a resistor (e.g. 100kΩ). After the input voltage exceeds its own UVLO (rising) threshold, the PG MOSFET is turned on so that PG is pulled to GND before output voltage is ready. After feedback voltage VFB reaches VPG,R, PG is pulled high (after one delay time typical 200µs). When VFB drops to VPG,F, or rises to VOVP for one OVP delay time, PG is pulled low (after one delay time typical 30µs). Sil erg External Bootstrap Capacitor Connection This device integrates a floating power supply for the gate driver that operates the high-side power switch. Proper operation requires a 0.1µF low ESR ceramic capacitor to be connected between BS and LX. This bootstrap capacitor provides the gate driver supply voltage for the high-side N-channel MOSFET power switch. dF BYP Input The control and drive circuit can also be powered by external 3.3V power supply. When a 3.3V external power supply is connected to the BYP pin, the VCC LDO is turned off and the switch between BYP and VCC is turned on. The overall efficiency may be improved by connecting the BYP pin to external 3.3V switching power supply. Connect a 1.0µF low ESR ceramic capacitor from BYP pin to GND when BYP is supplied by 3.3V external power. Leave the BYP pin floating or connect this pin to the GND if it is not used. rep are de nti a Output Power Good Indicator The buck power good indicator is an open drain output controlled by a window comparator connected to the feedback signal. If VFB is greater than VPG,R and less than VOVP for at least the power good delay time (low to high), PG will be high-impedance. VCC lP Output Discharge SY8388A discharges the output voltage when the converter shuts down from VIN or EN, or thermal shutdown, so that output voltage can be discharged in a minimal time, even output load current is zero. The discharge FET in parallel with the low-side synchronous rectifier turns on after the low-side synchronous rectifier turns off when shut down logic is triggered. The output discharge current is typically 100mA when the LX voltage is 5V. Note that the discharge FET is not active beyond these shutdown conditions. VCC Linear Regulator An internal linear regulator (VCC) produces a 3.3V supply from VIN that powers the internal gate drivers, PWM logic, analog circuitry, and other blocks. Connect a 2.2μF low ESR ceramic capacitor from VCC to GND. Fault Protection Modes Output Current Limit Instant-PWM incorporates a cycle-by-cycle“valley” current limit. Inductor current is measured in the lowside synchronous rectifier when it turns on and as the inductor current ramps down. If the current exceeds the bottom FET current limit threshold, tON is inhibited until the current returns back to the limit threshold or lower. Bottom FET current limit IL VFB VREF VLX VFB 500µF and minimum load current is low, set feed-forward values as RFF = 1kΩ and CFF = 2.2nF to provide sufficient ripple to FB for small output ripple and good transient behavior. t ON t ON +t OFF,MIN Thermal Design Considerations Maximum power dissipation depends on the thermal resistance of the IC package, the PCB layout, the surrounding airflow, and the difference between the junction and ambient temperatures. The maximum power dissipation may be calculated by: PD,MAX = (TJ,MAX− TA) / θJA Where, TJ,MAX is the maximum junction temperature, TA is the ambient temperature, and θJA is the junction to ambient thermal resistance. Given this, the capacitive undershoot may be calculated by 2 L1  IOUT 2  COUT  (VIN,MIN  D MAX  VOUT ) or wo ok oo VUNDERSHOOT,CAP   Consider a 4A load increase using the ceramic capacitor case when VIN = 12V.At VOUT = 3.3V, the result is tON = 458ns, tOFF,MIN = 150ns, DMAX = 458 / (458 + 150) = 0.753 and VUNDERSHOOT,CAP   1.5H  (4A) 2  31.7mV 2  66F  (12V  0.753  3.3V) To comply with the recommended operating conditions, the maximum junction temperature is 125℃. The junction to ambient thermal resistance θJA is layout dependent. For the QFN2.5×2.5-16 package the thermal resistance θJA is 33℃/W when measured on a standard Silergy four-layer thermal test board. These standard thermal test layouts have a very large area with long 2-oz. copper traces connected to each IC pin and very large, unbroken 1-oz. internal power and ground planes. Using the POS capacitor case, the above result is VOVERSHOOT,CAP  2 L1  IOUT 2  COUT  VOUT Consider a 4A load decrease using the ceramic capacitor case above. At VOUT = 3.3V the result is de nti a VOVERSHOOT,CAP 1.5H  (4A)2   55.1mV 2  66F  3.3V Using the POS capacitor case, the above result is VOVERSHOOT,CAP  1.5H  (4A)2  24.2mV 2 150F  3.3V .C on fi Combine the ESR and capacitive undershoot and overshoot to calculate the total overshoot and undershoot for a given application. Sil erg yC orp Load Transient Considerations: The SY8388A adopts the instant PWM architecture to achieve good stability and fast transient responses. In applications with high step load current, adding an RC feed-forward compensation network RFF and CFF may further speed up the load transient responses. RFF = 1kΩ and CFF = 220pF have been shown to perform well in most applications. Increase CFF will speed up the load transient response if there is no stability issue. L1 LX RFF (opt.) rep are Capacitive overshoot (load decreasing) is a function of the output capacitance, the inductor value and the output voltage. dF 1.5H  (4A) 2  13.95mV 2 150F  (12V  0.753  3.3V) lP VUNDERSHOOT,CAP   Meeting the performance of the standard thermal test board in a typical tiny evaluation board area requires wide copper traces well-connected to the IC's backside pads leading to exposed copper areas on the component side of the board as well as good thermal via from the exposed pad connecting to a wide middle-layer ground plane and, perhaps, to an exposed copper area on the board's solder side. The maximum power dissipation at T A=25℃ may be calculated by the following formula: PD,MAX = (125℃ − 25℃) / (33℃/W) = 3W The maximum power dissipation depends on operating ambient temperature for fixed T J,MAX and thermal resistance θJA. Use the derating curve in figure below to calculate the effect of rising ambient temperature on the maximum power dissipation. VOUT R1 COUT FB CFF AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. R2 Silergy Corp. Confidential- Prepared for Customer Use Only 17 All Rights Reserved. SY8388A Avoid routing the feedback line near LX, BS or other high frequency signal as it is noise sensitive. Make the feedback sampling point Kelvin connect with COUT rather than the inductor output terminal. 3 2.5 2 LX Connection: Keep LX area small to prevent excessive EMI, while providing wide copper traces to minimize parasitic resistance and inductance. Wide LX copper trace between pin 5 and pin 15, 16 should be adopted to improve efficiency. 1.5 1 0.5 0 0 25 50 75 100 Ambient Temperature ( 125 ) or wo ok oo Maximum Power Dissipation (W) Maximum Power Derating Curve 3.5 BS Capacitor: Place the BS capacitor on the same layer as the device, keep the BS voltage path (BS, LX and CBS) as short as possible. Layout Design Follow these PCB layout guidelines for optimal performance and thermal dissipation. Control Signals: It is not recommended to connect control signals and IN directly. A resistor in a range of 1kΩ to 1MΩ should be used if they are pulled high by IN. rep are de nti a VCC Capacitor: Place the VCC capacitor close to VCC using short, direct copper trace to one nearest device GND pin (pin 14). GND Vias: Place adequate number of vias on the GND layer around the device for better thermal performance. The exposed GND pad should be connected by a larger copper area than its size, place four GND vias on it for heat dissipation. on fi BYP Capacitor: Place the BYP capacitor close to BYP using short, direct copper trace to one nearest device GND pin (pin 14) if bypass function is used. Sil erg yC orp .C Feedback Network: Place the feedback components (R1, R2, RFF and CFF) as close to FB pin as possible. PCB Board: A four-layer layout with 2-oz copper is strongly recommended to achieve better thermal performance. The top layer and bottom layer should place power IN and GND copper plane as wide as possible. Middle1 layer should place all GND layer for conducting heat and shielding middle2 layer signal line from top layer crosstalk. Place signal lines on middle2 layer instead of the other layers, so that the other layers’ GND plane not be cut apart by these signal lines. lP Output Capacitors: Guarantee the COUT negative sides are connected with GND pin by wide copper traces instead of vias, in order to achieve better accuracy and stability of output voltage. dF Input Capacitors: Place the input capacitor very near IN and GND, minimizing the loop formed by these connections. And the input capacitor should be connected to the IN and GND by wide copper plane. A 0.1μF input ceramic capacitor is recommended to reduce the input noise. AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 18 All Rights Reserved. SY8388A L IN Vias VIN CBS CIN CIN IN BS 3 2 1 4 LX 8 GND 13 7 LX 14 Exposed Pad (GND) 15 6 16 5 PG IN IN LX GND MODE VCC COUT FB BYP EN ILMT 12 9 10 11 GND Vias CVCC R2 CBYP or wo ok oo CIN COUT COUT R1 Feedback line GND VOUT CFF RFF VBYP rep are Middle1 Layer (GND Layer, not shown) Top Layer dF GND Middle2 Layer Exposed GND Vias Detail 0.5mm 0.35mm Exposed Pad (GND) Bottom Layer Sil erg yC orp .C on fi de nti a lP Figure4. PCB Layout Suggestion AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 19 All Rights Reserved. SY8388A dF or wo ok oo QFN2.5×2.5-16 Package Outline Drawing Bottom view erg yC orp .C on fi de nti a lP rep are Top view Sil Side view layout Recommended PCB (Reference only) Notes: All dimension in millimeter and exclude mold flash & metal burr. AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 20 All Rights Reserved. SY8388A Taping & Reel Specification or wo ok oo 1. QFN2.5×2.5 taping orientation lP rep are dF 2. Carrier Tape & Reel specification for packages Tape width (mm) QFN2.5×2.5 8 Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel 4 7" 400 160 3000 yC Sil erg 3. Others: NA Pocket pitch(mm) orp Package types .C on fi de nti a Reel Size AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 21 All Rights Reserved. SY8388A Revision History or wo ok oo The revision history provided is for informational purpose only and is believed to be accurate, however, not warranted. Please make sure that you have the latest revision. Date Revision Change Jan.22, 2021 Revision 0.9A 1. Add (IN-LX) voltage in Absolute Maximum Ratings; 2. Add “A 0.1μF input ceramic capacitor is recommended to reduce the input noise.” in the pin description and the layout design; 3. Update in Table1 (page14): ----Change “Pull ILMT to GNG by 0~20kΩ” to “Pull ILMT to GND by ≤10kΩ Resistor” (ILMT=Low); ---- Change “Pull ILMT to VCC by 0~150kΩ” to “Pull ILMT to VCC by ≤10kΩ Resistor” (ILMT=High). Revision 0.9A Fixed an error in the calculation formula of DMAX (tON is 458ns) (page17) Jul.24, 2020 Revision 0.9 Initial Release Sil erg yC orp .C on fi de nti a lP rep are dF Sep.21, 2020 AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 22 All Rights Reserved. SY8388A IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. rep are dF or wo ok oo 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. de nti a lP 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. .C on fi 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. yC orp 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. Sil erg 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2020 Silergy Corp. AN_SY8388A Rev. 0.9B © 2020 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only 23 All Rights Reserved.
SY8388ARHC 价格&库存
很抱歉,暂时无法提供与“SY8388ARHC”相匹配的价格&库存,您可以联系我们找货
SY8388ARHC
    • 1+3.13600
    • 100+2.52000
    • 750+2.24000
    • 1500+2.11680
    库存:1534
    SY8388ARHC
      • 1+2.86550
      库存:18
