MBR0520L
MBR0520L
    ST(先科)
    SOD123
    肖特基二极管 VR=20V If=500mA
MBR0520L 数据手册
MBR0520L-HAF Surface Mount Schottky Barrier Diode DESCRIPTION PIN Features • Very low forward voltage • Halogen and Antimony Free(HAF), RoHS compliant 1 Cathode 2 Anode 2 1 Top View Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25℃) Parameter Symbol Value Unit VR 20 V Average Rectified Forward Current IF(AV) 0.5 A Non-Repetitive Peak Forward Current (Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz) IFSM 5.5 A Tj - 65 to + 125 ℃ Tstg - 65 to + 150 ℃ Symbol Value Unit Typical Thermal Resistance from Junction to Ambient 1) RθJA 340 ℃/W Typical Thermal Resistance Junction to Lead RθJL 150 ℃/W Maximum Repetitive Reverse Voltage Operating Junction Temperature Range Storage Temperature Range Thermal Characteristics Parameter 1) Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout. Characteristics (Ta = 25℃) Parameter Reverse Breakdown Voltage at IR = 100 µA Forward Voltage at IF = 0.1 A at IF = 0.5 A at IF = 0.1 A, TJ = 125℃ at IF = 0.5 A, TJ = 125℃ Symbol Min. Max. Unit V(BR)R 20 - V - 0.3 0.385 0.22 0.33 - 75 250 5 8 VF Reverse Current at VR = 10 V at VR = 20 V at VR = 10 V, TJ = 125℃ at VR = 20 V, TJ = 125℃ IR 1/3 V μA μA mA mA ® Dated : 24/10/2022 Rev:02 MBR0520L-HAF Fig 1. Average Current Derating Curve Fig 2. Forward Characteristic Curve 0.6 0.5 Forward Current (A) Average Rectified Forward Current (A) Electrical Characteristic Curves 0.4 0.3 0.2 0.1 0 0 25 50 75 100 125 150 Ambient Temperature ( ℃) Forward Voltage (V) Fig 4. Junction Capacitance Reverse Current (mA) Junction Capacitance (pF) Fig 3. Reverse Characteristic Curve Reverse Voltage (V) Reverse Voltage (V) 2/3 ® Dated : 24/10/2022 Rev:02 MBR0520L-HAF PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 c A ∠ ALL ROUND HE A bp E D UNIT A bp c D E HE v ∠ mm 1.15 1.05 0.6 0.5 0.135 0.100 2.7 2.6 1.65 1.55 3.85 3.55 0.2 5 O Recommended Soldering Footprint 3.05 0.85 1.2 Packing information Package Tape Width (mm) SOD-123 8 Pitch Reel Size mm (inch) mm (inch) 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 3,000 Marking information " SD " = Part No. " III " = Cathode line " • " = HAF (Halogen and Antimony Free) Font type: Arial . SD 3/3 ® Dated : 24/10/2022 Rev:02
MBR0520L 价格&库存
很抱歉,暂时无法提供与“MBR0520L”相匹配的价格&库存,您可以联系我们找货
