MBR0520-HAF
Surface Mount Schottky Barrier Diode
PINNING
PIN
Features
• Very low forward voltage
• High current capability
• Halogen and Antimony Free(HAF),
RoHS compliant
DESCRIPTION
1
Cathode
2
Anode
2
1
SC
Top View
Marking Code: "SC"
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRRM
V
Working Peak Reverse Voltage
VRWM
V
VR
V
Average Rectified Forward Current
IF(AV)
0.5
A
Non-Repetitive Peak Forward Current (Surge Applied at Rated
Load Conditions Halfwave, Single Phase, 60 Hz)
IFSM
5.5
A
Junction Temperature Range
Tj
- 65 to + 150
Storage Temperature Range
Tstg
- 65 to + 150
Symbol
Max.
Unit
RθJL
150
℃/W
RθJA
340
℃/W
Max.
Unit
DC Reverse Voltage
Thermal Characteristics
Parameter
Thermal Resistance Junction to Lead 1)
Thermal Resistance Junction to Ambient
2)
1)
Device mounted on FR-4 substrate PC board, 2oz copper, with 1-inch square copper plate.
2)
Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout.
Characteristics at Ta = 25℃
Parameter
Symbol
Forward Voltage
at IF = 0.1 A
at IF = 0.5 A
at IF = 0.1 A, Tj = 100℃
at IF = 0.5 A, Tj = 100℃
Reverse Current
at VR = 10 V
at VR = 20 V
at VR = 10 V, Tj = 100℃
at VR = 20 V, Tj = 100℃
VF
IR
Junction Capacitance
at VR = 5 V ( test signal range 100 KHz to 1 MHz )
CT
1/3
0.375
0.44
0.26
0.36
V
40
150
3
7
µA
µA
mA
mA
110
pF
Dated : 17/03/2022 Rev:02
MBR0520-HAF
Electrical Characteristics Curves
Current Derating Curve
Fig 2. Forward Characteristics Curve
0.6
Forward Current (A)
Average Rectified Current (A)
Fig 1. Average Rectified
0.5
0.4
0.3
0.2
0.1
50
75
100
125
150
Ambient Temperature (℃)
Forward Voltage (V)
Fig 4. Junction Capacitance
Reverse Current (mA)
Junction Capacitance (pF)
Fig 3. Reverse Characteristics Curve
Reverse Voltage (V)
Reverse Voltage (V)
2/3
MBR0520-HAF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
c
A
∠ ALL ROUND
HE
A
bp
E
D
UNIT
A
bp
c
D
E
HE
v
mm
1.15
1.05
0.6
0.5
0.135
0.100
2.7
2.6
1.65
1.55
3.85
3.55
0.2
5
O
Recommended Soldering Footprint
3.05
0.85
1.2
Packing information
Package
Tape Width
(mm)
SOD-123
8
Pitch
Reel Size
mm
(inch)
mm
(inch)
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
3,000
Marking information
" III " = Cathode line
" SC " = Part No.
" • " = HAF (Halogen and Antimony Free)
Font type: Arial
. SC
3/3
很抱歉,暂时无法提供与“MBR0520”相匹配的价格&库存,您可以联系我们找货
