SR8200
SR8200
    ST(先科)
    DO-201AD
    肖特基二极管 Vrrm=200V If=8A Vf=920V Cj=400pF
SR8200 数据手册
SR8200-HAF Schottky Barrier Rectifier Reverse Voltage - 200 V Forward Current - 8 A Features • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Metal silicon junction,majority carrier conduction • Low power loss,high efficiency • High forward surge current capability • Halogen and Antimony Free(HAF), RoHS compliant Mechanical Data • Case: JEDEC DO-201AD molded plastic body • Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 • Polarity: Color band denotes cathode end • Mounting Position: Any Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Units Maximum Repetitive Peak Reverse Voltage VRRM 200 V Maximum RMS Voltage VRMS 140 V Maximum DC Blocking Voltage VDC 200 V Maximum Average Forward Rectified Current IF(AV) 8 A Peak Forward Surge Current, 8.3 ms Single Halfsine-wave Superimposed on rated load (JEDEC method) IFSM 150 A Maximum Forward Voltage at 8 A VF 0.92 V IR 0.05 2 mA Cj 400 pF RθJA 30 ℃/W Tj - 55 to + 150 ℃ Tstg - 55 to + 150 ℃ Maximum Reverse Current at Rated DC Blocking Voltage 1) Typical Junction Capacitance Typical Thermal Resistance Tj = 25℃ Tj = 100℃ 2) Operating Junction Temperature Range Storage Temperature Range 1) 2) Measured at 1 MHz and applied reverse voltage of 4 V D.C. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted. 1/3 ® Dated: 02/09/2021 SS Rev: 01 SR8200-HAF Electrical Characteristics Curves 2/3 ® Dated: 02/09/2021 SS Rev: 01 SR8200-HAF Marking information " HF " = HAF (Halogen and Antimony Free) " SR8200 " = Part No. Font type: Arial SR8200HF 3/3 ® Dated: 02/09/2021 SS Rev: 01
SR8200 价格&库存
很抱歉,暂时无法提供与“SR8200”相匹配的价格&库存,您可以联系我们找货
