BAS116-HAF
Silicon Epitaxial Planar Switching Diode
Features
3
• Low leakage switching diode
• Plastic SMD package
• Low leakage current
• Halogen and Antimony Free(HAF), RoHS compliant
1
2
1. Anode 2. NC 3. Cathode
TO-236 Plastic Package
Application
• Low leakage current applications in
surface mounted circuits.
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
VRRM
85
V
Continuous Reverse Voltage
VR
75
V
Continuous Forward Current
IF
215
mA
IFRM
500
mA
Repetitive Peak Reverse Voltage
Repetitive Peak Forward Current
Non-Repetitive Peak Forward Surge Current
t = 1 µs
t = 1 ms
t=1s
Power Dissipation
Junction Temperature
Storage Temperature Range
Ptot
4
1
0.5
250
Tj
150
O
C
Tstg
- 65 to + 150
O
C
Symbol
Max.
Unit
RθJA
500
/W
IFSM
A
mW
Thermal Characteristics
Parameter
Thermal Resistance from Junction to Ambient 1)
1)
Device mounted on FR-4 PCB with minimum recommended pad layout.
1/4
Dated: 18/11/2021 Rev: 01
BAS116-HAF
Characteristics at Ta = 25 OC
Parameter
Symbol
Min.
Max.
Unit
VF
VF
VF
VF
0.9
1
1.1
1.25
V
V
V
V
IR
5
80
nA
V(BR)R
75
V
Diode Capacitance
at VR = 0, f = 1 MHz
Cd
2
pF
Reverse Recovery Time
at IF = IR = 10 mA, RL = 100 Ω, Irr = 0.1 x IR
trr
3
µs
Forward Voltage
at IF = 1 mA
at IF = 10 mA
at IF = 50 mA
at IF = 150 mA
Reverse Current
at VR = 75 V
at VR = 75 V, Tj = 150 OC
Reverse Breakdown Voltage
at IR = 10 µA
2/4
BAS116-HAF
Electrical Characteristics Curves
Fig 2. Capacitance Characteristics Curve
PD, Power Dissipation (mW)
Cj, Junction Capacitance(pF)
Fig 1. Power Derating Curve
Ta, Ambient Temperature
VR, Reverse Voltage (V)
Fig 4. Forward Characteristics Curve
IF, Forward Current(mA)
IR, Reverse Current (µA)
Fig 3. Reverse Characteristics Curve
TJ=125
TJ=25
TJ=75
TJ=-55
VF, Forward Voltage (V)
3/4
BAS116-HAF
Package Outline (Dimensions in mm)
Unit
mm
A
1.20
0.89
A1
0.100
0.013
B
1.40
1.20
C
0.19
0.08
TO-236
D
3.04
2.80
E
2.6
2.2
F
1.02
0.89
G
2.04
1.78
L
0.51
0.37
L1
0.2
MIN
Recommended Soldering Footprint
2.0
1.0
0.8
1.0
0.8
1.9
Packing information
Pitch
Reel Size
Package
Tape Width
(mm)
mm
inch
mm
inch
TO-236
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
3,000
Marking information
" JV " = Part No.
" • " = HAF (Halogen and Antimony Free)
"YM" = Date Code Marking
"Y" = Year
"M" = Month
JV
Font type: Arial
4/4
很抱歉,暂时无法提供与“BAS116”相匹配的价格&库存,您可以联系我们找货
