RB501V-40
RB501V-40
    ST(先科)
    SC-76
    肖特基二极管 VR=40V IF=1A CT=6.22pF
RB501V-40 数据手册
RB501V-40-HAF Silicon Epitaxial Planar Schottky Barrier Diode PINNING Features • Small surface mounting type • High reliability • Halogen and Antimony Free(HAF), RoHS compliant DESCRIPTION PIN 1 Cathode 2 Anode 2 1 S7 Applications • Low current rectification Top View Marking Code: "S7" Simplified outline SC-76 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Peak Reverse Voltage VRM 45 V Reverse Voltage VR 40 V Mean Rectifying Current IO 0.1 A IFSM 1 A Tj 125 O Tstg - 40 to + 125 O Peak Forward Surge Current (60 Hz for 1 Cyc.) Junction Temperature Storage Temperature Range C C Characteristics at Ta = 25 OC Parameter Symbol Typ. Max. 0.27 0.34 0.55 - Unit Forward Voltage at IF = 10 mA at IF = 100 mA at IF = 100 mA , Ta = 125℃ VF Reverse Current at VR = 10 V at VR = 10 V , Ta = 125℃ IR 1.95 30 - µA mA Capacitance Between Terminals at VR = 10 V, f = 1 MHz CT 6.22 - pF V Note: ESD sensitive product handling required. ® 1/3 Dated: 25/05/2021 Rev: 02 RB501V-40-HAF Electrical characteristic curves Fig 1. Reverse Characteristic Curve Reverse Current (µA) Forward Current (mA) Fig 2. Forward Characteristic Curve Forward voltage (mV) Reverse Voltage (V) Fig 4. IFSM Curve Forward Current:IFSM (A) Junction Capacitance (pF) Fig 3. Junction Capacitance Reverse Voltage (V) Time (ms) ® 2/3 Dated: 25/05/2021 Rev: 02 RB501V-40-HAF PACKAGE OUTLINE Plastic surface mounted package; 2 leads SC-76 A c HE A D E bp UNIT A bp C D E HE mm 1.10 0.80 0.40 0.25 0.15 0.10 1.80 1.60 1.35 1.15 2.80 2.30 Recommended Soldering Footprint Packing information Package Tape Width (mm) SC-76 8 Pitch Reel Size Per Reel Packing Quantity mm inch mm inch 4 ± 0.1 0.157 ± 0.004 178 7 3,000 Marking information " III " = Cathode line " • " = HAF (Halogen and Antimony Free) . S7 " S7 " = Part No. Font type: Arial ® 3/3 Dated: 25/05/2021 Rev: 02
RB501V-40 价格&库存
很抱歉,暂时无法提供与“RB501V-40”相匹配的价格&库存,您可以联系我们找货
