SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MZR
Series
・Downsizing and Lower ESR, 2,000hours at 105℃
・Rated voltage range : 6.3 to 50V, Nominal capacitance range : 22 to 2,200μF
・Solvent resistant type(see PRECAUTIONS AND GUIDELINES)
・Vibration resistance structure
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
Low ESR, 105℃
MZR
Downsized
MZJ
◆SPECIFICATIONS
Items
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
Surge Voltage Test
Characteristics
-55 to +105℃
6.3 to 50Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3μA, whichever is greater.
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V
tanδ(Max.)
0.26 0.19 0.16 0.14 0.12 0.10
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
2
2
2
2
2
2
Z(-40℃)/Z(+20℃)
3
3
3
3
3
3
Z(-55℃)/Z(+20℃)
4
4
4
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
at 105℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charging with the specified surge voltage for 30±5 seconds through
a protective resistor (as required for RC=0.1±0.05sec) and open-circuiting for 5.5 minutes at a room temperature of 15 to 35℃.
Rated voltage (Vdc)
6.3
10
16
25
35
50
7.2
12
18
29
40
58
Surge voltage (Vdc)
Appearance
No significant damage
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
Leakage current
(Caution)
Surge Voltage Test intends to evaluate capacitors in durability of an exceptional excessive voltage under specific conditions.It does
not imply long-term use at all.
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
B±0.2
φD±0.5
P
C±0.2
0.3max.
L±0.3 (Note)
W
0.3max.
Vent for JA0
W
B±0.2
φD±0.5
Vent for JA0
Code : G(Vibration resistant structure)
code : HA0 and JA0
Size code
E61
F61
F80
HA0
JA0
D
5
6.3
6.3
8
10
L
A
B
C
5.8 5.3 5.3 5.9
5.8 6.6 6.6 7.2
7.7 6.6 6.6 7.2
10.0 8.3 8.3 9.0
10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.4
1.9
1.9
3.1
4.5
A±0.2
L±0.5
A±0.2
P
C±0.2
Code : A
code : E61 to JA0
Note : L±0.5 for HA0 and JA0
: Dummy terminals
◆MARKING
EX) 35V330µF
3Q
330
VZR
● Rated
voltage symbol
Rated voltage (Vdc)
Symbol
6.3
j
10
A
16
C
25
E
35
V
50
H
Applying voltage over the rated voltages causes the capacitors to have short lifetime.
Besides, applying voltage over the specified surge voltages may cause to have short circuit failure. A protection
circuit should be used if applied voltage will exceed the rated voltages.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
MZRSeries
TM
AIchip
Low ESR, 105℃
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E MZ R AAA A RA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 220µF:221, 470µF:471)
Taping code
Terminal code (A, G)
Voltage code (ex. 6.3V:6R3, 10V:100, 35V:350)
Series code
Category
Please refer to "Product code guide (surface mount type)"
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
220
330
680
1,500
2,200
150
220
470
1,000
1,500
100
220
330
680
1,000
68
100
220
470
820
47
100
150
330
560
22
47
100
220
330
6.3
10
16
25
35
50
Size code
tanδ
ESR
(Ω max./20℃, 100kHz)
Rated ripple current
(mArms/105℃, 100kHz)
Part No.
E61
F61
F80
HA0
JA0
E61
F61
F80
HA0
JA0
E61
F61
F80
HA0
JA0
E61
F61
F80
HA0
JA0
E61
F61
F80
HA0
JA0
E61
F61
F80
HA0
JA0
0.26
0.26
0.26
0.26
0.26
0.19
0.19
0.19
0.19
0.19
0.16
0.16
0.16
0.16
0.16
0.14
0.14
0.14
0.14
0.14
0.12
0.12
0.12
0.12
0.12
0.10
0.10
0.10
0.10
0.10
0.36
0.26
0.16
0.08
0.06
0.36
0.26
0.16
0.08
0.06
0.36
0.26
0.16
0.08
0.06
0.36
0.26
0.16
0.08
0.06
0.36
0.26
0.16
0.08
0.06
0.88
0.68
0.34
0.18
0.12
240
300
600
850
1,190
240
300
600
850
1,190
240
300
600
850
1,190
240
300
600
850
1,190
240
300
600
850
1,190
165
195
350
670
900
EMZR6R3ARA221ME61G
EMZR6R3ARA331MF61G
EMZR6R3ARA681MF80G
EMZR6R3□RA152MHA0G
EMZR6R3□RA222MJA0G
EMZR100ARA151ME61G
EMZR100ARA221MF61G
EMZR100ARA471MF80G
EMZR100□RA102MHA0G
EMZR100□RA152MJA0G
EMZR160ARA101ME61G
EMZR160ARA221MF61G
EMZR160ARA331MF80G
EMZR160□RA681MHA0G
EMZR160□RA102MJA0G
EMZR250ARA680ME61G
EMZR250ARA101MF61G
EMZR250ARA221MF80G
EMZR250□RA471MHA0G
EMZR250□RA821MJA0G
EMZR350ARA470ME61G
EMZR350ARA101MF61G
EMZR350ARA151MF80G
EMZR350□RA331MHA0G
EMZR350□RA561MJA0G
EMZR500ARA220ME61G
EMZR500ARA470MF61G
EMZR500ARA101MF80G
EMZR500□RA221MHA0G
EMZR500□RA331MJA0G
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
22 to 150
220 to 560
680 to 2,200
120
0.40
0.50
0.60
1k
0.75
0.85
0.87
10k
0.90
0.94
0.95
100k
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
很抱歉,暂时无法提供与“EMZR500ARA101MF80G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.93501
- 100+0.85251
- 500+0.77001
- 1000+0.68751
- 2000+0.63251
- 4000+0.61601
