TIP41C
TIP41C
    ST(先科)
    TO220FB-3L
    通用三极管 TO220FB-3L NPN IC=6A
TIP41C 数据手册
TIP41C-HAF NPN Silicon Epitaxial Planar Power Transistor Features • Halogen and Antimony Free(HAF), RoHS compliant 1.Base 2.Collector 3.Emitter TO-220FB Plastic Package Applications • For power switching and amplifier applications Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage VCBO 100 V Collector Emitter Voltage VCEO 100 V Emitter Base Voltage VEBO 5 V Collector Current IC 6 A Collector Current (Pulse) ICP 10 A Power Dissipation (Ta = 25 OC) Ptot 2 W Power Dissipation (Tc = 25 OC) Ptot 65 W Tj 150 O C Tstg - 65 to + 150 O C Symbol Max. Thermal Resistance from Junction to Case RθJC 1.9 /W Thermal Resistance from Junction to Ambient RθJA 62.5 /W Junction Temperature Storage Temperature Range Thermal Characteristics Parameter 1/5 Unit ® Dated: 05/06/2023 Rev: 03 TIP41C-HAF Characteristics at Ta = 25 OC Parameter DC Current Gain at VCE = 4 V, IC = 0.3 A at VCE = 4 V, IC = 3 A Collector Emitter Cutoff Current at VCE = 100 V Collector Emitter Cutoff Current at VCE = 60 V Emitter Base Cutoff Current at VEB = 5 V Collector Base Breakdown Voltage at IC = 100 µA Collector Emitter Breakdown Voltage at IC = 30 mA Emitter Base Breakdown Voltage at IE = 1 mA Collector Emitter Saturation Voltage at IC = 6 A, IB = 600 mA Base Emitter Saturation Voltage at IC = 6 A, IB = 600 mA Base Emitter On Voltage at VCE = 4 V, IC = 6 A Transition Frequency at VCE = 10 V, IC = 500 mA, f = 1 MHz 2/5 Symbol Min. Max. Unit hFE hFE 30 15 75 - ICES - 0.4 mA ICEO - 0.7 mA IEBO - 1 mA V(BR)CBO 100 - V V(BR)CEO 100 - V V(BR)EBO 5 - V VCE(sat) - 1.5 V VBE(sat) - 2 V VBE(on) - 2 V fT 3 - MHz ® Dated: 05/06/2023 Rev: 03 TIP41C-HAF Electrical Characteristics Curves Fig. 1 Output Characteristics Curve Fig. 2 Collector Current vs. Base to Emitter Voltage Fig. 4 VBESAT vs. Collector Current Fig. 3 DC Current Gain vs. Collector Current 3/5 ® Dated: 05/06/2023 Rev: 03 TIP41C-HAF Electrical Characteristics Curves Fig. 6 Output Capacitance Fig. 5 VCESAT vs. Collector Current Fig 7. Power Derating Curve 4/5 ® Dated: 05/06/2023 Rev: 03 TIP41C-HAF Package Outline Dimensions (Units: mm) UNIT A 2.9 B 6.8 C 0.7 D 15 E 1.5 F 0.9 2.7 6.4 0.3 11 1.1 0.7 UNIT P P1 Q mm 13.3 12.7 8.2 7.6 3.7 3.5 mm TO-220FB G 2.54 W 10.2 H 4.7 H1 2.5 K 3.1 L 16.8 L1 9.4 N 1.4 TYP. 9.8 4.3 2.2 2.7 14.8 9.0 1.2 Packing information Package Carton Quantity Box Quantity Base Quantity Delivery Mode TO-220FB 5 K / Carton 1 K / Box 50 pcs / Tube Tube Marking information " TIP41C " = Part No. " ****** " = Date Code Marking Font type: Arial TIP41C ****** 5/5 ® Dated: 05/06/2023 Rev: 03
TIP41C 价格&库存
很抱歉,暂时无法提供与“TIP41C”相匹配的价格&库存,您可以联系我们找货
