13009
    ST(先科)
    TO220FB-3L
    通用三极管 TO220FB-3L NPN Ic=12A
13009 数据手册
13009-HAF NPN Silicon Epitaxial Planar Power Transistor Features • High voltage capability • High switching speed • Halogen and Antimony Free(HAF), RoHS compliant Applications • Electronic Ballast 1.Base 2.Collector 3.Emitter TO-220FB Plastic Package • Switching Regulator • Motor Control • Switched Mode Power Supply Absolute Maximum Ratings (Ta = 25℃) Parameter Symbol Value Unit Collector Base Voltage VCBO 700 V Collector Emitter Voltage VCEO 400 V Emitter Base Voltage VEBO 9 V Collector Current IC 12 A Collector Current(Pulse) ICM 24 A Base Current IB 6 A PD 2 31 W Tj 150 Tstg 55 to + 150 Power Dissipation Ta = 25 TC = 25 Junction Temperature Storage Temperature Range Thermal Characteristics Parameter Symbol Max. Unit Thermal Resistance from Junction to Ambient RθJA 62.5 /W Thermal Resistance from Junction to Case RθJC 4 /W 1/5 ® Dated: 09/02/2022 Rev:01 13009-HAF Characteristics at Ta = 25 Parameter DC Current Gain at VCE = 5 V, IC = 5 A at VCE = 5 V, IC = 8 A Symbol Min. Typ. Max. Unit hFE hFE 8 6 - 40 30 - IEBO - - 1 mA Emitter Base Cutoff Current at VEB = 9 V Collector Base Breakdown Voltage at IC = 1 mA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 1 mA Collector Emitter Saturation Voltage at IC = 8 A , IB = 4 A V(BR)CBO 700 - - V V(BR)CEO 400 - - V V(BR)EBO 9 - - V VCE(sat) - - 0.8 V Base Emitter Saturation Voltage at IC = 8 A , IB = 4 A VBE(sat) - - 1.5 V fT 4 - - MHz Cob - 100 - pF tON - - 1.1 µs tstg - - 3 µs tf - - 0.7 µs Gain Bandwidth Product at VCE = 10 V, IC = 0.5 A Collector Output Capacitance at VCB = 10 V, f = 0.1 MHz Turn-On Time at VCC = 125 V, IB1 = -IB2 =1.6 A , IC = 8 A , RL =15.6 Ω Storage Time at VCC = 125 V, IB1 = -IB2 =1.6 A , IC = 8 A , RL =15.6 Ω Fall Time at VCC = 125 V, IB1 = -IB2 =1.6 A , IC = 8 A , RL =15.6 Ω 2/5 ® Dated: 09/02/2022 Rev:01 13009-HAF Electrical Characteristics Curves Fig. 1 Output Characteristics Curve Fig. 2 Output Characteristics Curve Fig. 3 Collector Curren vs. VBE Fig. 4 hFE vs. Collector Current 3/5 ® Dated: 09/02/2022 Rev:01 13009-HAF Electrical Characteristics Curves Fig. 6 VCE(sat) vs. Collector Current Fig. 5 VBE(sat) vs. Collector Current Fig. 8 Power Derating Curve Fig. 7 Output Capacitance 4/5 ® Dated: 09/02/2022 Rev:01 13009-HAF TO-220FB Package Outline Dimensions (Units: mm) UNIT A 2.9 B 6.8 C 0.7 D 15 E 1.5 F 0.9 2.54 W 10.2 2.7 6.4 0.3 11 1.1 0.7 TYP. 9.8 UNIT P P1 Q mm 13.3 12.7 8.2 7.6 3.7 3.5 mm G H 4.7 4.3 H1 2.5 2.2 K 3.1 2.7 L 16.8 14.8 L1 9.4 9.0 N 1.4 1.2 Marking information " 13009 " = Part No. " ****** " = Date Code Marking Font type: Arial 13009 ****** 5/5 ® Dated: 09/02/2022 Rev:01
13009 价格&库存
很抱歉,暂时无法提供与“13009”相匹配的价格&库存,您可以联系我们找货
