S1032-F-30A
S1032-F-30A
    SART(萨特)
    FUSE_10.25X3.2MM_SM
    一次性保险丝(熔断) 30A 100V 10.25x3.2mm
S1032-F-30A 数据手册
File No.: JS-S1032-F-00 Revision: L Page: 1/ 6 Surface Mount Fuses 1032 Size>Fast Acting> S1032-F Series General • Fast acting,Inrush withstand capability • Surface mount high current fuse • Available in ratings of 20 to 60 Amperes • Higher voltage rating up to 100VDC • 10.25mm×3.20mm square shape surface mount • -55°C ~125°C Operating temperature • Excellent environmental integrity • Enhanced thermal cycling endurance • RoHS compliant • Halogen Free Agency / Certificate Information Agency File Number Application Ampere Range E319512 20A~60A E319512 • Storage system power • Cooling fan system for PC server • Voltage regulator module • Base station power supply • Voltage regulator module for PC server • High end servers / Blade computing • Battery Management System Electrical Specifications Part Number Current Rating (A) Voltage Rating (V) S1032-F-20A 20 100 S1032-F-25A 25 100 S1032-F-30A 30 100 S1032-F-40A 40 72 S1032-F-50A 50 72 S1032-F-60A 60 72 * Measured at≤10% rated current and 25℃ ** MeltingI2T at 10 times of rated current Interrupting Rating 100VDC 300A 72VDC 500A 32VDC 1000A 72VDC 180A 60VDC 600A Nanjing SART Science & Technology Development Co., Ltd. ADD.: Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Typical Cold DCR* (mΩ) Nominal I2T** (A2s) 3.08 264 2.15 413 2.08 594 1.23 1024 1.00 1650 0.88 2376 File No.: JS-S1032-F-00 Revision: L Page: 2/ 6 Surface Mount Fuses 1032 Size>Fast Acting> S1032-F Series Part Number Information S1032—F—40A “40A” Ampere Rating: 40A “F” Electrical Characteristic: F=Fast Acting “1032” Size Number “S” Symbol of SART Dimensions Recommended Land Patterns Type L (mm) W/T (mm) D (mm) S1032 10.25±0.20 3.20±0.15 1.75±0.15 Materials Components Material Body Ceramic Terminations Au Plated Brass Cap Element Tin Plated Copper Dimensions A(mm) B (mm) C(mm) D(mm) Spec 5.72±0.30 12.60±0.30 3.43±0.30 3.25±0.30 Dimensions of Standard Test Board Glass epoxy body on double side; Board thickness: 1.6mm; Thickness of Copper layer: ≥100μm; Width of Copper trace: One side 15mm and the other side 33mm Nanjing SART Science & Technology Development Co., Ltd. ADD.: Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com File No.: JS-S1032-F-00 Revision: L Page: 3/ 6 Surface Mount Fuses 1032 Size>Fast Acting> S1032-F Series I2T VS Time Curve Time Current Curve 60A 50A 40A 20A 25A 30A 40A 50A 60A 10000 1E7 30A 25A 1000 20A 1000000 10 100000 I 2t (A 2S) Time (seconds) 100 1 0.1 10000 0.01 1000 1E-3 1E-4 10 100 1000 100 1E-4 1E-3 0.01 Current (Amperes) 0.1 1 10 100 Time (seconds) Electrical Characteristics Type S1032 Ampere Rating % of Current Rating Opening Time 20A~60A 100 Min.4hours 20A~60A 200 Max.60sec 20A~60A 1000 Min. 1ms Temperature Derating Curve Nanjing SART Science & Technology Development Co., Ltd. ADD.: Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com 1000 10000 Surface Mount Fuses 1032 Size>Fast Acting> S1032-F Series File No.: JS-S1032-F-00 Revision: L Page: 4/ 6 Product Characteristics Item Time/Current Endurance Test Test condition/ Methods Performance Standard 100% of current rating No Fusing; 4hr Min. UL248-14 200% of current rating 60sec Max. SART SPEC 1000%of current rating 1ms Min. SART SPEC 100% of rating current for 4 hours and testing Temperature rise at the last 5min. No fusing; 20A~40A:
S1032-F-30A 价格&库存
很抱歉,暂时无法提供与“S1032-F-30A”相匹配的价格&库存,您可以联系我们找货
