TD214A
TD214A
    LIGHTNING(天电光电)
    SSOP4_4.4X2.7MM_SM
    交流输入,光电晶体管耦合器 PO=150mW Ic=50mA VF=1.4V Viso=3750Vrms
TD214A 数据手册
TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler Description SCHEMATIC The TD214 series combine two AlGaAs infrared emitting diodes as the emitter which is optically coupled to a silicon planar phototransistor 1 4 2 3 detector in a plastic SSOP4 package With the robust coplanar double mold structure, TD214 series provide the most stable isolation feature. Features  High isolation 3750 VRMS  CTR flexibility available see order information  AC input with transistor output  Operating temperature range - 55 °C to 110 °C  REACH compliance  Halogen free  MSL class 1  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC - GB4943.1, GB8898  cUL- CSA Component Acceptance PIN DEFINITION 1. Anode/ Cathode 2. Cathode/Anode 3. Emitter 4. Collector PACKAGE OUTLINE Service Notice No. 5A Applications  Switch mode power supplies  Programmable controllers  Household appliances  Office equipment Document No: Preliminary Rev: A00 Release Date: 2021/6/22 1 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF ±60 mA Peak Forward Current IFP ±1 A Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 6 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON 2 Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Document No: Preliminary Rev: A00 Release Date: 2021/6/22 2 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - - 1.4 V IF=10mA Input Capacitance Cin - 10 - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 80 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 6 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS TD214 Current Transfer Ratio TD214A CTR TD214B CTR Symmetry 20 - 400 50 - 150 80 - 400 0.7 - 1.3 - 0.07 0.2 V IF=20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. % IF=1mA, VCE=5V IF=±1mA, VCE=5V Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance RISO Floating Capacitance CIO - 0.4 1 pF V=0, f=1MHz Response Time (Rise) tr - 7 18 μs Response Time (Fall) tf - 9 18 μs VCE=2V, IC=2mA RL=100Ω 10^12 10^14 3 3 Note 3. Fig.12&13 Note 4. Fig.14 Document No: Preliminary Rev: A00 Release Date: 2021/6/22 3 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current vs. Collector-emitter Voltage Fig.6 Collector Current vs. Collector-emitter Voltage Document No: Preliminary Rev: A00 Release Date: 2021/6/22 4 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Document No: Preliminary Rev: A00 Release Date: 2021/6/22 5 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler Fig.11 Frequency Response TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Document No: Preliminary Rev: A00 Release Date: 2021/6/22 6 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Document No: Preliminary Rev: A00 Release Date: 2021/6/22 7 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Option T2 Document No: Preliminary Rev: A00 Release Date: 2021/6/22 8 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 & T2 Document No: Preliminary Rev: A00 Release Date: 2021/6/22 9 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No: Preliminary Rev: A00 Release Date: 2021/6/22 10 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 214 X Y : Company Abbr. : Part Number : CTR Rank : Fiscal Year A WW : Manufacturing Code : Work Week ORDERING INFORMATION LABEL INFORMATION TD214X(Z)-G TD – Company Abbr. 214 – Part Number X – Rank (A/B or None) Z – Tape and Reel Option (T1/T2) G – Green PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box T1 5000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 75k Units T2 5000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 75k Units Document No: Preliminary Rev: A00 Release Date: 2021/6/22 11 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No: Preliminary Rev: A00 Release Date: 2021/6/22 12 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler TEMPERATURE PROFILE OF SOLDERING WAVE SOLDERING (JESD22-A111 COMPLIANT) HAND SOLDERING BY SOLDERING IRON   Soldering Temperature 380+0/-5°C Soldering Time 3 sec max. One time soldering is recommended for all soldering method. Do not solder more than three times for IR reflow soldering. Document No: Preliminary Rev: A00 Release Date: 2021/6/22 13 TD214 Series www.tdled.com SSOP4, AC Input, Photo Transistor Coupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No: Preliminary Rev: A00 Release Date: 2021/6/22 14
TD214A 价格&库存
很抱歉,暂时无法提供与“TD214A”相匹配的价格&库存,您可以联系我们找货
