TPL920ADJ-QF7R
TPL920ADJ-QF7R
    3PEAK(思瑞浦)
    QFN20_5X5MM_EP
    2-A输出,高PSRR,低噪声LDO稳压器
TPL920ADJ-QF7R 数据手册
TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Features ◼ ◼ Applications Input Voltage Range: ◼ Wireless Communication: CPU, ASIC, FPGA, CPLD, DSP ◆ Without BIAS: 1.4 V to 6.5 V ◼ High-Performance Analog: ADC, DAC, LVDS, VCO ◆ With BIAS: 1.1 V to 6.5V ◼ Noise-Sensitive Imaging: CMOS Sensors, Video ASICs Output Voltage Options: Description ◆ Fixed Output Voltage: 0.8 V to 3.95 V ◆ Adjustable Output Voltage: 0.8 V to 5.2 V The TPL920 series products are 2-A high-current, 6-μVRMS low- ±1% Output Accuracy Over Line, Load Regulation, and noise, high-PSRR, high-accuracy linear regulators with typically Operating Temperature Range With BIAS 110-mV ultra-low dropout voltage at 2-A load condition. The ◼ 2A Maximum Output Current TPL920 series products support both fixed output voltage ◼ Low Dropout Voltage: 110 mV typ at 2 A ranges from 0.8 V to 3.95 V and adjustable output voltage ◼ High PSRR: ranges from 0.8 V to 5.2 V with external resistor divider. ◼ ◆ 70dB at 1kHz ◆ 40dB at 1MHz Ultra-low noise, high PSRR, and high output current capability ◼ 6 μVRMS Output Voltage Noise makes the TPL920 series products ideal power supply for noise- ◼ Excellent Transient Response sensitive applications, such as high-speed communication ◼ Enable and Adjustable Soft-Start Control facilities, test and measurement devices, or high-definition ◼ Open-Drain Power-Good (PG) Output imaging equipment. Accurate output voltage tolerance, output ◼ Stable with a 22 μF or Larger Ceramic Output Capacitor voltage remote sensing, excellent transient response, and ◼ Thermal Shutdown and Over-Current Protection adjustable soft-start control ensures the TPL920 series products ◼ Operating Junction Temperature: –40°C to +125°C optimal power supply for the large-scale processors or digital ◼ Package Options: loads, such as ASIC, FPGA, CPLD and DSP. ◆ 5×5 QFN-20 The TPL920 series products provide 5×5 QFN-20 package with guaranteed operating junction temperature range (T J) from – 40°C to +125°C. Typical Application Schematic CIN COUT VIN Digital I/O or VIN Optiona l VBIAS IN PG EN OUT TPL920 VOUT SNS BIAS CBIAS FB NR/SS www.3peakic.com.cn 1 / 17 GND 50mV 100 mV 200 mV 400 mV 800 mV 1.6V CNR /SS GND Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Product Family Table Part Number Output Voltage Orderable Number Package TPL920 Adjustable (0.8 V ~ 5.2 V) TPL920ADJ-QF7R 5×5 QFN-20 www.3peakic.com.cn 2 / 17 Transport Media, Quantity 3,000 MSL MSL3 Marking information L920A Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Typical Application Schematic ...................................................................................................................................... 1 Product Family Table ...................................................................................................................................................... 2 Table of Contents ............................................................................................................................................................ 3 Revision History .............................................................................................................................................................. 4 Pin Configuration and Functions .................................................................................................................................. 5 Specifications .................................................................................................................................................................. 6 Absolute Maximum Ratings .......................................................................................................................................................... 6 ESD Ratings ................................................................................................................................................................................. 6 Recommended Operating Conditions ........................................................................................................................................... 6 Thermal Information ...................................................................................................................................................................... 6 Electrical Characteristics ............................................................................................................................................................... 7 Typical Performance Characteristics............................................................................................................................................. 9 Detailed Description ..................................................................................................................................................... 11 Overview ..................................................................................................................................................................................... 11 Functional Block Diagram ........................................................................................................................................................... 11 Feature Description ..................................................................................................................................................................... 11 Application and Implementation.................................................................................................................................. 15 Application Information................................................................................................................................................................ 15 Typical Application ...................................................................................................................................................................... 15 Layout Requirements .................................................................................................................................................................. 16 Package Outline Dimensions ....................................................................................................................................... 17 5×5 QFN-20 ................................................................................................................................................................................ 17 www.3peakic.com.cn 3 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Revision History Date Revision 2019/04/30 Rev.Pre Preliminary Version 2020/05/08 Rev.A.0 Initial Release www.3peakic.com.cn Notes 4 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Pin Configuration and Functions TPL920 Series QFN-20 Package OUT 1 SNS 2 OUT OUT GND IN IN Top View 20 19 18 17 16 Exposed PAD 15 IN 14 EN 13 NR/SS BIAS 50mV 5 11 1.6V 6 7 8 9 10 800 mV 12 400 mV 4 GND PG 200 mV 3 100 mV FB Pin Functions NAME 50mV, 100mV, 200mV, 400mV, 800mV, 1.6V PIN NUMBER TYPE DESCRIPTION Fixed output voltage setting pins. Connecting these pins to ground increases the 5, 6, 7, 9, 10, 11 I output voltage. Multiple pins may be simultaneously connected to GND to select the desired output voltage. Leave these pins open when use external resistor divider. BIAS 12 I EN 14 I BIAS voltage input pin. A 10-µF capacitor or larger must be connected between this pin and ground. BIAS must be left open or tied to ground when not used. Regulator enable pin. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to IN directly. Output voltage feedback pin. Connect to an external resistor divider to adjust the FB 3 I output voltage. A 10-nF feed-forward capacitor from FB to OUT (as close as possible to FB pin) is recommended to maximize regulator ac performance. GND 8, 18 – IN 15, 16, 17 I NR/SS 13 I OUT 1, 19, 20 O PG 4 O Ground reference pin. Connect GND pin to PCB ground plane directly. Input voltage pin. A 10-μF or larger ceramic capacitor from IN to ground (as close as possible to IN pin) is required to reduce the jitter from previous-stage power supply. Noise-reduction and soft-start pin. A 10-nF or larger capacitor from NR/SS to GND (as close as possible to NR/SS pin) is recommended to maximize ac performance. Regulated output voltage pin. A 22-μF or larger ceramic capacitor from OUT to ground (as close as possible to OUT pin) is required to ensure regulator stability. Open-drain power-good output pin. Leave PG pin open when not used. Output voltage sense input pin. Connect this pin to the load side of the output trace SNS 2 I only when using fixed output voltage. Leave this pin open when using external resistor divider. (1) Exposed PAD must be connected to a large-area ground plane to maximum the thermal performance. www.3peakic.com.cn 5 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Specifications Absolute Maximum Ratings MIN MAX UNIT IN, BIAS, EN, PG –0.3 7 V OUT, SNS –0.3 VIN + 0.3 V NR/SS, FB –0.3 3.6 V 50mV, 100mV, 200mV, 400mV, 800mV, 1.6V –0.3 VOUT + 0.3 V TJ Junction Temperature Range –40 150 °C TSTG Storage Temperature Range –65 150 °C TL Lead Temperature (Soldering 10 sec) 260 °C (1) Stresses beyond the Absolute Maximum Ratings may permanently damage the device. (2) All voltage values are with respect to GND. ESD Ratings Condition Minimum Level Unit HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 ±4000 V CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 ±1500 V Recommended Operating Conditions MIN TYP MAX UNIT IN Input voltage 1.1 6.5 V BIAS BIAS voltage 3 6.5 V EN Enable voltage 0 6.5 V OUT Output voltage 0.8 5.2 V CIN Input capacitor 10 µF COUT Output capacitor 22 µF CFF Feed-forward capacitor 10 nF CNR/SS NR/SS capacitor 10 nF RPG Power-good pull-up resistor R1 High-side resistor of the resistor divider R2 Low-side resistor of the resistor divider TJ Junction Temperature Range 10 100 kΩ 12.1 –40 kΩ 160 kΩ 125 °C Thermal Information PACKAGE θJA θJC,bottom UNIT 5×5 QFN-20 54.5 11.15 °C/W www.3peakic.com.cn 6 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Electrical Characteristics TJ = –40°C to +125°C (typical value at TJ = +25°C), VIN = VOUT(NOM) + 0.4 V or 1.4 V, whichever is greater; VBIAS = open, VOUT(NOM) = 0.8 V, VEN = 1.1 V, CIN = 10 µF, COUT = 47 µF, CNR/SS = 0 nF, CFF = open, OUT connect to 50 Ω to ground, PG connected to 100 kΩ to OUT, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT 1.1 6.5 V 3 6.5 V 1.0 V Supply Input Voltage and Current VIN Input supply voltage range VBIAS Bias supply voltage range VIN = 1.1 V Input supply UVLO with BIAS VIN rising with VBIAS = 3 V Hysteresis VBIAS = 3 V 60 Input supply UVLO without BIAS VIN rising 1.3 UVLOIN1 UVLOIN2 UVLOBIAS IGND 0.75 Hysteresis mV 1.4 V 200 mV Bias supply UVLO VBIAS rising, VIN = 1.1 V 2.7 Hysteresis VIN = 1.1 V 180 VIN = 6.5 V, IOUT = 5 mA 17 30 mA VIN = 1.4 V, IOUT = 2 A 12 25 mA 6 20 mA 10 25 µA 3.5 10 mA GND pin current VIN = 1.1 V, VBIAS = 3 V, VOUT(NOM) = 0.8 V, IOUT = 2A ISD Shutdown current IBIAS BIAS pin current VIN = 6.5 V, VEN = 0.5 V, PG = open VIN = 1.1 V, VBIAS = 6.5 V, VOUT(NOM) = 0.8 V, IOUT =2A 2.95 V mV Enable and Power Good VIH(EN) EN pin high-level input voltage Device enable 1.1 6.5 V VIL(EN) EN pin low-level input voltage Device disable 0 0.4 V IEN EN pin current VIN = 6.5 V, VEN = 0 V to 6.5 V –0.2 0.2 µA PG pin threshold VOUT falling 82% 93% × VOUT VPG Hysteresis 88% 2% × VOUT VOL(PG) PG pin low-level output voltage VOUT < VPG, source 1 mA to PG pin 0.4 V IPG PG pin leakage current VOUT > VPG, apply 6.5 V at PG pin 2 µA 0.8 + 1% V 100 nA Regulated Output Voltage and Current VFB Feedback voltage IFB FB pin leakage current VNR/SS NR/SS pin voltage INR/SS NR/SS pin charging current Output voltage range VOUT Accuracy www.3peakic.com.cn 0.8 – 1% VIN = 6.5 V, stress VFB = 0.8V 0.8 –100 0.8 VIN = 6.5 V, VNR/SS = GND 4 7.2 V 9 µA Fixed 0.8 3.95 V Adjustable (resistor tolerances are not included) 0.8 5.2 V –1% 1% VOUT = 0.8 V to 5.2 V, IOUT = 5 mA to 2 A (resistor tolerances are not included) 7 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Electrical Characteristics (continued) TJ = –40°C to +125°C (typical value at TJ = +25°C), VIN = VOUT(NOM) + 0.4 V or 1.4 V, whichever is greater; VBIAS = open, VOUT(NOM) = 0.8 V, VEN = 1.1 V, CIN = 10 µF, COUT = 47 µF, CNR/SS = 0 nF, CFF = open, OUT connect to 50 Ω to ground, PG connected to 100 k Ω to OUT, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT Regulated Output Voltage and Current Line regulation ΔVOUT Load regulation Dropout voltage without BIAS VDO Dropout voltage with BIAS VIN = 1.4 V to 6.5 V, IOUT = 5 mA 0.03 mV/V VIN = 1.1 V, VBIAS = 3 V to 6.5 V, IOUT = 5 mA to 2 A 0.7 mV/A IOUT = 5 mA to 2 A 0.8 mV/A VIN = 1.4 V, IOUT = 1 A, VFB = 0.8 V – 3% 55 130 mV VIN = 1.4 V, IOUT = 2 A, VFB = 0.8 V – 3% 110 260 mV VIN = 5.4 V, IOUT = 2 A, VFB = 0.8 V – 3% 120 280 mV VIN = 5.6 V, IOUT = 2 A, VFB = 0.8 V – 3% 120 280 mV VIN = 1.1 V, VBIAS = 5 V, IOUT = 1 A, VFB = 0.8 V – 3% 55 130 mV VIN = 1.1 V, VBIAS = 5 V, IOUT = 2 A, VFB = 0.8 V – 3% 110 260 mV 3.4 4.2 A ILIM Output current limit VOUT forced at 0.9 × VOUT(NOM), VIN = VOUT(NOM) + 0.4 V ISC Short-circuit current limit RLOAD ≤ 20 mΩ 2.1 0.9 A f = 1 kHz, VBIAS = 3 V 70 dB IOUT = 2 A, CNR/SS = 100 nF, f = 1 MHz, VBIAS = 3 V 40 dB CFF = 10 nF, COUT = 22 μF f = 1 kHz 70 dB f = 1 MHz 40 dB 6 μVRMS 8 μVRMS 11 μVRMS 160 °C 20 °C PSRR and Noise PSRR Power supply ripple rejection BW = 10 Hz to 100 kHz, VIN = 1.1 V, VOUT = 0.8 V, VBIAS = 5 V, IOUT = 2 A, CNR/SS = 100 nF, CFF = 10 nF, COUT = 47 μF || 10μF || 10μF BW = 10 Hz to 100 kHz, VN Output noise voltage VOUT = 5 V, IOUT = 2 A, CNR/SS = 100 nF, CFF = 100 nF, COUT = 47 μF || 10μF || 10μF BW = 10 Hz to 100 kHz, VOUT = 5 V, IOUT = 2 A, CNR/SS = 100 nF, CFF = 10 nF, COUT = 47 μF || 10μF || 10μF Temperature Range TSD TJ Thermal shutdown threshold Temperature increasing Hysteresis Operating junction temperature www.3peakic.com.cn –40 8 / 17 125 Rev.A.0 °C TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Typical Performance Characteristics TA = +25°C, VIN = VOUT(NOM) + 0.4 V or 1.4 V, whichever is greater; VBIAS = open, VOUT(NOM) = 0.8 V, VEN = 1.1 V, CIN = 10 µF, COUT = 47 µF, CNR/SS = 0 nF, CFF = open, OUT connect to 50 Ω to ground, PG connected to 100 k Ω to OUT, unless otherwise noted. 120 140 IOUT = 0.1 A IOUT = 0.1 A 100 IOUT = 1 A IOUT = 2 A PSRR(dB) PSRR(dB) 80 60 120 IOUT = 1 A 100 IOUT = 2 A 80 60 40 40 20 20 0 0 10 100 1K 10K 100K 1M 10M 10 100 1K Frequency(Hz) 10K 100K 1M VIN = 1.1 V, VBIAS = 3 V, VOUT = 0.8 V, VIN = 5.5 V, VBIAS = 3 V, VOUT = 5.2 V, COUT = 47µF // 10µF // 10µF, CNR/SS =100nF, CFF = open COUT = 47µF // 10µF // 10µF, CNR/SS =100nF, CFF = open Figure 1 PSRR vs. Frequency and IOUT Figure 2 PSRR vs. Frequency and IOUT 120 IOUT = 2 A 80 VOUT = 0.8 V VOUT = 5.2 V 100 IOUT = 1 A PSRR(dB) PSRR(dB) 120 IOUT = 0.1 A 100 60 80 60 40 40 20 20 0 0 10 100 1K 10K 100K 1M 10M 10 100 1K Frequency(Hz) 10K 100K 1M 10M Frequency(Hz) VIN = 5.5 V, VBIAS = open, VOUT = 5.2 V, VIN = VIN = VOUT(NOM) + 0.3 V, VBIAS = 3V, COUT = 47µF // 10µF // 10µF, CNR/SS =100nF, CFF = open COUT = 47µF // 10µF // 10µF, CNR/SS =100nF, CFF = open Figure 3 PSRR vs. Frequency and IOUT Figure 4 PSRR vs. Frequency and VOUT 150 150 −40°C −40°C 25°C 25°C Dropout Voltage (mV) Dropout Voltage (mV) 10M Frequency(Hz) 85°C 100 50 85°C 100 50 0 0 0 0.5 1 1.5 2 0 Load Current (A) VIN = 1.1 V 0.5 1 1.5 Load Current (A) VIN = 5.5 V Figure 5 Dropout Voltage vs. IOUT www.3peakic.com.cn Figure 6 Dropout Voltage vs. IOUT 9 / 17 Rev.A.0 2 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Typical Performance Characteristics (continued) TA = +25°C, VIN = VOUT(NOM) + 0.4 V or 1.4 V, whichever is greater; VBIAS = open, VOUT(NOM) = 0.8 V, VEN = 1.1 V, CIN = 10 µF, COUT = 47 µF, CNR/SS = 0 nF, 1 1 0.8 0.8 Enable Threshold (V) Enable Threshold (V) CFF = open, OUT connect to 50 Ω to ground, PG connected to 100 k Ω to OUT, unless otherwise noted. 0.6 0.4 VIH(EN) 0.2 VIL(EN) 0 0.6 0.4 VIH(EN) VIL(EN) 0.2 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 Ambient Temperature (°C) Supply Voltage (V) VIN = 1.4 V, VBIAS = open, VOUT = 0.8 V, IOUT = 1 mA VBIAS = open, VOUT = 0.8 V, IOUT = 1 mA Figure 7 Enable Threshold vs Temperature Figure 8 Enable Threshold vs Input Voltage 1.5 UVLOIN2 Threshold (V) UVLOIN1 Threshold (V) 1 0.8 0.6 0.4 VIN,rising 0.2 VIN,falling 0 1 0.5 VIN,rising VIN,falling 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 Ambient Temperature (°C) 20 35 50 65 80 95 110 125 Ambient Temperature (°C) VBIAS = 3 V, VOUT = 0.8 V, IOUT = 1 mA VBIAS = open, VOUT = 0.8 V, IOUT = 1 mA Figure 9 UVLOIN1 vs. Temperature Figure 10 UVLOIN2 vs. Temperature 0.820 0.820 25°C 0.810 Output Voltage (V) Output Voltage (V) –40°C 85°C 125°C 0.800 0.790 0.780 –40°C 25°C 0.810 85°C 125°C 0.800 0.790 0.780 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 0 Supply Voltage (V) VBIAS = 3 V, VOUT = 0.8 V, IOUT = 5 mA 1 1.5 Load Current (A) VIN = 1.1 V, VBIAS = 3 V, VOUT = 0.8 V Figure 11 Line Regulation www.3peakic.com.cn 0.5 Figure 12 Load Regulation 10 / 17 Rev.A.0 2 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Detailed Description Overview The TPL920 series products are 2-A high-current, 6-μVRMS low-noise, high-PSRR, high-accuracy linear regulators with typically 110mV ultra-low dropout voltage at 2-A load condition. The TPL920 series products support both fixed output voltage ranges from 0.8 V to 3.95 V and adjustable output voltage ranges from 0.8 V to 5.2 V with external resistor divider. Ultra-low noise, high PSRR, and high output current capability makes the TPL920 series products ideal power supply for noisesensitive applications, such as high-speed communication facilities, test and measurement devices, or high-definition imaging equipment. Accurate output voltage tolerance, output voltage remote sensing, excellent transient response, and adjustable soft-start control ensures the TPL920 series products optimal power supply for the large-scale processors or digital loads, such as ASIC, FPGA, CPLD and DSP. Functional Block Diagram IN OUT Charge Pump BIAS Curren t Control Acti ve Discha rge PSRR Control Regula tor Control Thermal Control UVLO Control SNS Device Ena ble Control 2R EA EN Thermal Shu tdo wn + – FB R VREF 2R 4R INR /SS 16R NR/SS PG 8R 32R 1.6V 800 mV 400 mV 200 mV 100 mV 50mV Power Goo d Control GND Figure 13 Functional Block Diagram Feature Description Enable (EN) The TPL920 series provide a device enable pin (EN) to enable or disable the device. Connect this pin to the GPIO of an external digital logic control circuit to control the device. When the V EN voltage falls below VIL(EN), the LDO device turns off, and when the VEN ramps above VIH(EN), the LDO device turns on. Under-Voltage Lockout (UVLO) The TPL920 series use an under-voltage lockout circuit to keep the output shut off until the internal circuitry operates properly. Voltage Regulation The TPL920 series provide two options to set the output voltage: fixed output voltage by the programming pins or adjustable the output voltage by external resistors. www.3peakic.com.cn 11 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator • Fixed Output Voltage Setting The TPL920 series integrate resistor divider internally to set the fixed output voltage. The fixed output voltage can be set from 0.8V to 3.95V by connecting the output voltage setting pins (pin 5 to pin 11) to ground or left them open. Use Equation 1 to calculate the output voltage. VOUT = VNR/SS + VPin _ Settings (1) Table 1 provides a full list of different output voltage target and the corresponding pin settings. Table 1 Fixed Output Voltage Setting VOUT (V) 50mV 100mV 200mV 400mV 800mV 1.6V VOUT (V) 50mV 100mV 200mV 400mV 800mV 1.6V Pin 5 6 7 9 10 11 Pin 5 6 7 9 10 11 0.80 Open Open Open Open Open Open 2.40 Open Open Open Open Open GND 0.85 GND Open Open Open Open Open 2.45 GND Open Open Open Open GND 0.90 Open GND Open Open Open Open 2.50 Open GND Open Open Open GND 0.95 GND GND Open Open Open Open 2.55 GND GND Open Open Open GND 1.00 Open Open GND Open Open Open 2.60 Open Open GND Open Open GND 1.05 GND Open GND Open Open Open 2.65 GND Open GND Open Open GND 1.10 Open GND GND Open Open Open 2.70 Open GND GND Open Open GND 1.15 GND GND GND Open Open Open 2.75 GND GND GND Open Open GND 1.20 Open Open Open GND Open Open 2.80 Open Open Open GND Open GND 1.25 GND Open Open GND Open Open 2.85 GND Open Open GND Open GND 1.30 Open GND Open GND Open Open 2.90 Open GND Open GND Open GND 1.35 GND GND Open GND Open Open 2.95 GND GND Open GND Open GND 1.40 Open Open GND GND Open Open 3.00 Open Open GND GND Open GND 1.45 GND Open GND GND Open Open 3.05 GND Open GND GND Open GND 1.50 Open GND GND GND Open Open 3.10 Open GND GND GND Open GND 1.55 GND GND GND GND Open Open 3.15 GND GND GND GND Open GND 1.60 Open Open Open Open GND Open 3.20 Open Open Open Open GND GND 1.65 GND Open Open Open GND Open 3.25 GND Open Open Open GND GND 1.70 Open GND Open Open GND Open 3.30 Open GND Open Open GND GND 1.75 GND GND Open Open GND Open 3.35 GND GND Open Open GND GND 1.80 Open Open GND Open GND Open 3.40 Open Open GND Open GND GND 1.85 GND Open GND Open GND Open 3.45 GND Open GND Open GND GND 1.90 Open GND GND Open GND Open 3.50 Open GND GND Open GND GND 1.95 GND GND GND Open GND Open 3.55 GND GND GND Open GND GND 2.00 Open Open Open GND GND Open 3.60 Open Open Open GND GND GND 2.05 GND Open Open GND GND Open 3.65 GND Open Open GND GND GND 2.10 Open GND Open GND GND Open 3.70 Open GND Open GND GND GND 2.15 GND GND Open GND GND Open 3.75 GND GND Open GND GND GND 2.20 Open Open GND GND GND Open 3.80 Open Open GND GND GND GND 2.25 GND Open GND GND GND Open 3.85 GND Open GND GND GND GND 2.30 Open GND GND GND GND Open 3.90 Open GND GND GND GND GND 2.35 GND GND GND GND GND Open 3.95 GND GND GND GND GND GND www.3peakic.com.cn 12 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator • Adjustable Output Voltage Setting The TPL920 series also provide an adjustable output voltage option. Using external resistors divider, the output voltage of TPL920 series is determined by the value of the resistor R1 and R2 in Figure 14. Use Equation 2 to calculate the output voltage. R1   VOUT = VFB   1 +   R2  (2) Where the feedback voltage VFB is 0.8 V. Table 2 provides a list of recommended resistor combinations to achieve the common output voltage values. Table 2 External Resistor Combinations Target Output Voltage (V) External Resistors Divider Calculated Output Voltage (V) R1 (kΩ) R2 (kΩ) 0.80 0 Open 0.800 0.81 2 160 0.810 0.82 4.02 160 0.820 0.83 6.04 160 0.830 0.84 8.06 160 0.840 0.85 10 160 0.850 0.86 12 160 0.860 0.87 12.4 143 0.869 0.88 12.4 124 0.880 0.89 12 107 0.890 0.90 12.4 100 0.899 0.95 12.4 66.5 0.949 1.00 12.4 49.9 0.999 1.10 12.4 33.2 1.099 1.20 12.4 24.9 1.198 1.50 12.4 14.3 1.494 1.80 12.4 10 1.792 1.90 12.1 8.87 1.891 2.50 12.4 5.9 2.481 2.85 12.1 4.75 2.838 3.00 12.1 4.42 2.990 3.30 11.8 3.74 3.324 3.60 12.1 3.48 3.582 4.50 11.8 2.55 4.502 5.00 12.4 2.37 4.986 www.3peakic.com.cn 13 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Programmable Soft Start The TPL930 series integrate a programmable soft-start function to control the output voltage ramp-up slew rate and start-up time. By selecting the external capacitor at the NR/SS pin (CNR/SS), the output start-up time can be can calculated with Equation 3. t Start −up = 1.25  VNR/SS  CNR/SS INR/SS (3) Where: • the typical value of VNR/SS is 0.8V • the typical value of INR/SS is 7.2uA • CNR/SS is the external capacitor at the NR/SS pin Charge Pump Noise The TPL920 series integrate a charge pump to improve the PSRR and transient response under low input voltage conditions and it generates a minimal amount of noise at the frequency around 15 MHz. It is recommended to use 10-nF to 100-nF bypass capacitors close to the load a ferrite bead between the LDO output and the load input capacitors forms a pi-filter to reduce the high-frequency noise level. Power Good (PG) The TPL920 series integrate an open-drain output power good indicator. Connect PG pin to a pull-up voltage through a resistor from 10 kΩ to 100 kΩ if power good function is used, or left PG pin open if it is not used. After regulator startup, the PG pin keeps low impendence until the output voltage reached the power good threshold VPG,TH. When output voltage is higher than VPG,TH , the PG pin turns to high output impedance, and PG is pulled up to high voltage level to indicate the output voltage is ready. Output Active Discharge The TPL920 series integrate an output discharge path from OUT to GND. When the device is disabled, either EN or VIN is lower than turn-on threshold, the output will actively discharge the output voltage through an internal resistor of several hundred ohms. Do not rely on this active discharge circuit for discharging large output capacitors when the input voltage falls below the output voltage. Reverse current flow through internal power MOSFET can permanently damage the device, and external current protection is essential at this condition. Over-Current Protection and Short-to-Ground Protection The TPL920 series integrate an internal current limit that helps to protect the device during fault conditions. • When the output is pulled down below the target output voltage, over-current protection starts to work and limit the output current to a typical value of 3.4 A. • When the output is shorted to ground directly, short-to-ground protection starts to work and limit the output current to ISC. Under the over-current conditions, the internal junction temperature ramps up quickly. When the junction temperature is high enough, it will cause the over temperature protection. Over-Temperature Protection The recommended operating junction temperature range is –40°C to 125°C. When the junction temperature is between 125°C and the thermal shutdown (TSD) threshold, the regulator can still work well, but will reduce the device lifetime for long-term using. The over-temperature protection works when the junction temperature exceeds the thermal shutdown (TSD) threshold, which turns off the regulator immediately. Until when the device cools down and the junction temperature falls below the thermal shutdown threshold minus thermal shutdown hysteresis, the regulator turns on again. www.3peakic.com.cn 14 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Application and Implementation NOTE Information in the following applications sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Application Information The TPL920 series products are 2-A high-current, 6-μVRMS low-noise, high-PSRR, high-accuracy linear regulators with typically 110mV ultra-low dropout voltage at 2-A load condition. The following application schematic shows a typical usage of the TPL920 series. Typical Application Adjustable Output Operation Figure 14 shows a typical application schematic of the TPL920 series with adjustable output operation. Refer to section Adjustable Output Voltage Setting to set the output voltage. CIN COUT VIN Digital I/O or VIN Optiona l VBIAS IN PG EN OUT TPL920 VOUT SNS BIAS CBIAS FB NR/SS 100 mV GND 50mV 200 mV 800 mV 400 mV 1.6V CNR /SS GND Figure 14 Adjustable Output Operation Fixed Output Operation Figure 15 shows a typical application schematic of the TPL920 series with fixed output operation. Refer to section Fixed Output Voltage Setting to set the output voltage. In this example, output voltage is set to 1.8 V (VNR/SS +0.8 V + 0.2 V). CIN COUT VIN Digital I/O or VIN IN PG EN OUT TPL920 VBIAS VOUT SNS BIAS CBIAS FB NR/SS GND 50mV 100 mV 200 mV 400 mV 800 mV 1.6V CNR /SS Figure 15 Fixed 1.8V Output Voltage Operation www.3peakic.com.cn 15 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Input Capacitor and Output Capacitor The TPL920 series is designed to be stable with low equivalent series resistance (ESR) ceramic capacitors at the input, output, and noise-reduction pin (NR/SS). It is recommended to use ceramic capacitors with X7R-, X5R-, and COG-rated dielectric materials to get good capacitive stability across temperature. 3PEAK recommends adding a 10 μF or greater capacitor with a 0.1 μF bypass capacitor in parallel at IN pin to keep the input voltage stable. The voltage rating of the capacitors must be greater than the maximum input voltage. To ensure loop stability, the TPL920 series requires an output capacitor with a minimum effective capacitance value of 10 μF. 3PEAK recommends selecting a X7R-type 22-μF ceramic capacitor with low ESR over temperature. Both input capacitors and output capacitors must be placed as close to the device pins as possible. Power Dissipation During normal operation, LDO junction temperature should not exceed 125°C. Using below equations to calculate the power dissipation and estimate the junction temperature. The power dissipation can be calculated using Equation 4. PD = ( VIN − VOUT )  IOUT + VIN  IGND (4) The junction temperature can be estimated using Equation 5. θJA is the junction-to-ambient thermal resistance. TJ = TA + PD  JA (5) Layout Requirements • Both input capacitors and output capacitors must be placed as close to the device pins as possible, and vias between capacitors and device power pins must be avoid. • It is recommended to bypass the input pin to ground with a 0.1 μF bypass capacitor. The loop area formed by the bypass capacitor connection, IN pin and the GND pin of the system must be as small as possible. • It is recommended to use wide trace lengths or thick copper weight to minimize I×R drop and heat dissipation. www.3peakic.com.cn 16 / 17 Rev.A.0 TPL920 Series 2-A Output, High-PSRR, Low-Noise LDO Regulator Package Outline Dimensions 5×5 QFN-20 Symbol A A1 A3 D E D1 E1 k b e L ⚫ Dimensions In Millimeters Min. Max. 0.700 0.800 0.000 0.050 0.203REF. 4.900 5.100 4.900 5.100 3.000 3.200 3.000 3.200 0.400REF. 0.250 0.350 0.650BSC. 0.450 0.650 Dimensions In Inches Min. Max. 0.028 0.031 0.000 0.002 0.008REF. 0.193 0.201 0.193 0.201 0.118 0.126 0.118 0.126 0.016REF. 0.010 0.014 0.016BSC. 0.018 0.026 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. www.3peakic.com.cn 17 / 17 Rev.A.0
TPL920ADJ-QF7R 价格&库存
很抱歉,暂时无法提供与“TPL920ADJ-QF7R”相匹配的价格&库存,您可以联系我们找货
