TOS-3104AMRL-B11
Single Digit Display LED
Chip
Part Number
TOS-3104AMRL-B11
Material
Source Color
AIGaInP
Ultra-red
Face
Color
Segment
Color
Black
White
Features
• (0.30”) 7.62mm digit height
• Common cathode
• I.C. compatible
• Low power requirement
• RoHS compliant
Applications
• Audio equipment
• Instrument panels
• Digital read out display
Package Dimensions & Internal Circuit Diagram
Notes:
1. All dimensions are in millimeters, tolerance: ±0.25 ; Angle: ±0.1° unless otherwise noted.
2. Specifications are subject to change without notice.
REV.: A-1
Prepared by ZG.YANG (23228)
Released Date: 2016/10/12
Doc No :GD1610002
Page 1/2
Absolute Maximum Rating @ Ta=25°C
Parameter
Maximum Rating
Unit
Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width)
80
mA
Power Dissipation
75
mW
Continuous Forward Current
mA
Recommend Operating Current
12
mA
Reverse Voltage
5
V
Operating Temperature Range
-25°C to +85°C
Storage Temperature Range
-30°C to +85°C
Lead-Free Solder Temperature (1/16 Inch Below Seating Plane)
260°C for 3 Sec
Electrical / Optical Characteristic @ Ta=25°C
Parameter
Symbol
Dominant Wavelength
Min.
Typ.
Max.
Unit
Test Condition
λd
640
nm
IF=20mA
Spectral Line Half-Width
△λ
15
nm
IF=20mA
Forward Voltage
VF
2.3
V
IF=20mA
Reverse Current
IR
100
µA
VR=5V
Iv-m
2.0:1
Luminous Intensity Matching Rate
1.8
2.0
Grade
IF=20mA
Displays need to be stored in an environment below 30 degree and below 60% humidity.
The lifetime of the displays is 1 year.
REV.: A-1
Doc No :GD1610002
Page 2/2
很抱歉,暂时无法提供与“TOS-3104AMRL-B11”相匹配的价格&库存,您可以联系我们找货
