TPL910ADJ-DF6R
TPL910ADJ-DF6R
    3PEAK(思瑞浦)
    DFN8_3X3MM_EP
    1A输出、高PSRR、低噪声、低损耗线性稳压器 DFN8_3X3MM_EP
TPL910ADJ-DF6R 数据手册
TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Features Description ◼ Input Voltage Range: 2.2 V to 6.5 V The TPL910 series products are 1-A high-current, 24-μVRMS ◼ Output Voltage Options: low-noise, high-PSRR, high-accuracy linear regulators with only ◼ ◆ Fixed Output Voltage: 0.8 V to 5 V 500-mV maximum ultra-low dropout voltage at 1-A load current. ◆ Adjustable Output Voltage: 0.8 V to 5.2 V The TPL910 series products support both fixed output voltage 3% Accuracy over Line Regulation, Load Regulation, and ranges from 0.8 V to 5 V and adjustable output voltage ranges Operating Temperature Range from 0.8 V to 5.2 V with external resistor divider. ◼ 1 A Maximum Output Current ◼ Low Dropout Voltage: 500 mV Maximum at 1 A Ultra-low noise, high PSRR, and high output current capability ◼ High PSRR: makes the TPL910 series products ideal power supply for noise- ◆ 65 dB at 1 kHz sensitive applications, such as high-speed communication ◆ 50 dB at 100 kHz facilities, test and measurement devices, or high-definition ◼ 24 μVRMS Output Voltage Noise (100 Hz to 100kHz) imaging equipment. Accurate output voltage tolerance, output ◼ Excellent Transient Response remote sensing, excellent transient response, and adjustable ◼ Stable with a 10 μF or Larger Ceramic Output Capacitor soft-start control ensures the TPL910 series products optimal ◼ Thermal Shutdown and Over-Current Protection power supply for the large-scale processors or digital loads, ◼ Operating Junction Temperature: –40°C to +125°C such as ASIC, FPGA, CPLD and DSP. ◼ Package: 3×3 DFN-8 The TPL910 series products provide 3×3 DFN-8 package with Applications guaranteed operating junction temperature range (T J) from – ◼ Wireless Communication: CPU, ASIC, FPGA, CPLD, DSP ◼ High-Performance Analog: ADC, DAC, LVDS, VCO ◼ Noise-Sensitive Imaging: CMOS Sensors, Video ASICs 40°C to +125°C. Typical Application Schematic CIN VIN VIN Digital I/O or VIN EN VOUT VOUT R1 TPL910 CFF COUT FB R2 NR CNR www.3peakic.com.cn GND 1 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Product Family Table Part Number Output Voltage Orderable Number Package TPL910 Adjustable (0.8 V ~ 5.2 V) TPL910ADJ-DF6R 3×3 DFN-8 www.3peakic.com.cn 2 / 17 Transport Media, Quantity 4,000 MSL MSL3 Marking information L910A Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Typical Application Schematic ...................................................................................................................................... 1 Product Family Table ...................................................................................................................................................... 2 Table of Contents ............................................................................................................................................................ 3 Revision History .............................................................................................................................................................. 4 Pin Configuration and Functions .................................................................................................................................. 5 Specifications .................................................................................................................................................................. 6 Absolute Maximum Ratings .......................................................................................................................................................... 6 ESD Ratings ................................................................................................................................................................................. 6 Recommended Operating Conditions ........................................................................................................................................... 6 Thermal Information ...................................................................................................................................................................... 6 Electrical Characteristics ............................................................................................................................................................... 7 Typical Performance Characteristics............................................................................................................................................. 9 Detailed Description ..................................................................................................................................................... 11 Overview ..................................................................................................................................................................................... 11 Functional Block Diagram ........................................................................................................................................................... 11 Feature Description ..................................................................................................................................................................... 11 Application and Implementation.................................................................................................................................. 14 Application Information................................................................................................................................................................ 14 Typical Application ...................................................................................................................................................................... 14 Layout Requirements .................................................................................................................................................................. 15 Package Outline Dimensions ....................................................................................................................................... 16 3×3 DFN-8 .................................................................................................................................................................................. 17 www.3peakic.com.cn 3 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Revision History Date Revision Notes 2019/04/30 Rev.Pre Preliminary Version 2020/05/08 Rev.A.0 Initial Release 1. Update the top view figure of DFN-8 Package in Page 5 2021/06/07 Rev.A.1 2. Add Tape and Reel Information in Page 16 3. Change Package Outline Dimensions, 3×3 DFN-8, in Page 17 www.3peakic.com.cn 4 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Pin Configuration and Functions TPL910 Series DFN-8 Package Top View OUT 1 OUT 2 8 IN 7 IN Exposed PAD FB 3 6 NR GND 4 5 EN Pin Functions NAME PIN NUMBER TYPE EN 5 I DESCRIPTION Regulator enable pin. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to IN directly. Output voltage feedback pin. Connect to an external resistor divider to adjust the FB 3 I output voltage. A 10-nF feed-forward capacitor from FB to OUT (as close as possible to FB pin) is recommended to maximize regulator ac performance. GND 4 – IN 7, 8 I NR 6 I OUT 1, 2 O Ground reference pin. Connect GND pin to PCB ground plane directly. Input voltage pin. A 10-μF or larger ceramic capacitor from IN to ground (as close as possible to IN pin) is required to reduce the jitter from previous-stage power supply. Noise-reduction and soft-start pin. A 10-nF or larger capacitor from NR/SS to GND (as close as possible to NR/SS pin) is recommended to maximize ac performance. Regulated output voltage pin. A 10-μF or larger ceramic capacitor from OUT to ground (as close as possible to OUT pin) is required to ensure regulator stability. (1) Exposed PAD must be connected to a large-area ground plane to maximum the thermal performance. www.3peakic.com.cn 5 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Specifications Absolute Maximum Ratings MIN MAX UNIT IN, EN –0.3 7 V OUT –0.3 VIN + 0.3 V FB, NR –0.3 3.6 V TJ Junction Temperature Range –40 150 °C TSTG Storage Temperature Range –65 150 °C TL Lead Temperature (Soldering 10 sec) 260 °C (1) Stresses beyond the Absolute Maximum Ratings may permanently damage the device. (2) All voltage values are with respect to GND. ESD Ratings Condition Minimum Level Unit HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 ±4000 V CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 ±1500 V Recommended Operating Conditions MIN TYP MAX UNIT 2.2 6.5 V IN Input voltage EN Enable voltage 0 6.5 V OUT Output voltage 0.8 5.2 V OUT Output current 0 1 A CIN Input capacitor 10 µF COUT Output capacitor 10 µF CFF Feed-forward capacitor 10 nF CNR NR capacitor 10 nF PD Power dissipation 1000 mW TJ Junction Temperature Range –40 125 °C Thermal Information PACKAGE θJA θJC,bottom UNIT 3×3 DFN-8 69.3 8.16 °C/W www.3peakic.com.cn 6 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Electrical Characteristics TJ = –40°C to +125°C (typical value at TJ = +25°C), VIN = VOUT(NOM) + 0.5 V or 2.2 V, whichever is greater; VEN = 2.2 V, IOUT = 1 mA, CIN = 10 µF, COUT = 47 µF, CNR = 10 nF, CFF = open, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT 6.5 V 2.1 V Supply Input Voltage and Current VIN UVLO Input supply voltage range (1) Input supply UVLO 2.2 VIN rising, RL = 1 kΩ 1.3 Hysteresis 200 IGND GND pin current ISD Shutdown current mV VIN = 6.5 V, IOUT = 1 mA 15 30 mA VIN = 6.5 V, IOUT = 1 A 15 30 mA VIN = 6.5 V, VEN = Low 10 25 µA Device Enable VIH(EN) EN pin high-level input voltage Device enable 1.2 6.5 V VIL(EN) EN pin low-level input voltage Device disable 0 0.4 V IEN EN pin current VIN = 6.5 V, VEN = 0 V to 6.5 V 0.1 1 µA 0.8 0.81 V 0.1 1 µA Regulated Output Voltage and Current VFB Feedback voltage IFB FB pin leakage current VNR NR/SS pin voltage INR NR/SS pin charging current 0.79 VIN = 6.5 V, stress VFB = 0.8V 0.8 VIN = 6.5 V, VNR = GND VIN = VOUT(NOM) + 0.5 V or 2.5 V to 6 V, VOUT = 0.8 V VOUT Output accuracy (2) to 5.2 V, IOUT = 100 mA to 500 mA VIN = VOUT(NOM) + 0.5 V or 2.2 V to 6.5 V, VOUT = 0.8 V to 5.2 V, IOUT = 100 mA to 1 A ΔVOUT Line regulation Load regulation 7.2 2% –3% 3% VIN = VOUT(NOM) + 0.5 V or 2.2 V to 6.5 V, IOUT = 100 mA IOUT = 100 mA to 1 A mV/V 0.07 mV/A VIN = VOUT(NOM) + 0.5 V or 2.2 V to 6.5 V, IOUT = 750 mA, VFB = GND or VSNS = GND VIN = VOUT(NOM) + 0.5 V or 2.2 V to 6.5 V, IOUT = 1 A, VFB = GND or VSNS = GND ILIM Output current limit tSTR Start-up time VOUT forced at 0.9 × VOUT(NOM), VIN ≥ 3.3 V VOUT(NOM) = 3.3 V, VOUT = 0% to 90% VOUT(NOM), RL = 3.3 kΩ, COUT = 10 μF, CNR = 100 nF 1.1. µA 0.03 mA, VFB = GND or VSNS = GND Dropout voltage (1) 9 –2% VIN = VOUT(NOM) + 0.5 V or 2.2 V to 6.5 V, IOUT = 500 VDO V 250 mV 350 mV 500 mV 1.4 A 13 ms (1) Minimum VIN = VOUT(NOM) + VDO or 2.2 V, whichever is greater. (2) Resistor tolerance is not included. Output accuracy is not tested at this condition: VOUT = 0.8 V, 4.5V ≤ VIN ≤ 6.5 V, and 750 mA ≤ IOUT ≤ 1 A, because the power dissipation is out of package limitation. www.3peakic.com.cn 7 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Electrical Characteristics (continued) TJ = –40°C to +125°C (typical value at TJ = +25°C), VIN = VOUT(NOM) + 0.5 V or 2.2 V, whichever is greater; VEN = 2.2 V, IOUT = 1 mA, CIN = 10 µF, COUT = 47 µF, CNR = 10 nF, CFF = open, unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT PSRR and Noise PSRR VN Power supply ripple rejection Output noise voltage VIN = 5.5 V, VOUT = 5.2 V, IOUT = 1 A f = 1 kHz 65 dB f = 100 kHz 50 dB f = 1 MHz 30 dB 24 μVRMS 160 °C 20 °C BW = 100 Hz to 100 kHz, VIN = 5.5 V, VOUT = 5.2 V, IOUT = 1 A, CNR = 100 nF, CFF = 10 nF Temperature Range TSD TJ Thermal shutdown threshold Temperature increasing Hysteresis Operating junction temperature www.3peakic.com.cn –40 8 / 17 125 Rev.A.1 °C TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Typical Performance Characteristics VIN = VOUT(NOM) + 0.5 V or 2.2 V, whichever is greater; VEN = 2.2 V, CIN = 10 µF, COUT = 47 µF, CNR = 10 nF, CFF = open, unless otherwise noted. 0.820 0.810 –40°C 25°C –40°C 25°C 85°C 125°C 85°C 125°C Output Voltage (V) Output Voltage (V) 0.820 0.800 0.790 0.780 0.810 0.800 0.790 0.780 0 0.2 0.4 0.6 0.8 1 0 0.01 Load Current (A) VOUT = 0.8 V Figure 2 Load Regulation at Light Load 0.820 250 –40°C 25°C 85°C 0.810 −40°C Dropout Voltage (mV) Output Voltage (V) 0.03 VOUT = 0.8 V Figure 1 Load Regulation 125°C 0.800 0.790 0.780 200 25°C 85°C 150 125°C 100 50 0 2.2 2.6 3.0 3.4 3.8 4.2 4.6 5.0 5.4 5.8 6.2 6.6 0 0.2 0.4 Supply Voltage (V) 0.6 0.8 1 Load Current (A) VOUT = 0.8 V, IOUT = 5 mA VOUT = 1.5 V Figure 3 Line Regulation Figure 4 Dropout Voltage vs. Load Current 1 Enable Threshold (V) 200 Dropout Voltage (mV) 0.02 Load Current (A) 150 100 50 0 0.8 0.6 0.4 VIH(EN) 0.2 VIL(EN) 0 2.2 2.6 3 3.4 3.8 4.2 4.6 5 5.4 5.8 6.2 6.6 Supply Voltage (V) 5 20 35 50 65 80 95 110 125 Ambient Temperature (°C) Figure 5 Dropout Voltage vs. Supply Voltage www.3peakic.com.cn -40 -25 -10 Figure 6 Enable Threshold vs. Temperature 9 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Typical Performance Characteristics (continued) VIN = VOUT(NOM) + 0.5 V or 2.2 V, whichever is greater; VEN = 2.2 V, CIN = 10 µF, COUT = 47 µF, CNR = 10 nF, CFF = open, unless otherwise noted. 1 120 0.8 100 PSRR(dB) Enable Threshold (V) IOUT = 0.1 A 0.6 0.4 VIH(EN) IOUT = 1 A 80 60 40 VIL(EN) 0.2 20 0 2.2 2.6 3 3.4 3.8 4.2 4.6 5 5.4 5.8 6.2 6.6 0 10 Supply Voltage (V) 100 1K 10K 100K 1M 10M Frequency(Hz) VIN = 5.5 V, VOUT = 5.2 V, COUT = 47µF // 10µF // 10µF, CNR/SS =100nF, CFF = open Figure 7 Enable Threshold vs. Supply Voltage VIN = 2.2V to 6.5V, VOUT = 0.8V Figure 8 PSRR IOUT = 0.1A to 1A, VOUT = 0.8V Figure 9 Line Transient www.3peakic.com.cn Figure 10 Load Transient 10 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Detailed Description Overview The TPL910 series products are 1-A high-current, 24-μVRMS low-noise, high-PSRR, high-accuracy linear regulators with only 500-mV maximum ultra-low dropout voltage at 1-A load current. The TPL910 series products support both fixed output voltage ranges from 0.8 V to 5 V and adjustable output voltage ranges from 0.8 V to 5.2 V with external resistor divider. Ultra-low noise, high PSRR, and high output current capability makes the TPL910 series products ideal power supply for noisesensitive applications, such as high-speed communication facilities, test and measurement devices, or high-definition imaging equipment. Accurate output voltage tolerance, output remote sensing, excellent transient response, and adjustable soft-start control ensures the TPL910 series products optimal power supply for the large-scale processors or digital loads, such as ASIC, FPGA, CPLD and DSP. Functional Block Diagram IN OUT UVLO Control Curren t Control PSRR Control Regula tor Control Acti ve Discha rge Thermal Control EN Ena ble Control + EA – FB VREF INR /SS GND NR Figure 11 Functional Block Diagram Feature Description Enable (EN) The TPL910 series provide a device enable pin (EN) to enable or disable the device. Connect this pin to the GPIO of an external digital logic control circuit to control the device. When the V EN voltage falls below VIL(EN), the LDO device turns off, and when the VEN ramps above VIH(EN), the LDO device turns on. Under-Voltage Lockout (IN and UVLO) The TPL910 series use an under-voltage lockout circuit to keep the output shut off until the internal circuitry operates properly. Voltage Regulation (OUT and FB) The TPL910 series provide adjustable output voltage option. Using external resistors divider, the output voltage of TPL910 series is determined by the value of the resistor R1 and R2 in Figure 12. Use Equation 1 to calculate the output voltage. www.3peakic.com.cn 11 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator R1   VOUT = VFB   1 +   R2  (1) Where the feedback voltage VFB is 0.8 V. Table 1 provides a list of recommended resistor combinations to achieve the common output voltage values. Table 1 External Resistor Combinations Target Output Voltage (V) External Resistors Divider Calculated Output Voltage (V) R1 (kΩ) R2 (kΩ) 0.80 0 Open 0.800 0.81 2 160 0.810 0.82 4.02 160 0.820 0.83 6.04 160 0.830 0.84 8.06 160 0.840 0.85 10 160 0.850 0.86 12 160 0.860 0.87 12.4 143 0.869 0.88 12.4 124 0.880 0.89 12 107 0.890 0.90 12.4 100 0.899 0.95 12.4 66.5 0.949 1.00 12.4 49.9 0.999 1.10 12.4 33.2 1.099 1.20 12.4 24.9 1.198 1.50 12.4 14.3 1.494 1.80 12.4 10 1.792 1.90 12.1 8.87 1.891 2.50 12.4 5.9 2.481 2.85 12.1 4.75 2.838 3.00 12.1 4.42 2.990 3.30 11.8 3.74 3.324 3.60 12.1 3.48 3.582 4.50 11.8 2.55 4.502 5.00 12.4 2.37 4.986 Output Active Discharge The TPL910 series integrate an output discharge path from OUT to GND. When the device is disabled, either EN or VIN is lower than turn-on threshold, the output will actively discharge the output voltage through an internal resistor of several hundred ohms. Do not rely on this active discharge circuit for discharging large output capacitors when the input voltage falls below the output voltage. Reverse current flow through internal power MOSFET can permanently damage the device, and external current protection is essential at this condition. Over-Current Protection The TPL910 series integrate an internal current limit that helps to protect the device during fault conditions. When the output is pulled down below the target output voltage, over-current protection starts to work and limit the output current to a typical value of 1.4 A. Under the over-current conditions, the internal junction temperature ramps up quickly. When the junction temperature is high enough, www.3peakic.com.cn 12 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator it will cause the over temperature protection. Over-Temperature Protection The recommended operating junction temperature range is –40°C to 125°C. When the junction temperature is between 125°C and the thermal shutdown (TSD) threshold, the regulator can still work well, but will reduce the device lifetime for long-term using. The over-temperature protection works when the junction temperature exceeds the thermal shutdown (TSD) threshold, which turns off the regulator immediately. Until when the device cools down and the junction temperature falls below the thermal shutdown threshold minus thermal shutdown hysteresis, the regulator turns on again. www.3peakic.com.cn 13 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Application and Implementation NOTE Information in the following applications sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Application Information The TPL910 series products are 1-A high-current, 24-μVRMS low-noise, high-PSRR, high-accuracy linear regulators with only 500-mV maximum ultra-low dropout voltage. The following application schematic shows a typical usage of the TPL910 series. Typical Application Adjustable Output Operation Figure 12 shows the typical application schematic of the TPL910 series. CIN VIN VIN Digital I/O or VIN EN VOUT VOUT R1 TPL910 CFF COUT FB R2 NR GND CNR Figure 12 Adjustable Output Operation Input Capacitor and Output Capacitor The TPL910 series is designed to be stable with low equivalent series resistance (ESR) ceramic capacitors at the input, output, and noise-reduction pin (NR/SS). It is recommended to use ceramic capacitors with X7R-, X5R-, and COG-rated dielectric materials to get good capacitive stability across temperature. 3PEAK recommends adding a 10 μF or greater capacitor with a 0.1 μF bypass capacitor in parallel at IN pin to keep the input voltage stable. The voltage rating of the capacitors must be greater than the maximum input voltage. To ensure loop stability, the TPL910 series requires an output capacitor with a minimum effective capacitance value of 3.3 μF. 3PEAK recommends selecting a X7R-type 10-μF ceramic capacitor with low ESR over temperature. Both input capacitors and output capacitors must be placed as close to the device pins as possible. Power Dissipation During normal operation, LDO junction temperature should not exceed 125°C. Using below equations to calculate the power dissipation and estimate the junction temperature. The power dissipation can be calculated using Equation 2. PD = ( VIN − VOUT )  IOUT + VIN  IGND (2) The junction temperature can be estimated using Equation 3. θJA is the junction-to-ambient thermal resistance. www.3peakic.com.cn 14 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator TJ = TA + PD  JA (3) Layout Requirements • Both input capacitors and output capacitors must be placed as close to the device pins as possible, and vias between capacitors and device power pins must be avoid. • It is recommended to bypass the input pin to ground with a 0.1 μF bypass capacitor. The loop area formed by the bypass capacitor connection, IN pin and the GND pin of the system must be as small as possible. • It is recommended to use wide trace lengths or thick copper weight to minimize I×R drop and heat dissipation. www.3peakic.com.cn 15 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Tape and Reel Information Order Number Package TPL910ADJ-DF6R 3×3 DFN-8 www.3peakic.com.cn D1 W1 A0 B0 K0 P0 W0 Pin1 (mm) (mm) (mm) (mm) (mm) (mm) (mm) Quadrant 330.0 17.6 3.4 3.4 1.1 8.0 12.0 Q2 16 / 17 Rev.A.1 TPL910 Series 1-A Output, High-PSRR, Low-Noise LDO Regulator Package Outline Dimensions 3×3 DFN-8 Top View Side View / Bottom View 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. www.3peakic.com.cn 17 / 17 Rev.A.1
TPL910ADJ-DF6R 价格&库存
很抱歉,暂时无法提供与“TPL910ADJ-DF6R”相匹配的价格&库存,您可以联系我们找货
