HG25Q64
3V 64M-BIT
SERIAL FLASH MEMORY WITH DUAL, QUAD SPI
1.
GENERAL DESCRIPTIONS
The HG25Q64 (64M-bit) Serial Flash memory provides a storage solution for systems with limited space,
pins and power. The 25Q series offers flexibility and performance well beyond ordinary Serial Flash devices.
They are ideal for code shadowing to RAM, executing code directly from Dual/Quad SPI (XIP) and storing
voice, text and data. The device operates on 2.7V to 3.6V power supply with current consumption as low as
1µA for power-down. All devices are offered in space-saving packages.
The HG25Q64 array is organized into 32,768 programmable pages of 256-bytes each. Up to 256 bytes can
be programmed at a time. Pages can be erased in groups of 16 (4KB sector erase), groups of 128 (32KB
block erase), groups of 256 (64KB block erase) or the entire chip (chip erase). The HG25Q64 has 2,048
erasable sectors and 128 erasable blocks respectively. The small 4KB sectors allow for greater flexibility in
applications that require data and parameter storage. (See Figure 2.)
The HG25Q64 supports the standard Serial Peripheral Interface (SPI), Dual/Quad I/O SPI: Serial Clock, Chip
Select, Serial Data I/O0 (DI), I/O1 (DO), I/O2 and I/O3. SPI clock frequencies of W25Q64JV of up to 133MHz
are supported allowing equivalent clock rates of 266MHz (133MHz x 2) for Dual I/O and 532MHz (133MHz x
4) for Quad I/O when using the Fast Read Dual/Quad I/O. These transfer rates can outperform standard
Asynchronous 8 and 16-bit Parallel Flash memories.
Additionally, the device supports JEDEC standard manufacturer and device ID, and a 64-bit Unique Serial
Number and three 256-bytes Security Registers.
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing Qty
HG25Q64N
DIP8
25Q64
TUBE
2000/box
HG25Q64M/TR
SOP8
25Q64
REEL
2500/reel
2. FEATURES
New Family of SpiFlash Memories
– HG25Q64 : 64M-bit / 8M-byte
– Standard SPI: CLK, /CS, DI, DO
– Dual SPI: CLK, /CS, IO0, IO1
– Quad SPI: CLK, /CS, IO0, IO1, IO2, IO3
– Software & Hardware Reset(1)
Flexible Architecture with 4KB sectors
– Uniform Sector/Block Erase (4K/32K/64K-Byte)
– Program 1 to 256 byte per programmable page
– Erase/Program Suspend & Resume
Highest Performance Serial Flash
– 133MHz Single, Dual/Quad SPI clocks
– 266/532MHz equivalent Dual/Quad SPI
– Min. 100K Program-Erase cycles per sector
– More than 20-year data retention
Low Power, Wide Temperature Range
– Single 2.7 to 3.6V supply
很抱歉,暂时无法提供与“HG25Q64M/TR”相匹配的价格&库存,您可以联系我们找货
