MUR1040DC
MUR1040DC
    YFW(佑风微)
    TO263
    快/超快恢复二极管 400V 10A 950mV 35ns
MUR1040DC 数据手册
MUR1040AC-FAC-DC ULTRAFST RECOVERY RECTIFIERS Reverse Voltage - 400 V Forward Current - 10 A         FEATURES  High speed switching capability  High current capability  High forward surge capability  Low power losses,High efficiency    For use in low voltage, high frequency inverters  Lead free in comply with EU RoHS 2011/65/EU directives     MECHANICAL DATA  Case: TO-220AC TO-220FAC TO-263/DC  Solder bath temperature275℃maximum,10s per JESD22-106 Primary Characteristic Io VRRM IFSM VF TJ Max 10A 400V 160A 0.95V 150°C Maximum Ratings (Per Leg) at Ta=25°C unless otherwise specified Parameter Symbols Value Units Maximum Repetitive Peak Reverse Voltage VRRM 400 V Maximum RMS voltage VRMS 400 V Maximum DC Blocking Voltage VDC 400 V Io 10 A Peak Forward Surge Current, 8.3ms Single Half Sine-wave IFSM 160 A Operating Temperature Range TJ -40 ~ +150 °C TSTG -40 ~ +150 °C RθJA/ RθJC 2/4 °C/W Maximum Average Forward Rectified Current Storage Temperature Range Typical Thermal Resistance (Note1) TO-220AC TO-263/DC TO-220FAC Note1: Thermal resistance from Junction to case per leg mounted on heatsink. Electrical Characteristics (Per Leg) unless otherwise specified Characteristics Symbols Forward Voltage Drop(Note2) at IF=3A at IF=5A at IF=10A Maximum Reverse Current at VR=400V TA=25°C TA=125°C Units Max 0.91 - 0.76 - 0.97 - TA=125°C 0.83 1.3 TA=25°C VF TA=25°C 1.08 TA=125°C 0.95 - TA=25°C 0.007 1 TA=125°C Maximum Reverse Recovery Time at IF=0.5A, IR=1A, IRR=0.25A Note2:Pulse test: 300 μs pulse width, 1 % duty cycle www.yfwdiode.com Value Typ IR TRR 1/4 5 - - 35 V uA uA nS Dongguan YFW Electronics Co, Ltd. MUR1040AC-FAC-DC RATINGS AND CHARACTERISTIC CURVES 8.3ms Single Half Sine Wave JEDEC Method TA=125℃ TA=125℃ TA=25℃ TA=25℃ Marking on the body Ordering information Part Number Package Unit Weight Base Quantity Delivery mode MUR1040 TO-220AC 0.067oz(1.9g) 50 pcs / tube 1000pcs/box 5000pcs/carton MUR1040F TO-220FAC 0.06oz(1.7g) 50 pcs / tube 1000pcs/box 5000pcs/carton MUR1040DC TO-263 0.04oz(1.16g) 50 pcs / tube 1000pcs/box 5000pcs/carton MUR1040DC-R TO-263 0.04oz(1.16g) 800 pcs / reel 800pcs/box4000pcs/carton Note: For Halogen Free molding compound, add "H" suffix to part number above. www.yfwdiode.com 2/4 Dongguan YFW Electronics Co, Ltd. MUR1040AC-FAC-DC Package Outline Dimensions millimeters www.yfwdiode.com 3/4 Dongguan YFW Electronics Co, Ltd. MUR1040AC-FAC-DC www.yfwdiode.com 4/4 Dongguan YFW Electronics Co, Ltd.
MUR1040DC 价格&库存
很抱歉,暂时无法提供与“MUR1040DC”相匹配的价格&库存,您可以联系我们找货
MUR1040DC
  • 1+1.42148
  • 10+1.30401
  • 30+1.28051
  • 100+1.21002
库存:88
