SPK0810-330MB
SPK0810-330MB
    LANTUMICRO(蓝图微电)
    IND_D9X13MM_TM
    色环电感 50@2.52MHz 75mΩ 33μH ±20% 1.9A 8.5MHz 13.00mm Ф9.00 x 13.00mm IND_D9X13MM_TM
SPK0810-330MB 数据手册
Unshielded DIP Power Inductors SPK Series Spike suppression coil LT-蓝图 Features: ◆特征: ● 低成本 ● Low cost ● 具有高功率,高饱和低电阻 ● High power,High saturation ,Low resistance ● 非屏蔽功率电感 ● Unshielded power inductor ● 磁芯由 UL 热缩管包覆以提供 ● Core is encapsulated by UL heat shrink tube to provide excellent mechanic and environmental protection 优良的机械和环境保护 ● 多种封装尺寸和宽电感范围 ● Various package size and wide inductance range ● 编带包装可用于自动插件 ● Tape packaging for auto-insertion ● 符合 RoHS,无卤和 REACH ● RoHS, Halogen Free and REACH Compliance ◆用途: Applications: ● 电视和音响设备 ● TVs and Audio equipment ● 通信设备 ● Telecommunication devices ● 噪声滤波器 ● Other noise filter ● 充电器,快充 ● Charger, fast charge ● DC/DC 转换器 ● DC/DC converters ◆环境: Environmental Data: ● 工作温度:-40℃ 至+125℃ ● Operating Temperature: -40℃ to +125℃ (Including coils self-temperature rise) (包括线圈自身温升) ◆试验设备: Test Equipment: ● 电感值:HP4284A, HP4285A 或同等仪器 ● L:HP4284A or HP4285A LCR meter or equivalent ● 电流:HP4284+42841A 或同等仪器 ● Isat & Irms: HP4284+42841A or equivalent ● 自谐振频率: HM 9461 或同等仪器 ● SRF: HM 9461 or equivalent ● 品质因子: HP4285A 或同等仪器 ● Q: HP4285A or equivalent ● 直流电阻: Chroma 16502 或同等仪器 ● DCR:Chroma 16502 or equivalent ◆产品型号: Product Identification: SPK ① 0608 ② ① K B ③ ④ ⑤ ② 类型 Type 径向引线固定电感 SPK 503 Raial Leaded Fixed Inductors ③ 外形尺寸(L×W×H) (mm) External Dimensions (L×H) (mm) 0608 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. Inductance 50 mH 7.0×11.0 http:www.szlantu.com.cn 1 Unshielded DIP Power Inductors ④ ⑤ 包装 Packing 公差 Inductance Tolerance B 散装 Bulk Package TF 编带 Tape J:±5%,K: ±10%, L: ±15% M: ±20%,P: ±25%, N: ±30% Shape and Dimensions(dimensions are in mm): ◆外观尺寸: Reference Marking is available if needed holepattern 如果需要,产品可印字 ITEM Part No A B C D E F H SPK0406 8.0 Max 15.0 Min 2.0±0.5 5.0 Max 0.55±0.1 0.85 2.0 SPK0608 11.0 Max 15.0 Min 2.5±0.5 7.0 Max 0.65±0.1 0.95 2.5 SPK0707 9.5 Max 15.0 Min 5.0±1.0 8.0 Max 0.65±0.1 0.95 5.0 SPK0807 9.5 Max 15.0 Min 5.0±1.0 9.0 Max 0.65±0.1 0.95 5.0 SPK0810 13.0 Max 15.0 Min 5.0±1.0 9.0 Max 0.65±0.1 0.95 5.0 SPK0912 15.0 Max 15.0 Min 5.0±1.0 10.0 Max 0.80±0.1 1.1 5.0 SPK1010 13.0 Max 15.0 Min 5.0±1.0 12.0 Max 0.80±0.1 1.1 5.0 SPK1012 15.0 Max 15.0 Min 6.0±1.0 12.0 Max 0.80±0.1 1.1 6.0 SPK1016 19.0 Max 15.0 Min 6.0±1.0 12.0 Max 0.80±0.1 1.1 6.0 SPK1018 21.0 Max 15.0 Min 6.0±1.0 12.0 Max 0.80±0.1 1.1 6.0 SPK1213 16.0 Max 15.0 Min 7.5±1.0 14.0 Max 0.80±0.1 1.1 7.5 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 2 Unshielded DIP Power Inductors Specifications: ◆规格特性: ● SPK0406 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Q SRF DCR Rated Current Test (MHz) ( Ω) (mA) Min Freq. Min Max Max Tole '@1KHz SPK0406-1R0M-□□ 1.0 M 100 7.96MHZ 120 0.035 2000 SPK0406-1R2M-□□ 1.2 M 100 7.96MHZ 120 0.058 1950 SPK0406-1R5M-□□ 1.5 M 100 7.96MHZ 120 0.075 1900 SPK0406-1R8M-□□ 1.8 M 100 7.96MHZ 120 0.110 1800 SPK0406-2R2M-□□ 2.2 M 100 7.96MHZ 100 0.120 1750 SPK0406-2R7M-□□ 2.7 M 100 7.96MHZ 80 0.125 1680 SPK0406-3R3M-□□ 3.3 M 100 7.96MHZ 75 0.130 1500 SPK0406-3R9M-□□ 3.9 M 100 7.96MHZ 70 0.135 1450 SPK0406-4R7M-□□ 4.7 M 100 7.96MHZ 50 0.140 1320 SPK0406-5R6M-□□ 5.6 M 100 7.96MHZ 45 0.145 1230 SPK0406-6R8M-□□ 6.8 M 100 7.96MHZ 30 0.150 1150 SPK0406-8R2M-□□ 8.2 M 100 7.96MHZ 22 0.160 1100 SPK0406-100M-□□ 10 M 80 2.52MHZ 20 0.230 1000 SPK0406-120M-□□ 12 M 80 2.52MHZ 17 0.240 970 SPK0406-150M-□□ 15 M 80 2.52MHZ 16 0.250 920 SPK0406-180M-□□ 18 M 80 2.52MHZ 12 0.330 860 SPK0406-220M-□□ 22 M 80 2.52MHZ 10 0.450 800 SPK0406-270M-□□ 27 M 80 2.52MHZ 9.5 0.500 710 SPK0406-330M-□□ 33 M 80 2.52MHZ 8.7 0.700 660 SPK0406-390M-□□ 39 M 70 2.52MHZ 8.2 0.740 600 SPK0406-470M-□□ 47 M 70 2.52MHZ 7.8 0.760 550 SPK0406-560M-□□ 56 M 50 2.52MHZ 7.6 0.800 500 SPK0406-680M-□□ 68 M 50 2.52MHZ 6.8 0.900 470 SPK0406-820M-□□ 82 M 50 2.52MHZ 6.0 0.950 430 SPK0406-101K-□□ 100 K 45 796KHZ 6.0 1.000 400 SPK0406-121K-□□ 120 K 45 796KHZ 5.5 1.100 370 SPK0406-151K-□□ 150 K 65 796KHZ 4.2 1.300 350 SPK0406-181K-□□ 180 K 65 796KHZ 3.6 1.500 320 SPK0406-221K-□□ 220 K 65 796KHZ 2.8 1.800 300 SPK0406-271K-□□ 270 K 50 796KHZ 2.4 1.900 275 SPK0406-331K-□□ 330 K 50 796KHZ 2.2 2.200 250 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 3 Unshielded DIP Power Inductors Inductance Part No L(μH) Q SRF DCR Rated Current Test (MHz) ( Ω) (mA) Min Freq. Min Max Max Tole '@1KHz SPK0406-391K-□□ 390 K 50 796KHZ 2.0 2.700 220 SPK0406-471K-□□ 470 K 50 796KHZ 1.7 3.600 200 SPK0406-561K-□□ 560 K 50 796KHZ 1.5 4.200 190 SPK0406-681K-□□ 680 K 50 796KHZ 1.3 4.600 170 SPK0406-821K-□□ 820 K 50 796KHZ 1.1 5.700 155 SPK0406-122K-□□ 1200 K 90 252KHZ 0.9 8.200 140 SPK0406-152K-□□ 1500 K 80 252KHZ 0.8 13.000 120 SPK0406-182K-□□ 1800 K 80 252KHZ 0.8 15.000 110 SPK0406-222K-□□ 2200 K 80 252KHZ 0.8 17.000 100 SPK0406-272K-□□ 2700 K 80 252KHZ 0.8 19.000 90 SPK0406-332K-□□ 3300 K 70 252KHZ 0.7 26.000 83 SPK0406-392K-□□ 3900 K 70 252KHZ 0.6 30.000 76 SPK0406-472K-□□ 4700 K 65 252KHZ 45.000 70 SPK0406-562K-□□ 5600 K 65 252KHZ 48.000 62 SPK0406-682K-□□ 6800 K 65 252KHZ 56.000 56 SPK0406-822K-□□ 8200 K 65 252KHZ 62.000 52 SPK0406-103K-□□ 10000 K 45 79.6KHZ 72.000 47 SPK0406-153K-□□ 15000 K 45 79.6KHZ 120.000 35 SPK0406-223K-□□ 22000 K 45 79.6KHZ 160.000 24 SPK0406-253K-□□ 25000 K 45 79.6KHZ 180.000 20 SRF DCR Rated Current Test (MHz) (Ω) (mA) Min Freq. Min Max Max ● SPK0608 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Q Tole '@1KHz SPK0608-3R3M-□□ 3.3 M 20 7.96MHZ 40.0 0.016 3500 SPK0608-4R7M-□□ 4.7 M 20 7.96MHZ 36.0 0.020 3000 SPK0608-6R8M-□□ 6.8 M 20 7.96MHZ 32.0 0.022 2500 SPK0608-100M-□□ 10 M 30 2.52MHZ 23.0 0.039 2000 SPK0608-150M-□□ 15 M 30 2.52MHZ 00 19.0 0.045 1700 SPK0608-220M-□□ 22 M 30 2.52MHZ 16.0 0.062 1400 SPK0608-330M-□□ 33 M 30 2.52MHZ 11.0 0.100 1100 SPK0608-470M-□□ 47 M 30 2.52MHZ 9.5 0.150 950 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 4 Unshielded DIP Power Inductors Inductance Part No L(μH) SPK0608-101K-□□ SPK0608-151K-□□ SPK0608-221K-□□ SPK0608-331K-□□ SPK0608-471K-□□ SPK0608-681K-□□ SPK0608-102K-□□ SPK0608-122K-□□ SPK0608-182K-□□ SPK0608-222K-□□ SPK0608-272K-□□ SPK0608-332K-□□ SPK0608-392K-□□ SPK0608-472K-□□ SPK0608-562K-□□ SPK0608-682K-□□ SPK0608-822K-□□ SPK0608-103K-□□ SPK0608-123K-□□ SPK0608-153K-□□ SPK0608-183K-□□ SPK0608-203K-□□ SPK0608-223K-□□ SPK0608-303K-□□ SPK0608-333K-□□ SPK0608-393K-□□ SPK0608-473K-□□ SPK0608-503K-□□ SPK0608-563K-□□ SPK0608-683K-□□ SPK0608-823K-□□ SPK0608-104K-□□ SPK0608-124K-□□ SPK0608-154K-□□ SRF DCR Rated Current Test (MHz) (Ω) (mA) Min Freq. Min Max Max Tole '@1KHz SPK0608-680M-□□ Q 68 M 30 2.52MHZ 9.0 0.220 800 100 K 20 796KHZ 6.5 0.350 650 150 K 20 796KHZ 5.5 0.430 540 220 K 20 796KHZ 4.8 0.900 440 330 K 20 796KHZ 3.7 1.500 350 470 K 20 796KHZ 2.8 1.800 300 680 K 20 796KHZ 2.5 2.500 250 1000 K 100 252KHZ 2.1 3.200 200 1200 K 70 252KHZ 3.500 180 1800 K 70 252KHZ 5.000 155 2200 K 70 252KHZ 6.800 140 2700 K 70 252KHZ 7.200 125 3300 K 70 252KHZ 10.500 115 3900 K 70 252KHZ 11.700 105 4700 K 70 252KHZ 13.600 95 5600 K 70 252KHZ 16.600 85 6800 K 70 252KHZ 19.600 80 8200 K 70 252KHZ 25.200 70 10000 K 70 79.6KHZ 29.500 65 12000 K 50 79.6KHZ 33.800 60 15000 K 50 79.6KHZ 45.400 55 18000 K 50 79.6KHZ 50.400 50 20000 K 50 79.6KHZ 76.000 47 22000 K 50 79.6KHZ 80.000 45 30000 K 50 79.6KHZ 91.500 40 33000 K 50 79.6KHZ 98.500 35 39000 K 50 79.6KHZ 140.000 32 47000 K 50 79.6KHZ 160.000 30 50000 K 50 79.6KHZ 170.000 29 56000 K 50 79.6KHZ 250.000 28 68000 K 50 79.6KHZ 282.000 25 82000 K 50 79.6KHZ 312.000 23 100000 K 30 25.2KHZ 380.000 20 120000 K 30 25.2KHZ 430.000 18 150000 K 30 25.2KHZ 520.000 16 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 5 Unshielded DIP Power Inductors ● SPK0707 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) SPK0707-1R5M-□□ SPK0707-2R2M-□□ SPK0707-3R3M-□□ SPK0707-4R7M-□□ SPK0707-6R8M-□□ SPK0707-100M-□□ SPK0707-150M-□□ SPK0707-220M-□□ SPK0707-330M-□□ SPK0707-470M-□□ SPK0707-680M-□□ SPK0707-101K-□□ SPK0707-151K-□□ SPK0707-221K-□□ SPK0707-331K-□□ SPK0707-471K-□□ SPK0707-681K-□□ SPK0707-102K-□□ SPK0707-152K-□□ SRF DCR Test (MHz) Min Freq. Tole '@1KHz SPK0707-1R0M-□□ Q Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Min Max Max Max 1.0 M 10 7.96MHz 70 0.006 6600 5000 1.5 M 10 7.96MHz 56 0.008 5400 4300 2.2 M 10 7.96MHz 45 0.011 4000 3700 3.3 M 10 7.96MHz 35 0.018 3600 2900 4.7 M 10 7.96MHz 29 0.022 3100 2600 6.8 M 10 7.96MHz 24 0.028 2500 2300 10 M 20 2.52MHz 19 0.043 2100 1900 15 M 20 2.52MHz 15 0.056 1700 1600 22 M 20 2.52MHz 12 0.086 1400 1300 33 M 20 2.52MHz 9.4 0.140 1100 1000 47 M 20 2.52MHz 7.6 0.170 960 940 68 M 20 2.52MHz 6.2 0.280 790 730 100 K 20 7.96MHz 5.0 0.330 600 670 150 K 20 7.96MHz 4.0 0.560 530 520 220 K 20 7.96MHz 3.2 0.720 440 420 330 K 20 7.96MHz 2.5 1.100 360 330 470 K 20 7.96MHz 2.0 1.700 300 270 680 K 20 7.96MHz 1.7 2.300 210 260 1000 K 70 2.52MHz 1.3 4.300 200 190 1500 K 50 2.52MHz 1.3 5.000 170 160 ● SPK0807 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) SPK0807-3R3M-□ SPK0807-4R7M-□ SPK0807-6R8M-□ SPK0807-100M-□□ SPK0807-150M-□□ SPK0807-220M-□□ SRF DCR Test (MHz) Min Freq. Tole '@1KHz SPK0807-2R2M-□ Q Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Min Max Max Max 2.2 M 10 7.96MHz 60 0.011 5500 4000 3.3 M 10 7.96MHz 38 0.013 3800 3400 4.7 M 10 7.96MHz 30 0.017 3700 3000 6.8 M 10 7.96MHz 24 0.023 2800 2600 10 M 20 2.52MHz 19 0.031 2500 2200 15 M 20 2.52MHz 15 0.042 2000 1900 22 M 20 2.52MHz 12 0.070 1600 1500 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 6 Unshielded DIP Power Inductors Inductance Part No L(μH) Q SRF DCR Test (MHz) Min Freq. Tole '@1KHz Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Min Max Max Max SPK0807-330M-□□ 33 M 20 2.52MHz 10 0.092 1300 1200 SPK0807-470M-□□ 47 M 20 2.52MHz 8.2 0.130 1100 1000 SPK0807-680M-□□ 68 M 20 2.52MHz 6.6 0.160 970 910 SPK0807-101K-□□ 100 K 15 796KHz 5.4 0.230 810 750 SPK0807-151K-□□ 150 K 15 796KHz 4.3 0.400 610 610 SPK0807-221K-□□ 220 K 15 796KHz 3.5 0.530 530 500 SPK0807-331K-□□ 330 K 15 796KHz 2.8 0.780 440 410 SPK0807-471K-□□ 470 K 10 796KHz 2.3 1.000 390 330 SPK0807-681K-□□ 680 K 10 796KHz 1.9 1.500 320 280 SPK0807-102K-□□ 1000 K 20 252KHz 1.5 2.200 260 230 SPK0807-152K-□□ 1500 K 30 252KHz 1.2 3.500 210 180 ● SPK0810 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Q SRF DCR Rated Current Test (MHz) ( Ω) (mA) Min Freq. Min Max Max Tole '@1KHz SPK0810-3R3M-□□ 3.3 M 30 7.96MHz 65 0.012 5000 SPK0810-3R9M-□□ 3.9 M 30 7.96MHz 55 0.014 4600 SPK0810-4R7M-□□ 4.7 M 30 7.96MHz 45 0.016 4300 SPK0810-5R6M-□□ 5.6 M 30 7.96MHz 38 0.020 3900 SPK0810-6R8M-□□ 6.8 M 30 7.96MHz 27 0.022 3700 SPK0810-8R2M-□□ 8.2 M 30 7.96MHz 21 0.024 3500 SPK0810-100M-□□ 10 M 50 2.52MHz 17 0.025 3200 SPK0810-120M-□□ 12 M 50 2.52MHz 15 0.027 3000 SPK0810-150M-□□ 15 M 50 2.52MHz 13 0.033 2800 SPK0810-180M-□□ 18 M 50 2.52MHz 12 0.039 2600 SPK0810-220M-□□ 22 M 50 2.52MHz 11 0.047 2400 SPK0810-270M-□□ 27 M 50 2.52MHz 10 0.052 2100 SPK0810-330M-□□ 33 M 50 2.52MHz 8.5 0.075 1900 SPK0810-390M-□□ 39 M 40 2.52MHz 7.7 0.082 1700 SPK0810-470M-□□ 47 M 40 2.52MHz 6.7 0.100 1500 SPK0810-560M-□□ 56 M 40 2.52MHz 6.4 0.150 1300 SPK0810-680M-□□ 68 M 30 2.52MHz 5.8 0.180 1200 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 7 Unshielded DIP Power Inductors Inductance Part No L(μH) Q SRF DCR Rated Current Test (MHz) ( Ω) (mA) Min Freq. Min Max Max Tole '@1KHz SPK0810-820M-□□ 82 M 30 2.52MHz 5.2 0.200 1100 SPK0810-101K-□□ 100 K 30 796KHz 4.4 0.200 900 SPK0810-121K-□□ 120 K 30 796KHz 4.2 0.220 800 SPK0810-151K-□□ 150 K 30 796KHz 3.7 0.240 720 SPK0810-181K-□□ 180 K 30 796KHz 3.5 0.280 650 SPK0810-221K-□□ 220 K 20 796KHz 3.3 0.350 600 SPK0810-271K-□□ 270 K 20 796KHz 2.9 0.400 550 SPK0810-331K-□□ 330 K 20 796KHz 2.6 0.470 500 SPK0810-391K-□□ 390 K 20 796KHz 2.4 0.680 460 SPK0810-471K-□□ 470 K 20 796KHz 2.2 0.800 420 SPK0810-561K-□□ 560 K 20 796KHz 2.0 1.000 380 SPK0810-681K-□□ 680 K 20 796KHz 1.8 1.200 350 SPK0810-821K-□□ 820 K 20 796KHz 1.7 1.500 310 SPK0810-102K-□□ 1000 K 40 252KHz 1.5 1.800 280 SPK0810-122K-□□ 1200 K 40 252KHz 1.4 2.000 250 SPK0810-152K-□□ 1500 K 40 252KHz 1.3 2.400 230 SPK0810-182K-□□ 1800 K 40 252KHz 1.1 2.800 210 SPK0810-222K-□□ 2200 K 40 252KHz 1.0 3.300 190 SPK0810-272K-□□ 2700 K 40 252KHz 0.88 5.000 170 SPK0810-392K-□□ 3900 K 40 252KHz 0.72 6.200 140 SPK0810-472K-□□ 4700 K 40 252KHz 0.65 7.000 130 SPK0810-562K-□□ 5600 K 40 252KHz 0.58 9.100 120 SPK0810-682K-□□ 6800 K 40 252KHz 0.55 10.000 110 SPK0810-822K-□□ 8200 K 20 252KHz 0.50 15.000 100 SPK0810-103K-□□ 10000 K 20 79.6KHz 0.42 24.000 90 SPK0810-333K-□□ 33000 K 60 79.6KHz 0.20 75.000 50 SPK0810-473K-□□ 47000 K 60 79.6KHz 0.20 80.000 40 SPK0810-104K-□□ 100000 K 20 79.6KHz 0.14 180.000 28 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 8 Unshielded DIP Power Inductors ● SPK0912 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Tole '@1KHz DCR Rated Current (Ω) (mA) Max Max SPK0912-1R0M-□□ 1.0 M 0.011 6000 SPK0912-1R5M-□□ 1.5 M 0.012 6000 SPK0912-2R2M-□□ 2.2 M 0.015 5300 SPK0912-3R3M-□□ 3.3 M 0.017 4800 SPK0912-4R7M-□□ 4.7 M 0.020 4500 SPK0912-6R8M-□□ 6.8 M 0.025 4200 SPK0912-100M -□□ 10 M 0.040 4000 SPK0912-120M -□□ 12 M 0.045 3800 SPK0912-150M -□□ 15 M 0.050 3500 SPK0912-180M -□□ 18 M 0.060 3200 SPK0912-220M -□□ 22 M 0.070 3000 SPK0912-270K -□□ 27 K 0.100 2800 SPK0912-330K-□□ 33 K 0.120 2500 SPK0912-390K-□□ 39 K 0.120 2000 SPK0912-470K-□□ 47 K 0.130 1900 SPK0912-560K-□□ 56 K 0.140 1800 SPK0912-680K-□□ 68 K 0.150 1700 SPK0912-820K-□□ 82 K 0.160 1600 SPK0912-101K-□□ 100 K 0.250 1500 SPK0912-121K-□□ 120 K 0.280 1200 SPK0912-151K-□□ 150 K 0.300 1000 SPK0912-181K-□□ 180 K 0.450 700 SPK0912-221K-□□ 220 K 0.500 600 SPK0912-271K-□□ 270 K 0.650 500 SPK0912-331K-□□ 330 K 0.850 450 SPK0912-391K-□□ 390 K 0.950 400 SPK0912-471K-□□ 470 K 1.100 350 SPK0912-561K-□□ 560 K 1.200 300 SPK0912-681K-□□ 680 K 1.300 250 SPK0912-821K-□□ 820 K 1.500 200 SPK0912-102K-□□ 1000 K 2.000 200 1500 K 2.300 180 SPK0912-152K-□□ SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 9 Unshielded DIP Power Inductors Inductance Part No L(μH) Tole '@1KHz DCR Rated Current (Ω) (mA) Max Max SPK0912-222K-□□ 2200 K 4.500 150 SPK0912-332K-□□ 3300 K 5.500 130 SPK0912-472K-□□ 4700 K 7.200 120 SPK0912-682K-□□ 6800 K 12.00 100 SPK0912-103K-□□ 10000 K 16.00 90 SPK0912-153K-□□ 15000 K 21.00 80 SPK0912-223K-□□ 22000 K 33.00 70 SPK0912-333K-□□ 33000 K 45.00 40 ● SPK1010 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Q Temperature Current Rise Current ( Ω) (mA) (mA) Min Max Max Max DCR Test (MHz) Min Freq. Tole '@1KHz Saturation SRF SPK1010-3R3M-□□ 3.3 M 10 7.96MHz 36 0.010 8800 5900 SPK1010-4R7M-□□ 4.7 M 10 7.96MHz 28 0.015 7200 4800 SPK1010-6R8M-□□ 6.8 M 10 7.96MHz 18 0.016 6700 4600 SPK1010-100M-□□ 10 M 20 2.52MHz 16 0.025 5000 3700 SPK1010-150M-□□ 15 M 20 2.52MHz 12 0.029 4200 3400 SPK1010-200M-□□ 22 M 20 2.52MHz 9.5 0.040 3400 2900 SPK1010-330M-□□ 33 M 20 2.52MHz 7.0 0.062 2800 3300 SPK1010-470M-□□ 47 M 20 2.52MHz 5.8 0.075 2300 2100 SPK1010-680M-□□ 68 M 20 2.52MHz 4.7 0.130 1900 1600 SPK1010-101K-□□ 100 K 20 796KHz 3.8 0.160 1600 1400 SPK1010-151K-□□ 150 K 20 796KHz 3.1 0.260 1300 1100 SPK1010-221K-□□ 220 K 20 796KHz 2.5 0.330 1100 1000 SPK1010-331K-□□ 330 K 20 796KHz 2.0 0.520 880 820 SPK1010-471K-□□ 470 K 10 796KHz 1.6 0.660 750 720 SPK1010-681K-□□ 680 K 10 796KHz 1.3 1.100 610 560 SPK1010-102K-□□ 1000 K 20 252KHz 1.1 1.400 510 500 SPK1010-152K-□□ 1500 K 30 252KHz 0.82 2.400 430 380 SPK1010-222K-□□ 2200 K 20 252KHz 0.76 3.200 350 330 SPK1010-332K-□□ 3300 K 30 252KHz 0.64 4.900 280 260 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 10 Unshielded DIP Power Inductors Inductance Part No L(μH) SPK1010-682K-□□ SPK1010-103K-□□ SPK1010-153K-□□ Saturation Temperature Current Rise Current (Ω) (mA) (mA) Min Max Max Max SRF DCR Test (MHz) Min Freq. Tole '@1KHz SPK1010-472K-□□ Q 4700 K 30 252KHz 0.54 7.600 240 210 6800 K 30 252KHz 0.45 9.800 200 180 10000 K 30 79.6KHz 0.38 18.000 170 140 15000 K 50 79.6KHz 0.29 24.000 130 120 Saturation Temperature Current Rise Current ● SPK1012 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Q SRF DCR Test (MHz) (Ω) (mA) (mA) Max Freq. Min Max Max Max Tole '@1KHz SPK1012-3R3M-□ 3.3 M 90 7.96MHz 59.00 0.025 5500 5500 4.7 M 100 7.96MHz 45.00 0.030 5000 5000 SPK1012-6R8M-□ 6.8 M 80 7.96MHz 34.00 0.040 4800 4800 10 M 100 2.52MHz 26.00 0.050 4200 4200 SPK1012-150M-□□ 15 M 100 2.52MHz 19.00 0.060 3800 3800 22 M 100 2.52MHz 14.00 0.080 3500 3500 SPK1012-330M-□□ 33 M 100 2.52MHz 10.00 0.100 3000 3000 47 K 90 2.52MHz 8.30 0.120 2000 2000 68 K 80 2.52MHz 6.70 0.150 1700 1700 100 K 70 796KHz 5.40 0.180 1500 1500 150 K 70 796KHz 4.30 0.250 1200 1200 220 K 40 796KHz 3.40 0.300 900 900 SPK1012-331K -□□ 330 K 40 796KHz 2.70 0.550 700 700 470 K 30 796KHz 2.30 0.650 550 550 SPK1012-681K -□□ 680 K 30 796KHz 1.90 0.850 500 500 1000 K 40 252KHz 1.60 1.400 300 300 SPK1012-152K -□□ 1500 K 30 252KHz 1.30 1.700 250 250 2200 K 50 252KHz 1.10 2.900 210 210 SPK1012-332K -□□ 3300 K 50 252KHz 0.60 3.700 200 200 4700 K 50 252KHz 0.56 5.600 190 190 6800 K 50 252KHz 0.45 9.400 180 180 10000 K 80 79.6KHz 0.35 12.000 180 170 12000 K 80 79.6KHz 0.31 13.000 160 160 15000 K 70 79.6KHz 0.28 18.000 140 140 SPK1012-183K-□□ 18000 K 80 79.6KHz 0.26 25.000 130 120 22000 K 80 79.6KHz 0.22 30.000 120 110 SPK1012-273K-□□ 27000 K 80 79.6KHz 0.20 35.000 110 100 33000 K 60 79.6KHz 0.19 40.000 100 90 39000 K 60 79.6KHz 0.17 50.000 90 80 SPK1012-4R7M-□ SPK1012-100M-□□ SPK1012-220M-□□ SPK1012-470K -□□ SPK1012-680K -□□ SPK1012-101K -□□ SPK1012-151K -□□ SPK1012-221K -□□ SPK1012-471K -□□ SPK1012-102K -□□ SPK1012-222K -□□ SPK1012-472K -□□ SPK1012-682K -□□ SPK1012-103K-□□ SPK1012-123K-□□ SPK1012-153K-□□ SPK1012-223K-□□ SPK1012-333K-□□ SPK1012-393K-□□ SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 11 Unshielded DIP Power Inductors Inductance Part No SPK1012-473K-□□ SPK1012-563K-□□ SPK1012-683K-□□ SPK1012-823K-□□ SPK1012-104K-□□ L(μH) Q Temperature Current Rise Current ( Ω) (mA) (mA) Min Max Max Max DCR Test (MHz) Max Freq. Tole '@1KHz Saturation SRF 47000 K 60 79.6KHz 0.15 50.000 80 75 56000 K 40 79.6KHz 0.13 65.000 75 70 68000 K 40 79.6KHz 0.12 70.000 70 65 82000 K 30 79.6KHz 0.10 100.000 60 55 100000 K 30 79.6KHz 0.10 135.000 55 45 ● SPK1016 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Max Max Max DCR Tole '@1KHz SPK1016-4R7M -□□ 4.7 M 0.020 8500 5800 SPK1016-5R6M -□□ 5.6 M 0.025 8500 5500 SPK1016-6R8M -□□ 6.8 M 0.025 8500 5400 SPK1016-8R2M -□□ 8.2 M 0.028 8000 5200 SPK1016-100M -□□ 10 M 0.035 7600 5000 SPK1016-120M -□□ 12 M 0.035 7500 4500 SPK1016-150M -□□ 15 M 0.040 6500 4000 SPK1016-180M -□□ 18 M 0.060 6000 4000 SPK1016-220M -□□ 22 M 0.080 5400 3800 SPK1016-330M -□□ 33 M 0.100 4400 3500 SPK1016-470K-□□ 47 K 0.120 3800 3000 SPK1016-560K-□□ 47 K 0.130 3400 2800 SPK1016-680K-□□ 68 K 0.140 3000 2500 SPK1016-101K-□□ 100 K 0.180 2500 2000 SPK1016-151K-□□ 150 K 0.220 1800 1600 SPK1016-221K-□□ 220 K 0.300 1500 1500 SPK1016-331K-□□ 330 K 0.600 1300 1300 SPK1016-471K-□□ 470 K 0.800 1000 1000 SPK1016-681K-□□ 680 K 1.000 900 900 SPK1016-102K-□□ 1000 K 1.200 700 700 SPK1016-152K-□□ 1500 K 1.500 520 520 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 12 Unshielded DIP Power Inductors Inductance Part No L(μH) Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Max Max Max DCR Tole '@1KHz SPK1016-222K-□□ 2200 K 2.200 450 450 SPK1016-332K-□□ 3300 K 3.300 350 350 SPK1016-472K-□□ 4700 K 4.700 300 300 SPK1016-682K-□□ 6800 K 6.800 250 250 SPK1016-103K-□□ 10000 K 10.00 180 180 Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Max Max Max ● SPK1018 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) DCR Tole '@1KHz SPK1018-4R7K-□□ 4.7 K 0.008 10000 6000 SPK1018-6R8K-□□ 6.8 K 0.011 8000 5000 SPK1018-100K-□□ 10 K 0.017 7000 4500 SPK1018-150K-□□ 15 K 0.022 5500 4000 SPK1018-220K-□□ 22 K 0.026 4500 3700 SPK1018-330K-□□ 33 K 0.032 3800 3300 SPK1018-470K-□□ 47 K 0.035 3200 3000 SPK1018-680K-□□ 68 K 0.047 2600 2600 SPK1018-101K-□□ 100 K 0.090 2200 2000 SPK1018-151K-□□ 150 K 0.129 1800 1600 SPK1018-221K-□□ 220 K 0.162 1500 1500 SPK1018-331K-□□ 330 K 0.212 1200 1200 SPK1018-471K-□□ 470 K 0.380 1000 1000 SPK1018-681K-□□ 680 K 0.548 840 840 SPK1018-102K-□□ 1000 K 0.844 660 660 SPK1018-152K-□□ 1500 K 1.180 550 550 SPK1018-222K-□□ 2200 K 2.000 460 440 SPK1018-332K-□□ 3300 K 2.530 380 380 SPK1018-472K-□□ 4700 K 3.190 320 320 SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 13 Unshielded DIP Power Inductors Inductance Part No SPK1018-682K-□□ SPK1018-103K-□□ SPK1018-153K-□□ SPK1018-223K-□□ SPK1018-333K-□□ SPK1018-473K-□□ SPK1018-683K-□□ SPK1018-104K-□□ L(μH) Saturation Temperature ( Ω) Current (mA) Rise Current (mA) Max Max Max DCR Tole '@1KHz 6800 K 5.690 260 250 10000 K 7.3000 220 220 15000 K 10.500 180 180 22000 K 21.800 140 130 33000 K 25.700 120 120 47000 K 36.100 100 100 68000 K 57.300 80 80 100000 K 89.700 60 60 Saturation Temperature Current Rise Current ( Ω) (mA) (mA) Max Max Max ● SPK1213 Series Electrical Characteristics (Electrical specifications at 25℃) Inductance Part No L(μH) DCR Tole '@1KHz SPK1213-100M-□□ SPK1213-150M-□□ SPK1213-220M-□□ SPK1213-330M-□□ SPK1213-470K -□□ SPK1213-680K -□□ SPK1213-101K-□□ SPK1213-151K-□□ SPK1213-221K-□□ SPK1213-331K-□□ SPK1213-471K-□□ SPK1213-681K-□□ SPK1213-102K-□□ SPK1213-152K-□□ SPK1213-222K-□□ SPK1213-332K-□□ SPK1213-472K-□□ SPK1213-682K-□□ SPK1213-103K-□□ 10 M 0.023 8000 5100 15 M 0.028 6500 4500 22 M 0.035 5500 4200 33 M 0.043 4500 3700 47 K 0.052 3600 3400 68 K 0.068 3100 3000 100 K 0.097 2600 2500 150 K 0.140 2100 2100 220 K 0.200 1700 1700 330 K 0.300 1400 1400 470 K 0.430 1100 1100 680 K 0.610 950 990 1000 K 1.000 780 780 1500 K 1.300 640 680 2200 K 2.000 530 550 3300 K 3.100 430 440 4700 K 4.400 360 370 6800 K 6.500 300 300 10000 K 10.000 240 240 ● Saturation Current: DC current at which inductance drops 10% from its value without current ● Temperature Rise Current: the actual value of DC current when the temperature rise isΔT 40℃ (Ta=25℃) ● Rated DC Current:The less value which is Isat or Irms ● Special remind:Circuit design, component, PCB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 14 Unshielded DIP Power Inductors Packaging: ◆产品包装: ● In bag pakeage PE 袋 Outside Carton 不足整箱用内盒或填充物装满 Part No. PE 胶袋每袋数量 SPK0406 1000PCS SPK0608 1000PCS SPK0707 1000PCS SPK0807 1000PCS SPK0810 500PCS SPK0912 300PCS SPK1010 200PCS SPK1012 200PCS SPK1016 200PCS SPK1018 200PCS SPK1213 200PCS SHENZHEN LANTU MICRO ELECTRIC TECHNOLOGY CO., LTD. http:www.szlantu.com.cn 15 Unshielded DIP Power Inductors Reliability Testing: ◆可靠性测试: Items Terminal Strength Reference docu ments: GB/T 2423.60-2008 端子強度(SMT) Requirements Test Methods and Remarks 1. Pulling test: Solder the inductor to the testing jig using leadfree Define: A: sectional area of terminal solder. Then apply a force in the A≦8mm2 force≧5N time:30sec 8mm2
SPK0810-330MB 价格&库存
很抱歉,暂时无法提供与“SPK0810-330MB”相匹配的价格&库存,您可以联系我们找货
