XKXED8K5LI-112YXC-32.768K 数据手册
CRYSTAL UNIT
32.768KHZ
YST310S
Applications
Features
‧RTC.
‧Dimensions: 3.20 x 1.50 x 0.75 mm.
‧High precision and high frequency stability.
‧Standard Frequency: 32.768KHz
‧Excellent heat resistance and environmental characteristics.
Specifications
32.768 KHz
7pF, 9pF,12.5pF, or specify
Standard Frequency
Load Capacitance
Frequency Tolerance (at 25 ℃)
±10ppm, ±20ppm, or specify
Parabolic Coefficient
( - 0.03 ± 0.01 ) * 10-6 / ℃2
-20~+70℃,-40~+85℃,or specify
Operating Temperature
Storage Temperature
-55~+125℃
Shunt Capacitance
1.2 pF Max.
Motional Capacitance
4.4fF
Level of Drive
1.0μWMax
Aging (at 25 ℃)
±3ppm/year Max.
Equivalent Series Resistance(ESR)
YST310S
70KΩMax.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
Marking
1.5±0.1
3.2±0.1
Top View Crystal Connection
0.75 ±0.1
Top View
Side View
1.0
1.50
1.0
1.80
1.70
Bottom View
Top View Suggested Layout
Marking: "YXC32XX" or "0XXXX"
Units: mm
www.yxcxtal.com
CRYSTAL UNIT
32.768KHZ
YST310S
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-3215
180±2.0
12.0±0.3
3.45±0.1
1.75±0.1
4.0±0.1
1.05±0.1
61.0±1.0
12.0±1.0
3000 pcs per reel
www.yxcxtal.com
XKXED8K5LI-112YXC-32.768K 价格&库存
很抱歉,暂时无法提供与“XKXED8K5LI-112YXC-32.768K”相匹配的价格&库存,您可以联系我们找货
