BZX84C5V1
BZX84C5V1
    HOTTECH(合科泰)
    SOT23-6
    齐纳/稳压二极管 5.1V 2μA SOT23-6 60Ω 900mV
BZX84C5V1 数据手册
BZX84C2V0-BZX84C75 ZENER DIODE FEATURES  Planar Die Construction  300mW Power Dissipation  Surface Mount device SOT-23 MECHANICAL DATA     Case: SOT-23 Case Material: Molded Plastic. UL flammability Classification Rating: 94V-0 Weight: 0.008 grams (approximate) MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Parameter Symbol Value Unit Maximum Forward Voltage @ IF =10mA VF 0.9 V Power Dissipation PD 350 mW Thermal Resistance From Junction To Ambient(Note1) RθJA 417 °C/W TJ,TSTG -65 ~+150 °C Junction and Storage Temperature Range Note1:Alumina = 0.4 X 0.3 X 0.024 in, 99.5% alumina © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 1/5 BZX84C2V0-BZX84C75 ZENER DIODE ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Zener Voltage Range(Note2) f = 1kHz TYPE VZ @ IZT Nom(V) Range(V) Maximum Zener Zener Zener Voltage Range(Note2) Reverse Forward Impedance(Note3) Impedance ZZT @ ZZK @ IZK VZ2 @ IZ2 IZ2 VZ3 @ IZ3 IZ3 ZZT3 @ IZT3 IR VR I F VF IZT IZK IZT (mA) Ω (mA) (V) (mA) (V) (mA) Ω (mA) (uA) (V) (mA) (V) BZX84C2V0 2.0 1.8~2.0 5 100 - - - - - - - - 120 0.5 - - BZX84C2V2 2.2 2.08~2.2 5 100 - - - - - - - - 120 0.7 - - BZX84C2V4 2.4 2.2~2.6 5 100 600 1.0 1.7~2.1 1.0 2.6~3.2 20 50 20 50 1.0 10 0.9 BZX84C2V7 2.7 2.5~2.9 5 100 600 1.0 1.9~2.4 1.0 3~3.6 20 50 20 20 1.0 10 0.9 BZX84C3V0 3.0 2.8~3.2 5 95 600 1.0 2.1~2.7 1.0 3.3~3.9 20 50 20 10 1.0 10 0.9 BZX84C3V3 3.3 3.1~3.5 5 95 600 1.0 2.3~2.9 1.0 3.6~4.2 20 40 20 5 1.0 10 0.9 BZX84C3V6 3.6 3.4~3.8 5 90 600 1.0 2.7~3.3 1.0 3.9~4.5 20 40 20 5 1.0 10 0.9 BZX84C3V9 3.9 3.7~4.1 5 90 600 1.0 2.9~3.5 1.0 4.1~4.7 20 30 20 3 1.0 10 0.9 BZX84C4V3 4.3 4.0~4.6 5 90 600 1.0 3.3~4 1.0 4.4~5.1 20 30 20 3 1.0 10 0.9 BZX84C4V7 4.7 4.4~5.0 5 80 500 1.0 3.7~4.7 1.0 4.5~5.4 20 15 20 3 2.0 10 0.9 BZX84C5V1 5.1 4.8~5.4 5 60 480 1.0 4.2~5.3 1.0 5~5.9 20 15 20 2 2.0 10 0.9 BZX84C5V6 5.6 5.2~6.0 5 40 400 1.0 4.8~6 1.0 5.2~6.3 20 10 20 1 2.0 10 0.9 BZX84C6V2 6.2 5.8~6.6 5 10 150 1.0 5.6~6.6 1.0 5.8~6.8 20 6 20 3 4.0 10 0.9 BZX84C6V8 6.8 6.4~7.2 5 15 80 1.0 6.3~7.2 1.0 6.4~7.4 20 6 20 2 4.0 10 0.9 BZX84C7V5 7.5 7.0~7.9 5 15 80 1.0 6.9~7.9 1.0 7~8 20 6 20 1 5.0 10 0.9 BZX84C8V2 8.2 7.7~8.7 5 15 80 1.0 7.6~8.7 1.0 7.7~8.8 20 6 20 0.7 5.0 10 0.9 BZX84C9V1 9.1 8.5~9.6 5 15 100 1.0 8.4~9.6 1.0 8.5~9.7 20 8 20 0.5 6.0 10 0.9 BZX84C10 10 9.4~10.6 5 20 150 1.0 9.3~10.6 1.0 9.4~10.7 20 10 20 0.2 7.0 10 0.9 BZX84C11 11 10.4~11.6 5 20 150 1.0 10.2~11.6 1.0 10.4~11.8 20 10 20 0.1 8.0 10 0.9 BZX84C12 12 11.4~12.7 5 25 150 1.0 11.2~12.7 1.0 11.4~12.9 20 10 20 0.1 8.0 10 0.9 BZX84C13 13 12.4~14.1 5 30 170 1.0 12.3~14 1.0 12.5~14.2 20 15 20 0.1 8.0 10 0.9 BZX84C15 15 13.8~15.6 5 30 200 1.0 13.7~15.5 1.0 13.9~15.7 20 20 20 0.05 10.5 10 0.9 BZX84C16 16 15.3~17.1 5 40 200 1.0 15.2~17 1.0 15.4~17.2 20 20 20 0.05 11.2 10 0.9 BZX84C18 18 16.8~19.1 5 45 225 1.0 16.7~19 1.0 16.9~19.2 20 20 20 0.05 12.6 10 0.9 BZX84C20 20 18.8~21.2 5 55 225 1.0 18.7~21.1 1.0 18.9~21.4 20 20 20 0.05 14.0 10 0.9 BZX84C22 22 20.8~23.3 5 55 250 1.0 20.7~23.2 1.0 20.9~23.4 20 25 20 0.05 15.4 10 0.9 BZX84C24 24 22.8~25.6 5 70 250 1.0 22.7~25.5 1.0 22.9~25.7 20 25 20 0.05 16.8 10 0.9 BZX84C27 27 25.1~28.9 2 80 300 0.5 25~28.9 0.1 25.2~29.3 10 45 10 0.05 18.9 10 0.9 BZX84C30 30 28~32 2 80 300 0.5 27.8~32 0.1 28.1~32.4 10 50 10 0.05 21 10 0.9 BZX84C33 33 31~35 2 80 325 0.5 30.8~35 0.1 31.1~35.4 10 55 10 0.05 23.1 10 0.9 BZX84C36 36 34~38 2 90 350 0.5 33.8~38 0.1 34.1~38.4 10 60 10 0.05 25.2 10 0.9 BZX84C39 39 37~41 2 130 350 0.5 36.7~41 0.1 37.1~41.5 10 70 10 0.05 27.3 10 0.9 BZX84C43 43 40~46 2 150 375 0.5 39.7~46 0.1 40.1~46.5 10 80 10 0.05 30.1 10 0.9 BZX84C47 47 44~50 2 170 375 0.5 43.7~50 0.1 44.1~50.5 10 90 10 0.05 32.9 10 0.9 BZX84C51 51 48~54 2 180 400 0.5 47.6~54 0.1 48.1~54.6 10 100 10 0.05 35.7 10 0.9 BZX84C56 56 52~60 2 200 425 0.5 51.5~60 0.1 52.1~60.8 10 110 10 0.05 39.2 10 0.9 BZX84C62 62 58~66 2 215 450 0.5 57.4~66 0.1 58.2~67 10 120 10 0.05 43.4 10 0.9 BZX84C68 68 64~72 2 240 475 0.5 63.4~72 0.1 64.2~73.2 10 130 10 0.05 47.6 10 0.9 BZX84C75 75 70~79 2 255 500 0.5 69.4~79 0.1 70.3~80.2 10 140 10 0.05 52.5 10 0.9 Note: (2) Tested with pulses tp = 20 ms. (3) The Zener impedance, ZZK , for the 27 through 75 volt types is tested at 0.5 mA rather than the test current of 0.1 mA used for VZ2 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 2/5 BZX84C2V0-BZX84C75 ZENER DIODE Typical Characteristics Zener Characteristics(VZ Up to 10 V) Zener Characteristics(11 V to 43 V) 100 100 PD =300mW Pulsed 1 43 39 36 33 30 27 1 0.5 1 2 3 4 5 6 7 8 9 10 0.5 10 11 15 20 VZ, ZENER VOLTAGE (V) 25 30 35 40 50 Typical Leakage Current 100 Pulsed TYPICAL Ta VALUES 35 45 VZ, ZENER VOLTAGE (V) Temperature Coefficients 40 FOR BZX84CXXX SERIES 10 30 IR, LEAKAGE CURRENT (uA) θVZ, TEMPERATURE COEFFICIENT (mV/℃) 24 20 22 10 18 10 9.1 8.2 7.5 6.2 6.8 5.1 5.6 4.7 2.4 10 PD =300mW 11 12 13 IZ, ZENER CURRENT (mA) Pulsed IZ, ZENER CURRENT (mA) Ta =25℃ 15 16 Ta =25℃ 25 20 VZ @ IZT 15 10 5 1 0.1 0.01 Ta=100℃ 1E-3 0 Ta=25℃ -5 1E-4 0 4 8 12 16 20 24 28 32 36 40 0 44 5 VZ, NOMINAL ZENER VOLTAGE (V) 10 15 20 25 35 40 45 Effect of Zener Voltage on Zener Impedance Typical Capacitance 1000 1000 Ta=25℃ Ta=25℃ f=1MHz ZZT, DYNAMIC IMPEDANCE(Ω) 100 1V BIAS BIAS AT 50% OF VZ NOM 10 IZ(AC)=0.1IZ(DC) IZ=1mA 0V BIAS C, CAPACITANCE (pF) 30 VZ, NOMINAL ZENER VOLTAGE (V) 1 f=1kHz 100 IZ=5mA 10 1 1 10 100 VZ, NOMINAL ZENER VOLTAGE (V) 1 10 100 VZ, NOMINAL ZENER VOLTAGE (V) Power Derating Curve 350 POWER DISSIPATION PD (mW) 300 250 200 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta © SHENZHEN HOTTECH ELECTRONICS CO.,LTD 125 150 (℃ ) E-mail:hkt@heketai.com 3/5 BZX84C2V0-BZX84C75 ZENER DIODE SOT-23 Package Outline Dimensions Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 0.900 1.150 0.035 0.045 A1 0.000 0.100 0.000 0.004 A2 0.900 1.050 0.035 0.041 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 e e1 0.950 TYP 1.800 L 0.037 TYP 2.000 0.071 0.550 RE F 0.079 0.022 REF L1 0.300 0.500 0.012 0.020 θ 0° 8° 0° 8° SOT-23 Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 4/5 BZX84C2V0-BZX84C75 ZENER DIODE SOT-23 Tape and Reel SOT-23 Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SOT-23 3.15 2.77 1.22 Ø1.50 1.75 3.50 4.00 4.00 2.00 8.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SOT-23 Tape Leader and Trailer SOT-23 Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 9.50 12.30 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 © SHENZHEN HOTTECH ELECTRONICS CO.,LTD E-mail:hkt@heketai.com 5/5
BZX84C5V1 价格&库存
很抱歉,暂时无法提供与“BZX84C5V1”相匹配的价格&库存,您可以联系我们找货
