RS8411XF
RS8411XF
    RUNIC(润石)
    SOT23-5
    通用放大器 1通道 1.2MHz 0.67V/μs SOT23-5
RS8411XF 数据手册
RS841X 36V, 1.2MHz Rail-to-Rail Output CMOS Operational Amplifier FEATURES • HIGH GAIN BANDWIDTH:1.2MHz • INPUT OFFSET VOLTAGE:±0.8mV (Typical) • QUIESCENT CURRENT:100uA/Amp • Rail to Rail Output • Common-Mode Input Voltage Range Include Ground • Supply Range: +3V to +36V • SPECIFIED UP TO +125°C • Micro SIZE PACKAGES: SOT23-5 APPLICATIONS DESCRIPTION The RS841X families of products offer high voltage (36V) operation and rail-to-rail output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (1.2MHz) and slew rate of 0.67V/us. The op-amps are unity gain stable and feature an ultralow input bias current. The devices are stable at capacitance up to 300pF.The input can operate normally within 100mV below of the negative power rail to 2V below of the positive power rail. The RS841X families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single power supplies of 3V to 36V or dual power supplies of ±1.5V to ±18V. • SENSORS • PHOTODIODE AMPLIFICATION PART NUMBER • ACTIVE FILTERS RS8411 • TEST EQUIPMENT • DRIVING A/D CONVERTERS REV A.1 Device Information (1) PACKAGE BODY SIZE(NOM) SOT23-5 2.90mm x 1.60mm SOIC-8 4.90mm x 3.90mm RS8412 MSOP-8 3.00mm 3.00mm SOIC-14 8.65mm x 3.90mm RS8414 TSSOP-14 5.00mm x 4.40mm (1) For all available packages, see the orderable addendum at the end of the data sheet. 1 / 14 www.run-ic.com RS841X Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. Version A.1 Change Date 2020.12 Change Item Initial version completed 2 / 15 www.run-ic.com RS841X Pin Configuration and Functions (Top View) RS8411 1 V- 2 +IN 3 5 V+ +IN 1 V- 2 -IN 3 5 V+ 4 OUT + OUT RS8411B + - 4 -IN SOT23-5 - SOT23-5 Pin Description NAME PIN RS8411B 1 I/O +IN RS8411 3 V- 2 2 - -IN OUT V+ 4 1 5 3 4 5 I O - I DESCRIPTION Positive (noninverting) input Negative (lowest) power supply or ground (for single supply operation) Negative (inverting) input Output Positive (highest) power supply 3 / 15 www.run-ic.com RS841X Pin Configuration and Functions (Top View) RS8412 OUT A 1 -IN A 2 +IN A 3 V- 4 + A B+ 8 V+ 7 OUTB 6 -IN B 5 +IN B SOIC-8(SOP8)/MSOP8 Pin Description -INA +INA -INB +INB OUTA OUTB PIN SOIC-8(SOP8)/MSOP-8 2 3 6 5 1 7 V- 4 - V+ 8 - NAME I/O DESCRIPTION I I I I O O Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Output, channel A Output, channel B Negative (lowest) power supply or ground (for single supply operation) Positive (highest) power supply 4 / 15 www.run-ic.com RS841X Pin Configuration and Functions (Top View) RS8414 OUT A 1 14 OUT D -IN A 2 13 -IN D +IN A 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C -IN B 6 9 -IN C OUT B 7 8 OUT C A - + D + - - + B + C SOIC-14(SOP14),TSSOP-14 Pin Description -INA +INA -INB +INB -INC +INC -IND +IND OUTA OUTB OUTC OUTD PIN SOIC-14(SOP14)/TSSOP-14 2 3 6 5 9 10 13 12 1 7 8 14 V- 11 - V+ 4 - NAME I/O DESCRIPTION I I I I I I I I O O O O Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Inverting input, channel C Noninverting input, channel C Inverting input, channel D Noninverting input, channel D Output, channel A Output, channel B Output, channel C Output, channel D Negative (lowest) power supply or ground (for single supply operation) Positive (highest) power supply 5 / 15 www.run-ic.com RS841X SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN MAX -0.7 36 (V-)-0.2 (V+) +0.2 (V-)-0.2 (V+) +0.2 -10 10 -100 100 Continuous -40 125 150 -55 150 Supply, Vs=(V+) - (V-) Signal input pin (2) Signal output pin (3) Signal input pin (2) Signal output pin (3) Output short-circuit (4) Operating range, TA Junction, TJ Storage, Tstg Voltage Current Temperature UNIT V mA mA °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be currentlimited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.5V beyond the supply rails should be currentlimited to ±100mA or less. (4) Short-circuit to ground, one amplifier per package. ESD Ratings VALUE V(ESD) (1) Electrostatic discharge Human-body model (HBM) ±5000 Machine Model (MM) ±200 UNIT V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) MIN Supply voltage Vs= (V+) - (V- Single-supply Dual-supply NOM MAX 3 36 ±1.5 ±18 UNIT V Thermal Information THERMAL METRIC (1) RS8411 5PINS RS8412 8PINS SOT23-5 SOIC-8 MSOP-8 RS8414 14PINS TSSOPSOIC-14 14 UNIT RϴJA Junction-to-ambient thermal resistance 273.8 124.7 165 83.8 120.8 °C/W RϴJC(top) Junction-to-case(top) thermal resistance 126.8 66.9 53 70.7 34.3 °C/W RϴJB ѰJT ѰJB Junction-to-board thermal resistance 85.9 67.9 87 59.5 62.8 °C/W Junction-to-top characterization parameter Junction-to-board characterization parameter 10.9 84.9 19.2 67.2 4.9 85 11.6 37.7 10.5 56.5 °C/W °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A N/A N/A N/A °C/W 6 / 15 www.run-ic.com RS841X PACKAGE/ORDERING INFORMATION Orderable Device Package Type Pin Channel Op Temp(°C) Device Marking (1) Package Qty RS8411XF SOT23-5 5 1 -40℃~125℃ 8411 Tape and Reel,3000 RS8411BXF SOT23-5 5 1 -40℃~125℃ 8411B Tape and Reel,3000 RS8412XK SOIC-8(SOP8) 8 2 -40℃~125℃ RS8412 Tape and Reel,4000 RS8412XM MSOP-8 8 2 -40℃~125℃ RS8412 Tape and Reel,4000 RS8414XP SOIC-14(SOP14) 14 4 -40℃~125℃ RS8414 Tape and Reel,4000 RS8414XQ TSSOP-14 14 4 -40℃~125℃ RS8414 Tape and Reel,4000 NOTE: (1) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the environmental category on the device. 7 / 15 www.run-ic.com RS841X ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=3V to 36V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS TJ RS841X MIN TYP MAX 100 150 36 200 300 UNITS POWER SUPPLY Vs Operating Voltage Range 25C 3 Quiescent Current/Amplifier Vs=±2.5V, Io=0mA Vs=±18V, Io=0mA 25C Power-Supply Rejection Ratio Vs=5V to 36V 25C 98 120 Vos Input Offset Voltage VCM= VS/2 25C -40C to 125C -4 ±0.8 ±1.1 Vos Tc Input Offset Voltage Average Drift IQ PSRR V uA dB INPUT IB Input Bias Current VCM=0V IOS Input Offset Current VCM=0V VCM Common-Mode Voltage Range Vs= ±18V Common-Mode Rejection Ratio Vs= ±2.5V, VCM=(V-)-0.1V to (V+)-2V Vs= ±18V, VCM=(V-)-0.1V to (V+)-2V CMRR -40C to 125C 3 25C -40C to 125C 25C -40C to 125C 10 600 10 600 25C (V-)-0.1 25C 70 25C 70 92 4 mV uV/C 60 60 (V+)-2 pA pA V 110 dB OUTPUT AOL VOH VOL ISC CLOAD Open-Loop Voltage Gain RL=10KΩ, Vo=(V-)-0.6V to (V+)-0.6V 25C Output Swing Vs=±18V, RL=10KΩ 25C Short-circuit current Capacitive load drive VS=36V, Vo=0V 25C 25C 70 100 V V mA pF G=+1, CL=100pF 25C 25C 0.67 1.2 V/us MHz 25C 5 us 25C 25C 5 10 us us 25C 16 uVpp 25C TBD nV/√Hz 115 dB 17.85 -17.85 FREQUENCY RESPONSE SR GBW Slew Rate Gain-Bandwidth Product ts Setting Time,0.01% tOR tON Overload Recovery Time Turn On Time VS=±2.5V, G=+1, CL=100pF, Step=2V VIN·Gain≥VS,G=11 NOISE En Input Voltage Noise en Input Voltage Noise Density f = 0.1Hz to 10Hz, Vs=±2.5V f = 1KHz 8 / 15 www.run-ic.com RS841X TYPICAL CHARACTERISTICS At TA = +25C, Vs=±18V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. 120 Gain Phase 90 Phase Margin (°) Open-Loop Gain(dB) 100 SUPPLY VOLTAGE vs QUIESCENT CURRENT 400 110 80 70 60 50 40 30 20 10 0 -20 10 100 1K 10K 100K 1M Quiescent Current(uA) OPEN-LOOP GAIN AND PHASE vs FREQUENCY RS8412 350 300 250 200 150 100 -10 10M 0 Frequency(Hz) 12 16 20 24 28 32 36 LARGE SIGNAL STEP RESPONSE Input Output 2V/div 2V/div 8 Supply Voltage(V) LARGE SIGNAL STEP RESPONSE Input Output VS=±18V G=+1 CL=0PF VS=±18V G=+1 CL=100PF 100us/div 100us/div SMALL SIGNAL STEP RESPONSE SMALL SIGNAL STEP RESPONSE Input Output Input Output 50mV/div 50mV/div 4 VS=±18V G=+1 CL=0PF VS=±18V G=+1 CL=100PF 100us/div 100us/div | 9 / 15 www.run-ic.com RS841X TYPICAL CHARACTERISTICS At TA = +25C, Vs=±18V, RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. 20 2V/div VOUT 0V 5us/div 5us/div Output Voltage Swing vs Output Current 0.1Hz TO 10Hz NOISE AT Vs=5V 15 VOH VOL 10 5 2uV/div Output Voltage(V) VIN 10V/div VOUT Input Output VS=±18V G=11 2V/div 0V VIN NEGATIVE OVERVOLTAGE RECOVERY 10V/div POSITIVE OVERVOLTAGE RECOVERY Input VS=±18V Output G=11 0 -5 -10 -15 -20 0 10 20 30 40 50 60 1s/div 70 Output Current(mA) 10 / 15 www.run-ic.com RS841X PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 11 / 15 www.run-ic.com RS841X MSOP-8 b e E E1 4.8 1.02 D 0.65 0.41 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.250 0.380 0.010 0.015 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.650(BSC) 0.026(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 12 / 15 www.run-ic.com RS841X TSSOP-14 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 13 / 15 1° 7° www.run-ic.com RS841X SOIC-8(SOP8) b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 14 / 15 www.run-ic.com RS841X SOIC-14(SOP14) e b 5.2 1.27 E E1 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 A c θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 15 / 15 www.run-ic.com
RS8411XF 价格&库存
很抱歉,暂时无法提供与“RS8411XF”相匹配的价格&库存,您可以联系我们找货
