S2M
S2M
    YFW(佑风微)
    SMB(DO-214AA)
    整流二极管 IR=5μA If=2A VF=1.1V CJ=25pF SMB
S2M 数据手册
S2A THRU S2M SMB Surface Mount General Purpose Silicon Rectifiers Pinning Reverse Voltage - 50 to 1000 V 1.Cathode Forward Current - 2 A 2.Anode         1 FEATURES  For surface mounted applications  Low profile package  Glass Passivated Chip Junction  Ideal for automated placement   2     DO-214AA/SMB Marking Code  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: DO-214AA/SMB  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 0.093g / 0.003oz Maximum Ratings and Electrical characteristics S2A S2A S2B S2B S2D S2D S2G S2G S2J S2J S2K S2K S2M S2M Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S2A S2B S2D S2G S2J S2K S2M Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Tc = 125 °C IF(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load IFSM 60 A Maximum Instantaneous Forward Voltage at 2 A VF 1.1 V IR 5 50 μA Cj 25 pF RθJA/ RθJC 60/20 °C/W Tj, Tstg -55 ~ +150 °C Parameter Maximum DC Reverse Current Ta = 25 °C at Rated DC Blocking Voltage Ta=125 °C Typical Junction Capacitance(1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 G uangDong YFW Electronics Co, Ltd. S2A THRU S2M SMB Fig.2 Typical Instaneous Reverse Characteristics Instaneous Reverse Current ( μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =150°C T J =125°C 10 T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 600 800 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 10 Junction Capacitance ( pF) Instaneous Forward Current (A) 400 200 Instaneous Reverse Voltage (V) Case Temperature (°C) 1.0 100 T J =25°C 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.yfwdiode.com 2/3 G uangDong YFW Electronics Co, Ltd. S2A THRU S2M SMB DO-214AA SMB Package Outline Plastic surface mounted package; 2 leads L A A1 C A b D E E1 UNIT mm mil VM A A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 E1 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 160 130 The recommended mounting pad size 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) Summary of Packing Options Package DO-214AA SMB www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 3/3 G uangDong YFW Electronics Co, Ltd.
很抱歉,暂时无法提供与“S2M”相匹配的价格&库存,您可以联系我们找货
