LM331BXF
LM331BXF
    RUNIC(润石)
    SOT23-5
    比较器 Vs=3V~32V Vos=10mV SOT23-5
LM331BXF 数据手册
LM331 General-Purpose High-Voltage Open-Drain Output Single Comparator 1 FEATURES • Supply Range: +3V to +32V • Low Supply Current 65μA (TYP) per channel at VS = 5V • Low Output Saturation Voltage • Open-Drain Output for Maximum Flexibility • SPECIFIED UP TO +125°C • Micro SIZE PACKAGES: SOT23-5 2 APPLICATIONS • Hysteresis Comparators • Factory Automation & Control • Industrial Equipment • Test and Measurement • Cordless Power Tool • Vacuum Robot • Wireless Infrastructure 3 DESCRIPTIONS The LM331 is the single comparator version, and the outputs can be connected to other open-collector outputs to achieve wired-AND relationships. It can operate from 3V to 32V, and have low power consuming 65uA (TYP) per channel. The LM331 consist one voltage comparators that are designed to operate from a single power supply over a wide range of voltages. Quiescent current is independent of the supply voltage. The device is the most cost-effective solutions for applications where low offset voltage, high supply voltage capability, low supply current, and space saving are the primary specifications in circuit design for portable consumer products. The LM331 is available in Green SOT23-5 packages. It operates over an ambient temperature range of -40°C to +125°C. Device Information (1) PART NUMBER LM331 (1) REV A.2 PACKAGE BODY SIZE (NOM) SOT23-5 2.90mm×1.60mm For all available packages, see the orderable addendum at the end of the data sheet. 1 / 14 www.run-ic.com LM331 Table of Contents 1 FEATURES .......................................................................................................................................................1 2 APPLICATIONS ................................................................................................................................................1 3 DESCRIPTIONS ................................................................................................................................................1 4 Revision History ..............................................................................................................................................3 5 PACKAGE/ORDERING INFORMATION (1) ......................................................................................................4 6 Pin Configuration and Functions (Top View) ...............................................................................................5 7 SPECIFICATIONS ............................................................................................................................................6 7.1 Absolute Maximum Ratings ........................................................................................................................6 7.2 ESD Ratings................................................................................................................................................6 7.3 Recommended Operating Conditions .........................................................................................................6 7.4 Thermal Information: LM331 .......................................................................................................................7 7.5 ELECTRICAL CHARACTERISTICS ...........................................................................................................8 7.6 TYPICAL CHARACTERISTICS ..................................................................................................................9 8 Detailed Description ..................................................................................................................................... 10 8.1 Overview .................................................................................................................................................. 10 9 Application and Implementation ................................................................................................................. 11 9.1 Application Information ............................................................................................................................ 11 9.2 Typical Application ................................................................................................................................... 11 9.3 Detailed Design Procedure ...................................................................................................................... 11 9.4 Input Voltage Range ................................................................................................................................ 11 10 PACKAGE OUTLINE DIMENSIONS ........................................................................................................... 12 11 TAPE AND REEL INFORMATION .............................................................................................................. 13 2 / 14 www.run-ic.com LM331 4 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date A.0 2020/02/11 A.1 2022/02/23 A.2 2022/07/15 Change Item Pre version completed 1.Modify ELECTRICAL CHARACTERISTICS and TYPICAL CHARACTERISTICS 2.Add TAPE AND REEL INFORMATION Change Supply Range: +3V to +32V 3 / 14 www.run-ic.com LM331 5 PACKAGE/ORDERING INFORMATION (1) Orderable Device LM331BXF LM331CXF -40°C ~+125°C Device Marking (2) 331B Tape and Reel,3000 -40°C ~+125°C 331C Tape and Reel,3000 Package Type Pin Channel Op Temp(°C) SOT23-5 5 1 SOT23-5 5 1 Package Qty NOTE: (1) This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the right-hand navigation. (2) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the environmental category on the device. 4 / 14 www.run-ic.com LM331 6 Pin Configuration and Functions (Top View) LM331C LM331B V- 2 -IN 3 5 V+ -IN 1 - V- 2 4 OUT +IN 3 SOT23-5 5 V+ 4 OUT - + 1 + +IN SOT23-5 Pin Description PIN SOT23-5 I/O (1) NAME (1) DESCRIPTION LM331B LM331C +IN 1 3 I Noninverting input V- 2 2 P Negative (lowest) power supply -IN 3 1 I Inverting input OUT 4 4 O Output V+ 5 5 P Positive (highest) power supply I=Input, O=Output, P=Power 5 / 14 www.run-ic.com LM331 7 SPECIFICATIONS 7.1 Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN MAX Supply, VS=(V+) - (V-) Voltage Input pin (IN+, IN-) 36 (2) Signal output pin (3) (V-)-0.3 (V+) +0.3 (V-)-0.3 (V+) +0.3 -10 10 mA 55 mA Signal input pin (IN+, IN-) (2) Current Signal output pin (3) -55 Output short-circuit (4) Junction, TJ V Continuous Operating range, TA Temperature UNIT (5) Storage, Tstg -40 125 -40 150 -65 150 °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.3V beyond the supply rails should be current-limited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.3V beyond the supply rails should be current-limited to ±55mA or less. (4) Short-circuit from output to VS can cause excessive heating and eventual destruction. (5) The maximum power dissipation is a function of TJ(MAX), RθJA, and TA. The maximum allowable power dissipation at any ambient temperature is PD = (T J(MAX) - TA) / RθJA. All numbers apply for packages soldered directly onto a PCB. 7.2 ESD Ratings The following ESD information is provided for handling of ESD-sensitive devices in an ESD protected area only. VALUE V(ESD) Electrostatic discharge Human-Body Model (HBM), per ANSI/ESDA/JEDEC JS001, all pins (1) Charged Device Model (CDM), per JEDEC specification JESD22-C101, all pins (2) UNIT ±2000 V ±1000 (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. 7.3 Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) MIN Supply voltage,VS= (V+) - (V-) Single-supply Dual-supply 6 / 14 NOM MAX 3 32 ±1.5 ±16 UNIT V www.run-ic.com LM331 7.4 Thermal Information: LM331 LM331 THERMAL METRIC (1) 5PINS UNIT SOT23-5 RϴJA Junction-to-ambient thermal resistance 273.8 °C/W RϴJC(top) Junction-to-case(top) thermal resistance 126.8 °C/W RϴJB Junction-to-board thermal resistance 85.9 °C/W ѰJT Junction-to-top characterization parameter 10.9 °C/W ѰJB Junction-to-board characterization parameter 84.9 °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A °C/W (1) Thermal resistance varies with operating conditions. 7 / 14 www.run-ic.com LM331 7.5 ELECTRICAL CHARACTERISTICS (At TA = +25ºC, VCM=(VS/2), VS=5V, unless otherwise noted.) LM331 PARAMETER CONDITIONS UINTS MIN VS Operating Voltage Range IQ Quiescent Current VOS Input offset voltage IB Input Bias Current 3 VS=5V, no load VS=32V, no load, TA=-40C to +125C VS=5V to 32V VS=5V to 32V TA=-40C to +125C TA=25C 65 -7.5 ±5 -10 VCM Common-Mode Voltage Range 10 AVD Large signal differential voltage amplification VOL Low-Level output voltage IOL Output Current(sinking) TA=-40C to +125C High-Level Output Leakage Current VS=3V to 32V VS=3V to 32V TA=-40C to +125C VS=15V, Vo=1.4V to 11.4V RL≥15k to (V+) Isink≤4mA, VID=-1V VO=1.5V; VID=-1V; VS=5V (V+) =Vo=5V; VID=1V (V+) =Vo=32V; VID=1V uA 7.5 10 10 pA 100 nA 50 pA 100 nA (V+)-1.5 (V-)+0.5 (V+)-2.0 200 300 mV 50 (V-)+0.5 50 V 100 100 TA=25C Input Offset Current MAX 32 TA=-40C to +125C IOS ILEAK TYP V V/mV 360 15 mV mA 2 20 nA 4 50 nA Switching Characteristics VS=5V TPHL Propagation Delay H To L VS=32V VS=5V TPLH Propagation Delay L To H VS=32V RPU=5.1KΩ, Overdrive =10mV RPU=5.1KΩ, Overdrive =100mV RPU=5.1KΩ, Overdrive =10mV RPU=5.1KΩ, Overdrive =100mV RPU=5.1KΩ, Overdrive =10mV RPU=5.1KΩ, Overdrive =100mV RPU=5.1KΩ, Overdrive =10mV RPU=5.1KΩ, Overdrive =100mV 8 / 14 0.5 0.3 0.64 0.5 us 1.5 0.3 1.5 0.25 www.run-ic.com LM331 7.6 TYPICAL CHARACTERISTICS Input Bias Current(pA) Total Supply Current(uA) NOTE: The graphs and tables provided following this note are a statistical summary based on a limited number of samples and are provided for informational purposes only. At TA = +25C, VS=5V, RPULLUP=5.1K VCM = Vs/2, CL=15pF, VOVERDRIVE=100mV, unless otherwise noted. 100K 90 No Load,Output High 80 10K 70 60 50 40 30 20 -40°C 25°C 125°C 10 0 2 5 8 10 1 0.1 -40 -20 Supply Voltage(V) 0 20 40 60 80 100 120 140 Temperature(℃) Figure 2. INPUT BIAS CURRENT vs TEMPERATURE 0.6 3.5 VS=5V VS=5V 3 0.5 2.5 Time(us) 0.4 Time(us) 100 11 14 17 20 23 26 29 32 Figure 1. Total Supply Current vs Supply Voltage 0.3 0.2 2 1.5 1 0.1 0.5 0 0 0 0 50 100 150 200 250 300 350 400 Overdrive(mV) Figure 3. Response Time vs Input Overdrives Negative Transition 50 100 150 200 250 300 350 400 Overdrive(mV) Figure 4. Response Time vs Input Overdrives Positive Transition 3.5 0.8 VS=32V 0.7 VS=32V 3 0.6 2.5 0.5 Time(us) Time(us) 1K 0.4 0.3 2 1.5 1 0.2 0.5 0.1 0 0 0 0 50 100 150 200 250 300 350 400 Overdrive(mV) Figure 5. Response Time vs Input Overdrives Negative Transition 50 100 150 200 250 300 350 400 Overdrive(mV) Figure 6. Response Time vs Input Overdrives Positive Transition 9 / 14 www.run-ic.com LM331 8 Detailed Description 8.1 Overview The LM331 family of comparators can operate up to 32V on the supply pin. This standard device has proven ubiquity and versatility across a wide range of applications. This is due to its low power and high speed. The open-drain output allows the user to configure the output's logic low voltage (VOL) and can be utilized to enable the comparator to be used in AND functionality. V+ IN+ IN- + OUT VFigure 7. Functional Block Diagram 10 / 14 www.run-ic.com LM331 9 Application and Implementation Information in the following applications sections is not part of the RUNIC component specification, and RUNIC does not warrant its accuracy or completeness. RUNIC’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. 9.1 Application Information LM331 is typically used to compare a single signal to a reference or two signals against each other. Many users take advantage of the open drain output (logic high with pull-up) to drive the comparison logic output to a logic voltage level to an MCU or logic device. The wide supply range and high voltage capability makes this comparator optimal for level shifting to a higher or lower voltage. 9.2 Typical Application VLOGIC VLOGIC VSUP VIN + VSUP RPULLUP VIN+ LM331 Vref RPULLUP + LM331 CL VIN- CL Figure 8. Single-Ended and Differential Comparator Configurations 9.3 Detailed Design Procedure When using the device in a general comparator application, determine the following: • Input Voltage Range • Minimum Overdrive Voltage • Output and Drive Current • Response Time 9.4 Input Voltage Range When choosing the input voltage range, the input common mode voltage range (VICR) must be taken in to account. If temperature operation is below 25°C the VICR can range from 0 V to V S– 2.0 V. This limits the input voltage range to as high as VS– 2.0 V and as low as 0 V. Operation outside of this range can yield incorrect comparisons. 11 / 14 www.run-ic.com LM331 10 PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° NOTE: A. All linear dimension is in millimeters. B. This drawing is subject to change without notice. C. Body dimensions do not include mold flash or protrusion. Mold flash and protrusion shall not exceed 0.15 per side. D. BSC: Basic Dimension. Theoretically exact value shown without tolerances. 12 / 14 www.run-ic.com LM331 11 TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSION Reel Diameter Reel Width(W1) DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL Package Type Reel Diameter SOT23-5 7’’ Reel Width (mm) 9.5 A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) W (mm) Pin1 Quadrant 3.20 3.20 1.40 4.0 4.0 2.0 8.0 Q3 NOTE: 1. All dimensions are nominal. 2. Plastic or metal protrusions of 0.15mm maximum per side are not included. 13 / 14 www.run-ic.com LM331 IMPORTANT NOTICE AND DISCLAIMER Jiangsu RUNIC Technology Co., Ltd. will accurately and reliably provide technical and reliability data (including data sheets), design resources (including reference designs), application or other design advice, WEB tools, safety information and other resources, without warranty of any defect, and will not make any express or implied warranty, including but not limited to the warranty of merchantability Implied warranty that it is suitable for a specific purpose or does not infringe the intellectual property rights of any third party. These resources are intended for skilled developers designing with RUNIC products You will be solely responsible for: (1) Selecting the appropriate products for your application; (2) Designing, validating and testing your application; (3) Ensuring your application meets applicable standards and any other safety, security or other requirements; (4) RUNIC and the RUNIC logo are registered trademarks of RUNIC INCORPORATED. All trademarks are the property of their respective owners; (5) For change details, review the revision history included in any revised document. The resources are subject to change without notice. Our company will not be liable for the use of this product and the infringement of patents or third-party intellectual property rights due to its use. 14 / 14 www.run-ic.com
LM331BXF 价格&库存
很抱歉,暂时无法提供与“LM331BXF”相匹配的价格&库存,您可以联系我们找货
