H2 Series
●Low ESR, high ripple current, high voltage
Load life of 2000 hours at 105℃
RoHS Compliant
◆ 规格表 Specifications
项目Items
特性参数Characteristics
使用温度范围
Category
Temperture Range
额定工作电压范围
Rated Voltage Range
静电容量允许偏差
Capacitance tolerance
漏电流
Leakage Current
损耗角正切值tanδ
Dissipation Factor
温度特性
Low Temperture
Characteristics
(Max.Impedance Ratio)
耐久性
Endurence
耐湿负荷特性
Damp Heat
(Steady State)
浪涌电压特性
(Surge Voltage)
-55 ~ +105℃
35 ~ 100V
±20%(M)
(at 20℃,120Hz)
施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃)
I≤0.1CV 或299μA(取大值)
Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20℃
Rated voltage (V)
35~100
(at 20℃,120Hz)
tanδ (Max.)
0.12
Z(-25℃)/Z(+20℃)
≦1.25
Z(-55℃)/Z(+20℃)
≦1.25
(100KHz)
105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of rated
voltage for 2000 hours at 105℃.
Appearance
No significant damage
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦150% of the specified value
ESR
Leakage current
≦The specified value
在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated
voltage for 1000 hours at 60℃,90%~ 95% RH.
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
浪涌电压=额定电压× 1.15(V)
Surge Voltage=Rated voltage × 1.15(V)
在105℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求
The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃
for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
◆ 外形图Dimensions (mm)
ΦD
P
Φd
α
-1-
5
2.0
0.5
6.3
2.5
0.6
8
3.5
0.6
10
5.0
0.6
(L﹤16)1.0
(16≦L﹤22)1.5
(L≧22)2.0
H2 Series
◆ 纹波电流补正系数 Rated Ripple Current Coefficient
10kHz ≦ f
﹤ 100kHz
100kHz≦ f ﹤ 500kHz
0.30
0.70
1.00
Case size
ΦD×L(mm)
ESR(mΩ)
at 20℃,100 KHz
Leakage Current
(μA)
Rated ripple current
(mArms/105℃/100kHz)
Catalog Part Number
10
5*8
120
299
1100
8100LEM0508H2RR00O
22
6.3*8
100
299
1350
8220LEMAA08H2RR00O
33
5*8
120
299
1100
8330LEM0508H2RR00O
39
6.3*8
90
299
1350
8390LEMAA08H2RR00O
39
8*9
60
299
1800
8390LEM0809H2RR00O
47
5*7
80
299
1350
8470LEM0507H2RR00O
47
6.3*8
60
299
1800
8470LEMAA08H2RR00O
56
6.3*8
80
299
1350
8560LEMAA08H2RR00O
56
8*9
60
299
1800
8560LEM0809H2RR00O
68
6.3*8
70
299
1500
8680LEMAA08H2RR00O
68
8*9
50
299
2000
8680LEM0809H2RR00O
82
6.3*11
60
299
1800
8820LEMAA11H2RR00O
82
8*9
40
299
2000
8820LEM0809H2RR00O
100
5*11
45
350
1800
8101LEM0511H2RR00O
100
6.3*8
40
350
2000
8101LEMAA08H2RR00O
150
6.3*12
35
525
2500
8151LEMAA12H2RR00O
220
8*9
35
770
2350
8221LEM0809H2RR00O
220
8*12
35
770
2500
8221LEM0812H2RR00O
220
10*12.5
30
770
2750
8221LEM10ABH2RR00O
330
10*12.5
30
1155
2900
8331LEM10ABH2RR00O
470
10*13
30
1645
2900
8471LEM1013H2RR00O
10
5*8
120
299
550
8100LFM0508H2RR00O
15
6.3*8
100
299
800
8150LFMAA08H2RR00O
22
6.3*8
100
299
850
8220LFMAA08H2RR00O
33
8*9
50
299
1300
8330LFM0809H2RR00O
33
8*12
40
299
1500
8330LFM0812H2RR00O
39
8*9
50
299
1300
8390LFM0809H2RR00O
39
8*12
40
299
1500
8390LFM0812H2RR00O
47
8*12
40
299
1500
8470LFM0812H2RR00O
56
8*12
40
299
1500
8560LFM0812H2RR00O
82
10*12.5
35
410
2100
8820LFM10ABH2RR00O
100
10*12.5
35
500
2100
8101LFM10ABH2RR00O
220
10*12.5
35
1100
2500
8221LFM10ABH2RR00O
频率Frequency(Hz)
系数 Coefficient
120Hz ≦ f ﹤1kHz 1kHz≦ f ﹤ 10kHz
0.05
◆ 尺寸与个技术参数一览表 Standard Ratings
Cap(uF)
W Rated
Rated voltage
capacitance
(V)
(uF)
35
50
-2常规插件的固态电容是不适用于回流焊的 ,需需过回流焊工艺的即需要贴片的固态 .
H2 Series
Cap(uF)
Rated voltage W
Rated capacitance
(V)
(uF)
63
80
100
Case size
ΦD×L(mm)
ESR(mΩ)
Leakage Current
(μA)
at 20℃,100 KHz
(mArms/105℃/100kHz)
Catalog Part Number
10
5*8
120
299
500
8100LGM0508H2RR00O
15
6.3*8
100
299
750
8150LGMAA08H2RR00O
22
6.3*8
100
299
750
8220LGMAA08H2RR00O
33
8*9
55
299
1100
8330LGM0809H2RR00O
39
8*9
55
299
1100
8390LGM0809H2RR00O
47
8*12
45
299
1300
8470LGM0812H2RR00O
56
8*12
45
353
1300
8560LGM0812H2RR00O
82
10*12.5
38
517
1800
8820LGM10ABH2RR00O
100
10*12.5
38
630
1800
8101LGM10ABH2RR00O
10
6.3*8
120
299
550
8100LHMAA08H2RR00O
15
6.3*8
120
299
550
8150LHMAA08H2RR00O
22
8*9
80
299
1100
8220LHM0809H2RR00O
22
8*12
60
299
1300
8220LHM0812H2RR00O
33
10*12.5
45
299
1700
8330LHM10ABH2RR00O
39
10*12.5
45
312
1700
8390LHM10ABH2RR00O
47
10*12.5
45
376
1800
8470LHM10ABH2RR00O
56
10*12.5
45
448
1800
8560LHM10ABH2RR00O
10
8*9
90
299
850
8100MAM0809H2RR00O
15
8*12
70
299
1190
8150MAM0812H2RR00O
22
10*12.5
60
299
1550
8220MAM10ABH2RR00O
33
10*12.5
60
330
1550
8330MAM10ABH2RR00O
-3-
很抱歉,暂时无法提供与“8471LEM1013H2RR00O”相匹配的价格&库存,您可以联系我们找货
