VRH3301NTX
VRH3301NTX
    ANASEM(安纳森)
    VRH3301NTX
VRH3301NTX 数据手册
AnaSem 安纳森 Analog Semiconductor IC VRH Series High speed, Low dropout, ±1% High output accuracy CMOS Voltage Regulator with On/Off circuit (IMPORTANT: Please check the last page for Genuine Product Labeling) Website: Tel: Email: Rev. E13-01 www.anasemi.com +852-3590-8442 sales@anasemi.com AnaSem .......... Future of the analog world Rev. E13-01 Products Data Sheet AnaSem Analog Semiconductor IC High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series GENERAL DESCRIPTIONS The VRH series are positive voltage regulators with high speed, low voltage dropout and high accuracy output achieved by low current consumption. The output voltage is guaranteed within ±1% within the given temperature range by Vref controlling the temperature characteristic. It corresponds to the low ESR capacitor as an output stabilization capacitor. The charged ESR capacitor can be discharged with an internal switch by making the EN=VSS, as a result the VOUT quickly returns to the VSS level. To make the current capacity of the output transistor not exceeded, the over-current protection circuit is built in. HALOGEN RoHS COMPLIANCE FEATURES Output voltage range ······································································· 0.9V~5.0V (selectable with a step of 0.05V) Operating voltage range ·································································· 1.6V~6.0V High accuracy output voltage ··························································· ±1% (VOUT=1.95V ~ 5.0V) / ±20mV (VOUT=0.9V ~ 1.9V) Maximum output current ·································································· 250mA Dropout voltage ················································································ Typ. 90mV (output=3.0V, IOUT=100mA) Low current consumption ·································································· Typ. 25µA High ripple rejection ························································································· Typ. 75dB at 1KHz Low ESR capacitor ························································································· 1.0 µF ceramic capacitor Operating temperature range ·································································· –40°C ~ +85°C Built-in over-current protector ···························································································· Limit current : 300mA CL high-speed auto-discharge Built-in On/Off circuit Small package ························································································· SOT-25 (2.9×2.8×1.1mm), LLP-4 (1.2×1.6×0.6mm), SDFN-4 (1.0×1.0×0.4mm), APPLICATIONS Battery powered devices Cellular phone Digital / Video cameras Portable games Handheld instruments AnaSem 1 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 PRODUCTS NUMBERING GUIDE VRH Discharge function X : Auto discharge Package form T : SOT-25 L : LLP-4 V : SDFN-4 Function specification L : VOUT=0.9V~1.9V N : VOUT=1.95V~5.0V Accuracy rate 1 : ±1% 2 : ±20mV Output voltage 090 ~ 500 : Selectable with a step of 0.05V in the range of 0.9V ~ 5.0V e.g.) 090 : 0.90V, 285 : 2.85V PIN CONFIGURATION / MARKING SPECIFICATION (SOT-25) Pin Configuration Vout NC 5 4 A B C D E F F F F 1 2 3 Vin Vss EN (Top view) No. Symbol Descriptions 1 VIN Voltage input 2 VSS Power ground 3 EN Chip enable 4 NC Non connection (open) 5 VOUT Output Marking Specification Code Mark A H BCD 090~500 E X F Internal rule Contents Products series name Output voltage Discharge function Lot number AnaSem 2 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 PIN CONFIGURATION / MARKING SPECIFICATION (LLP-4) Vin EN 4 3 Pin Configuration No. Symbol 1 VOUT 2 VSS Power ground 3 EN Chip enable F F F 4 VIN Voltage input 1 2 5 VSS Power ground Vout Vss A B 5 Vss C D E Descriptions Output Marking Specification (Top view) Code Mark Contents A H Products series name B X Discharge function CDE 090~500 F Internal rule Output voltage Lot number PIN CONFIGURATION / MARKING SPECIFICATION (SDFN-4) Vin EN 4 3 A B C D Pin Configuration 5 Vss 2 1 No. Symbol Descriptions 1 VOUT 2 VSS Power ground 3 EN Chip enable 4 VIN Voltage input 5 VSS Power ground Output (Top view) Marking Specification Code Mark AB 09~50 CD Internal rule Contents Output voltage Lot number AnaSem 3 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 BLOCK DIAGRAM VIN VOUT Over-current Protector + Voltage Reference _ Vss EN ABSOLUTE MAXIMUM RATINGS Items Input voltage range Output current Output voltage range Symbol VIN IOUT VOUT PD PD PD TOPR TSTG SOT-25 LLP-4 SDFN-4 Operating temperature range Storage temperature range Power dissipation ※1) Ratings –0.3 ~ +7.0 500 VSS –0.3 ~ VIN +0.3 600 1000 550 –40 ~ +85 –55 ~ +125 Unit V mA V mW mW mW °C °C Note : ※1) Power dissipation depends on conditions of mounting on boards. PCB dimension is 50mm×50mm×1.6mm. TYPICAL APPLICATION CIRCUITS EN VOUT CL = 1µF VSS VIN CIN = 1µF AnaSem 4 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 ELECTRICAL CHARACTERISTICS (Ta=25°C unless otherwise specified) Items Symbol Conditions VOUT+1.0V≦VIN≦6.0V Output voltage VOUT Dropout voltage IOUT VDROP Typ. Max. Unit VOUT ×0.99 VOUT VOUT ×1.01 V IOUT=30mA Test circuit 1 Ta=–40°C ~ +85°C Output current VOUT≧1.95V Min. VOUT≦1.90V –20 - +20 mV 1.2V≦VOUT≦1.65V - 250 - mA 1.7V≦VOUT≦2.25V - 250 - mA 2.3V≦VOUT≦2.85V - 250 - mA VIN≧VOUT+1.0V 1 2.9V≦VOUT≦3.45V - 250 - mA 3.5V≦VOUT≦4.05V - 250 - mA 4.0V≦VOUT≦5.00V - 250 - mA 1.2V≦VOUT≦1.65V - 210 340 mV 1.7V≦VOUT≦2.25V - 130 205 mV 2.3V≦VOUT≦2.85V - 100 150 mV IOUT=100mA 1 2.9V≦VOUT≦3.45V - 90 137 mV 3.5V≦VOUT≦4.05V - 85 125 mV 4.1V≦VOUT≦5.00V - 80 115 mV AnaSem 5 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 ELECTRICAL CHARACTERISTICS (continued) (Ta=25°C unless otherwise specified) Items Symbol Conditions Min. Typ. Max. Unit Test circuit Current consumption IDD VIN=VOUT+1.0V, VOUT=Open, IOUT=0mA - 25 40 µA 2 Standby current ISTB EN=VSS - 0.01 0.1 µA 2 Input voltage VIN 1.6 - 6.0 V 1 - 10 40 mV 1 - 0.01 0.1 %/V 1 - 75 - dB 3 300 - - mA 1 - 40 - mA 1 ppm /°C 1 Load regulation Line regulation Ripple rejection Limit current Short circuit current Output voltage temperature coefficient ∆VOUT VIN=VOUT+1.0V, IOUT=0.1mA ~ 100mA ∆VOUT / VOUT+1.0V≦VIN≦6.0V, IOUT=30mA ∆VIN•VOUT Rr ILIMIT ISHORT VIN=VOUT+1.0V, f=1KHz, ∆VRIP=0.5VP-P, IOUT=30mA EN=VIN VIN=VOUT+1.0V, VOUT=0V ∆VOUT / VEN=VIN, IOUT=300mA ∆Ta•VOUT Ta=–40°C ~ +85°C ±20 EN high level voltage VENH 1.2 - 6.0 V 4 EN low level voltage VENL - - 0.3 V 4 EN high level current IENH VEN= VIN=5V 0.25 - 5.0 µA 4 EN low level current IENL VEN= VSS –0.1 - 0.1 µA 4 CL auto-discharge resistance RDIS VIN=6.0V, VOUT=4.0V, VEN= VSS - 160 - Ω 1 AnaSem 6 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TEST CIRCUITS Circuit (1) - Output voltage, Output current, Dropout voltage, Input voltage, Load regulation, Line regulation, Limit current, Short circuit current, Output voltage temperature coefficient, CL auto-discharge resistance VOUT EN VSS A CL CIN VIN VIN V IOUT Circuit (2) - Current consumption, Standby current A VIN VIN VOUT EN VSS VIN VOUT EN VSS CL CIN Circuit (3) - Ripple rejection CL V V IOUT Circuit (4) - EN high level voltage, EN low level voltage, EN high level current, EN low level current VIN CIN A VIN VOUT EN VSS CL AnaSem 7 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 DESCRIPTION OF OPERATION General operation In reference to following block diagram of the VRH series ; *1) VIN VOUT Over-current Protector R1 RDIS VFEEDBACK + Voltage VREF Reference VSS R2 _ Error Amp. 4MΩ EN By the error amplifier, the reference voltage (VREF) is compared with VFEEDBACK which is divided by feedback resistors R1 and R2. It supplies the output transistor (see note *1) to keep a stabilized output voltage against with any fluctuation of input voltage by negative feedback system. Note *1) The VRH series has P-channel MOSFET which is connected to the VOUT terminal as the output transistor. To prevent the VRH series from being damaged due to inverse current from VOUT terminal to VIN terminal through a parasitic diode, VOUT should not be exceeded VIN+0.3V. EN terminal (shutdown function) & CL auto-discharge The VRH series can be shutdown through EN terminal. The P-channel MOSFET is turned off and operation of all internal circuits stops to reduce the current consumption when the signal of EN terminal is set to the shutdown level. In shutdown mode, the VRH series enables the electric charge at the CL to be discharged via the auto-discharge resistance (RDIS ; 160Ω), and the VOUT terminal can be rapidly returned to the VSS level as a result. Output capacitor (CL) For phase compensation, an output capacitor (CL) is required to connected between VOUT terminal and VSS terminal as close as possible. A ceramic capacitor with capacitance value of at least 1.0µF is recommended. Of course, the suitable capacitance value should be different by the condition of each application. In addition, an input capacitor (CIN) with capacitance value of at least 1.0µF is also recommended between VIN terminal and VSS terminal for stable input power. Over current protection and short circuit protection Built-in over current protection circuit performs circuit protection from over current as a current limiter. When the load current reaches the limit level, the output voltage drops and output current also decreases accordingly. A current of typ. 40mA will flow when output terminal is shorted. AnaSem 8 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Output Current VRH1202xxx (VOUT=1.2V) VRH1202xxx (VOUT=1.2V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF EN=VIN, Ta=25°C, CIN=CL=1.0µF 1.6 VIN=2.2V VIN=1.6V VIN=6.0V Output Voltage : VOUT (V) Output Voltage : VOUT (V) 1.6 1.2 0.8 0.4 0 1.2 0.8 0.4 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 100 200 300 400 500 0 100 Output Current : IOUT (mA) VRH1802xxx (VOUT=1.8V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 400 500 VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 2.4 VIN=2.8V VIN=1.9V VIN=6.0V Output Voltage : VOUT (V) Output Voltage : VOUT (V) 300 VRH1802xxx (VOUT=1.8V) 2.4 1.8 1.2 0.6 0 1.8 1.2 0.6 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 100 200 300 400 500 0 100 Output Current : IOUT (mA) 200 300 400 500 Output Current : IOUT (mA) VRH2801xxx (VOUT=2.8V) VRH2801xxx (VOUT=2.8V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.0 3.0 2.5 2.5 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 200 Output Current : IOUT (mA) 2.0 1.5 1.0 VIN=3.8V VIN=2.9V VIN=6.0V 0.5 0 2.0 1.5 1.0 Ta=+25°C Ta=–40°C Ta=+85°C 0.5 0 0 100 200 300 400 500 0 Output Current : IOUT (mA) 100 200 300 400 500 Output Current : IOUT (mA) AnaSem 9 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Output Current (continued) VRH3001xxx (VOUT=3.0V) VRH3001xxx (VOUT=3.0V) VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 3.5 3.0 3.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.5 2.5 2.0 1.5 1.0 VIN=4.0V VIN=3.1V VIN=6.0V 0.5 0 2.5 2.0 1.5 1.0 Ta=+25°C Ta=–40°C Ta=+85°C 0.5 0 0 100 200 300 400 500 0 100 Output Current : IOUT (mA) VRH3301xxx (VOUT=3.3V) 400 500 VIN=EN=VOUT+1.0V, CIN=CL=1.0µF 4.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 300 VRH3301xxx (VOUT=3.3V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 4.0 200 Output Current : IOUT (mA) 3.0 2.0 1.0 VIN=4.3V VIN=3.4V VIN=6.0V 0 3.0 2.0 1.0 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 100 200 300 400 500 0 Output Current : IOUT (mA) 100 200 300 400 500 Output Current : IOUT (mA) AnaSem 10 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Input Voltage VRH1202xxx (VOUT=1.2V) VRH1202xxx (VOUT=1.2V) EN=VIN, Ta=25°C, CIN=CL=1.0µF EN=VIN, Ta=25°C, CIN=CL=1.0µF 1.4 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 1.4 1.3 1.2 1.1 1.0 1mA 30mA 100mA 0.9 0.8 0.5 1.0 1.5 2.0 1.3 1.2 1.1 1.0 0.8 2.5 2.5 1mA 30mA 100mA 0.9 3.0 3.5 Input Voltage : VIN (V) VRH1802xxx (VOUT=1.8V) 1.9 1.9 1.8 1.7 1.6 1mA 30mA 100mA 1.5 2.0 2.5 1.6 1mA 30mA 100mA 1.5 4.5 6.0 EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) 5.5 VRH2801xxx (VOUT=2.8V) 2.9 2.8 2.7 2.6 1mA 30mA 100mA 2.5 3.0 5.0 Input Voltage : VIN (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 2.5 6.0 1.7 1.4 4.0 3.0 VRH2801xxx (VOUT=2.8V) 2.4 2.0 5.5 1.8 Input Voltage : VIN (V) 3.0 5.0 EN=VIN, Ta=25°C, CIN=CL=1.0µF 2.0 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 1.5 4.5 VRH1802xxx (VOUT=1.8V) 2.0 1.4 1.0 4.0 Input Voltage : VIN (V) 3.5 4.0 2.9 2.8 2.7 2.6 1mA 30mA 100mA 2.5 2.4 4.0 Input Voltage : VIN (V) 4.5 5.0 5.5 6.0 Input Voltage : VIN (V) AnaSem 11 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Input Voltage (continued) VRH3001xxx (VOUT=3.0V) VRH3001xxx (VOUT=3.0V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.2 3.1 3.1 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.2 3.0 2.9 2.8 2.7 1mA 30mA 100mA 2.6 2.5 2.0 2.5 3.0 3.5 3.0 2.9 2.8 2.7 2.5 4.0 4.0 1mA 30mA 100mA 2.6 4.5 Input Voltage : VIN (V) VRH3301xxx (VOUT=3.3V) 3.3 3.3 3.2 3.1 3.0 1mA 30mA 100mA 2.9 3.0 6.0 EN=VIN, Ta=25°C, CIN=CL=1.0µF 3.4 Output Voltage : VOUT (V) Output Voltage : VOUT (V) EN=VIN, Ta=25°C, CIN=CL=1.0µF 2.5 5.5 VRH3301xxx (VOUT=3.3V) 3.4 2.8 2.0 5.0 Input Voltage : VIN (V) 3.5 4.0 4.5 3.2 3.1 3.0 1mA 30mA 100mA 2.9 2.8 3.5 Input Voltage : VIN (V) 4.0 4.5 5.0 5.5 6.0 Input Voltage : VIN (V) AnaSem 12 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Dropout Voltage vs. Output Current VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) EN=VIN, CIN=CL=1.0µF 0.40 0.70 0.35 Dropout Voltage : VDROP (V) Dropout Voltage : VDROP (V) EN=VIN, CIN=CL=1.0µF 0.80 0.60 0.50 Required minimum operation condition 0.40 0.30 0.20 Ta=+25°C Ta=–40°C Ta=+85°C 0.10 0 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 0 0 50 100 150 200 250 0 50 Output Current : IOUT (mA) VRH2801xxx (VOUT=2.8V) 200 250 0.35 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 EN=VIN, CIN=CL=1.0µF 0.40 Dropout Voltage : VDROP (V) Dropout Voltage : VDROP (V) 150 VRH3001xxx (VOUT=3.0V) EN=VIN, CIN=CL=1.0µF 0.40 100 Output Current : IOUT (mA) 0.00 0.35 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 0.00 0 50 100 150 200 250 0 Output Current : IOUT (mA) 50 100 150 200 250 Output Current : IOUT (mA) VRH3301xxx (VOUT=3.3V) EN=VIN, CIN=CL=1.0µF Dropout Voltage : VDROP (V) 0.40 0.35 0.30 0.25 0.20 0.15 0.10 Ta=+25°C Ta=–40°C Ta=+85°C 0.05 0.00 0 50 100 150 200 250 Output Current : IOUT (mA) AnaSem 13 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Output Voltage vs. Ambient Temperature VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 1.30 1.25 1.20 1.15 1.10 -50 -25 0 25 50 75 Ambient Temperature : Ta (°C) 100 Output Voltage : VOUT (V) VRH2801xxx (VOUT=2.8V) 2.90 2.85 2.80 2.75 -25 0 25 VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 1.90 1.85 1.80 1.75 1.70 -50 -25 0 25 50 75 Ambient Temperature : Ta (°C) 100 VRH3001xxx (VOUT=3.0V) VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 2.70 -50 Output Voltage : VOUT (V) VRH1802xxx (VOUT=1.8V) 50 75 100 Output Voltage : VOUT (V) Output Voltage : VOUT (V) VRH1202xxx (VOUT=1.2V) VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 3.10 3.05 3.00 2.95 2.90 -50 -25 Ambient Temperature : Ta (°C) 0 25 50 75 100 Ambient Temperature : Ta (°C) VRH3301xxx (VOUT=3.3V) Output Voltage : VOUT (V) VIN=EN=VOUT+1.0V, IOUT=30mA, CIN=CL=1.0µF 3.40 3.35 3.30 3.25 3.20 -50 -25 0 25 50 75 100 Ambient Temperature : Ta (°C) CL-Discharge Resistance : RDIS (Ω) TYPICAL CHARACTERISTICS – CL-Discharge Resistance vs. Ambient Temperature 300 VIN=6.0V, EN=VSS, VOUT=4.0V CIN=CL=1.0µF 250 200 150 100 50 0 -50 -25 0 25 50 75 100 Ambient Temperature : Ta (°C) AnaSem 14 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Supply Current vs. Input Voltage VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) EN=VIN, CIN=CL=1.0µF 60 50 50 Supply Current : IDD (µA) Supply Current : IDD (µA) EN=VIN, CIN=CL=1.0µF 60 40 30 20 10 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 1 2 3 4 5 40 30 20 10 Ta=+25°C Ta=–40°C Ta=+85°C 0 6 0 1 Input Voltage : VIN (V) VRH2801xxx (VOUT=2.8V) 60 50 50 Supply Current : IDD (µA) Supply Current : IDD (µA) EN=VIN, CIN=CL=1.0µF 40 30 20 Ta=+25°C Ta=–40°C Ta=+85°C 10 2 3 4 5 6 4 5 EN=VIN, CIN=CL=1.0µF 40 30 20 Ta=+25°C Ta=–40°C Ta=+85°C 10 0 0 1 3 VRH3001xxx (VOUT=3.0V) 60 0 2 Input Voltage : VIN (V) 6 0 Input Voltage : VIN (V) 1 2 3 4 5 6 Input Voltage : VIN (V) VRH3301xxx (VOUT=3.3V) EN=VIN, CIN=CL=1.0µF Supply Current : IDD (µA) 60 50 40 30 20 10 Ta=+25°C Ta=–40°C Ta=+85°C 0 0 1 2 3 4 5 6 Input Voltage : VIN (V) AnaSem 15 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Load Transient Response VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 300 200 Output Current 100 1.0 0.9 0 1.8 1.6 1.5 100 1.4 50 VRH3001xxx (VOUT=3.0V) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 2.5 100 2.4 50 2.3 0 Output Voltage : VOUT (V) 150 Output Current 3.1 Output Current : IOUT (mA) Output Voltage : VOUT (V) 250 200 2.6 0 Time (40µs/div) 300 2.7 150 Output Current VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 2.8 200 1.3 VRH2801xxx (VOUT=2.8V) Output Voltage 250 1.7 Time (40µs/div) 2.9 300 Output Voltage 3.0 300 Output Voltage 2.9 250 200 2.8 150 Output Current 2.7 100 2.6 50 2.5 Output Current : IOUT (mA) 1.1 Output Voltage : VOUT (V) Output Voltage 1.2 1.9 Output Current : IOUT (mA) Output Voltage : VOUT (V) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 400 Output Current : IOUT (mA) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 1.3 0 Time (40µs/div) Time (40µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN=VOUT+1.0V Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 3.3 300 Output Voltage 3.2 250 200 3.1 150 Output Current 3.0 100 2.9 50 2.8 Output Current : IOUT (mA) Output Voltage : VOUT (V) 3.4 0 Time (40µs/div) AnaSem 16 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (IOUT=1mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 4 1.30 1 1.25 Output Voltage 0 1.20 -1 1.15 -2 1.10 2.00 Input Voltage 3 1.90 2 1.85 Output Voltage 1 1.80 0 1.75 -1 1.70 Time (20µs/div) Time (20µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage 4 2.95 2.85 Output Voltage 2 2.80 1 2.75 0 3.20 Input Voltage 2.90 3 6 2.70 Input Voltage : VIN (V) Input Voltage : VIN (V) 5 3.00 Output Voltage : VOUT (V) 6 1.95 5 3.15 4 3.10 3 3.05 Output Voltage 2 3.00 1 2.95 0 Output Voltage : VOUT (V) 2 1.35 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 3 VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 1.40 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 2.90 Time (20µs/div) Time (20µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 3.50 Input Voltage 3.45 4 3.40 3 3.35 2 Output Voltage 1 3.30 3.25 0 Output Voltage : VOUT (V) 6 3.20 Time (20µs/div) AnaSem 17 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (IOUT=30mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 4 1.30 1 1.25 Output Voltage 0 1.20 -1 1.15 -2 1.10 2.00 Input Voltage 3 1.90 2 1.85 Output Voltage 1 1.80 0 1.75 -1 1.70 Time (20µs/div) Time (20µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage 4 2.95 2.85 Output Voltage 2 2.80 1 2.75 0 3.20 Input Voltage 2.90 3 6 2.70 Input Voltage : VIN (V) Input Voltage : VIN (V) 5 VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 3.00 Output Voltage : VOUT (V) 6 1.95 5 3.15 4 3.10 3 3.05 2 Output Voltage 1 2.95 0 Time (20µs/div) 3.00 Output Voltage : VOUT (V) 2 1.35 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 3 VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 1.40 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 2.90 Time (20µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 3.50 Input Voltage 3.45 4 3.40 3 3.35 2 Output Voltage 1 3.30 3.25 0 Output Voltage : VOUT (V) 6 3.20 Time (20µs/div) AnaSem 18 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Transient Response (IOUT=100mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 1.30 1 1.25 Output Voltage 0 1.20 -1 1.15 -2 1.10 2.00 Input Voltage 3 1.90 2 1.85 Output Voltage 1 1.80 0 1.75 -1 1.70 Time (20µs/div) Time (20µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage 4 2.95 2.90 3 2.85 Output Voltage 2 2.80 1 2.75 0 3.20 Input Voltage Input Voltage : VIN (V) Input Voltage : VIN (V) 5 6 3.00 Output Voltage : VOUT (V) 6 1.95 5 3.15 4 3.10 3 3.05 2 Output Voltage 1 2.95 0 2.70 3.00 Output Voltage : VOUT (V) 2 1.35 Input Voltage : VIN (V) Input Voltage 5 Output Voltage : VOUT (V) Input Voltage : VIN (V) 3 1.40 Output Voltage : VOUT (V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF 4 2.90 Time (20µs/div) Time (20µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=Tf=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 3.50 Input Voltage 3.45 4 3.40 3 3.35 2 Output Voltage 1 3.30 3.25 0 Output Voltage : VOUT (V) 6 3.20 Time (20µs/div) AnaSem 19 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (IOUT=1mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 3.0 2 2.5 1 2.0 Output Voltage 1.5 -1 1.0 -2 0.5 -3 2 5 1 4 3 0 Output Voltage -1 -2 0 0 -3 Time (25µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 7 4 7 3 6 2 5 3 6 2 5 1 4 Output Voltage 8 Input Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 Output Voltage : VOUT (V) 5 0 2 1 Time (25µs/div) 4 6 1 4 Output Voltage 0 3 -1 2 -2 1 -3 Time (25µs/div) Output Voltage : VOUT (V) 0 7 Input Voltage 3 Input Voltage : VIN (V) Input Voltage 4 Output Voltage : VOUT (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 4 0 Time (25µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 10 Input Voltage : VIN (V) 5 Input Voltage 9 4 8 3 7 2 6 5 1 0 Output Voltage 4 -1 3 -2 2 -3 1 -4 Output Voltage : VOUT (V) 6 0 Time (25µs/div) AnaSem 20 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (IOUT=30mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) VIN=EN, Tr=5µs, Ta=25°C, CIN= CL=1.0µF 3.0 2 2.5 1 2.0 Output Voltage 1.5 -1 1.0 -2 0.5 -3 3 2 5 1 4 3 0 Output Voltage -1 -2 0 0 -3 Time (25µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 7 4 7 3 6 2 5 3 6 2 5 1 4 Output Voltage 8 Input Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 Output Voltage : VOUT (V) 5 0 2 1 Time (25µs/div) 4 6 1 4 Output Voltage 0 3 -1 2 -2 1 -3 Time (25µs/div) Output Voltage : VOUT (V) 0 7 Input Voltage Output Voltage : VOUT (V) Input Voltage 4 Input Voltage : VIN (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) 4 0 Time (25µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 10 Input Voltage : VIN (V) 5 Input Voltage 9 4 8 3 7 2 6 5 1 0 Output Voltage 4 -1 3 -2 2 -3 1 -4 Output Voltage : VOUT (V) 6 0 Time (25µs/div) AnaSem 21 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Input Rise Time (IOUT=100mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.0 2 2.5 1 2.0 Output Voltage 1.5 -1 1.0 -2 0.5 -3 3 2 5 1 4 3 0 Output Voltage -1 -2 0 0 -3 Time (25µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF Input Voltage : VIN (V) 5 7 4 7 3 6 2 5 3 6 2 5 1 4 Output Voltage 8 Input Voltage 3 -1 2 -2 1 -3 0 Input Voltage : VIN (V) Input Voltage VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 Output Voltage : VOUT (V) 5 0 2 1 Time (25µs/div) 4 6 1 4 Output Voltage 0 3 -1 2 -2 1 -3 Time (25µs/div) Output Voltage : VOUT (V) 0 7 Input Voltage Output Voltage : VOUT (V) Input Voltage 4 Input Voltage : VIN (V) 3 Input Voltage : VIN (V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 3.5 Output Voltage : VOUT (V) 4 0 Time (25µs/div) VRH3301xxx (VOUT=3.3V) VIN=EN, Tr=5µs, Ta=25°C, CIN=CL=1.0µF 10 Input Voltage : VIN (V) 5 Input Voltage 9 4 8 3 7 2 6 1 5 0 Output Voltage 4 -1 3 -2 2 -3 1 -4 Output Voltage : VOUT (V) 6 0 Time (25µs/div) AnaSem 22 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (IOUT=1mA) VRH1802xxx (VOUT=1.8V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 5 6 2 5 1 4 0 3 -1 2 Output Voltage -2 1 -3 Output Voltage : VOUT (V) 4 5 1 4 0 -1 2 1 0 Time (40µs/div) VRH3001xxx (VOUT=3.0V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 5 7 4 7 3 6 2 5 3 6 2 5 1 4 Output Voltage 8 EN Input Voltage 3 -1 2 -2 1 -3 0 EN Input Voltage : VEN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 5 EN Input Voltage : VEN (V) 3 Output Voltage -3 VRH2801xxx (VOUT=2.8V) 0 6 2 Time (40µs/div) 4 7 EN Input Voltage 3 -2 0 8 1 Output Voltage 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) EN Input Voltage : VEN (V) EN Input Voltage EN Input Voltage : VEN (V) 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VRH1202xxx (VOUT=1.2V) 0 Time (40µs/div) VRH3301xxx (VOUT=3.3V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 9 5 EN Input Voltage 8 4 7 3 6 5 2 Output Voltage 1 4 0 3 -1 2 -2 1 -3 Output Voltage : VOUT (V) EN Input Voltage : VEN (V) 6 0 Time (40µs/div) AnaSem 23 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (IOUT=30mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 5 6 2 5 1 4 0 3 -1 2 Output Voltage -2 1 -3 Output Voltage : VOUT (V) 4 5 1 4 0 3 Output Voltage -1 2 1 -3 0 Time (40µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 5 7 4 7 3 6 2 5 3 6 2 5 1 4 Output Voltage 8 EN Input Voltage 3 -1 2 -2 1 -3 0 EN Input Voltage : VEN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 5 EN Input Voltage : VEN (V) 6 2 -2 0 0 7 EN Input Voltage 3 Time (40µs/div) 4 8 1 Output Voltage 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) EN Input Voltage : VEN (V) EN Input Voltage EN Input Voltage : VEN (V) 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) VRH3301xxx (VOUT=3.3V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 9 5 EN Input Voltage 8 4 7 3 6 5 2 1 Output Voltage 4 0 3 -1 2 -2 1 -3 Output Voltage : VOUT (V) EN Input Voltage : VEN (V) 6 0 Time (40µs/div) AnaSem 24 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – EN Rise Time (IOUT=100mA) VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) 5 6 2 5 1 4 0 3 -1 2 Output Voltage -2 1 -3 Output Voltage : VOUT (V) 4 6 2 5 1 4 0 3 Output Voltage -1 -2 2 1 -3 0 0 Time (40µs/div) VRH2801xxx (VOUT=2.8V) VRH3001xxx (VOUT=3.0V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 8 5 7 4 7 3 6 2 5 3 6 2 5 1 8 EN Input Voltage 4 Output Voltage 0 3 -1 2 -2 1 -3 0 EN Input Voltage : VEN (V) EN Input Voltage VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) 5 EN Input Voltage : VEN (V) 7 EN Input Voltage 3 Time (40µs/div) 4 8 1 Output Voltage 4 0 3 -1 2 -2 1 -3 Time (40µs/div) Output Voltage : VOUT (V) EN Input Voltage : VEN (V) EN Input Voltage EN Input Voltage : VEN (V) 3 VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) VRH3301xxx (VOUT=3.3V) EN Input Voltage : VEN (V) 6 5 EN Input Voltage 9 8 4 7 3 6 5 2 Output Voltage 1 4 0 3 -1 2 -2 1 -3 Output Voltage : VOUT (V) VIN=VOUT+1.0V Tr=5µs, Ta=25°C, CIN=CL=1.0µF 0 Time (40µs/div) AnaSem 25 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TYPICAL CHARACTERISTICS – Ripple Rejection Rate VRH1202xxx (VOUT=1.2V) VRH1802xxx (VOUT=1.8V) VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 100 Ripple Rejection Rate : RR (dB) Ripple Rejection Rate : RR (dB) 100 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 10 100 Ripple Frequency : f (KHz) 80 70 60 50 40 30 20 10 0 0.01 1000 VRH2801xxx (VOUT=2.8V) 90 0.1 VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 100 Ripple Rejection Rate : RR (dB) 100 Ripple Rejection Rate : RR (dB) 1000 VRH3001xxx (VOUT=3.0V) VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF 90 80 70 60 50 40 30 20 10 0 0.01 1 10 100 Ripple Frequency : f (KHz) 0.1 1 10 100 1000 90 80 70 60 50 40 30 20 10 0 0.01 Ripple Frequency : f (KHz) 0.1 1 10 100 1000 Ripple Frequency : f (KHz) VRH3301xxx (VOUT=3.3V) VIN=EN=(VOUT+1.0)Vdc+0.5Vp-pac IOUT=30mA, Ta=25°C, CIN=CL=1.0µF Ripple Rejection Rate : RR (dB) 100 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 10 100 Ripple Frequency : f (KHz) 1000 AnaSem 26 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 PACKAGE DIMENSIONS (SOT-25) (Unit : mm) +0.10 0.65 –0.15 a 0.45 1.6±0.15 2.8±0.2 a Min 0.1 1.1~1.3 2.9±0.2 (Marked Side) 0~0.1 a a 0.95 +0.10 0.65 –0.15 3~7° a 0.95 1.9±0.2 +0.10 0.16 –0.15 a = 0.32 +0.10 –0.15 Flat length = 0.2 min. 2.9±0.2 1.0 0.7 1.0 0.7 2.4 0~0.1 1.1±1.3 Recommended land pattern 1.0 0.7 0.95 0.95 1.9 AnaSem 27 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (SOT-25) (Unit : mm) Mark 1.4±0.1 3.5±0.05 3.4±0.1 Mark 2.0±0.05 4.0±0.1 8.0±0.2 ø1.5 +0.1 –0 0.3±0.03 1.75±0.1 4.0±0.1 3.18±0.1 1.75 Max. Taping direction REEL DIMENSIONS (SOT-25) (Unit : mm) 120° ø60±1 2.0±0.5 (3,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 28 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 PACKAGE DIMENSIONS (LLP-4) 0.9±0.05 (0.3) (Marked Side) (0.075) 0.2±0.05 0.7±0.05 (0.3) 1.2±0.05 1.6±0.05 0.2±0.05 (Unit : mm) 4*0.3±0.05 Recommended land pattern 0.15±0.05 1.0 0.35 0.35 0.4 2.0 0.7 0.4 Max. 0.6 (Typ. 0.55) 0.6±0.05 0.3 0.3 0.6 AnaSem 29 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (LLP-4) (Unit : mm) ø0.5±0.1 3.5±0.05 1.8±0.05 Mark Mark 0.75±0.05 2.0±0.05 4.0±0.1 8.0±0.2 ø1.5 +0.1 –0 0.25±0.05 1.75±0.1 4.0±0.1 1.4±0.05 Taping direction REEL DIMENSIONS (LLP-4) (Unit : mm) 120° ø60±1 2.0±0.5 (3,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 30 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 PACKAGE DIMENSIONS (SDFN-4) (Unit : mm) 0.22±0.05 1.0±0.05 0.48±0.05 (Marked Side) 3 4 2 1 0.25±0.05 1.0±0.05 0.48±0.05 (C0.12) 0.4 Max. 0.65 Recommended land pattern 0.65 0.48 0.48 0.4 0.22 1.3 45° 0.22 AnaSem 31 www.anasemi.com sales@anasemi.com .......... Future of the analog world High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 TAPING AND LOADING SPECIFICATIONS (SDFN-4) (Unit : mm) 1.1 3.5±0.05 2.0±0.05 8.0±0.3 ø1.5 +0.1 –0 0.2±0.1 1.75±0.1 4.0±0.1 1.2 Max. ø0.5±0.1 2.0±0.1 1.1 Taping direction REEL DIMENSIONS (SDFN-4) (Unit : mm) 120° ø60±1 2.0±0.5 (10,000 pcs / reel) ø178±2 ø13±0.5 90° 9.0±0.5 AnaSem 32 www.anasemi.com sales@anasemi.com .......... Future of the analog world AnaSem AnaSem may change the products described in this data sheet, or may discontinue production or services without any notice in order to supply the best products through improve the design and performance. Customers are recommended to obtain the latest data or information before placing orders in order to make sure the data or information required is the newest. It is necessary for customers to fully understand the products described in this data sheet and to use it in accordance with its specifications. The products described in this data sheet are not intended to use for the apparatus which have influence on human lives due to the failure or malfunction of the products. AnaSem Corp. is not responsible for any support to customer’s application, product design, software performance, patent infringement or service. AnaSem Corp. does not disclose or imply a guarantee or description about being licensed based on patents, copy-rights, circuit location license, or other intellectual properties associated with the devices or combinations in which the products or service of AnaSem Corp. are used or can be used, or which cover the methods. Customers should not export, directly or indirectly, any products without obtaining required licenses and approvals in advance from appropriate government agencies. AnaSem www.anasemi.com sales@anasemi.com High speed, Low dropout, ±1% High output accuracy with On/Off circuit CMOS Voltage Regulator VRH Series Rev. E13-01 GENUINE PRODUCT LEGITIMATE LABEL DEFINITION Green colored Circle “RoHS” Label Other specific customized Labels Ordinary Product Information Bar Code Our internal Outgoing Check Code 3 Our Internal QR Check Code 2 AnaSem Logo and Brand Name (Black color Logo) Our Internal Product Check Code 1 Genuine labels MUST include our correct contact information as shown 2 .......... Future of the AnaSem analog world www.anasemi.com sales@anasemi.com
VRH3301NTX 价格&库存
很抱歉,暂时无法提供与“VRH3301NTX”相匹配的价格&库存,您可以联系我们找货
