SIG2012-ITSP16-RL
SIG2012-ITSP16-RL
    SIGNALMICRO(信格勒)
    TSSOP16
    模数转换器(ADC) TSSOP16 3ppm 10SPS 20bit 2.7V~5.25V -40℃~+105℃
SIG2012-ITSP16-RL 数据手册
SIG2012 SIG2012: 10SPS, 20-bit Sigma-Delta ADC with PGA FEATURES DESCRIPTION PGA Gain: 128 or 256 Data Rates: 10SPS RMS Noise: 44nV at 10SPS Offset Drift: 10nV/°C Gain Drift: 2ppm/°C Internal or External Clock Parity Check Power Supply AVDD: 2.7V to 5.25V DVDD: 2.7V to 5.25V Current: 0.8mA Package: 16-lead TSSOP The SIG2012 is a low noise, low drift, and high-resolution 20-bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA) that offers high-accuracy measurement solutions for bridge sensors. The device contains a low noise PGA with gains selected from 128 or 256, a delta-sigma (Δ-Σ) modulator, and a SINC4 digital filter. The output data rate from the device is fixed to 10SPS. SPI-compatible interface is used for device configuration and parity check is provided for data integrity. The on-chip oscillator or an external clock can be used as the clock source to the device. The SIG2012 is available in 16-lead TSSOP package and is fully specified over the -40°C to +125°C temperature range. APPLICATIONS Weigh Scales Strain Gauges Pressure Sensors Industrial Process Control Function Block Diagram AVDD TSSOP-16 DVDD REFP REFN BUF Gain=128 or 256 AINP AINN PGA ΔΣ ADC Digital Filter Serial Interface Internal Oscillator AVSS GAIN Sept. 2019 DVDD 1 16 DOUT/DRDYn DGND 2 15 SCLK CLKIN 3 14 DIN NC 4 13 CSn NC 5 12 AVDD NC 6 11 AVSS AINP 7 10 REFP AINN 8 9 REFN DOUT/DRDYn SCLK CLKIN DGND Signal Micro Incorporated http://www.signal-micro.cn SIG2012 TSSOP-16 SIG2012 PIN CONFIGURATION and DESCRIPTIONS TOP VIEW (Not To Scale) PIN DVDD 1 16 DOUT/DRDYn DGND 2 15 SCLK CLKIN 3 14 DIN NC 4 13 CSn NC 5 12 AVDD NC 6 11 AVSS AINP 7 10 REFP AINN 8 9 REFN FUNCTION NO. 1 2 NAME DVDD DGND 3 CLKIN Digital Input 4 GAIN Digital Input 5 6 7 8 9 10 11 12 13 14 15 16 NC NC AINP AINN REFN REFP AVSS AVDD DGND DVDD SCLK DOUT/DRDYn Digital Digital Analog Input Analog Input Analog Input Analog Input Analog Analog Digital Input Digital Input Digital Input Digital Output Sept. 2019 Digital Digital SIG2012 TSSOP-16 DESCRIPTION Digital power supply, 2.7V to 5.25V. Digital ground reference point. 1) Internal oscillator: Connect to DGND. 2) External clock: Connect to external clock input. PGA gain control: DGND for gain=128 and DVDD for gain=256. Gain=128 if float. No connection (float) or connect to DVDD/DGND. No connection (float) or connect to DVDD/DGND. Positive analog input. Negative analog input. Negative reference input. Positive reference input. Negative analog power supply. Positive analog power supply. 2.7V to 5.25V relative to AVSS. Connect to DGND or no connection (float). Connect to DVDD or DGND. Serial data clock. Serial data output and data ready indicator. Signal Micro Incorporated http://www.signal-micro.cn 2 SIG2012 PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE ORDERING NUMBER PACKING OPTION SIG2012 TSSOP-16 -40°C to +125°C SIG2012-ITSP16-RL Reel, 5000 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range, unless otherwise noted.(1) Voltage Current Temperature MIN MAX UNIT AVDD to AVSS –0.3 6.5 V AVSS to DGND –0.3 0.3 V DVDD to DGND –0.3 6.5 V V Analog input VAVSS – 0.3 VAVDD + 0.3 Digital input VDGND – 0.3 VDVDD + 0.3 V Input current –10 10 mA Junction (TJ) –50 150 °C Storage (Tstg) -60 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings SYMBOL PARAMTER CONDITION VALUE UNIT HBM Human-body model ANSI/ESDA/JEDEC JS-001 ±8000 V MM Machine model JEDEC EIA/JESD22-A115C ±400 V This integrated circuit can be damaged by ESD. Signal Micro recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 3 SIG2012 Electrical Characteristics Minimum/Maximum specifications apply from -40˚C to +125˚C. Typical specifications are at +25˚C. All specification are at VAVDD=5V, VAVSS=0V, VDVDD=3.3V, VREF=5V, fCLK=1.2288MHz, data rate=10SPS, unless otherwise noted. TEST CONDITION OR NOTES PARAMETER MIN(1) TYP MAX(1) UNITS +VREF/Gain VAVDD – 0.5 VAVDD – 0.5 – |VINMAX|·Gain/2 V V ANALOG INPUTS Differential Input Voltage Absolute Input Voltage VIN = VINP – VINN –VREF/Gain VAVSS + 0.5 VAVSS + 0.5 + |VINMAX|·Gain/2 Common Mode Input Range Absolute Input Current V 1 nA PGA Gain 128/256 V/V Resolution 20 Bits Data Rate 10 SPS SYSTEM PERFORMANCE Noise See Noise Table 1 Integral Nonlinearity (INL) ±15 Offset Error ±2 μV Offset Drift vs. Temperature ±10 nV/°C Gain Error ±0.3 Gain Drift vs. Temperature Normal Mode Rejection (NMRR) Common Mode Rejection (CMRR) (2) Power Supply Rejection (PSRR) REFERENCE INPUT Differential Reference Voltage (VREF) Absolute Negative Reference Voltage (VREFN) Absolute Positive Reference Voltage (VREFP) Average Voltage Input Current 2 ppm % 5 ppm/°C fIN=50/60Hz, ±2%, 100 110 dB fIN=50/60Hz 100 120 dB AVDD 75 90 dB DVDD 80 120 dB VREF = VREFP – VREFN 0.5 VAVDD – VAVSS + 0.1 V VAVSS – 0.05 VREFP – 0.5 V VREFN + 0.5 VAVDD + 0.05 V 20 nA ADC CLOCK External Clock Internal Oscillator Frequency Range 1 Duty Cycle 1.2288 40% Nominal Frequency 1.25 1.2288 Accuracy –3% High-level Output Voltage (VOH) IOH = 1mA 0.8·VDVDD Low-level Output Voltage (VOL) IOL = –1mA MHz 60% ±0.5% MHz 3% DIGITAL INPUT/OUTPUT V 0.2·VDVDD V High-level Input Voltage (VIH) 0.7·VDVDD VDVDD V Low-level Input Voltage (VIL) VDGND 0.3·VDVDD V Input Hysteresis 0.5 Input Leakage V ±10 μA POWER SUPPLY AVSS Voltage (VAVSS) 0 V AVDD Voltage (VAVDD) 2.7 5.25 V DVDD Voltage (VDVDD) 2.7 5.25 V 0.65 0.9 mA DVDD Current (IDVDD) 150 225 Total Power Dissipation 3.75 AVDD, AVSS Current (IAVDD) Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn μA mW 4 SIG2012 TEMPERATURE RANGE Specified temperature range –40 125 °C Operating temperature range –50 125 °C Storage temperature range –60 150 °C (1) Compliance to datasheet limits is assured by one or more methods: production test, characterization and/or design. (2) Power supply rejection is specified DC change in voltage. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 5 SIG2012 Timing Requirements: Serial Interface Over the operating ambient temperature range and DVDD = 2.7V to 5.25V, unless otherwise noted. B7 DOUT B6 B5 B4 B3 B2 B1 B0 t2 t3 SCLK t4 Figure 1. Serial Interface Timing Requirements SYMBOL t2 t3 t4 DESCRIPTION SCLK rising edge to valid DOUT/DRDYn: propagation delay(1) SCLK high pulse width SCLK low pulse width MIN SCLK period 400 MAX 50 UNIT ns ns ns 106 ns 200 200 (1) DOUT load = 20pF || 100k Ω to DGND. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 6 SIG2012 NOISE PERFORMANCE Table 1 and Table 2 show ADC noise performance in root mean square (RMS) value, peak-to-peak values, effective number of bits (ENOB), and noise-free bits. The ENOB and noise-free bits listed in the tables are calculated using Equation (1) and Equation (2): ENOB= log 2 (2×VREF ⁄Gain⁄VRMS ) (1) Noise Free Bits= log 2 �2×VREF ⁄Gain⁄Vp-p � (2) The noise data listed in the table are typical and are generated from continuous ADC readings with differential input voltage of 0 V. Table 1. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 5 V, VREF = 5 V Gain Data Rate RMS Noise(nV) Peak-to-Peak Noise(nV) ENOB(RMS) Noise-Free Bits 128 10SPS 44 250 20.8 18.3 256 10SPS 44 250 19.8 17.3 Table 2. ADC Noise in µVRMS (µVPP) at TA = 25°C, VAVDD = 3 V, VREF = 3 V Gain Data Rate RMS Noise(nV) Peak-to-Peak Noise(nV) ENOB(RMS) Noise-Free Bits 128 10SPS 44 250 20.1 17.6 256 10SPS 44 250 19.1 16.6 Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 7 SIG2012 CIRCUIT DESCRIPTION AVDD DVDD REFP REFN BUF Gain=128 or 256 AINP AINN PGA ΔΣ ADC Digital Filter Serial Interface SCLK Internal Oscillator DGND AVSS GAIN Figure 2. SIG2012 Block Diagram OVERVIEW The SIG2012 is low noise, low drift, and high-resolution 20-bit analog-to-digital converter (ADC) with integrated programmable gain amplifier (PGA). The ADC provides high-accuracy measurement solutions for bridge sensors. Figure 2 shows the device block diagram. The ADC features a high input-impedance, low-noise, programmable gain amplifier (PGA). The PGA gain is selectable with 128 or 256 by GAIN input pin. A delta-sigma modulator measures the PGA output voltage according to the buffered reference voltage to provide high speed bitstream to the digital filter. Unlike SAR ADCs, this ADC is much easier to drive due to very high impedance at both analog and reference inputs. The digital filter provides SINC4 filter mode, allowing good line-cycle rejection. The date rate is fixed to 10SPS. The SP-compatible serial interface is used to read the conversion data. The serial interface consists of two signals: SCLK and DOUT/DRDYn. The DOUT/DRDYn pin serves as dual function of register and ADC data output and also the indicator for data ready after the conversion is done. Parity check is provided for data integrity. The ADC has two clock options: internal oscillator and external clock. The nominal clock frequency is 1.2288MHz. The ADC operates with a single analog power supply with range from 2.7V to 5.25V. The digital power supply range is 2.7 V to 5.25 V. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 8 SIG2012 Programmable Gain Amplifier (PGA) The ADC features a low-drift, low-noise, high input impedance programmable gain amplifier (PGA). The PGA input is equipped with an electromagnetic-interference (EMI) filter consisting of two 350-Ω input resistors, and two 8pF filter capacitors, as shown in the Figure 3. 350Ω A1 8pF ADC A2 350Ω 8pF Figure 3. Simplified PGA Block Diagram The ADC full-scale voltage range is determined by the reference voltage and the PGA gain. Table 3 shows the fullscale voltage range verses gain for 5V reference voltage. Table 3. ADC Full-Scale Voltage Range with VREF = 5V FULL SCALE RANGE (V)(1) ±39 mV ±19.5 mV GAIN 128 256 (1) The full scale input range is proportional to VREF. Just like most amplifiers, there should be some headroom for the output of PGA to be away from the power supply (VAVDD) and ground (VAVSS) due to the limitation of voltage driving capability of PGA output device as shown in Figure 4. For correct linear operation, the absolute PGA output voltage must locate within the range [VAVSS + 0.5, VAVDD – 0.5]. The analog input common voltage must meet Equation (3): (VAVSS + 0.5 + VIN · Gain / 2) ≤ VCM ≤ (VAVDD – 0.5 – VIN · Gain / 2) (3) Where VIN = differential input voltage = VINP – VINN VCM = input common mode voltage = (VINP + VINN)/2 Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 9 SIG2012 PGA Input PGA Output VAV DD VAV DD – 0.5V VOUTP = VCM+VIN ×Gain/2 VINP VCM VINN VOUTN = VCM–VIN ×Gain/2 VAV SS + 0.5V VAV SS Figure 4. PGA Input and Output Range Digital Filter and Conversion Time A delta-sigma (Ʃ–Δ) ADC consists of a modulator followed by a programmable digital decimation filter to produce the final high-resolution data output. Caution must be taken to choose the type of filtering based on the consideration of tradeoffs between resolution, data rate, line cycle rejection, and conversion latency. This ADC only provides sinc4 filter. Figure 5 shows the frequency response of the SINC4 and SINC1 filters normalized to output data rate. 0 SINC1 SINC4 Amplitude (dB) -20 -40 -60 -80 -100 -120 -140 -160 0 1 2 3 4 5 6 7 Normalized Frequency 8 9 10 Figure 5. Frequency Response of SINC1/SINC4 Filter While the order of the SINC filter doesn’t affect the notch positions, the higher order SINC4 filter has wider notches resulting in better rejection in the band (±1 Hz) around the notches. The higher order SINC4 filter also gives better stop-band rejection with the tradeoff of longer settling time for the same output data rate. The SINC4 filter normally takes four conversion cycles to settle, while SINC1 filter settles in one conversion cycle. Clock Mode The system clock of this ADC can be either from the internal oscillator or provided by external clock source to the CLKIN pin. Figure 6 illustrates the configuration for each clock mode. If the CLKIN pin is shorted to analog ground (AVSS), the internal oscillator is enabled. If an external clock is detected at the CLKIN pin, the ADC automatically selects the external clock. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 10 SIG2012 2.4576MHz Clock CLKIN CLKIN Option (a) : Internal Oscillator Option (b): External Clock Figure 6. Clock Mode Configurations Power-On Reset (POR) The ADC has two power supplies, analog and digital. The analog power supply (AVDD) range is 2.7V to 5V. The digital supply (DVDD) range is 2.7V to 5V. Figure 7 shows the POR sequence. The internal POR circuitry forces the ADC in reset state if the digital supply voltage (VDVDD) is below POR voltage threshold which is about 1.3V. After the digital supply voltage (VDVDD) exceeds POR voltage threshold, additional 54 ms of waiting time is needed for power supply to be fully settled before sending any command, otherwise the command is ignored. VDVDD POR level: 1.3V typical fCLK Internal Reset ADC Reset ADC Normal Operation 54ms Figure 7. Power-On Reset Sequence SPI Interface The ADC provides a 2-wire SPI-compatible interface with SPI Mode 1 supported. Please see Timing Requirements: Serial Interface section for the timing information related to serial interface. SERIAL CLOCK (SCLK) The serial clock is a Schmitt-triggered input to make it noise immune. This pin is used to clock data into and out of the device. Output data on DOUT pin are updated on the rising edge of SCLK. DATA OUTPUT (DOUT/DRDYn) The DOUT/DRDYn pin is a dual-function output. This pin serves as the serial interface data output and also as an indicator for new data ready for retrieval. First, conversion or register data are shifted out on DOUT/DRDYn pin on the rising edge of SCLK. Second, while the SPI interface is at idle state, the DOUT/DRDYn pin goes low to indicate that new conversion data are ready for retrieval. Data Format The device provides 20 bits of conversion data output in binary 2’s complement format, left justified, MSB first. The ADC input is bipolar-differential and is scaled such that zero differential input results in an ideal code of 20’h00000, positive full scale input results in an ideal code of 20’h7FFFF, and negative full scale input results in an ideal code of 20’h80000. The output clips if the signal exceeds full-scale. Table 4 lists the ideal output codes for different input signals. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 11 SIG2012 Table 4. Ideal Output Code vs. Input Signal INPUT SIGNAL VIN = VINP – VINN ≥ FS (219 – 1) / 219 FS / 219 0 -FS / 219 ≤ –FS IDEAL OUTPUT CODE 20’h7FFFF 20’h00001 20’h00000 20’hFFFFF 20’h80000 Reading ADC Data As shown in Figure 8, the ADC data is 3 bytes long with 4-bit of LSB fixed to 4’b1111 after 20-bit conversion data, DATA [19:0]. Parity byte is appended to the conversion data bytes after more than 24 SCLKs is applied. Part of parity byte is formed by the checksum byte, which is the 8-bit sum of data conversion bytes plus an offset value, 8’h5B. The first and last bit of parity byte are forced with 1’b1. CHECKSUM [7:0] = DATA [19:12] + DATA [11:4] + {DATA [3:0], 4’b1111} + 8’h5B PARITY [7:0] = {1’b1, CHECKSUM [6:1], 1’b1} After four bytes are read, the data byte sequence is repeated when more SCLKs are sent. The repeating byte sequence starts with the first byte DATA [19:12]. The read operation needs to complete 2 system clock cycles before the next new data is ready, otherwise the retrieved data is corrupted by the updating of new data on DOUT/DRDYn pin. 1 9 21 17 25 8*n 33 SCLK Data Ready DOUT New Data Ready DATA[19:12] DATA[11:4] DATA[3:0] 4'b1111 PARITY[7:0] DATA REPEAT Optional Figure 8. Reading Data Sequence Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 12 SIG2012 REVISION HISTORY The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please go to web to make sure you have the latest revision. DATE REVISION Jan. 20, 2019 May 15, 2019 Sept. 8, 2019 CHANGE Initial release. Add ordering information. Add pin 4 GAIN description for float condition. DISCLAIMER Signal Micro reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. All trademarks and registered trademarks are the property of their respective owners. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 13 SIG2012 PACKAGE OUTLINE DIMENSIONS 0.30 0.19 0.65 16 0.10 M 9 0.15 NOM 4.50 4.30 6.60 6.20 0.25 0o-8o 0.75 0.50 8 1 5.10 4.90 1.10 MAX 0.15 0.05 0.10 Seating Plane A. Compliant to JEDEC STARDARDS MO-153-AD. B. All linear dimensions are in millimeters. C. This drawing is subject to change without notice. Sept. 2019 Signal Micro Incorporated http://www.signal-micro.cn 14
SIG2012-ITSP16-RL 价格&库存
很抱歉,暂时无法提供与“SIG2012-ITSP16-RL”相匹配的价格&库存,您可以联系我们找货
