ML3.5*6.0*0.8
ML3.5*6.0*0.8
    METALLIONS(美铼)
    FILTER_D3.5X6MM_TM
    直插磁珠 3A Ф3.50 x 6.00mm FILTER_D3.5X6MM_TM 60Ω@100MHz
ML3.5*6.0*0.8 数据手册
ITEM SR71 ML 3.5*6.0*0.8TAPING PART NO. ELECTRICAL IMPEDANCE REQUIREMENTS Z:60 MIN OHM(100MHZ) TEST MEHOD APPEARANCE STANDARD VISION INSPECTION LEVEL MIL-SID-105D CHARACT&SIZE LEVEL S-3 SURFACE LEVEL II TEST EQUIPMENT HP-4191A TEST FREQUENCY 100MHZ AQL=0.1 COIL SPEC DIMENSION A (UNIT:mm) D A=3.50±0.20m/m C C=0.80±0.20m/m D=6.00±0.20m/m ——1—— TEST DATA CUSTOMER QUANTITY ITEM ML 3.5*6.0*0.8 TAPING COIL SPEC TEST FREQUENCY PART NO. HUMIDITY 63% TEMPERATURE 23℃ TEST EQUIPMENT TESTRESOLUTION Z MHZ Ω MIN Z MHZ Ω MIN 100MHZ HP-4191A DIMENSION(UNIT:mm) Z 100MHZ A B C D 60Ω MIN 3.50 ±0.20 0.80 ±0.20 6.00 ±0.20 1 78 3.51 0.80 5.98 2 76 3.50 0.85 6.00 3 78 3.48 0.88 6.00 4 81 3.56 0.90 6.01 5 80 3.50 0.98 6.01 SPEC 6 7 8 9 10 MEAN R A C D E F ——3—— ITEM:SR71 M 3.5*6.0*0.8 TAPING IMPEDANCE(Ohm 1000 100 10 1 1 10 100 FREQUENCY(MHZ) METER:HP-4191A ——4—— 1000 ITEM SR71 ML 3.5*6.0*0.8TAPING PART NO. PACKAGING Available in tape and reel bulk TAPE DIMENSION: TYPE B ML3.5*6.0*0.8 63.00 ±3.00 E F H I J P d1-d2 6.00 52.2 4.20 1.35 0.80 5.00 1.20 ±0.50 ±1.50 MIN MAX MAX ±0.50 MAX 0.8MAX I P d1 E ——2—— d2 F H
ML3.5*6.0*0.8 价格&库存
很抱歉,暂时无法提供与“ML3.5*6.0*0.8”相匹配的价格&库存,您可以联系我们找货
