1
Technical Data
Materlal:
Pin(outer sleeve):Brass,machined CuZn38Pb2
Plating(outer sleeve):
Tin Plated:2 μm/80μ"NI,5 μm/200 μ"Sn
Gold Plated:2 μm"/80 μ"Ni,0.8 μ" gold
Insuiator:PPS UL94V-0
Mating pin∅:0.47/0.50mm
2
3
4
8
7
5
6
Electrical:
Current rating:3Amps/contact max.
Contact resistance:≤4m Ω/contact
Insuiation resistance:≥1000M Ω at V=100V
Operaing voltage:60VAC/DC
Mechanical:
Mechanical lige:min 500 cycle
Operaling temperature:-40 °C to+105°C
Soldering temperature:+255 °C
Critical Dimensions: *
P.C.B LAYOUT
2.00mm Machined Pin Header
MH200V-11-XX-1000
很抱歉,暂时无法提供与“MH200V-11-40-1000”相匹配的价格&库存,您可以联系我们找货
