3.0mm Round Through Hole LED EL304YGD
LIGHT EMITTING DIODE SPECIFICATION
CUSTOMER NAME:
DESCRIPTION:
EL304YGD
REVISION:
V2.2
ISSUE DATE:
2018-07-25
Contains trade secret information which is the property of Ekinglux and shall not be made available to, or copied or
used by anyone outside Ekinglux without its written authorization. Copyright © 2017 Ekinglux Optoelectronics Technology
Co., Ltd. All rights reserved
www.ekingluxs.com
Sales@ekingluxs.com
1
Features:
●Long operating life
●Low Power Consumption
●Low voltage DC operated
●RoHS Compliant
Application:
●Status indicator
●Industrial control panel
●Sensor status indication
●Wearable and portable devices
Part Number
EL304YGD
Dice Material
AlGaInP
Emitted Color
Yellow Green
Lens Color
Green Diffused
Electro-Optical Characteristics(Ta=25℃, @20mA)
Parameter
Luminous Intensity
Radiation Bandwidth
Forward Voltage
Luminous Flux
Dominant Wavelength
CIE Coordinates CIE
Color Temperature
Viewing Angle
Reverse Current
Symbol
IV
△λ
VF
Φ
λd
x,y
Tc
2θ1/2
IR
Min.
50
1.90
567
Typ.
30
2.00
570
60
Max.
100
2.40
575
10
Unit
mcd
nm
v
Lm
nm
k
deg
uA
Absolute Maximum Ratings(Ta=25℃)
Parameter
Peak Forward Current(1/10 Duty Cycle, 0.1ms Pulse Width)
Forward Current
Reverse Voltage
Electrostatic Discharge
Operating Temperature Range
Storage Temperature Range
Wave soldering
www.ekingluxs.com
Symbol
IFP
IF
VR
ESD
Topr
Tstg
Tsld
Max.
Unit
100
mA
30
mA
5
v
2000
v
o
-30to+85
C
o
-40to+90
C
260℃for 5secs
Sales@ekingluxs.com
2
Optical & Electrical Characteristics
Relative Intensity vs.Wavelength
100%
Relative lntensity(%)
Ta=25°c
80%
60%
40%
20%
0%
350
400
450
500
550
600
650
Wavelength (nm)
Permissible Forward Current(mA)
50
Forward Current(mA)
Ta=25°c
40
30
1.6
2.0 2.4 2.8 3.2
Forward Voltage(V)
3.6
Relative lntensity vs.Forward Currenr
50
40
30
60
80
100
Ambient Temperature(°c)
1.0
Relative lntensity
Relative lntensity
60
1.2
Ta=25°c
1.0
0.8
0.6
0.4
0.2
Relative lntensity vs.Ambient Temperature
1.2
Forward Current vs.Ambient Temperature
Forward Current vs.Forward Voltage
0.8
0.6
0.4
0.2
60
80
Forward Currenr(mA)
-20°
-30°
-40°
Radiation Pattern
-10° 0° 10°
Ta=25°c
20 40
60
80
100
20°
30°
40°
50°
-50°
-60°
60°
-70°
70°
80°
-80°
-90°
1.0
www.ekingluxs.com
0.5
90°
1.0
Sales@ekingluxs.com
3
Bin Limits
Bin Range Of Luminous Intensity (Unit:mcd)
Bin Code
L1
L2
L3
Min
50
Max
100
Condition
IF=20mA
Bin Range Of Forward Voltage (Unit:V)
Bin Code
V1
V2
V3
V4
V5
Min
1.9
2.0
2.1
2.2
2.3
Max
2.0
2.1
2.2
2.3
2.4
Condition
IF=20mA
Bin Range Of Wavelength (Unit:nm)
Bin Code
YG1
YG2
YG3
YG4
YG5
Min
567
569
571
573
Max
569
571
573
575
Condition
IF=20mA
Notes:
1.Tolerance of Luminous Intensity ±10%
2.Tolerance of Forward Voltage ±0.1V
www.ekingluxs.com
Sales@ekingluxs.com
4
Reliability Test Items And Conditions
Test Items
Reference
Thermal Shock
Test Conditions
Time
-40℃(30min)
100
-100℃(30min) Cycles
-10℃~65℃;
10cycles
0%~90%RH
MIL-STD-202G
Temperature And Humidity
Cyclic
High Temperature Storage
Low Temperature Storage
High Temperature High
Humidity Storage
High Temperature Life Test
JEITA ED-4701 200
203
JEITA ED -4071 200
201
JEITA ED -4071 200
202
JEITA ED -4071 100
103
JESD22-A108D
Life Test
Resistance to Sodering
Heat
GB/T 4937,Ⅱ,
2.2&2.3
Criterion
22
0/22
22
0/22
Ta=100℃
1000H
22
0/22
Ta=-40℃
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
2 times
22
0/22
Ta=60℃;
RH=90%
Ta=80℃
Ta=25℃
IF=20mA
Tsol*=(240±5)
℃10secs
JESD22-A108D
Quantity
Criteria For Judging Damage
Test Items
Forward Voltage
Recerse Current
Symbol
VF
IR
Test Conditions
IF=IFT
VR=5V
Luminous Intensity
IV
IF=IFT
Resistance to
Soldering Heat
Initial Data±10%
IR≤10uA
Average IV degradation≤30%;Single LED IV
degradation≤50%
Meterial without internal cracks,no meterial
between stripped,no deaded light
www.ekingluxs.com
Sales@ekingluxs.com
5
Product size (Unit:mm)
Notes:
1. All dimensions are in millimeters (inches).
2. Tolerance is ±0.25(0.01") unless otherwise noted.
3. Lead spacing is measured where the leads emerge from the package.
www.ekingluxs.com
Sales@ekingluxs.com
6
LabelStyle
Packaging
www.ekingluxs.com
Sales@ekingluxs.com
7
Precautions
1. Lead Forming
1.1 During lead formation, the leads should be bent at a point at least 3mm from the base of the epoxy bulb.
1.2 Lead forming should be done before soldering.
1.3 Avoid stressing the LED package during leads forming. The stress to the base may damage the LED’s characteristics or it
may break the LEDs.
1.4 Cut the LED lead frames at room temperature. Cutting the lead frames at high temperatures may cause failure of the
LEDs.
1.5 When mounting the LEDs onto a PCB, the PCB holes must be aligned exactly with the lead position of the LED. If the
LEDs are mounted with stress at the leads, it causes deterioration of the epoxy resin and this will degrade the LEDs.
2. Storage
2.1 The LEDs should be stored at 30°C or less and 70%RH or less after being shipped from Everlight and the storage life
limits are 3 months. If the LEDs are stored for 3 months or more, they can be stored for a year in a sealed container with a
nitrogen atmosphere and moisture absorbent material.
2.2 Please avoid rapid transitions in ambient temperature, especially, in high humidity environments where condensation
can occur.
3. Soldering
3.1 Careful attention should be paid during soldering. When soldering, leave more then 3mm from solder joint to epoxy
bulb, and soldering beyond the base of the tie bar is recommended.
3.2 Recommended soldering conditions:
3.3 Recommended soldering profile
www.ekingluxs.com
Sales@ekingluxs.com
8
3.4 Avoiding applying any stress to the lead frame while the LEDs are at high temperature particularly when soldering.
3.5 Dip and hand soldering should not be done more than one time
3.6 After soldering the LEDs, the epoxy bulb should be protected from mechanical shock or vibration until the LEDs return
to room temperature.
3.7 A rapid-rate process is not recommended for cooling the LEDs down from the peak temperature.
3.8 Although the recommended soldering conditions are specified in the above table, dip or hand soldering at the lowest
possible temperature is desirable for the LEDs.
3.9 Wave soldering parameter must be set and maintain according to recommended temperature and dwell time in the
solder wave.
4. Cleaning
4.1 When necessary, cleaning should occur only with isopropyl alcohol at room temperature for a duration of no more
than one minute. Dry at room temperature before use.
4.2 Do not clean the LEDs by the ultrasonic. When it is absolutely necessary, the influence of ultrasonic cleaning on the
LEDs depends on factors such as ultrasonic power and the assembled condition. Ultrasonic cleaning shall be pre-qualified
to ensure this will not cause damage to the LED
www.ekingluxs.com
Sales@ekingluxs.com
9
很抱歉,暂时无法提供与“EL304YGD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18044
- 10+0.16475
- 30+0.16161
