WAS4735Q-16/TR
WAS4735Q-16/TR
    WILLSEMI(韦尔)
    QFN-16_2.6X1.8MM
    模拟开关芯片 4:1高速(-3dB带宽1.2GHz)交换机 2.3V~5.5V QFN16_2.6X1.8MM
WAS4735Q-16/TR 数据手册
WAS4735Q WAS4735Q 4:1 High speed (-3dB bandwidth 1.2GHz) Switch Http//:www.sh-willsemi.com Descriptions The WAS4735Q is a bi-directional, low power, high-speed 4:1 switch that operates from a single +2.3V to +5.5V power supply. The WAS4735Q high-speed is designed for switching (-3dB bandwidth 1.2GHz) of QFN1826-16L signals in D1- D1+ D2+ D2- handset and consumer applications, such as cell phones, digital cameras, and notebooks with hubs or 12 D0+ 13 controllers with limited USB I/Os. The WAS4735Q has low bit-to-bit skew and high channel-to-channel noise isolation, and is compatible 11 10 9 8 D3+ D0- 14 7 D3- /OE 15 6 NC 16 2 1 with various standards, such as high-speed USB 2.0 3 SEL0 5 SEL1 4 GND D+ D- Vcc (480Mbps), MHL video 720p/60fps and 1080i/30fps. Each switch is bi-directional and offers little attenuation Pin configuration (Top view) of the high-speed signals at the outputs. Its bandwidth is quite marginal to pass high-speed differential signals (2.4Gbps) with good signal integrity. DF* The WAS4735Q is featured with special circuitry on the D+/D-, which allows the device to withstand a VBUS short to D+ or D- when the USB devices are either powered off or on. Marking DF = Device code The WAS4735Q is available in QFN1826-16L package. * = Month (A~Z) Standard products are Pb-Free and halogen-Free. Order information Device Package Shipping WAS4735Q-16/TR QFN1826-16L 3000/Reel&Tape Applications  Cell phones  MID  Router Features  Other electronics equipments  Supply voltage : 2.3 ~ 5.5V  -3dB Bandwidth : 1.2GHz @ CL=0pF  Off isolation : -50dB @ 250MHz  Crosstalk : -30dB @ 250MHz  Low quiescent current : 60uA typical Will Semiconductor Ltd. 1 Jun, 2014 - Rev. 1.1 WAS4735Q Pin descriptions Pin Number Symbol Descriptions 1 GND 2 D+ D+ Common Port (HS or FS USB) 3 D- D- Common Port (HS or FS USB) 4 Vcc 5 SEL1 Path Selection Control Input (See Table Below) 6 SEL0 Path Selection Control Input (See Table Below) 7 D3- D- From Fourth Source Path (HS or FS USB) 8 D3+ D+ From Fourth Source Path (HS or FS USB) 9 D2- D- From Third Source Path (HS or FS USB) 10 D2+ D+ From Third Source Path (HS or FS USB) 11 D1+ D+ From Second Source Path (HS or FS USB) 12 D1- D- From Second Source Path (HS or FS USB) 13 D0+ D+ From First Source Path (HS or FS USB) 14 D0- D- From First Source Path (HS or FS USB) 15 /OE Enable Control Input (See Table Below) 16 NC No Connect Ground Power Supply Function descriptions SEL0 /OE SEL1 Function 1 X X D+,D- Switch Paths Open 0 0 0 D+ = D0+, D- = D0- 0 0 1 D+ = D1+, D- = D1- 0 1 0 D+ = D2+, D- = D2- 0 1 1 D+ = D3+, D- = D3- Logic symbol and typical applications 4G Processor D0+ D1+ D2+ D3+ D0D1D2D3- SEL1 SEL0 USB #0 USB Port D+ 2G modem USB #1 WAS4735Q Application Processor USB #2 4:1 MUX D- Control Logic Symbol Will Semiconductor Ltd. /OE Vbus D+ D- GND 3G Processor USB #3 Typical Applications (Mobile Phone Example) 2 Jun, 2014 - Rev. 1.1 WAS4735Q Absolute maximum ratings Parameter Symbol Value Unit Supply voltage range VCC -0.5 ~ 6.5 V Data input/output voltage range VDATA -0.5 ~ 6.5 V Select input voltage range VSEL -0.5 ~ 6.5 V Continues output current IOUT ± 50 mA TJ 150 o 260 o -65 ~ 150 o Junction temperature range Lead temperature range Storage temperature range Thermal resistance TL TSTG C C C o RθJA 250 I/O to VCC, I/O to GND ± 6000 V I/O to I/O ± 4000 V Symbol Value Unit Supply voltage range VCC 2.3 ~ 5.5 V Data input/output voltage range VDATA 0.0 ~ VCC V Select input voltage range VSEL 0.0 ~ VCC V Enable control input voltage range VOE 0.0 ~ VCC ESD protection (HBM) C/W Recommend operating ratings Parameter Operating temperature range Will Semiconductor Ltd. TA -40 ~ 85 3 V o C Jun, 2014 - Rev. 1.1 WAS4735Q o Electronics Characteristics (Ta=25 C, VCC=4.5V, unless otherwise noted) Parameter Symbol Select and OE logic high level VIH Select and OE logic low level VIL Supply quiescent current ICC Select input leakage current ISEL Off state switch leakage current Conditions Min. Typ. Max. Unit VCC=3.0~4.5 1.7 V VCC=2.3~3.0 1.4 V VCC=3.0~4.5 0.6 V VCC=2.3~3.0 0.4 V 80 uA ±1.0 uA IOFF ±1.0 uA On state switch leakage current ION ±1.0 uA On-Resistance RON 5.0 7.5 Ω 0.15 0.20 Ω 1.8 2.2 Ω On-Resistance match ∆ RON IOUT=0, VSEL >1.5V or VSEL
WAS4735Q-16/TR 价格&库存
很抱歉,暂时无法提供与“WAS4735Q-16/TR”相匹配的价格&库存,您可以联系我们找货
WAS4735Q-16/TR
  • 1+1.16199
  • 30+1.12049
  • 100+1.07899
  • 500+0.99600
  • 1000+0.95450
  • 2000+0.92960
