78L09
D
D
D
D
D
D
Positive-Voltage Regulators
3-Terminal Regulators
Output Current up to 100 mA
No External Components
Internal Thermal-Overload Protection
Internal Short-Circuit Current Limiting
Provided Pb-Free packages from the end
of 2004
O
C
I
TO-92
78L09ACZ
INPUT
COMMON
OUTPUT
description
This series of fixed-voltage integrated-circuit
voltage regulators is designed for a wide range of
applications. These applications include on-card
regulation for elimination of noise and distribution
problems associated with single-point regulation.
In addition, they can be used with power-pass
elements to make high-current voltage regulators.
One of these regulators can deliver up to 100 mA
of output current. The internal limiting and
thermal-shutdown features of these regulators
make them essentially immune to overload. When
used as a replacement for a zener diode-resistor
combination, an effective improvement in output
impedance can be obtained, together with lower
bias current.
OUTPUT GND INPUT
SOT-89
78L09CPK
electrical characteristics at specified virtual junction temperature, VI = 16V, I o =40mA (unless
otherwise noted)
PARAMETER
78L09
TJ‡
TEST CONDITIONS
MIN
25°C
Output voltage
Input
voltage regulation
20 V
I
1 mA
A tto 40 mA
A
8.6
TYP
9
IO =1mA to 40MA, V1= 12V to 24V
Full range
8.55
9
IO = 1 mA to 70 mA
VI = 12V to 24V
Full range
8.55
9
25°C
25
C
UNIT
MAX
9.4
9.45
45
9.45
175
40
125
V
mV
mV
Ripple rejection
VI = 13V to 24V
VI = 15V to 25V
Output
voltage regulation
IO = 1 mA to 100 mA
IO = 1 mA to 40 mA
25°C
25
C
Output
noise voltage
f = 10 Hz to 100 kHz
25°C
58
µV
Dropout voltage
25°C
1.7
V
Bias
Bias current
ccurrent
rrent
25°C
4.1
Bias
current change
f = 120 Hz
25°C
38
125°C
VI =13V to 24V
IO = 1 mA to 40 mA
Full
Fullll range
F
dB
45
19
90
11
40
6
5.5
1.5
0.1
mV
mV
mA
mA
mA
mA
‡ Pulse-testing techniques maintain TJ as close to TA as possible. Thermal effects must be taken into account separately. All characteristics are
measured with a 0.33-µF capacitor across the input and a 0.1-µF capacitor across the output. Full range for the 78L05 is T J = 0°C to 70°C
Wing Shing Computer Components Co., (H.K.)Ltd.
Homepage: http://www.wingshing.com
Tel:(852)2341 9276 Fax:(852)2797 8153
E-mail: wsccltd@hkstar.com
2-1
WS
78L09
absolute maximum ratings over operating temperature range (unless othewise noted)
78L09
PARAMETER
UNIT
voltage, VI
Input voltage
30
V
Virtual junction temperature range, TJ
150
°C
Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds
260
°C
–65 to 150
°C
Storage temperature range, Tstg
recommended operating conditions
78L09
voltage VI
Input voltage,
MIN
MAX
UNIT
11.5
24
V
100
mA
70
°C
Output current, IO
Operating
g virtual jjunction temperature, TJ
Pad Location 78L09
90um
3
90um
85um
2
90um
99
95um
1
100um
Chip size 1.0 x 1.2 mm
Pad N
1
2
3
Pad Name
Ground
Input
Output
2-2
X (um)
Y (um)
95
820
535
100
1010
1015
很抱歉,暂时无法提供与“WS78L09”相匹配的价格&库存,您可以联系我们找货
