■ High accuracy thermistor
AT Thermistor
The AT series thermistor features high accuracy with tight resistance and B-value tolerances (±1%).
Features: – Uniform shape facilitates automated assembly
– Long term reliability
– Five different standard shapes available
■ Product number explanation
■ Dimensions
Fig. 1
103 AT-□-FT
11: See Fig. 1
2: See Fig. 2
3: See Fig. 3
4: See Fig. 4
5: See Fig. 5
6 ± 0.2
103AT-11
S
AAA
Resin
0.7
2.4 max.
8.5±1
17±1.5
4.0 max.
2.4 max.
2.5 ± 0.5
Product number
102AT-2
202AT-2
502AT-2
103AT-2
203AT-2
Unit: mm
Resin
Tie bar
0.5 tin plated 42 alloy
8.5±1 1.0
17±1.5
4.0 max.
Unit: mm
Fig. 4
2.5 max.
Resin
3±1
6±1
30 ± 1
2.4 ± 1
3.5 ± 1
Φ0.5 tin plated copper wire
Color code:
Black:
Red:
Yellow:
White:
None:
2.54 ± 0.25
Color code
3.7 max.
Fig. 3
2.54 ± 0.25
Color code
3.7 max.
Fig. 2
■ Applications
Office automation, measuring instruments, controllers, mobile devices,
battery chargers, battery packs, fan motors, home electronics,
HVAC equipment, solar systems, security, thermometers, automotive,
vending machines, refrigerated display cases, agricultural equipment
Resin
600 + 20
Unit: mm
Rated zero-power resistance at 25 ℃
E.g.:
103 = 10 x 10³ Ω
Fig. 5
5±1
15 max.
5 max.
(AT-5 only)
FT:
Taping
No marking: Untaped bulk products
Shape
0.3 TPE resin parallel wire
Bare lead wire
PVC AWG30
8.0 max.
40 to 100
(3)
Unit: mm
Unit: mm
■ Specifications
Product number
R251
B value2
102AT-11
1.00 kΩ
3100 K ± 1%
202AT-11
2.00 kΩ
3182 K ± 1%
502AT-11
5.00 kΩ
3324 K ± 1%
103AT-11
10.0 kΩ
3435 K ± 1%
203AT-11
20.0 kΩ
4013 K ± 1%
102AT-2
1.00 kΩ
202AT-2
2.00 kΩ
± 1%
Dissipation factor
(mw / ℃)
12
Rated power at
25 ℃ (mW)
approx. 2.6
approx. 75
13
- 50 to 105
- 50 to 90
3182 K ± 1%
502AT-2
5.00 kΩ
3324 K ± 1%
10.0 kΩ
3435 K ± 1%
203AT-2
20.0 kΩ
4013 K ± 1%
103AT-4
10.0 kΩ
3435 K ± 1%
103AT-5
10.0 kΩ
3435 K ± 1%
Operating temperature
range (℃)
- 50 to 90
approx. 2.0
approx. 15
10
approx. 10
approx. 2.5
: B value calculated from rated zero-power resistance at 25 ℃ and 85 ℃
2
: Time required to reach 63.2% of temperature difference. Measured with sensor suspended in mid-air.
3
Thermal time
constant (s)³
3100 K ± 1%
103AT-2、
3
: Rated zero-power resistance at 25 ℃
1
R25 tolerance
approx. 15
- 50 to 110
- 30 to 90
12.5
- 50 to 110
■ Reliability data
Item
Test conditions
Resistance to soldering heat
Solderability
Tensile strength (lead wire)
Termination bending
Free fall
Voltage proof
Insulation resistance
Dry heat
Damp heat
(under electrical load)
AT-2, 3, 4
AT-5
AT-2, 3
AT-4, 5
AT-11
AT-2, 3
AT-4
AT-5
AT-11
AT-2, 3
AT-4
AT-5
AT-11, 2, 3
AT-4
AT-5
AT-11, 2, 3, 5
AT-4
AT-11, 2, 3, 5
AT-4
AT-11
AT-2, 3, 5
AT-4
AT-11
AT-2, 3, 4, 5
AT-11
AT-2, 3
Temperature cycle
(thermal shock)
Criteria
10 s at 260 ℃ or 3.5 s at 350 ℃
5 s at 260 ℃ or 1.5 s at 350 ℃
2 s at 245 ℃. Flux material: Rosin 25%, ethyl alcohol 75%.
2 s at 235 ℃. Flux material: Rosin 25%, ethyl alcohol 75%.
10 s at 30 N (horizontal pull)
A load of 2 N is applied to the wire terminations in vertical direction for 10 s (see Fig. 1)
60 s at 5 N (horizontal pull)
A load of 2 N is applied to the wire terminations in vertical direction for 3 s (see Fig. 1)
5 N, ten times, 90°
One time, 90°
1 N, five times, 90°
2.5 N, two times, 90°
Three times natural fall to a maple board from 1 m height.
Three times natural fall to a maple board from 0.75 m height.
One time natural fall to a maple board from 1 m height.
1000 V AC for one minute
100 V DC for one second
500 V DC
100 V DC
1000 hours at 105 ℃ (90 ℃4)
1000 hours at 110 ℃ (90 ℃4)
1000 hours at 90 ℃
1000 hours at 70 ℃ and 90% humidity
Electrical load: 1 mA DC
1000 hours at 40 ℃ and 90% humidity
100 cycles as below:
1. - 55 ℃ for 30 minutes 2. Room temperature for 3 minutes
3. 85 ℃ for 30 minutes
4. Room temperature for 3 minutes
1. - 30 ℃ for 30 minutes 2. Room temperature for 3 minutes
3. 90 ℃ for 30 minutes
1. - 20 ℃ for 30 minutes 2. Room temperature for 1 minute
3. 70 ℃ for 30 minutes
4. Room temperature for 1 minute
AT-4
AT-5
ΔR, ΔB ± 1%
More than 90% soldered
ΔR, ΔB ± 1% and visual
inspection
Less than 1 mA
Over 100 MΩ
ΔR, ΔB ± 1%
: Conditions for 102AT-11, 202AT-11, 102AT-2, 202AT-2
4
■ Resistance / temperature characteristics
Temperature
- 50
- 40
- 30
- 20
- 10
30
40
50
60
70
80
85
90
100
110
B25/85
102AT
24.46
14.43
8.834
5.594
3.651
2.449
1.684
1.184
1.000
0.8486
0.6189
0.4587
0.3446
0.2622
0.1999
0.1751
0.1536
202AT
55.66
32.34
19.48
12.11
7.763
5.114
3.454
2.387
2.000
1.684
1.211
0.8854
0.6587
0.4975
0.3807
0.3346
0.2949
3100 K
3182 K
Product number
502AT
154.6
88.91
52.87
32.44
20.48
13.29
8.840
6.013
5.000
4.179
2.961
2.137
1.567
1.168
0.8835
0.7722
0.6771
0.5265
0.4128
3324 K
103AT
329.5
188.5
111.3
67.77
42.47
27.28
17.96
12.09
10.00
8.313
5.827
4.160
3.020
2.228
1.668
1.451
1.266
0.9731
0.7576
3435 K
■ Caution
203AT
1253
642.0
342.5
190.0
109.1
64.88
39.71
24.96
20.00
16.12
10.65
7.181
4.943
3.464
2.468
2.096
1.788
1.315
0.9807
4013 K
AT-2, 3, 5
• When bending the lead wires using for example a radio
plier make sure to have a minimum distance from the
sensor head of 3 mm.
• Do not apply a mechanical load of more than 2 N in the
way depicted in Fig. 1 below. The variation of the load
direction should be less then 0.3 mm (see Fig. 2).
±0.3
2N
Fig. 1
Fig. 2
• When soldering make sure to have a minimum
distance of 5 mm (8.5 mm), use a soldering iron with
50 W and solder for maximum 7 (2) seconds at 340 ˚C
(350 ˚C). If you plan to cut the lead wire shorter than
the above minimum distance please contact us.
The values in brackets are for AT-5.
Unit: kΩ
●AT-5: 2500 pcs / reel
6.35 ± 1.3 12.7 ± 1.0
2.4 ± 1
2.0 max.
2.0 max.
5 +ー 0.8
0.2
12.7 ± 0.3
φ0.5 ± 0.05
0.6 ± 0.3
1.5 max.
18.0 ± 0.5
12.5 min
+ 0.75
9.0 ー
0.5
11.0 max.
3 max.
+ 2.0
9.0 ー 1.0
3±1
3.5 ± 1
16.0 ± 0.5
■ Taping dimensions
φ4.0 ± 0.3
Unit: mm
13
