PANEL
PCB SWITCHES
-1
1S
M
Small round cap •
variable heights • illumination option
DISTINCTIVE FEATURES
Round caps Ø6.5 mm
3 different standard total height options : 16.0-22.5 mm
SWITCH SPECIFICATIONS : see Multimec™ 3F series.
16.0 - 22.5 ±0.2
3F+1S - SMD
10.0
10.0
EC
2
10
2
S-
16.0
16.0 -- 22.5
22.5 ±0.2
±0.2
3F+1S - TH - W/LED
The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm.
1
PCB SWITCHES
1S
Small round cap •
BUILD YOUR PART NUMBER
ILLUMINATED
3F
1S
SERIES
MOUNTING
TH9
through-hole
CAP
LED
05
blue
HEIGHT
COLOR
11
transparent
16.0
16.0
green
19.0
19.0
40
yellow
22.5
22.5
65
white
80
red
2040
green/yellow
8020
red/green
8040
red/yellow
NON-ILLUMINATED
3F
1S
SERIES
MOUNTING
TH9
through-hole
SH9
surface mount
CAP
COLOR
09
black
HEIGHT
16.0
16.0
19.0
19.0
22.5
22.5
NOTICE : Please note that not all combinations of above numbers are available.
Please refer to www.apem.com for information on the 5G series version - 1SS/1IS/1LS.
MOUNTING
• Panel cut-out : min. Ø7.0 mm
• Switch spacing AxB : min. 12.7 x 10.3 mm
2
MATERIALS
• Cap :
- solid color 1S: PPS UL94V0
- illuminated : polycarbonate UL94HB
Available for Multimec caps
STANDARD LEGENDS
STANDARD LEGENDS
LEGEND
1D09_
1F096R_
000
1
001
001
2
002
002
3
003
003
4
004
004
5
005
005
6
006
006
7
007
007
8
008
008
9
009
009
107
107
019
019
1ZB09D_
1ZB16DLMH_
1ZC_
1Z_
1ZW_
10R_ & 10RF_
10RM16_
10Q_
10QM16_
054
054
054
059
059
059
10A_
10C_
033
133
034
134
135
135
136
123
123
136
123*
136
123
123
ON/OFF
123
123
017
017
STOP
018
018
031
031
038
038
CANCEL
048
048
ENTER
105
105
118
118
START
RESET
ESC
038
051
ON
116
OFF
117
OK
118*
SET
119
MENU
120
FUNC
121
HOME
122
118
118
STANDARD OPTIONS
• 1D: pad printed
• 10A: pad printed / laser marked
• 1F: reverse printed
• 10C: pad printed / laser marked
• 1ZB: pad printed / laser marked
• 10R(F) & 10Q: pad printed / reverse printed
• 1ZC: pad printed *reverse printed *laser marked
• 10RM & 10QM: metal symbol
• 1Z & 1ZW: pad printed / laser marked
1
PANEL
PCB SWITCHES
Legends
PCB SWITCHES
Legends
HOW TO ORDER
POSITIONING OF LEGENDS ON ROCKER-ACTION CAPS
LEGEND ILLUMINATION
• Option 1 - laser marked: In case of laser marked
legends an “LM” is added after the cap colour,
before the legend code. We recommend using
hard paint (additional “H” ) for increased lifetime
of the paint. E.g. 1ZB16DLMH13609
When ordering legends for caps with hinge-type cap retention system, it is important to note the position of the cap.
An extra letter (U, D, R or L) needs to be added to the part
number to refer to the position of the hinges in relation to
the legend. See samples:
• Option 2 - reverse printed: In case of reverse
printed caps an “R” is added after the cap colour,
before the legend code. Especially relevant
when standard legends have both negative and
positive print options. E.g. 1FS096R00009
Rocker-action caps without a lens: 1A, 1B, 1M, 1ZA and 1ZB
ON/OFF
UP
1A09U01706
ON/OFF
RIGHT
1ZB16RLMH11809
OK
ON/OFF
• Option 3 - metal symbol: Only available
ON/OFF
for
10RM andON/OFF
10QM
ON/OFF(therefore the “M”). E.g.
ON/OFF
10RM16059
ON/OFF
ON/OFF
ON/OFF
ON/OFF
3
1
ON/OFF -
4
DOWN
2
1B09D01706
2
4
1
ORIENTATION OF THE SWITCH
LEFT
1ZB09L00106
1
3
3
1
1
ON/OFF
ON/OFF
3
4
1
2
2
4
2
UP
4
-2
1
1
4
3
3
DOWN
STANDARD AND CUSTOM LEGENDS
3
• Standard are only certain legends on certain caps. See the table on the previous page.
• All standard pad-printed legends are white on black caps.
• All standard reverse-printed and laser marked legends are black on frosted white cap.
STANDARD LEGENDS
CAP COLOR
CAP
DIRECTION*
TYPE*
LEGEND
LEGEND COLOR*
1D
00
Blue
D
Down
UV
UV printed
001
1
00
Blue
1F
02
Green
U
Up
2
03
Grey
Grey
R
Right
Laser marked
on soft paint
002
03
LM
3
06
White
Yellow
L
Left
Laser marked
on hard paint
003
04
LMH
etc
08
Red
06
White
09
Black
08
Red
MC
09
Black
Multi
color
16
Frosted white
Etc
*Only for hingetype caps
R
Reverse
printed
*In case of illumination
Etc
*In case of reverse printed
the colour of the paint
Notice: The size of the legends listed may not correspond to the actual size.
If you decide to use one of the standard legends without any adjustments (without a new cliché or programming) on another cap than designated in the
table, then there is no cliché or programming cost, for this to apply the cap has to be black and the print white.
For further information on legends please contact APEM.
2
1A
1B
1D
1E/1F
38
40
42
50
53
57
1GA/1GC
1H
1K
36
Metal dark grey /
No ral code
08
Metal light grey /
No ral code
06
Metal dark blue /
No ral code
Melon / 1028
04
Aqua blue / 5021
Tele grey / 7046
03
Dusty blue / 5014
Mint green / 6029
02
CODE
Noble red / 3002
Ultra blue / 5002
00
CAP
Signal white / 9003
Black / 9004
Red / 3000
34
White / 9010
33
Yellow / 1023
32
Grey / 7004
30
green / 6018
09
Blue / 5012
Colour / RAL
Code
1M
1N
1P
1Q
1R
1S
1T/1U/1V
1WA* / 1WD
1X
1ZA
1ZB
1ZC
10A
The RAL Codes mentioned are the codes nearest to the solid colors in the multimec™ range.
*3E actuators and Varimec use different materials and therefor have a different color code and are not represented in this table
3
PANEL
PCB SWITCHES
Solid colors
PCB SWITCHES
Cap & Bezel Specifications
Multimec™ caps
ACCESSORY SPECIFICATIONS
4
MATERIAL
PARTS
TEMP. LIMIT
UL RATING
ABS
Solid color 1A, 1B, 1D, 1E, 1F, 1H, 1K, 1M, 1N, 1P, 1Q, 1R, 1T, 1U, 1V, 1WA, 1WD, 1X, 1ZA, 1ZB,
1ZC and AQC
Bezels 2C, 2D and 2K, reflectors for 1KB, 1KC, 1Y and 1YA
Max 65 °C
Max 149 °F
UL94HB
Polycarbonate
All lenses and transparent colour caps, lids for 1KB & 1KC
Max 85 °C
Max 185 °F
UL94HB
Polyamide
1GA, 1GC, 1S and 2S
Max 160 °C
Max 320 °F
UL94V2
Legends adhesion
DS/EN ISO 2409 Class 1 & ASTM D3359 Class 4B
03
EC
M
U
-M
M
EC
I
LT
PANEL
PCB SWITCHES
22
3F
Multimec™ 3F
High performance tactile switches •
robust
10 x 10 mm; h=10.4 mm
Illuminated RAS option
Slip-on cap retention system - great for custom caps
ENVIRONMENTAL SPECIFICATIONS
• Sealing : IP67 according to IEC 60529
• Working and storage temperature :
- non-illuminated : -40 °C/+160 °C (-40 °F to +320 °F)
- illuminated : -40 °C /+85 °C (-40 °F to +185 °F)
• Soldering :
- through-hole : IEC 60068-2-20 8
- surface mount : JEDEC J-STD-020E
ELECTRICAL SPECIFICATIONS
• Recommended load :
- Gold contacts : 0.5µ-50 mA 24 VDC
- Silver contacts : 0.5-50 mA 24 VDC
• Contact resistance : 10 MΩ
• Contact bounce : 10,000,000 cycles
• Terminals : SnCu + 2 µNI + 3 µSn100
All tolerance if not otherwise specified ±0.2 mm.
• Max. actuation force : 100 N for 10 sec
1
6,4
10,4
robust
3F - SMD
14
Ø 6,5
10
6,4
10,4
10
7,62
14
0,8
Ø 6,5
6,4
10,4
0,8
7,62
3F - TH
Min 10,16
Max 12,5
0,3
Ø 6,5
10
6,4
10,4
10
0,8
0,3
Min 10,16
Max 12,5
7,62
Ø 6,5
0,8
7,62
3F - TH W/LED
10
10
2,54
2,54
3F - RAS
10
7,62
12
5,08
7,62
2
10
7,62
12
PCB SWITCHES
Multimec™ 3F
5,08
7,62
PANEL
PCB SWITCHES
Multimec™ 3F
5,5
6,0
10
12
robust
5,08
2,54
3F - RAS W/LED
7,62
20,1
6,0
10
12
±0,3
17,8
5,5
7,62
5,08
2,54
2,54
7,62
20,1
±0,3
17,8
PCB LAYOUT & CIRCUIT DIAGRAM
7,62
2,54
4
2,5
Ø1,0(3x)
3
Ø1,0(3x)
2,54
1
3
Ø1,0(3x)
2,54
7,62
7,62
5,08
Ø1,0(4x)
7,62
5,08
7,62
3 +3
2,5
5,08
Ø1,0(4x)
7,62
7,62
5,08
7,62
2,54
ø1.0 (4X)
RAS bi-color illuminated
7,62
2,54
ø1.0 (4X)
3
2,54
4
7,62
Ø1,0(4x)
3
+3
5,08
7,62
2,54
1
5,08
7,62
3
1,2
3
3 +34
2,5
2,54
Ø 0,9
7,62 [0,300]
4
2,54 [0,100]
4
7,62
1
7,62
1 1
1
7,62
3
12,50
-2
1
5,08
1,2
2,5
1
-2
RAS illuminated
7,62
10,16
2
7,62
2
10,16 [0,400]
2,54
2,54 [0,100]
1
Ø 0,9
RAS
TH bi-color illuminated
33
2,5
Ø
0,9
12,50
10,16 [0,400]
7,62
2
2,54
4
1
7,62 [0,300]
4
3
1
7,62
3
2,5
Ø 0,9
-22
11
2,54
44
3
Ø 0,9
10,16
12,50
2
1,2
7,62
1,2
4
2
7,62
7,62
1
1,2
1
7,62
7,62
7,62
22
2,54 [0,100]
10,16
12,50
10,16
12,50
1
7,62
10,16
2
TH illuminated
1,2
2,54 [0,100]
SMD non-ill.
5,08
TH Non-ill.
PCB SWITCHES
Multimec™ 3F
robust
ILLUMINATED
3F
MOUNTING
SERIES
TH9
LED
through-hole
OPTIONAL
06
blue
Q
quiet contact
green
G
gold contacts
40
yellow
RAS
65
white
80
red
2040
green/yellow
8020
red/green
8040
red/yellow
24
high intensity green
46
high intensity yellow
87
high intensity red
right angle
NON-ILLUMINATED
3F
MOUNTING
SERIES
TH9
through-hole
SH9
surface mount
OPTIONAL
Q
quiet contact
RAS
right angle
(with TH only)
R
tape & reel
(with SMD only)
G
gold contacts
ABOUT THIS SERIES
Caps and accessories : for the full range of accessories for Multimec™ 3F please see the website.
4
robust
OPERATING FORCE
TAPE & REEL
Tape and reel is available for the parts listed and has the
following specifications
FORCE
10
• Reel diameter: Ø330 mm
9
• Tape width: 24 mm
• Pitch: see list
8
• Tape and reel material: antistatic or better
• Quantity per reel: see list
7
ORDERING CODE
PITCH
QUANTITY
PER REEL
3FSH9
3FSH9R
6
F(N)
PART NO.
5
3,5N
3.5
N
4
3
2
1
TRAVEL
0,4
0,6
0,8
1
L(mm)
1,2
1,4
1,6
1,8
2
MOUNTING
MOUNTING TOOLS FOR MULTIMEC™ THROUGH-HOLE SWITCHES
Part No. 9861000
1
2
3
4
5
5
PANEL
PCB SWITCHES
Multimec™ 3F
PCB SWITCHES
Multimec™ 3F
robust
MOUNTING (CONTINUED)
SPACE REQUIREMENT - MATRIX MOUNTING
Through-hole (TH)
Surface mount (SMD)
MULTIMEC™ SPACING EXAMPLES
13.6
13.6
12.7
12.7
1V+1T+1V
1N+1N+1N
SPACE REQUIREMENT - SWITCH/CAP
Cap dimensions
Switch spacing
Panel cut-out
6
CAP SERIES
RECOMMENDED
MIN.SWITCH SPACING AxB
NOMINAL CAP DIMENSION
WxH
RECOMMENDED
MIN. PANEL CUT-CUT
1D/1E/1F
1GA
12.7x11.3
Ø9.6
Ø10.0
12.7x11.3
Ø11.0
Ø11.4
1GC
15.3x15.3
Ø15.0
Ø15.4
1K/1KB/1KC
14.6x14.6
14.3x14.3
14.7x14.7
1N
13.6x11.3
Ø9.8/ 14.9
Ø10.2/15.1
1P/ 1Q/1R
12.8x10.3
6.5x12.5
7.0x13.0, R max. 1.0
1S
12.7x10.3
Ø6.5
Ø7.0
1T
12.7x12.3
10.6x10.6
11.0x11.0
1U
12.7x12.3
Ø10.6
Ø11.0
1V
15.95x12.1
10.6x13.25
11.0x13.65
1WA
14.2x10.3
12.5x6.5
12.9x6.9
1WD
16.9X10.3
15.2x8.0
15.6x8.4
1X
12.7x10.3
9.4x7.4
9.8x7.9
1ZC
14.6x14.6
Ø14.3
Ø14.7
robust
LED COMPONENT SPECIFICATIONS
Color
B
G
Y
W
R
G/Y
R/G
R/Y
G
Y
R
Color Codes
06
65
80
2040
8020
8040
24
46
87
120
120
60
110
100
100/60
100/100
75/75
60
60
60
ABSOLUTE MAXIMUM RATINGS (Ta=25°C)
Power
mW
Current forward
mA
30
30
30
30/20
30/30
30/30
25
25
25
Forward peak current
mA
150
90**
80**
100
90**
120/80
120/120
160/140
60
60
60
Voltage reverse
V
5
3
5
5
3
5
5
5
5
5
5
Operating
temperature
°C
-40/+85
-55/+100
-40/+85
-55/+100
-55/+100
-55/+100
-40/+85
-40/+85
-40/+85
-40/+85
Storage temperature
°C
-40/+85
-55/+100
-40/+100
-55/+100
-55/+100
-55/+100
-40/+85
-40/+100
-40/+100
-40/+100
Soldering temperature
°C
260 for max 3 sec
260 for max 2 sec
260 for max 5 sec
ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25°C)
Voltage forward
Typ. V
3.3
2.1
2.1
3.0
2.0
2.1/2.1
2.0/2.1
2/2.1
2.0*
2.0
2.0***
Max. V
4.0
2.6
2.6
4.0
2.6
2.6/2.4
2.6/2.6
2.5/2.5
2.4*
2.4
2.4***
Current reverse (VR=5V)
µA
Max. 50
100
100
100
100
100
100
2
10
10
10
Wave length
nm
460
569
588
NA
625
565
621/569
617/588
573
589
624
25
40
35
NA
40
30/35
40/30
45/35
NA
Spread angle
Spread
degree
nm
30
60
60
25
60
80/60
200
60
100
40
40
Luminous Intensity
Min. mcd
900
5.6
1.7
715
2.5
3.7/2.5
2.2/2.2
6/4
10
630
400
5.6
max
2850
8.7
12.6/8.7
4.8/4.8
14/8
800
Typ. mcd
Orientation
1600
12.6
The longer pin is the anode, the shorter is the cathode.
For bi-color LEDs the anode for the first color (ex. 8020) is the longer pin.
*/F=20mA, **1/10 duty cycles 0.1ms pulse width, ***/F=50mA, ****Luminous Flux mlm
7
PANEL
PCB SWITCHES
Multimec™ 3F
PCB SWITCHES
Multimec™ 3F
robust
USAGE GUIDELINES
HOW TO GET THE BEST RESULTS WITH
MEC SWITCHES ?
These guidelines are offered to users of MEC Switches as
an aid to ensure successful and reliable switch operation.
Please see the technical specifications for details on operating and storage temperatures and soldering guidelines
to make sure you select the best switch for your application. When reflow soldering is taking place, MEC strongly
recommend that the temperature profile is analyzed and
compared with the temperature rating of the switch. It is
also important to monitor the accumulated heat buildup
from both the pre-heat zones and the solder zone.
Most standard accessories for multimec™ 3 series switches
are made from ABS plastic with a maximum operating
temperature of 65 °C. It is strongly recommended that accessories are mounted after soldering of the switch.
If this is not possible care must be taken not to overheat
the accessories during the soldering process. The 1S and
1GA/1GC caps are, however, made of high temperature
materials and will meet the same temperature specifications as the switches. For accessories made from other
plastic materials please see multimec™ 3 cap & bezel
technical specifications.
offers a high level of sealing, however, with aqueous
solvent solutions care must be taken to avoid the worst
case situation with water jets, complete immersion into
a liquid with a temperature below the board or surface
tension reducing additives.
Recommended cleaning methods are demineralized
water. Any surface tension reducing agents, such as
soap, must not be used as they risk causing a potential leakage of the switch.
SOLDERING - THROUGH HOLE
VERSIONS
Hand soldering: max. 350 °C for max. 3 sec
Wave soldering: heat built up in the switch during
pre-heating and soldering must not exceed the
maximum operating temperature of the switch. Peak
temperature must not exceed 260 °C, and soldering
time is max 10 sec. (IEC 60068-2-20 8)
SOLDERING - SURFACE MOUNT
VERSIONS
LEDs have their own temperature specifications. When
fitted in a 3F switch the LED will determine the max. operating temperature, i.e. 3FTH924 has an upper temperature
limit of 85 °C!
For all methods - infrared, convection and vapor
phase. The upper limit 240 °C/40 sec must be observed. The soldering temperature profile must have
moderate temperature gradients. (JEDEC J-STD020E)
MOUNTING AND DISMOUNTING
ROHS COMPLIANCE
If switches are to be mounted in rows it is essential that
the recommendations regarding spacing are followed. PC
board thickness should be 1.4 ±0.2 mm and terminal hole
diameter should be 0.9 mm.
As of 1 July 2006 MEC has completed the conversion
to RoHS compliance. For more info please see our
homepage www.apem.com
All multimec™ caps and bezels are easily slid onto the switch
modules and can be changed at a later time .
TEMPERATURE LIMITS
Care must be taken when inserting the 3FT switch and
LED assembly into the PC board. Do not press direct on
the LED. This will force the LED down into the actuator
and risks to cause the switch contacts to remain in the
closed position. To correct the fault, the LED must be raised
slightly and centered in the actuator to assure unrestricted
movement of the actuator.
Switch
LEDs
Accessories
A mounting tool is available for through hole multimec 3
series switches.
SOLDERING AND CLEANING
MULTIMEC™ 3 SERIES
Multimec™ 3 series switches are fully sealed to IP67 specifications to prevent solder flux and aqueous based cleaning
solutions from entering the switch and contaminating the
contacts. The switches can be placed on the PC board with
other components and reflow soldered. Multimec™ 3 series
8
160 °C
80/85/100 °C
65/85/160 °C
PACKAGING
Multimec™ 3 series switches are packed in rigid
tubes of 50 pieces each.
A box contains 1.000 pcs.
The surface mount versions of multimec™ 3 series
switches with a height up to 12.5 mm can also be
delivered on tape/reel.
Each reel contains 250/500 pcs.
Right angle swithces are packed in trays.
A tray contains 100 pcs.
