TJ-S1615SW6TGLCCYRGB-A5 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
承 認 書
Specification For Approval
Customer: (客戶)
Description: (產品描述) SMD1615燈珠三色共陽RGB
Part number:(產品型號) TJ-S1615SW6TGLCCYRGB-A5
Date:
(日期)
Approved By: (客戶承認)
Prepared By:(我司承認)
Approval
核准
Check
Design
審核
製作
Sales
業務
Customer Service Hotline:400-676-8616
TEL:0769-8662 5999
0769-8200 2226
E-MIAL∶dg@togialed.com
FAX:0769-8200 2227
WEB:www.togialed.com
Features
1.6mmⅹ1.5mm SMT LED, 0.6mm thickness
Low power consumption
Wide view angle
Package: 4000pcs/reel
RoHS Compliant
Applications
Ideal for back light and indicator
Various colors and lens types available
Package outlines
Recommend Pad Layout
1.60 [0.06"]
3
4
0.50 [0.02"]
1
1.50 [0.06"]
2
1.60 [0.06"]
CHIP
0.60 [0.02"]
1.10 [0.04"]
0.90 [0.04"]
2.60 [0.10"]
3.00°
0.35 [0.01"]
0.70 [0.03"]
ATTENTION
3
4
2
1
2
3
4
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
B
G
1
R
Part No.
Emitted color
Dice
Red
AlGaInP
Green
InGaN/GaN
Blue
InGaN/GaN
Lens color
Water transparent
Notes:
1. All dimensions are in millimeters (inches);
2. Tolerances are 0.1mm (0.004inch) unless otherwise noted.
Absolute maximum ratings (TA=25℃)
Parameter
Value
Symbol
Power dissipation
Pd
Unit
R
G
B
72
111
111
mW
Forward current
If
30
mA
Reverse voltage
Vr
5
V
Operating temperature
Top
-40 ~+80
Storage temperature
Tstg
-40 ~+85
Ifp
125
mA
Peak pulsing current (1/8 duty f=1kHz)
Electro-optical characteristics (TA=25℃)
Parameter
Test
Condition
Value
Symbol
R
G
B
R
G
B
R
G
B
R
G
B
R
G
B
Unit
Min
Typ
Max
------620
520
460
1.8
2.8
2.8
60
300
60
635
520
460
18
35
25
------1200
500
120
------630
530
470
2.4
3.6
3.6
Wavelength at peak emission
If=20mA
λ p
Spectral half bandwidth
If=20mA
△λ
Dominant wavelength
If=20mA
λ d
Forward voltage
If=20mA
Vf
Luminous intensity
If=20mA
Iv
Viewing angle at 50% Iv
If=10mA
2θ 1/2
120
Deg
Vr=5V
Ir
10
A
Reverse current
nm
nm
nm
V
mcd
Optical characteristic curves (Red)
1.0
Spectral Radiance(Peak@625nm)
Normalized
Response
0.8
0.6
0.4
0.2
0.0
380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780
Wave Length(nm)
Forward Voltage (V)
Forward Current vs. Forward Voltage
Forward Current (mA)
Directive Characteristics
Optical characteristic curves (Green)
Spectral Radiance (Peak@525nm)
1.0
0.6
0.4
0.2
0.0
Wave Length(nm)
Forward Voltage (V)
Normalized
Response
0.8
Optical characteristic curves (Blue)
1.0
Spectral Radiance(Peak@465)
Normalized
Response
0.8
0.6
0.4
0.2
0.0
Wave Length(nm)
Forward Voltage (V)
Reflow Profile
Reflow Temp/Time
300
10 S Max.
260℃ Max.
250
230℃
4℃/S Max.
200
150~180℃
4℃/S Max.
Temperature
150
60~120 S
100
30~50 S
50
25℃
100
150
200
250
Time
300
(sec)
Notes:
1.We recommend the reflow temperature 245℃(±5℃).the maximum soldering
temperature should be limited to 260℃.
2.Don’t cause stress to the epoxy resin while it is exposed to high temperature.
3.Number of reflow process shall be 2 times or less.
Soldering iron
Basic spec is 5sec when 320℃(±20℃). If temperature is higher, time should
be shorter(+10℃ -1sec ).Power dissipation of iron should be smaller than 20W,
and temperatures should be controllable .Surface temperature of the device should
be under 350℃.
Rework
1.Customer must finish rework within 5 sec under 340℃.
2.The head of iron can not touch copper foil
3.Twin-head type is preferred.
Correct(
Mistake(
Avoid rubbing or scraping the resin by any object, during high temperature,
for example reflow solder etc.
Test circuit and handling precautions
Test circuit
R
V
LED
Handling precautions
1. Over-current-proof
Customer must apply resistors for protection; otherwise slight voltage shift
will cause big current change (Burn out will happen).
2. Storage
2.1 It is recommended to store the products in the following conditions:
Humidity: 60% R.H. Max.
Temperature : 5℃~30℃(41℉~86℉)
2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after
the package is Opened, the products should be used within a week or they
should be keeping to stored at≦20 R.H. with zip-lock sealed.
3. Baking
It is recommended to baking before soldering when the pack is unsealed
after 72hrs. The Conditions are as followings:
3.1 60±3℃ x(12~24hrs) and <5%RH, taped reel type
3.2 100±3℃ x(45min~1hr), bulk type
3.3 130±3℃ x(15~30min), bulk type
Test items and results of reliability
Operation
Sequence
Environmental
Sequence
Type
Number of
Test Item
Test Conditions
Note
Temperature Cycle
-20℃ 30min
80℃ 30min
100 cycle
0/22
Thermal Shock
-20℃ 15min
80℃ 15min
100 cycle
0/22
High Humidity Heat Cycle
30℃ 65℃
90%RH 24hrs/1cycle
10 cycle
0/22
High Temperature Storage
Ta=80℃
1000 hrs
0/22
Humidity Heat Storage
Ta=60℃
RH=90%
1000 hrs
0/22
Low Temperature Storage
Ta=-30℃
1000 hrs
0/22
Life Test
Ta=25℃
IF=20mA
1000 hrs
0/22
High Humidity Heat Life Test
60℃ RH=90%
IF=10mA
500 hrs
0/22
Low Temperature Life Test
Ta=-20℃
IF=20mA
1000 hrs
0/22
Damaged
1615 Series SMD Chip LED Lamps Packaging Specifications
Feeding Direction
Dimensions of Reel (Unit: mm)
Feeding Direction
RoHS
57.54 [2.27"]
13.30 [0.52"]
颜色标签
Lable
178.50 [7.03"]
9.40 [0.37"]
Dimensions of Tape (Unit: mm)
2.00 [0.08"]
A
0.23 [0.01"]
1.00 [0.04"]
5.25 [0.21"]
4.00 [0.16"]
1.75 [0.07"]
1.50 [ 0.06"]
8.00 [0.31"]
0.93 [0.04"]
4.00 [0.16"]
1.78 [0.07"]
A
Arrangement of Tape
Empty parts
(Min.20pcs)
Loaded parts
(LED:4000pcs)
Empty parts
(Min.40pcs)
Feeding Direction
Conclusion parts
(Min.100mm)
Introduction parts
(Min.300mm)
Notes:
1. Empty component pockets are sealed with top cover tape;
2. The maximum number of missing lamps is two;
3. The cathode is oriented towards the tape sprocket hole in accordance with
ANSI/EIA RS-481 specifications.
4. 4,000 pcs/Reel.
Packaging specifications
Moisture-proof bag
颜色标签
Reel(4,000PCS)
RoHS
RoHS
Lable
Lable
HS
Ro
La
ble
ble
La
HS
Ro
Outside box
Maximums four inside boxes
Inside box
Maximums ten reels
Notes:
Reeled products (numbers of products are 4,000pcs) packed in a seal off
moisture-proof bag along with a desiccant one by one, ten moisture-proof bag of
maximums (total maximum number of products are 40,000pcs) packed in an inside
box (about size: 240x 220x 120mm) and four inside boxes of maximums are put in
the outside box (about size: 460mm x 246mm x 250mm) Together with buffer
material, and it is packed. (Part No., Lot No., quantity should appear on the label on
the moisture-proof bag, part No. and quantity should appear on the label on
the
cardboard box.) The number of the loading steps of outside box (cardboard box)
has it to three steps.
TJ-S1615SW6TGLCCYRGB-A5 价格&库存
很抱歉,暂时无法提供与“TJ-S1615SW6TGLCCYRGB-A5”相匹配的价格&库存,您可以联系我们找货
