LUW CEUN.CE-5L6L-HNJN-1-350-R18-Z-XX 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LUW CEUN.CE
LUW CEUN.CE
OSLON ® Compact CM
Compact light source with a typical luminous flux of
100 lm at 350 mA and an operation range of 50 mA
up to 700 mA.
Applications
——Headlamps, LED & Laser & Night Vision
Features:
——Package: Ceramic package
——Chip technology: UX:3
——Typ. Radiation: 120° (Lambertian emitter)
——Color: Cx = 0.33, Cy = 0.34 acc. to CIE 1931 (● ultra white)
——Corrosion Robustness Class: 3A
——Qualifications: The product qualification test plan is based on the guidelines of AEC-Q101-REV-C,
Stress Test Qualification for Automotive Grade Discrete Semiconductors.
——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
1 Version 1.5 | 2019-10-17
LUW CEUN.CE
Ordering Information
Type
Luminous Flux 1)
IF = 350 mA
ΦV
LUW CEUN.CE-7K7L-HNJN-1
2 Version 1.5 | 2019-10-17
90 ... 159 lm
Ordering Code
Q65112A9412
LUW CEUN.CE
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
125 °C
Storage Temperature
Tstg
min.
max.
-40 °C
125 °C
Junction Temperature
Tj
max.
150 °C
Junction Temperature for short time applications*
Tj
max.
175 °C
Forward Current
TS = 25 °C
IF
min.
max.
50 mA
700 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
1000 mA
Reverse voltage 2)
TS = 25 °C
VR
max.
1.2 V
ESD withstand voltage
VESD
* The median lifetime (L70/B50) for Tj = 175°C is 100h.
3 Version 1.5 | 2019-10-17
Values
8 kV
LUW CEUN.CE
Characteristics
IF = 350 mA; TS = 25 °C
Parameter
Symbol
Chromaticity Coordinate 3)
Cx
Cy
typ.
typ.
0.33
0.34
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 350 mA
VF
min.
typ.
max.
2.75 V
2.97 V
3.25 V
Reverse voltage (ESD device)
VR ESD
min.
45 V
Reverse current
VR = 1.2 V
IR
max.
200 mA
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
max.
8.5 K / W
11.0 K / W
Electrical thermal resistance junction/solderpoint 5)
with efficiency ηe = 25 %
RthJS elec.
typ.
max.
6.4 K / W
8.3 K / W
2)
4 Version 1.5 | 2019-10-17
Values
LUW CEUN.CE
Brightness Groups
Group
Luminous Flux 1)
IF = 350 mA
min.
ΦV
Luminous Flux 1)
IF = 350 mA
max.
ΦV
Luminous Intensity 6)
IF = 350 mA
typ.
Iv
7K
90 lm
100 lm
31 cd
8K
100 lm
112 lm
35 cd
5L
112 lm
125 lm
39 cd
6L
125 lm
140 lm
44 cd
7L
140 lm
159 lm
49 cd
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 350 mA
min.
VF
Forward Voltage 4)
IF = 350 mA
max.
VF
8E
2.75 V
3.00 V
8F
3.00 V
3.25 V
5 Version 1.5 | 2019-10-17
LUW CEUN.CE
Chromaticity Coordinate Groups
3)
OHLN4807
JN
IN
HN
Chromaticity Coordinate Groups 3)
Group
Cx
Cy
Group
Cx
Cy
Group
Cx
Cy
HN
0.3127
0.3093
IN
0.3163
0.3181
JN
0.3203
0.3274
0.3255
0.3216
0.3300
0.3308
0.3349
0.3404
0.3246
0.3424
0.3298
0.3526
0.3355
0.3633
0.3096
0.3282
0.3138
0.3381
0.3186
0.3484
6 Version 1.5 | 2019-10-17
LUW CEUN.CE
Group Name on Label
Example: 5L-HN-8E
Brightness
Color Chromaticity
5L
HN
7 Version 1.5 | 2019-10-17
Forward Voltage
8E
LUW CEUN.CE
Relative Spectral Emission
6)
Φrel = f (λ); IF = 350 mA; TS = 25 °C
Φrel
LUW CEUN.CE
1.0
: Vλ
: ultra white
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
Note: Percentage of red: >5% acc. to ECE regulation
Percentage of UV: 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
17 Version 1.5 | 2019-10-17
LUW CEUN.CE
Schematic Transportation Box
8)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
200 ± 5 mm
195 ± 5 mm
18 Version 1.5 | 2019-10-17
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
Height
30 ± 5 mm
LUW CEUN.CE
Type Designation System
Special Characteristics
C:
intermediate cold white
Color coordinates according
CIE 1931/Emission color:
UW: ultra white
MW: multiphosphor white
Package Type
C: CERAMOS, OSLON
(ceramic), OSLON
Compact
L: Light
emitting
diode
L
UW
C
E
Lead / Package Properties
E:
OSLON Compact AlN based for Automotive
(Project Mini PowerLED)
Encapsulant Type / Lens Properties
U:
OSLON Compact with CLC layer ceramic
Chip Technology:
N:
high performance (>= 500µm)
P:
power performance (>= 500µm)
19 Version 1.5 | 2019-10-17
U
N
C
E
LUW CEUN.CE
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure
time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources
have a high secondary exposure potential due to their blinding effect. When looking at bright light sources
(e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials. Metal filled
materials can be affected by environments that contain traces of aggressive substances. Therefore, we
recommend that customers minimize device exposure to aggressive substances during storage, production,
and use.
For further application related information please visit www.osram-os.com/appnotes
20 Version 1.5 | 2019-10-17
LUW CEUN.CE
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
21 Version 1.5 | 2019-10-17
LUW CEUN.CE
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to
GUM with a coverage factor of k = 3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
7)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
8)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
22 Version 1.5 | 2019-10-17
LUW CEUN.CE
Revision History
Version
Date
Change
1.5
2019-10-17
Brightness Groups
23 Version 1.5 | 2019-10-17
LUW CEUN.CE
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
24 Version 1.5 | 2019-10-17
