LY T68F-U2V1-56-1-20-R18-Z 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LY T68F
LY T68F
TOPLED ® Black Surface
First SMT LED with integrated reflector. With our
great experience on SMT LED we are able to offer a
high quality product for all kind of applications.
Applications
——Electronic Equipment
——VMS
——Traffic lights
——White Goods
Features:
——Package: white PLCC-2 package, black surface, colorless clear resin
——Chip technology: Thinfilm
——Typ. Radiation: 120° (Lambertian emitter)
——Color: λdom = 590 nm (● yellow)
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)
1 Version 1.2 | 2018-05-23
LY T68F
Ordering Information
Type
Luminous Intensity 1)
IF = 20 mA
Iv
Ordering Code
LY T68F-V1AA-46-1
710 ... 1400 mcd
Q65110A7322
LY T68F-U1AA-46-1
450 ... 1400 mcd
Q65110A7730
LY T68F-T2V2-35-1
355 ... 1120 mcd
Q65110A7796
LY T68F-V1AA-56
710 ... 1400 mcd
Q65110A8502
LY T68F-V1AA-45-1
710 ... 1400 mcd
Q65110A8587
2 Version 1.2 | 2018-05-23
LY T68F
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
100 °C
Storage Temperature
Tstg
min.
max.
-40 °C
100 °C
Junction Temperature
Tj
max.
125 °C
Forward current
TS = 25 °C
IF
min.
max.
1 mA
50 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
100 mA
Reverse voltage 2)
TS = 25 °C
VR
max.
12 V
ESD withstand voltage
VESD
3 Version 1.2 | 2018-05-23
Values
2 kV
LY T68F
Characteristics
IF = 20 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
597 nm
Dominant Wavelength 3)
IF = 20 mA
λdom
min.
typ.
max.
583 nm
590 nm
595 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
18 nm
Viewing angle at 50 % IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 20 mA
VF
min.
typ.
max.
1.90 V
2.20 V
2.50 V
Reverse current 2)
VR = 12 V
IR
typ.
max.
0.01 µA
10 µA
Temperature Coefficient of Peak Wavelength
-10°C ≤ T ≤ 100°C
TCλpeak
typ.
0.12 nm / K
Temperature Coefficient of Dominant Wavelength
-10°C ≤ T ≤ 100°C
TCλdom
typ.
0.1 nm / K
Real thermal resistance junction/ambient 5), 6)
RthJA real
max.
500 K / W
Real thermal resistance junction/solderpoint 5)
RthJS real
max.
280 K / W
4 Version 1.2 | 2018-05-23
Values
LY T68F
Brightness Groups
Group
IF = 20 mA
min.
Iv
Luminous Intensity. 1)
IF = 20 mA
max.
Iv
Luminous Flux 7)
IF = 20 mA
typ.
ΦV
T2
355 mcd
450 mcd
1210 mlm
U1
450 mcd
560 mcd
1520 mlm
U2
560 mcd
710 mcd
1910 mlm
V1
710 mcd
900 mcd
2420 mlm
V2
900 mcd
1120 mcd
3030 mlm
AA
1120 mcd
1400 mcd
3780 mlm
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 20 mA
min.
VF
Forward Voltage 4)
IF = 20 mA
max.
VF
3A
1.90 V
2.05 V
3B
2.05 V
2.20 V
4A
2.20 V
2.35 V
4B
2.35 V
2.50 V
Wavelength Groups
Group
IF = 20 mA
min.
λdom
IF = 20 mA
max.
λdom
583 nm
586 nm
4
586 nm
589 nm
5
589 nm
592 nm
6
592 nm
595 nm
3
5 Version 1.2 | 2018-05-23
LY T68F
Group Name on Label
Example: AA-3-3A
Brightness
Wavelength
Forward Voltage
AA
3
3A
6 Version 1.2 | 2018-05-23
LY T68F
Relative Spectral Emission
7)
Irel = f (λ); IF = 20 mA; TS = 25 °C
Φrel
LY T68F
1,0
: Vλ
: yellow
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics
7)
Irel = f (ϕ); TS = 25 °C
LY T68F
ϕ [°]
-20°
-40°
-50°
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
0,8
0,6
-60°
-70°
-80°
-90°
-100°
7 Version 1.2 | 2018-05-23
0,4
0,2
0,0
Irel
LY T68F
Forward current
Relative Luminous Intensity
7), 8)
IF = f(VF); TS = 25 °C
IF [mA]
7), 8)
Iv/Iv(20 mA) = f(IF); TS = 25 °C
LY T68F
IV
LY T68F
100
IV(20mA)
4
80
3
60
2
40
1
VF [V]
8 Version 1.2 | 2018-05-23
10
2,8
80
2,6
60
2,4
40
2,2
1
1
1,7
IF [mA]
LY T68F
Forward Voltage
7)
Iv/Iv(25 °C) = f(Tj); IF = 20 mA
∆VF = VF - VF(25 °C) = f(Tj); IF = 20 mA
∆VF [V]
LY T68F
0,3
7)
Iv
LY T68F
2,5
Iv(25°C)
0,2
2,0
0,1
1,5
0,0
1,0
-0,1
0,5
-0,2
-0,3
-40 -20
60
80
100 120
Tj [°C]
9 Version 1.2 | 2018-05-23
0,0
-40 -20
60
80
100 120
Tj [°C]
LY T68F
Max. Permissible Forward Current
IF = f(T)
IF
OHL03044
60
mA
50
TA
TS
40
30
TA temp. ambient
TS temp. solder point
40
80 ˚C 100
T
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle; TS = 25 °C
IF = f(tp); D: Duty cycle; TS = 85 °C
OHL03045
0.12
A
D=
IF
0.10
0.08
0.06
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.04
0.02
OHL03045
0.12
A
D=
IF
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.10
0.08
0.06
0.04
tP
D= T
0.02
tP
IF
D= T
T
0 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
tp
10 Version 1.2 | 2018-05-23
tP
tP
IF
T
0 -5
tp
LY T68F
Dimensional Drawing
9)
2.1 (0.083)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
1.7 (0.067)
0.1 (0.004) (typ.)
A
3.7 (0.146)
3.3 (0.130) 4˚±1
3.4 (0.134)
3.0 (0.118)
(2.4) (0.095)
2.1 (0.083)
0.9 (0.035)
0.7 (0.028)
0.5 (0.020)
Cathode marking
1.1 (0.043)
C
0.18 (0.007)
0.12 (0.005)
0.6 (0.024)
0.4 (0.016)
GPLY6724
Approximate Weight:
34.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter then IEC
60068-2-43)
11 Version 1.2 | 2018-05-23
LY T68F
Recommended Solder Pad
9)
2.6 (0.102)
4.5 (0.177)
1.5 (0.059)
1.5 (0.059)
4.5 (0.177)
2.6 (0.102)
Padgeometrie für
verbesserte Wärmeableitung
Lötstopplack
Solder resist
Paddesign for
improved heat dissipation
Cu-Fläche > 16 mm 2
Cu-area > 16 mm 2
OHLPY970
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
9)
Fläche darf bei Verwendung von TOPLED®
elektrisch nicht beschaltet werden.
For TOPLED® assembly do not use
this area for electrical contact
Padgeometrie für
Paddesign for
3.3 (0.130)
2.3 (0.091)
11.1 (0.437)
0.8 (0.031)
1.5 (0.059)
1.1 (0.043)
3.7 (0.146)
3.3 (0.130)
Anode
0.7 (0.028)
Kathode/
Cathode
Cu Fläche /
Mo
se
3
ure
is
or .
se
is ha
Mo istist
nk
be
g
nk
-03
rd
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
life s
kin Ca
(if
ar
t.
wi
J-S
10 ba tor
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
tem ted
Ye ee urs
Sh ter
at
ed
low
uir
1
W Ho
un
Af
Ind no uir DE
1.
dy
d
e
4
ref
8
y
is
req
JE
2.
bo
e
Mo ore
tim
req
16
C/
e
es dit2b
a)
St
tim
or
is IP
mior
ed
vic
tim e
b)
g e
or
Hu
en
Flo
tim
or
De
2a kin nc
te
Flo
op
a)
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a
ve
Le
3
g
an
ve l
Le
Ba
te
ure
Le ve
ure
ist
Le
Da
ure
ist
Mo
ist ure
Mo
Mo ist
Mo
MO
TO
OP
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
16 Version 1.2 | 2018-05-23
LY T68F
Transportation Packing and Materials
9)
DE
R
18
-1
-1
+Q
P
OU
P:
44
01
C:
99
8
D/
(9
D)
210
021
34
O
H
12
(Q
)Q
TY
S S
em R
ic AM
o
nd O
uc p
to to
H
rs
NO
TC
BA
3G
5
14
2
(6
P)
NO
: 12
T
11
00
LO
(1
T)
NO
OD
M
Y
DE
-1
18
P
-1
Q
R
G
RO
UP
(G
44
01
D/
C:
(9
D)
AM
00
TY
:2
)Q
O
SR
34
NO
(X
PR
O
D
5
14 2
110 0
(Q
A
R
ic
NO
O
S
em
S
(1
T)
LO
T
NO
(6
P)
: 12
3G
BA
TC
H
H
12
o M
n O
d
u p
ct to
o
rs
M
Muster
u L
lt S
iT Y
O T6
P 76
L
E Bi
D Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
(X
PR
8
2199
2100
GR
L
el
at
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur s
d
ns
(p
or
d
Ho ururs s
de
cteg
itio
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
40 be oc
ry
tim e e
˚C
th
r
pr
ll
tim
cto
23
oo r
wi nt
tim e
l wi
fa
r
˚C
Fl oo
tim
s
at
at ale
e.
at
ica
Fl
th
oo r
th
ur
el
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
oc
ve l
vic
is
ingen
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou%
se
da
ed
ba
flo ba
Le ve
tu re
m
ba
e
al
d
Le
r
en re
re
e
re 10
ois tu
tim
se
fo
tu re
ale op se
fo >
M ois
r
se
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
rd
g
M ois
in
r-p
bla
in Fl RH g,
DM
ba
Ca
po If blath
kin
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re ty is
qu JE
2.
bo
M
or
tim e e
16
re C/
es idi 2b
r
a)
St
tim
mor
is IP
e
ed
r
oo
vic
tim
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
re
3.
b)
Fl oo
da
ba
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
Le
re
Ba
te
Le ve
tu re
Le
Da ois tu
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
OI
M TO
OP
M
Y
Barcode label
E Bi
D n1
Bi
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
352 ± 5 mm
352 ± 5 mm
33 ± 5 mm
17 Version 1.2 | 2018-05-23
OHA02044
LY T68F
Type Designation System
Wavelength
(λdom typ.)
A:
617 nm
R:
625 nm
Y:
587 nm
Emission Color
amber
red
yellow
Color coordinates according
CIE 1931/Emission color:
W:
white
CY: color on demand yellow
Package Type
T:
TOPLED
L:
Light
emitting
diode
A
L
T
6
Lead / Package Properties
6:
folded leads
W:
folded leads and UX:3, Ag-LF,
w/o TO2 jetting
Encapsulant Type / Lens Properties
8:
black surface, epoxy resin
T:
Black surface, silicone resin
Chip Technology:
6:
standard InGaAlP
B:
HOP 2000
F:
Thinfilm InGaAlP
G:
ThinGaN (Thinfilm InGaN)
(Subcon: Sapphire)
18 Version 1.2 | 2018-05-23
8
B
LY T68F
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the LED specified in this
data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this LED contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize LED exposure to aggressive substances during storage, production, and use. LEDs that showed visible discoloration when tested using the described tests above did
show no performance deviations within failure limits during the stated test duration. Respective failure limits
are described in the IEC60810.
For further application related informations please visit www.osram-os.com/appnotes
19 Version 1.2 | 2018-05-23
LY T68F
Disclaimer
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS webside.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to
invoice you for any costs incurred.
Product safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.
20 Version 1.2 | 2018-05-23
LY T68F
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k =
3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16 mm² per pad)
7)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data
or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical
data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical
improvements, these typ. data will be changed without any further notice.
8)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit.
9)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
10)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
21 Version 1.2 | 2018-05-23
LY T68F
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
22 Version 1.2 | 2018-05-23
