CXA1520-0000-000N00P240F 数据手册
CLD-DS77 Rev 3F
Product family data sheet
Cree® XLamp® CXA1520 LED
Product Description
features
Table of Contents
The XLamp® CXA1520 LED is Cree’s first
• Available in 4-step, 3‑step and 2-step
Characteristics.............................................2
High Density (HD) LED array, featuring
EasyWhite bins at 2700 K, 3000 K,
Operating Limits...........................................2
a 9‑mm optical source and enabling
3500 K, 4000 K and 5000 K CCT
Flux Characteristics, EasyWhite® Order
lighting manufacturers to create a new
• Available in ANSI white bins at
Codes and Bins............................................3
Flux Characteristics, ANSI White Order
generation of products that delivers the
same intensity and light quality as 39‑W
• Available in 70-, 80-, 90- and
Codes and Bins............................................5
ceramic metal halide (CMH) at up to 50
93‑minimum CRI options
Relative Spectral Power Distribution..........6
percent lower power. The new HD class
• Forward voltage option: 36‑V class
Electrical Characteristics.............................6
of CXA arrays provide unrivaled lumen
• 85 °C binning and characterization
Relative Luminous Flux................................7
density that can reduce system cost for
• Maximum drive current: 900 mA
Typical Spatial Distribution..........................8
the next generation of LED spotlights.
• 115° viewing angle, uniform
Performance Groups - Brightness..............8
chromaticity profile
Performance Groups - Chromaticity...........9
The CX Family LED Design Guide
• Top-side solder connections
Cree EasyWhite® Bins Plotted on the
provides basic information on the
• Thermocouple attach point
1931 CIE Color Space............................... 11
requirements to use the CXA1520 LED
• NEMA SSL-3 2011 standard flux bins
Cree ANSI White Bins Plotted on the
successfully in luminaire designs.
• RoHS and REACh compliant
1931 CIE Color Space............................... 12
• UL recognized component
Bin and Order Code Formats.................... 13
(E349212)
Mechanical Dimensions........................... 13
Thermal Design......................................... 14
Notes......................................................... 15
www.cree.com/Xlamp
Packaging.................................................. 16
Copyright © 2013-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and
EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLamp ® CXA1520 LED
Characteristics
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
900*
Reverse current
mA
0.1
Forward voltage (@ 500 mA, 85 °C)
V
Forward voltage (@ 500 mA, 25 °C)
V
35
42
Refer to the Operating Limits section.
Operating Limits
The maximum current rating of the CXA1520 is dependent on the case temperature (Tc) when the LED has reached thermal equilibrium
under steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal
interface material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions
section on page 13 for the location of the Tc measurement point.
CXA1520
1000
800
If (mA)
600
CXA1520
400
200
50
75
100
125
150
Case Temperature (°C)
Copyright © 2013-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a
2
XLamp ® CXA1520 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 500 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXA1520 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 13).
Nominal
CCT
CRI
Min
70
Minimum Luminous Flux
Typ
75
2-Step
90
70
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P2
1830
2028
P4
1965
2177
Q2
2100
2327
CXA1520-0000000N00Q250H
N4
1710
1895
CXA1520-0000000N0HN450H
P2
1830
2028
P4
1965
2177
CXA1520-0000000N0HP450H
CXA1520-0000000N0HP450G
CXA1520-0000000N0HP450F
M4
1485
1645
CXA1520-0000000N0UM450H
CXA1520-0000000N0UM450G
CXA1520-0000000N0UM450F
N2
1590
1762
CXA1520-0000000N0UN250H
N4
1710
1895
CXA1520-0000000N00N440H
P2
1830
2028
P4
1965
2177
CXA1520-0000000N00P440H
N2
1590
1762
CXA1520-0000000N0HN240H
N4
1710
1895
P2
1830
2028
CXA1520-0000000N0HP240H
CXA1520-0000000N0HP240G
CXA1520-0000000N0HP240F
M2
1380
1587
CXA1520-0000000N0UM240H
CXA1520-0000000N0UM240G
CXA1520-0000000N0UM240F
M4
1485
1645
CXA1520-0000000N0UM440H
N2
1590
1762
CXA1520-0000000N00N235H
N4
1710
1895
P2
1830
2028
CXA1520-0000000N00P235H
CXA1520-0000000N00P235G
CXA1520-0000000N00P235F
K4
1290
1484
CXA1520-0000000N0YK435H
CXA1520-0000000N0YK435G
CXA1520-0000000N0YK435F
M2
1380
1587
95
75
Group
90
80
50H
50H
50H
95
3500 K
93
40H
40H
40H
95
Order Code
Group
Order Code
Group
CXA1520-0000000N00P250H
4000 K
80
4-Step
Group
5000 K
80
3-Step
35H
35H
CXA1520-0000000N00P250F
CXA1520-0000000N00P450H
CXA1520-0000000N0HP250H
50F
CXA1520-0000000N00N435H
CXA1520-0000000N0YM235H
CXA1520-0000000N00P450F
CXA1520-0000000N00Q250F
CXA1520-0000000N0HN450G
50G
50G
CXA1520-0000000N0HP250G
CXA1520-0000000N0UN250G
CXA1520-0000000N0HN450F
50F
50F
CXA1520-0000000N0HP250F
CXA1520-0000000N0UN250F
CXA1520-0000000N00N440F
CXA1520-0000000N00P240H
CXA1520-0000000N0HN440H
Order Code
40F
CXA1520-0000000N00P240F
CXA1520-0000000N00P440F
CXA1520-0000000N0HN240G
40G
40G
CXA1520-0000000N0HN440G
CXA1520-0000000N0UM440G
CXA1520-0000000N0HN240F
40F
40F
CXA1520-0000000N00N235G
35G
35G
CXA1520-0000000N00N435G
CXA1520-0000000N0YM235G
CXA1520-0000000N0HN440F
CXA1520-0000000N0UM440F
CXA1520-0000000N00N235F
35F
35F
CXA1520-0000000N00N435F
CXA1520-0000000N0YM235F
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 15).
Cree XLamp CXA1520 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
3
XLamp ® CXA1520 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 500 mA, TJ = 85 °C) - Continued
Nominal
CCT
CRI
Min
Typ
80
3000 K
93
80
95
2700 K
93
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
N2
1590
1762
2-Step
Group
30H
Order Code
CXA1520-0000000N00N230H
3-Step
Group
30G
Order Code
CXA1520-0000000N00N230G
Group
30F
Order Code
CXA1520-0000000N00N230F
N4
1710
1895
CXA1520-0000000N00N430H
K2
1200
1380
CXA1520-0000000N0YK230H
K4
1290
1484
M2
1380
1587
CXA1520-0000000N0YM230H
CXA1520-0000000N0YM230G
CXA1520-0000000N0YM230F
M4
1485
1645
CXA1520-0000000N00M427H
CXA1520-0000000N00M427G
CXA1520-0000000N00M427F
N2
1590
1762
N4
1710
1895
CXA1520-0000000N00N427H
CXA1520-0000000N00N427G
CXA1520-0000000N00N427F
J4
1120
1288
CXA1520-0000000N0YJ427H
CXA1520-0000000N0YJ427G
CXA1520-0000000N0YJ427F
K2
1200
1380
95
30H
27H
27H
CXA1520-0000000N0YK430H
CXA1520-0000000N00N227H
CXA1520-0000000N0YK227H
CXA1520-0000000N00N430G
4-Step
CXA1520-0000000N0YK230G
30G
27G
27G
CXA1520-0000000N0YK430G
CXA1520-0000000N00N227G
CXA1520-0000000N0YK227G
CXA1520-0000000N00N430F
CXA1520-0000000N0YK230F
30H
27F
27F
CXA1520-0000000N0YK430F
CXA1520-0000000N00N227F
CXA1520-0000000N0YK227F
Notes
4
XLamp ® CXA1520 LED
Flux Characteristics, ANSI White Order Codes and Bins (If = 500 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
5000 K
80
4000 K
70
75
Chromaticity Regions
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P2
1830
2028
P4
1965
2177
Q2
2100
2327
CXA1520-0000-000N00Q20E3
N4
1710
1895
CXA1520-0000-000N0HN40E3
P2
1830
2028
P4
1965
2177
CXA1520-0000-000N0HP40E3
N4
1710
1895
CXA1520-0000-000N00N40E5
P2
1830
2028
P4
1965
2177
CXA1520-0000-000N00P20E3
3A0, 3B0, 3C0, 3D0, 50F
3A0, 3B0, 3C0, 3D0,50F
5A0, 5B0, 5C0, 5D0, 40F
CXA1520-0000-000N00P40E3
CXA1520-0000-000N0HP20E3
CXA1520-0000-000N00P20E5
CXA1520-0000-000N00P40E5
Notes
5
XLamp ® CXA1520 LED
Relative Spectral Power Distribution - White, Hot Binned, Baby
The following graph is the result of a series of pulsed measurements at 500 mA and TJ = 85 °C.
100%
90%
80%
70%
5000 K, 70 CRI
60%
4000 K, 70 CRI
50%
3000 K, 80 CRI
40%
3000 K, 93 CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
The following graph is the result of a series of steady-state measurements.
39
38
Voltage (V)
37
Tc = 25 °C
Tc = 55 °C
36
Tc = 85 °C
Tc = 105 °C
35
34
33
100
200
300
400
500
600
700
800
900
Current (mA)
6
XLamp ® CXA1520 LED
The relative luminous flux values provided below are the ratio of:
• Measurements of CXA1520 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 500 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 105 °C, IF = 700 mA, the relative luminous flux ratio is 120% in the chart below. A CXA1520
LED that measures 2100 lm during binning will deliver 2520 lm (2100 * 1.2) at steady-state operation of Tc = 105 °C, IF = 700 mA.
200%
180%
160%
140%
Tc = 25 °C
120%
Tc = 55 °C
100%
Tc = 85 °C
80%
Tc = 105 °C
60%
40%
20%
0%
100
200
300
400
500
600
700
800
900
Current (mA)
7
XLamp ® CXA1520 LED
Far Field
Relative Luminous Intensity
100%
80%
60%
40%
20%
-90
-70
-50
-30
0%
-10
10
30
50
70
90
Angle (º)
Performance Groups - Brightness (If = 500 mA, Tj = 85 °C)
XLamp CXA1520 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
J2
1040
1120
J4
1120
1200
K2
1200
1290
K4
1290
1380
M2
1380
1485
M4
1485
1590
N2
1590
1710
N4
1710
1830
P2
1830
1965
P4
1965
2100
Q2
2100
2260
Q4
2260
2420
8
XLamp ® CXA1520 LED
Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CXA1520 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
50H
40H
35H
30H
27H
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3429
0.3507
0.3434
0.3571
0.3475
0.3604
0.3469
0.3539
0.3784
0.3741
0.3804
0.3818
0.3867
0.3857
0.3844
0.3778
0.4030
0.3857
0.4061
0.3941
0.4132
0.3976
0.4099
0.3890
0.4291
0.3973
0.4333
0.4062
0.4395
0.4084
0.4351
0.3994
0.4528
0.4046
0.4578
0.4138
0.4638
0.4152
0.4586
0.4060
EasyWhite Color Temperatures – 3-Step Ellipse
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
40G
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
Bin Code
CCT
50G
Center Point
9
XLamp ® CXA1520 LED
Performance Groups - Chromaticity (Tj = 85 °C) - cONTINUED
EasyWhite Color Temperatures – 4-Step
Code
50F
40F
35F
30F
27F
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3407
0.3459
0.3415
0.3586
0.3499
0.3654
0.3484
0.3521
0.3744
0.3685
0.3782
0.3837
0.3912
0.3917
0.3863
0.3758
0.3981
0.3800
0.4040
0.3966
0.4186
0.4037
0.4116
0.3865
0.4242
0.3919
0.4322
0.4096
0.4449
0.4141
0.4359
0.3960
0.4475
0.3994
0.4573
0.4178
0.4695
0.4207
0.4589
0.4021
ANSI White Bins
Code
CCT
Bin
Code
3A0
3B0
0E3
5000 K
3C0
3D0
ANSI White Bins
x
y
Code
CCT
Bin
Code
x
y
.3371
.3490
.3670
.3578
.3451
.3554
.3702
.3722
.3440
.3427
.3825
.3798
5A0
.3366
.3369
.3783
.3646
.3376
.3616
.3702
.3722
.3463
.3687
.3736
.3874
.3451
.3554
.3869
.3958
.3371
.3490
.3825
.3798
.3463
.3687
.3825
.3798
.3551
.3760
.3869
.3958
.3533
.3620
.4006
.4044
.3451
.3554
.3950
.3875
.3451
.3554
.3783
.3646
.3533
.3620
.3825
.3798
.3515
.3487
.3950
.3875
.3440
.3427
.3898
.3716
5B0
0E5
4000 K
5C0
5D0
10
XLamp ® CXA1520 LED
Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.44
ANSI C78.377 Quadrangle
2700 K
EasyWhite 4-Step
0.43
3000 K
EasyWhite 3-Step
EasyWhite 2-Step
0.42
3500 K
0.41
4000 K
CCy
0.40
4500 K
0.39
5000 K
0.38
0.37
0.36
0.35
0.34
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.33
CCx
11
XLamp ® CXA1520 LED
Cree ANSI White Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.42
3500 K
0.41
4000 K
0.40
4500 K
5C
0.39
5B
5000 K
0.38
CCy
5D
0.37
5700 K
0.36
5A
3C
3B
3D
0.35
3A
0.34
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.33
CCx
12
XLamp ® CXA1520 LED
Bin codes and order codes are configured as follows:
Order Code Bin Code
Series = CXA15
Series = CXA15
Internal code
Chromaticity bin
CRI Specification
0 = Standard CRI
H = 80 min CRI
U = 90 min CRI
Y = 93 min CRI
Vf class
N0 = 36-V class
Internal code
6
5
4
SSSSSCC-WWW-FF-GGR-AAAAA
NOTICE
CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION
SSSSSCC-HHHH-HHHGGRNNNNN
CONTAINED WITHIN ARE THE PROPRIETARY AND
CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT
MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY
UNAUTHORIZED PERSON
WITHOUT
WRITTEN CONSENT
Kit THE
code
OF CREE INC.
D
3
Vf class
N0 = 36-V class
CRI Specification
B = 70 min CRI
H = 80 min CRI
U = 90 min CRI
Y = 93 min CRI
Performance class
Flux bin
REV
Performance class
Dimensions are in mm.
15.85
± 0.2
Tolerances unless otherwise
specified: ±.13
1.2
C
2.6
x° ±1°
1.3
1520N
1.2
Meaning of 1520N
2.6
1520N = 36‑V CXA1520
15.85
± 0.2
1.0 ± .15
Tc
3.3
OPTICAL
REFERENCE
5.5
R.5
4X
8.90
± 0.2
B
10.50
± 0.2
2.6
1.2
2.6
OPTICAL REFERENCE
0.55 ± 0.1
1.2
TOLERANCE U
DIMENSIONS
.X ±
.10
.XX ±
.03
.XXX ± .010
X°
1°
UNLESS OTHERWISE
DIMENSIONS ARE
MILLIMETERS AND AF
TOLERANCE
Copyright © 2013-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree , XLamp and EasyWhite are registered trademarks and the Cree logo is.XX
a ± UNLESS
.25
.XXX± .125
X° ± .5°
THIRD ANGLE PROJECTION
FOR SHEET METAL PA
13
.X ± 1.5
.XX ± .75
.XXX± .25
X° ± .5°
A
XLamp ® CXA1520 LED
Thermal Design
The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure the CXA LED is being operated within its designed limits. Please refer to page 2 for the Operating Limit specification.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to
ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please
refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface
materials (TIM) and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling document. The CX
Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXA LEDs successfully in luminaire designs.
To keep the CXA1520 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXA1520
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
100
200
300
400
500
600
700
800
900
Current (mA)
14
XLamp ® CXA1520 LED
Notes
Measurements
The luminous flux, radiant power, chromaticity and CRI measurements in this document are binning specifications only and solely
represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors
that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are
provided for informational purposes only and are not intended as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect
the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Documentation sections of www.cree.com.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/
UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
15
XLamp ® CXA1520 LED
Packaging
6
Cree CXA1520 LEDs are packaged
in trays of 20. Five trays are4 sealed in an anti-static bag and
placed inside a carton, for a total
of 100
5
3
2
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
NOTICE
ED PERSON WITHOUT
THE WRITTEN CONSENT
Dimensions are in inches.
Tolerances: ±.13
x° ±1°
5.875
4
5
6
3
5
2
R .375
4
1
3
2
1
NOTICE
NSENT
ED PERSON WITHOUT
THE WRITTEN CONSENT
5.875
.875
5.875
R .375
R .375
5.875
.875
.875
5.875
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
PATENT LABEL IS LOCATED
ON UNDERSIDE OF COVER
PATENT
LABEL
ISBIN
LOCATED
LABEL WITH
CREE
CODE,
QUANTITY, LOT
ON
UNDERSIDE
OF CARTON
TH CREE BIN
ANTITY, LOT #
ON UNDERSIDE .875
OF COVER
BAG
.38
.875
BAG
.38
.875
BAG
.38
LABEL WITH CREE BIN
L IS LOCATED
IDE OF COVER
LABEL WITH CREE BIN
LABEL WITH CREE BIN
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE BIN
DIMENSIONS ARE IN
LABEL WITH CREE BIN
6
5
6
WITH CREE
BIN
QUANTITY, LOT #
5
3.X
.XX
.XXX ±
X°
UNLESS OTHERWISE
SPECIFIED
3
DIMENSIONS ARE IN
notice.
Cree
, XLamp
TOLERANCE
UNLESS
SPECIFIED:and
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
DATE
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
0.1
.05
.005
1 °
.06
.03
.010
2 °
DRAWN BY
DATE
DATE
APPROVED
DATE
DATE
FOR SHEET METAL
PARTS ONLYDATE
APPROVED
.X
.06
.XX
.03
MATERIAL
.XXX ±
.010
X°
2 °
.X
.XX
.XXX ±
X°
4
4
.X
DRAWN BY
.XX
.XXX ±
CHECK ±
X°
DRAWN BY
CHECK
TITLE
CXA15
Phone (919) 361-
Fax (919) 313-530
SIZE
C
CXA15XX_DATASHEET
TITLE
SCALE
SIZE
SCALE
C
2
DATE
APPROVED
DATE
CXA15XX_DATASHEET_BAG2013
0.500
SHEET
OF
1 Drive
4600 Silicon
Durham, N.C 27703
Phone (919) 361-4770
Fax (919) 313-5303
TITLE
CXA15XX_DATASHEET
16
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
CXA
0.500
DRAWING NO.
2
CHECK
DRAW
DATE
4600 Silicon Drive
Durham, N.C 277
MATERIAL
DRAWING NO.
