ESMM161VSD272MA45T
ESMM161VSD272MA45T
    NCC(贵弥功)
    径向,Can-卡入式
    2700 µF 160 V 铝电解电容器 径向,Can - 卡入式 92 毫欧 @ 120Hz 85°C 时为 3000 小时
ESMM161VSD272MA45T 数据手册
SMM SERIES Engineering Bulletin Mar 07 SMM Series 䡲 The SMM series is a high voltage, long life snap-in capacitor series that offers downsized versions of the SMH series. Compared to our SMH series, the SMM capacitors have a longer rated lifetime of 3,000 hours with the full rated ripple current applied and are also one case size smaller than equivalently rated SMH capacitors. These characteristics allow downsizing for many power supplies and will provide better reliability due to increased life. The SMM capacitors are available in 2 or 4-pin snap-in styles and 4-pin straight terminals. The SMM series capacitors are RoHS compliant offering Pb-free construction. The standard SMM series capacitors are not solvent proof. Refer to guidelines and precautions on the website for usage and installation conditions recommended for United Chemi-Con products. Summary of Specifications 䡲 PC board 2 or 4-pin snap-in; optional 4-pin straight terminals. 䡲 Capacitance range: 47 to 3,300μF. 䡲 Voltage range: 160 to 450VDC. 䡲 Category temperature range: ⴑ25ⴗC to ⴐ85ⴗC. 䡲 Leakage current: 3 CV (μA) maximum after 5 minutes at ⴐ20ⴗC. 䡲 Standard capacitance tolerance: ⴣ20% 䡲 Nominal case size (DⴒL): 20ⴒ25mm to 35ⴒ50mm. 䡲 Rated lifetime: 3,000 hours at ⴐ85ⴗC with the rated ripple current applied. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 1/ 11 SMM SNAP MOUNT 85ⴗC Snap Mount 䡲 Downsize 䡲 High Voltage 䡲 Long Life 䡲 RoHS Compliant 䡲 ⴐ85ⴗC Maximum Temperature Engineering Bulletin Mar 07 SMM Series SMM Specifications - Snap Mount Item Characteristics Category Temperature Range ⴑ25 to ⴐ85ⴗC Rated Voltage Range 160 to 450VDC Capacitance Range 47 to 3,300␮F Capacitance Tolerance ⴣ20% ( M ) at ⴐ20ⴗC, 120Hz Leakage Current I ≤ 3 CV (␮A ) after 5 minutes at ⴐ20ⴗC. Where I = Max. leakage current (␮A ), C = Nominal capacitance (␮F ) and V = Rated voltage ( V ) Dissipation Factor ( Tan ␦) At ⴐ20ⴗC, 120Hz Rated Voltage ( V ) 160 - 400 420 - 450 0.15 0.20 Tan ␦ ( DF ) Max. Low Temperature Characteristics At 120Hz, impedance ( Z ) ratio between the ⴑ25ⴗC value and ⴐ20ⴗC value shall not exceed the values given below. Rated Voltage ( V ) 160 - 400 420 - 450 4 8 Z (ⴑ25ⴗC ) / Z (ⴐ20ⴗC ) Rated Ripple Current Multipliers Ambient Temperature (ⴗC ) ⴐ45ⴗC ⴐ60ⴗC ⴐ70ⴗC ⴐ85ⴗC 1.73 1.50 1.32 1.00 SMM SNAP MOUNT 85ⴗC Frequency (Hz ) Endurance (Load Life) DC Rated Voltage 50Hz 120Hz 300Hz 1kHz 10kHz 50kHz 160 - 250V 0.81 1.00 1.17 1.32 1.45 1.50 315 - 450V 0.77 1.00 1.16 1.30 1.41 1.43 The following specifications shall be satisfied when the capacitors are restored to ⴐ20ⴗC after subjecting them to DC voltage for 3,000 hours at ⴐ85ⴗC with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ ⴣ20% of initial measured value Tan ␦ ( DF ) : ≤ 200% of initial specified value Leakage current : ≤ initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to ⴐ20ⴗC after exposing them for 1,000 hours at ⴐ85ⴗC without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change: ≤ ⴣ15% of initial measured value Tan ␦ ( DF ) : ≤ 150% of initial specified value Leakage current : ≤ initial specified value 2 / 11 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 SMM Series Diagram of Dimensions - Snap Mount Unit: mm Snap Mount Types VSN Ø 20~ Ø 35; VNN Ø 22~ Ø 35 See Pin Detail Pb-free PVC Sleeve Type VRD Ø 35 See Pin Detail Pb-free PVC Sleeve PC board pin-out C* A* DⳭ1 PC board pin-out B 30° D35Ⳮ1 10 2-2x ** Vent ** Vent LⳲ2 2-4x LⳲ2 Type VQD Ø 35 Type VND Ø 35 See Pin Detail Pb-free PVC Sleeve PC board pin-out B See Pin Detail Pb-free PVC Sleeve C* A* 22.5 2-4x LⳲ2 30° W1 Edge of can W1 W W P Edge of can Edge of can P1 W W W1 W2 1.5ⴣ0.2 1.0 1.0 Type Straight Pin (VR) Standoff Pin (VQ) P 5.50ⴣ1.0 3.75ⴣ1.0 P1 — 2.0 max. W W1 1.5ⴣ0.1 0.7 CAUTION: * Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the PC board, but be electrically isolated from the negative or positive terminal. ** Vent may be located either on the bottom or side of the can. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 3 / 11 SMM VQ Standoff Pin W1 P P 4.0ⴣ0.5 3.5ⴣ0.5 5.8ⴣ1.0 5.8ⴣ1.0 SNAP MOUNT 85ⴗC VR & VQ Pin Dimensions P Type VSN Ø 20 - Ø 30 VSN Ø 35 VNN Ø 22 - Ø 35 VND Ø 35 22.5 2-4x LⳲ2 VR Straight Pin W2 C* D35Ⳮ1 ** Vent VS & VN Pin Dimensions PC board pin-out B A* 30° D35Ⳮ1 ** Vent 22.5 Engineering Bulletin Mar 07 SMM Series Part Numbering System for SMM Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 SMM SNAP MOUNT 85ⴗC E S MM 4 0 1 V S N 5 6 1 M A 4 0 T 9 Supplement Code. Field 18. All construction options listed have Sn100% terminal plating. S = PET sleeve without end disk. W = PET sleeve with end disk. M = Pb-free PVC sleeve without end disk. T = Pb-free PVC sleeve with end disk. 8 Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. N = Ø 20mm P = Ø 22mm Q = Ø 25.4mm R = Ø 30mm A = Ø 35mm The double digit length code is inserted in fields 16 and 17. 20 = 20mm 25 = 25mm 30 = 30mm 35 = 35mm 40 = 40mm 45 = 45mm 50 = 50mm 7 Capacitance Tolerance. Field 14. M = ⴣ20% 6 Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10␮F or more. R indicates the decimal point for capacitance less than 10␮F (e.g. 5R6 = 5.6␮F; 560 = 56␮F; 561 = 560␮F; 562 = 5,600␮F; 563 = 56,000␮F ). 5 Dummy Terminals. Field 10. N = No dummy terminals. D = 2 dummy terminals. 4 Terminal Type. Fields 8 and 9. VS = Snap-in pins, 4.0mm in length, 3.5mm for Ø35 only. VN = Snap-in pins, 5.8mm in length. VR = Straight pins. VQ = Straight standoff pins. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 4R0 = 4.0VDC; 400 = 40VDC; 401 = 400VDC). Rule Exception: Coding for rated voltage 315VDC = 3B1. 3 4 / 11 2 Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. 1 Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 160 Volts 200 Volts Surge Global Part Number† Nominal Case Size* DⴒL ( mm ) Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz ESMM161VSN271MN25T ESMM161VSN331MN25T ESMM161VSN391MN30T ESMM161VSN471MN30T ESMM161VSN561MN35T ESMM161VSN681MN40T ESMM161VSN821MN45T ESMM161VSN271MP20T ESMM161VSN391MP25T ESMM161VSN471MP30T ESMM161VSN561MP30T ESMM161VSN681MP35T ESMM161VSN821MP40T ESMM161VSN102MP45T ESMM161VSN122MP50T ESMM161VSN391MQ20T ESMM161VSN471MQ25T ESMM161VSN561MQ25T ESMM161VSN681MQ30T ESMM161VSN821MQ30T ESMM161VSN102MQ35T ESMM161VSN122MQ40T ESMM161VSN152MQ50T ESMM161VSN561MR20T ESMM161VSN681MR25T ESMM161VSN821MR25T ESMM161VSN102MR30T ESMM161VSN122MR30T ESMM161VSN152MR35T ESMM161VSN182MR40T ESMM161VSN222MR50T ESMM161VSN681MA20T ESMM161VSN821MA20T ESMM161VSN102MA25T ESMM161VSN122MA25T ESMM161VSN152MA30T ESMM161VSN182MA35T ESMM161VSN222MA40T ESMM161VSN272MA45T ESMM161VSN332MA50T 20ⴒ25 20ⴒ25 20ⴒ30 20ⴒ30 20ⴒ35 20ⴒ40 20ⴒ45 22ⴒ20 22ⴒ25 22ⴒ30 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 22ⴒ50 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ50 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ50 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 35ⴒ50 N25 N25 N30 N30 N35 N40 N45 P20 P25 P30 P30 P35 P40 P45 P50 Q20 Q25 Q25 Q30 Q30 Q35 Q40 Q50 R20 R25 R25 R30 R30 R35 R40 R50 A20 A20 A25 A25 A30 A35 A40 A45 A50 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.921 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.166 0.444 0.366 0.303 0.249 0.207 0.166 0.138 0.113 0.366 0.303 0.249 0.207 0.166 0.138 0.113 0.092 0.075 1.28 1.55 1.63 1.9 2.14 2.35 2.64 1.3 1.63 1.86 2.15 2.35 2.68 3.02 3.47 1.62 1.86 2.15 2.33 2.65 3.0 3.43 3.96 2.05 2.33 2.64 2.96 3.41 3.96 4.31 4.96 2.26 2.49 3.13 3.4 3.94 4.28 4.96 5.57 6.21 270 330 390 470 560 680 820 220 330 390 470 560 680 820 1,000 330 470 ESMM181VSN271MN25T ESMM181VSN331MN30T ESMM181VSN391MN30T ESMM181VSN471MN35T ESMM181VSN561MN40T ESMM181VSN681MN45T ESMM181VSN821MN50T ESMM181VSN221MP20T ESMM181VSN331MP25T ESMM181VSN391MP25T ESMM181VSN471MP30T ESMM181VSN561MP35T ESMM181VSN681MP35T ESMM181VSN821MP40T ESMM181VSN102MP50T ESMM181VSN331MQ20T ESMM181VSN471MQ25T 20ⴒ25 20ⴒ30 20ⴒ30 20ⴒ35 20ⴒ40 20ⴒ45 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ25 22ⴒ30 22ⴒ35 22ⴒ35 22ⴒ40 22ⴒ50 25.4ⴒ20 25.4ⴒ25 N25 N30 N30 N35 N40 N45 N50 P20 P25 P25 P30 P35 P35 P40 P50 Q20 Q25 0.921 0.753 0.638 0.529 0.444 0.366 0.303 1.13 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.753 0.529 1.29 1.77 1.84 1.91 2.15 2.41 2.72 1.18 1.77 1.84 1.91 2.25 2.48 2.86 3.1 1.49 2.08 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 5 / 11 SMM 270 330 390 470 560 680 820 270 390 470 560 680 820 1,000 1,200 390 470 560 680 820 1,000 1,200 1,500 560 680 820 1,000 1,200 1,500 1,800 2,200 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 SNAP MOUNT 85ⴗC 180 Volts 225 Volts Surge Capacitance (μF ) Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 180 Volts SMM SNAP MOUNT 85ⴗC 225 Volts Surge 200 Volts 250 Volts Surge Capacitance (μF ) Global Part Number† Nominal Case Size* DⴒL ( mm ) Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 560 680 820 1,000 1,200 470 680 820 1,000 1,200 1,500 1,800 680 1,000 1,200 1,500 1,800 2,200 2,700 ESMM181VSN561MQ25T ESMM181VSN681MQ30T ESMM181VSN821MQ35T ESMM181VSN102MQ40T ESMM181VSN122MQ45T ESMM181VSN471MR20T ESMM181VSN681MR25T ESMM181VSN821MR25T ESMM181VSN102MR30T ESMM181VSN122MR35T ESMM181VSN152MR40T ESMM181VSN182MR45T ESMM181VSN681MA20T ESMM181VSN102MA25T ESMM181VSN122MA30T ESMM181VSN152MA35T ESMM181VSN182MA35T ESMM181VSN222MA40T ESMM181VSN272MA50T 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ45 35ⴒ20 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ35 35ⴒ40 35ⴒ50 Q25 Q30 Q35 Q40 Q45 R20 R25 R25 R30 R35 R40 R45 A20 A25 A30 A35 A35 A40 A50 0.444 0.366 0.303 0.249 0.207 0.529 0.366 0.303 0.249 0.207 0.166 0.138 0.366 0.249 0.207 0.166 0.138 0.113 0.092 2.25 2.5 2.75 3.06 3.63 1.88 2.46 2.69 3.1 3.55 4.1 4.55 2.26 2.98 3.49 4.02 4.54 4.83 5.3 220 270 330 390 470 560 680 220 270 330 390 470 560 680 820 1,000 270 330 390 470 560 680 820 1,000 1,200 390 470 560 680 820 1,000 1,200 1,500 1,800 470 560 680 820 1,000 ESMM201VSN221MN25T ESMM201VSN271MN25T ESMM201VSN331MN30T ESMM201VSN391MN35T ESMM201VSN471MN35T ESMM201VSN561MN40T ESMM201VSN681MN50T ESMM201VSN221MP20T ESMM201VSN221MP25T ESMM201VSN331MP25T ESMM201VSN391MP30T ESMM201VSN471MP30T ESMM201VSN561MP35T ESMM201VSN681MP40T ESMM201VSN821MP45T ESMM201VSN102MP50T ESMM201VSN271MQ20T ESMM201VSN331MQ20T ESMM201VSN391MQ25T ESMM201VSN471MQ25T ESMM201VSN561MQ30T ESMM201VSN681MQ30T ESMM201VSN821MQ35T ESMM201VSN102MQ40T ESMM201VSN122MQ45T ESMM201VSN391MR20T ESMM201VSN471MR20T ESMM201VSN561MR25T ESMM201VSN681MR25T ESMM201VSN821MR30T ESMM201VSN102MR35T ESMM201VSN122MR35T ESMM201VSN152MR45T ESMM201VSN182MR50T ESMM201VSN471MA20T ESMM201VSN561MA20T ESMM201VSN681MA20T ESMM201VSN821MA25T ESMM201VSN102MA30T 20ⴒ25 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ35 20ⴒ40 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ25 22ⴒ30 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 22ⴒ50 25.4ⴒ20 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ35 30ⴒ45 30ⴒ50 35ⴒ20 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ30 N25 N25 N30 N35 N35 N40 N50 P20 P25 P25 P30 P30 P35 P40 P45 P50 Q20 Q20 Q25 Q25 Q30 Q30 Q35 Q40 Q45 R20 R20 R25 R25 R30 R35 R35 R45 R50 A20 A20 A20 A25 A30 1.13 0.921 0.753 0.638 0.529 0.444 0.366 1.13 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.166 0.138 0.529 0.444 0.366 0.303 0.249 1.19 1.39 1.56 1.74 2.03 2.18 2.48 1.18 1.37 1.51 1.73 1.97 2.18 2.48 2.81 3.28 1.35 1.49 1.71 1.95 2.15 2.48 2.79 3.28 3.61 1.71 1.88 2.15 2.48 2.8 3.15 3.61 4.13 4.6 1.88 2.05 2.36 2.83 3.26 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 6 / 11 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 200 Volts 250 Volts Surge Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 1,200 1,500 1,800 2,200 ESMM201VSN122MA30T ESMM201VSN152MA35T ESMM201VSN182MA40T ESMM201VSN222MA45T 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 A30 A35 A40 A45 0.207 0.166 0.138 0.113 3.57 4.06 4.59 5.25 220 270 330 390 470 560 180 270 330 390 470 560 680 270 330 390 470 560 680 820 1,000 330 390 470 560 680 820 1,000 1,200 1,500 390 470 560 680 820 1,000 1,200 1,500 1,800 ESMM221VSN221MN25T ESMM221VSN271MN30T ESMM221VSN331MN35T ESMM221VSN391MN40T ESMM221VSN471MN45T ESMM221VSN561MN50T ESMM221VSN181MP20T ESMM221VSN271MP25T ESMM221VSN331MP30T ESMM221VSN391MP35T ESMM221VSN471MP35T ESMM221VSN561MP40T ESMM221VSN681MP45T ESMM221VSN271MQ20T ESMM221VSN331MQ25T ESMM221VSN391MQ25T ESMM221VSN471MQ30T ESMM221VSN561MQ35T ESMM221VSN681MQ40T ESMM221VSN821MQ45T ESMM221VSN102MQ50T ESMM221VSN331MR20T ESMM221VSN391MR20T ESMM221VSN471MR25T ESMM221VSN561MR25T ESMM221VSN681MR30T ESMM221VSN821MR35T ESMM221VSN102MR40T ESMM221VSN122MR45T ESMM221VSN152MR50T ESMM221VSN391MA20T ESMM221VSN471MA20T ESMM221VSN561MA20T ESMM221VSN681MA25T ESMM221VSN821MA30T ESMM221VSN102MA30T ESMM221VSN122MA35T ESMM221VSN152MA40T ESMM221VSN182MA45T 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ40 20ⴒ45 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ30 22ⴒ35 22ⴒ35 22ⴒ40 22ⴒ45 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 25.4ⴒ50 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ45 30ⴒ50 35ⴒ20 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ30 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 N25 N30 N35 N40 N45 N50 P20 P25 P30 P35 P35 P40 P45 Q20 Q25 Q25 Q30 Q35 Q40 Q45 Q50 R20 R20 R25 R25 R30 R35 R40 R45 R50 A20 A20 A20 A25 A30 A30 A35 A40 A45 1.13 0.921 0.753 0.638 0.529 0.444 1.381 0.921 0.753 0.638 0.529 0.444 0.366 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.166 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.166 0.138 1.25 1.46 1.64 1.84 2.12 2.33 1.06 1.47 1.7 1.89 2.0 2.33 2.63 1.35 1.69 1.84 2.08 2.38 2.68 3.01 3.4 1.58 1.71 2.12 2.31 2.62 2.99 3.42 3.88 4.44 1.79 1.88 2.14 2.58 2.79 3.29 3.68 4.10 4.52 180 220 270 330 390 470 150 180 220 270 330 390 470 ESMM251VSN181MN25T ESMM251VSN221MN25T ESMM251VSN271MN30T ESMM251VSN331MN35T ESMM251VSN391MN40T ESMM251VSN471MN50T ESMM251VSN151MP20T ESMM251VSN181MP20T ESMM251VSN221MP25T ESMM251VSN271MP25T ESMM251VSN331MP30T ESMM251VSN391MP35T ESMM251VSN471MP35T 20ⴒ25 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ40 20ⴒ50 22ⴒ20 22ⴒ20 22ⴒ25 22ⴒ25 22ⴒ30 22ⴒ35 22ⴒ35 N25 N25 N30 N35 N40 N50 P20 P20 P25 P25 P30 P35 P35 1.381 1.13 0.921 0.753 0.638 0.529 1.658 1.381 1.13 0.921 0.753 0.638 0.529 1.20 1.26 1.42 1.68 1.92 2.06 0.97 1.06 1.24 1.5 1.66 1.88 2.15 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 7/ 11 SMM 250 Volts 300 Volts Surge Nominal Case Size* DⴒL ( mm ) SNAP MOUNT 85ⴗC 220 Volts 270 Volts Surge Global Part Number† Capacitance (μF ) Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 250 Volts SMM SNAP MOUNT 85ⴗC 300 Volts Surge 315 Volts 365 Volts Surge Capacitance (μF ) Global Part Number† Nominal Case Size* DⴒL ( mm ) Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 560 680 220 330 390 470 560 680 820 330 390 470 560 680 820 1,000 1,200 390 470 680 820 1,000 1,200 1,500 1,800 ESMM251VSN561MP40T ESMM251VSN681MP50T ESMM251VSN221MQ20T ESMM251VSN331MQ25T ESMM251VSN391MQ30T ESMM251VSN471MQ35T ESMM251VSN561MQ35T ESMM251VSN681MQ40T ESMM251VSN821MQ45T ESMM251VSN331MR20T ESMM251VSN391MR25T ESMM251VSN471MR25T ESMM251VSN561MR25T ESMM251VSN681MR30T ESMM251VSN821MR35T ESMM251VSN102MR40T ESMM251VSN122MR45T ESMM251VSN391MA20T ESMM251VSN471MA20T ESMM251VSN681MA25T ESMM251VSN821MA30T ESMM251VSN102MA35T ESMM251VSN122MA35T ESMM251VSN152MA40T ESMM251VSN182MA50T 22ⴒ40 22ⴒ50 25.4ⴒ20 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ45 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ35 35ⴒ40 35ⴒ50 P40 P50 Q20 Q25 Q30 Q35 Q35 Q40 Q45 R20 R25 R25 R25 R30 R35 R40 R45 A20 A20 A25 A30 A35 A35 A40 A50 0.444 0.366 1.13 0.753 0.638 0.529 0.444 0.366 0.303 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.207 0.638 0.529 0.366 0.303 0.249 0.207 0.166 0.138 2.48 2.61 1.22 1.61 1.88 2.15 2.35 2.67 3.01 1.58 1.86 2.05 2.35 2.71 2.98 3.56 3.99 1.71 1.88 2.58 2.96 3.48 3.84 4.33 4.54 120 150 180 220 270 330 100 150 180 220 270 330 390 120 150 180 220 270 330 390 470 560 180 220 270 330 390 470 560 680 820 270 390 ESMM3B1VSN121MN25T ESMM3B1VSN151MN30T ESMM3B1VSN181MN35T ESMM3B1VSN221MN35T ESMM3B1VSN271MN45T ESMM3B1VSN331MN50T ESMM3B1VSN101MP20T ESMM3B1VSN151MP25T ESMM3B1VSN181MP30T ESMM3B1VSN221MP30T ESMM3B1VSN271MP35T ESMM3B1VSN331MP40T ESMM3B1VSN391MP45T ESMM3B1VSN121MQ20T ESMM3B1VSN151MQ20T ESMM3B1VSN181MQ25T ESMM3B1VSN221MQ25T ESMM3B1VSN271MQ30T ESMM3B1VSN331MQ35T ESMM3B1VSN391MQ40T ESMM3B1VSN471MQ45T ESMM3B1VSN561MQ50T ESMM3B1VSN181MR20T ESMM3B1VSN221MR20T ESMM3B1VSN271MR25T ESMM3B1VSN331MR25T ESMM3B1VSN391MR30T ESMM3B1VSN471MR35T ESMM3B1VSN561MR35T ESMM3B1VSN681MR45T ESMM3B1VSN821MR50T ESMM3B1VSN271MA20T ESMM3B1VSN391MA25T 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ35 20ⴒ45 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ30 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 25.4ⴒ20 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 25.4ⴒ50 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ35 30ⴒ45 30ⴒ50 35ⴒ20 35ⴒ25 N25 N30 N35 N35 N45 N50 P20 P25 P30 P30 P35 P40 P45 Q20 Q20 Q25 Q25 Q30 Q35 Q40 Q45 Q50 R20 R20 R25 R25 R30 R35 R35 R45 R50 A20 A25 2.763 2.21 1.381 1.13 0.921 0.753 3.315 2.21 1.381 1.13 0.921 0.753 0.638 2.763 2.21 1.381 1.13 0.921 0.753 0.638 0.529 0.444 1.381 1.13 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.921 0.638 0.89 1.05 1.18 1.3 1.52 1.73 0.79 1.06 1.29 1.41 1.68 1.91 2.07 0.9 1.0 1.38 1.47 1.7 1.94 2.11 2.31 2.46 1.16 1.28 1.55 1.98 2.15 2.38 2.63 2.82 3.28 1.43 1.95 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 8 / 11 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 315 Volts 365 Volts Surge Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 470 560 680 820 1,000 ESMM3B1VSN471MA30T ESMM3B1VSN561MA30T ESMM3B1VSN681MA35T ESMM3B1VSN821MA40T ESMM3B1VSN102MA45T 35ⴒ30 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 A30 A30 A35 A40 A45 0.529 0.444 0.366 0.303 0.249 2.46 2.69 3.05 3.45 3.59 100 120 150 180 220 270 82 120 150 180 220 270 330 120 150 180 220 270 330 390 470 150 180 220 270 330 390 470 560 680 220 270 330 390 470 560 680 820 1,000 ESMM351VSN101MN25T ESMM351VSN121MN30T ESMM351VSN151MN30T ESMM351VSN181MN35T ESMM351VSN221MN45T ESMM351VSN271MN50T ESMM351VSN820MP20T ESMM351VSN121MP25T ESMM351VSN151MP30T ESMM351VSN181MP30T ESMM351VSN221MP35T ESMM351VSN271MP40T ESMM351VSN331MP45T ESMM351VSN121MQ20T ESMM351VSN151MQ25T ESMM351VSN181MQ25T ESMM351VSN221MQ30T ESMM351VSN271MQ35T ESMM351VSN331MQ35T ESMM351VSN391MQ40T ESMM351VSN471MQ50T ESMM351VSN151MR20T ESMM351VSN181MR20T ESMM351VSN221MR25T ESMM351VSN271MR25T ESMM351VSN331MR30T ESMM351VSN391MR35T ESMM351VSN471MR35T ESMM351VSN561MR40T ESMM351VSN681MR50T ESMM351VSN221MA20T ESMM351VSN271MA20T ESMM351VSN331MA25T ESMM351VSN391MA30T ESMM351VSN471MA30T ESMM351VSN561MA35T ESMM351VSN681MA40T ESMM351VSN821MA45T ESMM351VSN102MA50T 20ⴒ25 20ⴒ30 20ⴒ30 20ⴒ35 20ⴒ45 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ30 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ35 25.4ⴒ40 25.4ⴒ50 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 30ⴒ35 30ⴒ40 30ⴒ50 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ30 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 35ⴒ50 N25 N30 N30 N35 N45 N50 P20 P25 P30 P30 P35 P40 P45 Q20 Q25 Q25 Q30 Q35 Q35 Q40 Q50 R20 R20 R25 R25 R30 R35 R35 R40 R50 A20 A20 A25 A30 A30 A35 A40 A45 A50 3.315 2.763 2.21 1.381 1.13 0.921 4.043 2.763 2.21 1.381 1.13 0.921 0.753 2.763 2.21 1.381 1.13 0.921 0.753 0.638 0.529 2.21 1.381 1.13 0.921 0.753 0.638 0.529 0.444 0.366 1.13 0.921 0.753 0.638 0.529 0.444 0.366 0.303 0.249 0.81 0.96 1.1 1.24 1.37 1.56 0.72 1.04 1.2 1.34 1.47 1.7 1.87 0.9 1.22 1.37 1.53 1.73 1.97 2.14 2.55 1.06 1.16 1.54 1.8 2.03 2.23 2.53 2.73 3.15 1.29 1.49 1.8 2.3 2.55 2.75 3.15 3.47 3.6 68 82 100 120 150 180 220 68 82 100 120 150 180 ESMM401VSN680MN25T ESMM401VSN820MN30T ESMM401VSN101MN30T ESMM401VSN121MN35T ESMM401VSN151MN40T ESMM401VSN181MN45T ESMM401VSN221MN50T ESMM401VSN680MP20T ESMM401VSN820MP25T ESMM401VSN101MP25T ESMM401VSN121MP30T ESMM401VSN151MP35T ESMM401VSN181MP40T 20ⴒ25 20ⴒ30 20ⴒ30 20ⴒ35 20ⴒ40 20ⴒ45 20ⴒ50 22ⴒ20 22ⴒ25 22ⴒ25 22ⴒ30 22ⴒ35 22ⴒ40 N25 N30 N30 N35 N40 N45 N50 P20 P25 P25 P30 P35 P40 4.875 4.043 3.315 2.763 2.21 1.842 1.507 4.878 4.043 3.315 2.763 2.21 1.842 0.75 0.82 0.95 1.07 1.22 1.28 1.41 0.65 0.84 0.99 1.09 1.24 1.41 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 9 / 11 SMM 400 Volts 450 Volts Surge Nominal Case Size* DⴒL ( mm ) SNAP MOUNT 85ⴗC 350 Volts 400 Volts Surge Global Part Number† Capacitance (μF ) Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 400 Volts SMM SNAP MOUNT 85ⴗC 450 Volts Surge 420 Volts 470 Volts Surge Capacitance (μF ) Global Part Number† 220 270 82 100 120 150 180 220 270 330 390 120 150 180 220 270 330 390 470 560 180 220 270 330 390 470 560 680 ESMM401VSN221MP45T ESMM401VSN271MP50T ESMM401VSN820MQ20T ESMM401VSN101MQ20T ESMM401VSN121MQ25T ESMM401VSN151MQ30T ESMM401VSN181MQ30T ESMM401VSN221MQ35T ESMM401VSN271MQ40T ESMM401VSN331MQ45T ESMM401VSN391MQ50T ESMM401VSN121MR20T ESMM401VSN151MR25T ESMM401VSN181MR25T ESMM401VSN221MR30T ESMM401VSN271MR30T ESMM401VSN331MR35T ESMM401VSN391MR40T ESMM401VSN471MR45T ESMM401VSN561MR50T ESMM401VSN181MA20T ESMM401VSN221MA25T ESMM401VSN271MA25T ESMM401VSN331MA30T ESMM401VSN391MA35T ESMM401VSN471MA35T ESMM401VSN561MA40T ESMM401VSN681MA50T 56 68 82 100 120 150 180 47 56 82 100 120 150 180 220 68 82 100 120 150 180 220 270 330 100 120 150 180 220 270 ESMM421VSN560MN25T ESMM421VSN680MN25T ESMM421VSN820MN30T ESMM421VSN101MN35T ESMM421VSN121MN35T ESMM421VSN151MN40T ESMM421VSN181MN50T ESMM421VSN470MP20T ESMM421VSN560MP20T ESMM421VSN820MP25T ESMM421VSN101MP30T ESMM421VSN121MP30T ESMM421VSN151MP35T ESMM421VSN181MP40T ESMM421VSN221MP45T ESMM421VSN680MQ20T ESMM421VSN820MQ20T ESMM421VSN101MQ25T ESMM421VSN121MQ25T ESMM421VSN151MQ30T ESMM421VSN181MQ35T ESMM421VSN221MQ35T ESMM421VSN271MQ40T ESMM421VSN331MQ50T ESMM421VSN101MR20T ESMM421VSN121MR20T ESMM421VSN151MR25T ESMM421VSN181MR25T ESMM421VSN221MR30T ESMM421VSN271MR35T Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 22ⴒ45 22ⴒ50 25.4ⴒ20 25.4ⴒ20 25.4ⴒ25 25.4ⴒ30 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 25.4ⴒ50 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ45 30ⴒ50 35ⴒ20 35ⴒ25 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ35 35ⴒ40 35ⴒ50 P45 P50 Q20 Q20 Q25 Q30 Q30 Q35 Q40 Q45 Q50 R20 R25 R25 R30 R30 R35 R40 R45 R50 A20 A25 A25 A30 A35 A35 A40 A50 1.507 1.228 4.043 3.315 2.763 2.21 1.842 1.507 1.228 1.005 0.85 2.763 2.21 1.842 1.507 1.228 1.005 0.85 0.705 0.592 1.842 1.507 1.228 1.005 0.85 0.705 0.592 0.488 1.58 1.65 0.74 0.82 1.13 1.27 1.44 1.64 1.79 2.0 2.12 0.95 1.2 1.52 1.66 1.82 2.05 2.26 2.51 2.85 1.16 1.47 1.63 2.05 2.28 2.54 2.85 3.1 20ⴒ25 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ35 20ⴒ40 20ⴒ50 22ⴒ20 22ⴒ20 22ⴒ25 22ⴒ30 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 25.4ⴒ20 25.4ⴒ20 25.4ⴒ25 25.4ⴒ25 25.4ⴒ30 25.4ⴒ35 25.4ⴒ35 25.4ⴒ40 25.4ⴒ50 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ35 N25 N25 N30 N35 N35 N40 N50 P20 P20 P25 P30 P30 P35 P40 P45 Q20 Q20 Q25 Q25 Q30 Q35 Q35 Q40 Q50 R20 R20 R25 R25 R30 R35 5.92 4.875 4.043 3.315 2.763 2.21 1.842 7.053 5.92 4.043 3.315 2.763 2.21 1.842 1.507 4.875 4.043 3.315 2.763 2.21 1.842 1.507 1.228 1.005 3.315 2.763 2.21 1.842 1.507 1.228 0.58 0.7 0.8 0.9 1.04 1.17 1.27 0.54 0.59 0.85 0.97 1.07 1.21 1.33 1.55 0.68 0.74 0.98 1.08 1.26 1.42 1.58 1.74 2.2 0.87 0.95 1.3 1.48 1.65 1.9 Nominal Case Size* DⴒL ( mm ) † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 10 / 11 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Mar 07 SMM Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 420 Volts 470 Volts Surge Nominal Case Size* DⴒL ( mm ) Case Size Code Maximum ESR ( Ω ) at ⴐ20ⴗC, 120Hz Rated Ripple Current (A rms) at ⴐ85ⴗC, 120Hz 330 390 470 150 180 220 270 330 390 470 560 680 ESMM421VSN331MR35T ESMM421VSN391MR40T ESMM421VSN471MR45T ESMM421VSN151MA20T ESMM421VSN181MA20T ESMM421VSN221MA25T ESMM421VSN271MA30T ESMM421VSN331MA35T ESMM421VSN391MA35T ESMM421VSN471MA40T ESMM421VSN561MA45T ESMM421VSN681MA50T 30ⴒ35 30ⴒ40 30ⴒ45 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ35 35ⴒ40 35ⴒ45 35ⴒ50 R35 R40 R45 A20 A20 A25 A30 A35 A35 A40 A45 A50 1.005 0.85 0.705 2.21 1.842 1.507 1.228 1.005 0.85 0.705 0.592 0.488 1.98 2.22 2.5 1.11 1.16 1.47 1.94 2.17 2.27 2.61 2.95 3.15 56 68 82 100 120 150 47 56 68 82 100 120 150 180 220 68 82 100 120 150 180 220 270 330 82 100 120 150 180 220 270 330 390 470 120 150 180 220 270 330 390 470 560 ESMM451VSN560MN25T ESMM451VSN680MN30T ESMM451VSN820MN35T ESMM451VSN101MN35T ESMM451VSN121MN40T ESMM451VSN151MN45T ESMM451VSN470MP20T ESMM451VSN560MP20T ESMM451VSN680MP25T ESMM451VSN820MP25T ESMM451VSN101MP30T ESMM451VSN121MP35T ESMM451VSN151MP40T ESMM451VSN181MP45T ESMM451VSN221MP50T ESMM451VSN680MQ20T ESMM451VSN820MQ20T ESMM451VSN101MQ25T ESMM451VSN121MQ30T ESMM451VSN151MQ30T ESMM451VSN181MQ35T ESMM451VSN221MQ40T ESMM451VSN271MQ45T ESMM451VSN331MQ50T ESMM451VSN820MR20T ESMM451VSN101MR20T ESMM451VSN121MR25T ESMM451VSN151MR25T ESMM451VSN181MR30T ESMM451VSN221MR30T ESMM451VSN271MR35T ESMM451VSN331MR40T ESMM451VSN391MR45T ESMM451VSN471MR50T ESMM451VSN121MA20T ESMM451VSN151MA20T ESMM451VSN181MA25T ESMM451VSN221MA25T ESMM451VSN271MA30T ESMM451VSN331MA35T ESMM451VSN391MA40T ESMM451VSN471MA45T ESMM451VSN561MA50T 20ⴒ25 20ⴒ30 20ⴒ35 20ⴒ35 20ⴒ40 20ⴒ45 22ⴒ20 22ⴒ20 22ⴒ25 22ⴒ25 22ⴒ30 22ⴒ35 22ⴒ40 22ⴒ45 22ⴒ50 25.4ⴒ20 25.4ⴒ20 25.4ⴒ25 25.4ⴒ30 25.4ⴒ30 25.4ⴒ35 25.4ⴒ40 25.4ⴒ45 25.4ⴒ50 30ⴒ20 30ⴒ20 30ⴒ25 30ⴒ25 30ⴒ30 30ⴒ30 30ⴒ35 30ⴒ40 30ⴒ45 30ⴒ50 35ⴒ20 35ⴒ20 35ⴒ25 35ⴒ25 35ⴒ30 35ⴒ35 35ⴒ40 35ⴒ45 35ⴒ50 N25 N30 N35 N35 N40 N45 P20 P20 P25 P25 P30 P35 P40 P45 P50 Q20 Q20 Q25 Q30 Q30 Q35 Q40 Q45 Q50 R20 R20 R25 R25 R30 R30 R35 R40 R45 R50 A20 A20 A25 A25 A30 A35 A40 A45 A50 5.92 4.875 4.043 3.315 2.763 2.21 7.053 5.92 4.875 4.043 3.315 2.763 2.21 1.842 1.507 4.875 4.043 3.315 2.763 2.21 1.842 1.507 1.228 1.005 4.043 3.315 2.763 2.21 1.842 1.507 1.228 1.005 0.85 0.705 2.763 2.21 1.842 1.507 1.228 1.005 0.85 0.705 0.592 0.61 0.71 0.8 0.88 0.99 1.13 0.54 0.59 0.71 0.86 0.95 1.07 1.18 1.32 1.48 0.68 0.74 0.97 1.09 1.25 1.4 1.59 1.73 2.12 0.79 0.87 1.12 1.29 1.45 1.64 1.89 2.12 2.35 2.65 0.99 1.06 1.33 1.66 1.9 2.15 2.38 2.68 2.88 † For terminal and construction options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 11/ 11 SMM Global Part Number† SNAP MOUNT 85ⴗC 450 Volts 500 Volts Surge Capacitance (μF )
ESMM161VSD272MA45T 价格&库存
很抱歉,暂时无法提供与“ESMM161VSD272MA45T”相匹配的价格&库存,您可以联系我们找货
