1N4001 - 1N4007, BY133
1.0 AMP. Silicon Rectifiers
DO-41
Features
High efficiency, Low VF
High current capability
High reliability
High surge current capability
Low power loss
Eas ily clea ned w ith Freon, Alcohi l,Is opropa nop
a nd s im ilar s olvents
Mechanical Data
Cases: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Polarity: Color band denotes cathode end
High temperature soldering guaranteed:
o
260 C /10 seconds/.375”,(9.5mm) lead
lengths at 5 lbs.,(2.3kg) tension
Weight: 0.35 gram
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Symbol
VRRM
VRMS
VDC
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current .375”(9.5mm) Lead Length
@TA = 75 oC
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@1.0A
1N
4001
50
35
50
1N
4002
100
70
100
1N
4003
200
140
200
1N
4004
400
280
400
1N
4005
600
420
600
1N
4006
800
560
800
1N
4007
1000
700
1000
BY Units
133
1300 V
910
V
1300 V
I(AV)
1.0
A
IFSM
30
A
VF
1.0
V
Maximum DC Reverse Current @ TA=25 C
o
at Rated DC Blocking Voltage @ TA=125 C
IR
5.0
50
uA
uA
Maximum Full Load Reverse Current ,Full
Cycle Average .375”(9.5mm) Lead Length
o
@TA=75 C
HTIR
30
uA
Cj
RθJA
10
65
-65 to +150
o
Typical Junction Capacitance ( Note 1 )
Typical Thermal Resistance ( Note 2 )
Operating and Storage Temperature Range TJ ,TSTG
1. Measured at 1 MHz and Applied Reverse Voltage of 4.0 Volts D.C.
Notes:
2. Mount on Cu-Pad Size 5mm x 5mm on P.C.B.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
o
pF
C/W
o
C
mail:lge@lgesemi.com
FIG.2- TYPICAL REVERSE CHARACTERISTICS
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
1
10
0.8
4
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD RECTIFIED CURRENT AMPERES
RATINGS AND CHARACTERISTIC CURVES (1N4001 THRU 1N4007/BY133)
0.6
Single Phase
Half Wave 60Hz
Resistive or
Inductive Load
0.375" (9.5mm)
Lead Length
0.4
0.2
50
75
100
125
150
175
o
AMBIENT TEMPERATURE. ( C)
Tj=125 0C
1
0.4
0.1
Tj=25 0C
0.04
PEAK FORWARD SURGE CURRENT. (A)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT
50
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
40
8.3ms Single Half Sine Wave
JEDEC Method
30
2
6
4
8 10
40
NUMBER OF CYCLES AT 60Hz
FIG.4- TYPICAL JUNCTION CAPACITANCE
FIG.5- TYPICAL FORWARD CHARACTERISTICS
Tj=25 0C
100
JUNCTION CAPACITANCE.(pF)
INSTANTANEOUS FORWARD CURRENT. (A)
200
60
40
6
4
2
1
0.1
0.2
0.4
1
2
4
10
100
10
4
2
1
0.4
0.2
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
0.1
0.04
0.02
0.01
0.6
0.8
1.2
1.4
1.5
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-41
5000/AMMO
50000
42X28X31
14.00
12.00
ht t p : //
1.0
FORWARD VOLTAGE. (V)
REVERSE VOLTAGE. (V)
www.lgesemi .c o m
很抱歉,暂时无法提供与“1N4001”相匹配的价格&库存,您可以联系我们找货
