ZC82-1B-12UVWFTY
ZC82-1B-12UVWFTY
    GOLDEN(高登)
    磁保持继电器 12VDC 120A 250VAC,双线圈,铜柱连接,防磁
ZC82-1B-12UVWFTY 数据手册
Relay specification No shunt application 150A 250VAC DC 12V Marking(Up cover) GOLDEN 150A 250VAC COIL: 12VDC ZC82-1B-12SV1FTY Tin plated Red Black 红 24AWG UL1569 黑 24AWG UL1569 镀锡 QR code info : 80 5 1.Brand:GOLDEN 2.Part number :ZC82-120A-12V singel coil 3.Production date :20230727 43 21.6 37 红黑 套黑色热缩管 套黑色热缩管 Black heatshrink tube 100 Black heatshrink tube 4 16 16平方电刷线 套硅胶管 16mm flexible braided coppe with covered with silicon rubber case 1.5 Technical requirements : 1.Product specification :ZC82-120A 12V/3W singel coil ; 2.Coil wire connecting see the image below ; 3.Coil resistance :48Ω ±5% 4." " marked is key dimension,which need strictly control; 5.Product contact keep close when shipping out. Tin plated Relay coil operating diagram Red -VC E nterprise secrets copying prohibited Spec Size tolarance Designer Date +/-0.2 陈禄生 2023.10.13 Angel tolarance +/-1 Model Checker PN Date 2-Ø5.2 8 镀锡 Close Red -VC +VC Black Open -VC Golden relay ZC82-120A-12V single coil-3W Name ZC82-1B-12SV1FTY-001 Black Magnetic latching relay File No. 1:1 QTY Unit:MM Ratio Version V1.2 Page 1 1/1
ZC82-1B-12UVWFTY 价格&库存
很抱歉,暂时无法提供与“ZC82-1B-12UVWFTY”相匹配的价格&库存,您可以联系我们找货
