TM
TRIO mXTEND
(NN03-310)
DATASHEET
DATASHEET
TRIO mXTENDTM (NN03-310)
TRIO mXTEND™: The ultra slim, top performance
antenna
The power of 3. TRIO mXTEND™ can combine cellular connectivity, GNSS and Bluetooth in a
single chip antenna component. Leverage the possibilities of three independent radios in a
powerful, slimline solution.
Thanks to its 1mm height, it can be integrated into nearly all wireless platforms. It also offers
worldwide coverage and works in multiple frequency regions thanks to its modular, multiband
and multiport configuration.
TRIO mXTEND™ component (NN03-310)
Most used industries.
Asset Tracking.
Smart Metering.
ISM modules.
IoT sensors.
TRIO mXTEND™ benefits.
Top performance: Top multiband worldwide sub-6GHz cellular/IoT performance in a multiRAT and 3 independent port antenna components.
Multiband & Multiport: All cellular/ISM bands: 2G/3G/4G/5G and NB-IoT/LTE-M
applications with additional GNSS, Bluetooth, Wi-Fi 6E, UWB simultaneously.
Versatile: Triple radio architecture in a single, small, ultra-slim antenna package: 30 mm x
1.0 mm x 3.0 mm.
Global reach: Through multiband performance (worldwide standard compatible).
Reliability: Off-the-Shelf standard product, no antenna part customization (electronic
optimization).
Use cases: Best for top-performing compact tracking devices, IoT sensors, IoT cellular/ISM
modules, and mobile devices.
Operation bands summary.
GSM, UMTS, LTE, LTE-M, NB-IoT, 5G, GNSS, Bluetooth, and many more within the range of
400 MHz to 8000 MHz.
Last Update: July 2023
2
DATASHEET
1. AVAILABLE SOLUTIONS SUMMARY
Configuration
Frequency range
Frequency
Regions
CELLULAR LTE
698 – 960 MHz & 1710 – 2690 MHz
2
CELLULAR LTE + 5G
698 – 960 MHz, 1710 – 2690 MHz & 3400
– 3800 MHz
3
CELLULAR LTE +
GNSS
824 – 960 MHz, 1710 – 2170 MHz, 1561
MHz, 1575 MHz & 1598 – 1606 MHz
5
MOBILE + GNSS +
BLUETOOTH
824 – 960 MHz, 1710 – 1990 MHz, 1561
MHz, 1575 MHz, 1598 – 1606 MHz & 2400
– 2500MHz
6
ISM
863 – 928 MHz
2
2. DETAILED AVAILABLE SOLUTIONS
2.1. LTE SOLUTION
Technical features
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
698 – 960 MHz
> 55 %
1.1 dBi
1710 – 2690 MHz
> 65 %
2.4 dBi
< 3:1
Omnidirectional
Linear
0.25 g
-40 to +125 ºC
50
30.0 mm x 3.0 mm x 1.0 mm
Technical features. Measures from the evaluation board (142 mm x 60 mm x 1 mm).
3
DATASHEET
2.2. ANTENNA FOOTPRINT: 1 PORT CONFIGURATION
Measure
A
B
C
D
E
F
G
H
mm
12.0
23.0
3.0
0.5
1.0
8.5
2.0
2.5
Tolerance: ±0.05mm
Footprint dimensions for the single chip antenna component in one port configuration.
2.3. LTE + 5G SOLUTION
Technical features
698 – 960 MHz
1710 – 2690 MHz
3400 – 3800 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 50 %
1.5 dBi
> 60 %
2.7 dBi
> 65 %
3.8 dBi
< 2:1
< 3:1
Omnidirectional
Linear
0.25 g
-40 to +125 ºC
50
2.4. LTE + GNSS SOLUTION
Technical features
824 – 894 MHz
1850 – 2170 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 65%
1.9
> 70%
2.0
< 3:1
Omnidirectional
Linear
0.02 g.
-40 to +125 ºC
50
7.0 mm x 3.0 mm x 1.0 mm
4
DATASHEET
2.5. ANTENNA FOOTPRINT: 2 PORT CONFIGURATION
Measure
A
B
C
D
E
F
G
H
I
J
mm
12.0
23.0
3.0
0.5
1.0
8.5
2.0
2.5
10.0
7.0
Tolerance: ±0.05mm
Footprint dimensions for the single chip antenna component in two-port configuration.
2.6. LTE + GNSS + BLUETOOTH SOLUTION
Technical
features
Port 1
824-960 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 50%
0.4 dBi
< 2.8:1
Port 1
Port 2
1710-1990
1561-1606
MHz
MHz
> 60%
> 50%
1.9 dBi
0.9 dBi
< 2.1:1
< 2.1:1
Omnidirectional
Linear
0.25 g.
-40 to +125 ºC
50
Port 3
24002500MHz
> 75%
2.4 dBi
< 2.0:1
5
DATASHEET
2.7. ANTENNA FOOTPRINT: 3 PORT CONFIGURATION
Measure
A
B
C
D
E
F
G
H
mm
1.0
0.5
2.0
3.0
5.5
8.0
8.5
10.0
Tolerance: ±0.2mm
Footprint dimensions for the single chip antenna component in three port configuration.
If you are designing a device with a different size or operating frequency than shown above, you
can assess the performance of this solution using our free-of-charge Antenna Intelligence
Cloud™ tool. This tool provides a complete design report, including expected performance and
tailored design guide, within 24 hours. For additional information about Ignion's range of R&D
services, please visit: https://ignion.io/resources-support/technical-center/engineering-support/.
If you require further assistance, please contact support@ignion.io.
Purchase this or other evaluation boards through our main distributors by visiting the following
link: https://ignion.io/distributors/.
6
DATASHEET
Contact:
support@ignion.io
+34 935 660 710
Barcelona
Av. Alcalde Barnils, 64-68 Modul C, 3a pl.
Sant Cugat del Vallés
08174 Barcelona
Spain
Shenzhen
Topway Information Building, Binhai Avenue,
Nanshan District, Nº 3369 – Room 2303
Shenzhen, 518000
China
+86 13826538470
Tampa
8875 Hidden River Parkway
Suite 300
Tampa, FL 33637
USA
7
很抱歉,暂时无法提供与“NN03-310”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+49.547531+5.99620
- 10+44.5056510+5.38604
- 25+42.0758825+5.09199
- 100+36.46488100+4.41295
- 250+34.59440250+4.18659
- 500+31.04154500+3.75662
- 1000+26.179621000+3.16824
- 国内价格 香港价格
- 3000+24.870643000+3.00983
- 国内价格
- 15+33.16562
- 80+31.77516
- 350+30.55397
- 850+29.34487
- 2600+28.12368
