N1030B 160 ID
N1030B 160 ID
    GEEHY(极海)
    TOGGLE HALF BOOT GRAY
N1030B 160 ID 数据手册
SPECIFICATIONS Material: Silicone rubber conforms to AA-59588 Class lll, GR50 (unless otherwise specified). Mounting Nut: Brass, black oxide Temperature Range: -94 F to +400 F (-70 C to +204 C). Pressure Range: Exceeds 15 psi internal and 1500 psi external. Operational Life: 50,000 actuations (minimum). Shelf Life: Excess of 25 years. Resistant to: Salt spray, sunlight, ozone, weather, fungus,and most acids and lubricating oils. Agency Recognition: UL & ULC Recognized to UL Std. 50 TOGGLE BOOT CUSTOMER'S PANEL CUSTOMER'S BACKING FASTENER A A HEX .625 [15.9] CUSTOMER'S TOGGLE SWITCH 0.160 [4] TOGGLE BOOT CUSTOMER'S PANEL 0.437 [11] PERMISSIBLE RUBBER OVERLAY .005 [0.127] MAX. CUSTOMER'S BACKING FASTENER 15/32-32NS-2B SECTION A-A TOLERANCES: UNLESS OTHERWISE NOTED 1/32 [ 0.793]. CUSTOMER'S TOGGLE SWITCH A REV. REVISED THREADS NOTATION FROM 1/2-32 TO 15/32-32 DESCRIPTION MAXIMUM AND MINIMUM MEASURETITLE: MENTS ARE STATED DIRECTLY ON EACH DIMENSION. BOOT TOGGLE SWITCH MAT'L: SILICONE RUBBER conforms to A-A-59588, Gr.50 EXPOSED BAT (N-1030B 160 ID) FINISH: APM-HEXSEAL CORPORATION GRAY ENG. DWN: CHKD. SCALE 3:1 DAN LAW 10.10.12 DATE S. GOK 03.04.09 S. GOK 03.04.09 KEN S. 10.10.12 DWG.NO. N1030B 160 ID THIS DRAWING COVERS PROPRIETARY ITEM AND IS THE PROPERTY OF THE APM-HEXSEAL CORPORATION. THIS DRAWING IS NOT TO BE COPIED OR USED WITHOUT THE WRITTEN APPROVAL OF AN OFFICER OF THE APM-HEXSEAL CORPORATION.
N1030B 160 ID 价格&库存
很抱歉,暂时无法提供与“N1030B 160 ID”相匹配的价格&库存,您可以联系我们找货
