WMQ28N03T1
WMQ28N03T1
    WAYON(上海维安)
    PDFN8
    MOSFETs PDFN8 N-沟道 VDS=30V ID=28A
WMQ28N03T1 数据手册
WMQ28N03T1 30V N-Channel Enhancement Mode Power MOSFET Description WMQ28N03T1 uses advanced power trench technology that has been especially tailored to minimize the on-state resistance and D D D D D D D yet maintain superior switching performance. S S G G Features S ⚫ PDFN3030-8L VDS= 30V, ID = 28A D S S RDS(on) < 18mΩ @ VGS = 10V RDS(on) < 30mΩ @ VGS = 4.5V ⚫ Green Device Available ⚫ Low Gate Charge ⚫ Advanced High Cell Density Trench Technology ⚫ 100% EAS Guaranteed D RoHS compliant Applications G ⚫ Power Management Switches ⚫ DC/DC Converter S Absolute Maximum Ratings Parameter Symbol Value Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V 28 TC=25℃ Continuous Drain Current 1 ID Pulsed Drain Current2 A 18 TC=100℃ IDM 54 A EAS 12.8 mJ Avalanche Current IAS 16 A Total Power Dissipation4 PD 21 W TJ, TSTG -55 to+150 °C Symbol Value Unit Thermal Resistance from Junction-to-Ambient1 RθJA 74 °C/W Thermal Resistance from Junction-to-Case1 RθJC 5.95 °C/W Single Pulse Avalanche Energy3 Operating Junction and Storage Temperature Range Thermal Characteristics Parameter Rev.6.0, 2019 Doc:W0803134 1 / 6 S WMQ28N03T1 Electrical Characteristics Tc = 25°C, unless otherwise noted Parameter Symbol Test Conditions Min. Typ. Max. Unit Static Characteristics Drain-Source Breakdown Voltage Gate-Body Leakage Current Zero Gate Voltage Drain Current V(BR)DSS VGS = 0V, ID = 250µA 30 - - V lGSS VDS = 0V, VGS = ±20V - - ±100 nA - - 1 IDSS VDS = 24V, VGS = 0V - - 5 1.0 1.75 2.5 VGS = 10V, ID = 10A - 14 18 VGS = 4.5V, ID = 5A - 20 30 VDS = 5V, ID = 1A - 4.6 - - 500 - - 75 - - 51 - - 2.5 - - 7.3 - - 1.5 - TJ=25℃ TJ=55℃ Gate-Threshold Voltage VGS(th) Drain-Source On-Resistance2 RDS(on) Forward Transconductance2 gfs VDS = VGS, ID = 250µA μA V mΩ S Dynamic Characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss VDS = 15V, VGS =0V, f =1MHz pF Switching Characteristics Rg Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd - 2.3 - Turn-On Delay Time td(on) - 4.2 - - 9.9 - - 15.8 - - 6.2 - IS = 1A, VGS = 0V - - 1.2 V VG=VD=0V , Force Current - - 28 A Rise Time Turn-Off Delay Time Fall Time tr td(off) VDS = 0V, VGS =0V, f =1MHz Ω Gate Resistance VGS = 4.5V, VDS = 20V, ID= 10A VGS =10V, VDD = 12V, RG = 3.3Ω, ID= 5A tf nC nS Drain-source body diode Characteristics Diode Forward Voltage2 Continuous Source Current1,5 VSD IS Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≤ 300us , duty cycle ≤ 2% 3.The EAS data shows Max. rating . The test condition is V DD=25V, VGS=10V, L=0.1mH, IAS =16A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. Rev.6.0, 2019 www.way-on.com 2 / 6 WMQ28N03T1 Figure 1. Output Characteristics Figure 2. Transfer Characteristics Figure 3. Forward Characteristics of Reverse Figure 4. Gate Charge Characteristics Figure 5. RDS(on) vs. VGS Rev.6.0, 2019 Figure 6. RDS(on) vs. ID www.way-on.com 3 / 6 WMQ28N03T1 Figure 7. Capacitance Characteristics Figure 8. Safe Operating Area Figure 9. Normalized Maximum Transient Thermal Impedance Figure 10. Switching Time Waveform Figure 11. Unclamped Inductive Switching Waveform Rev.6.0, 2019 www.way-on.com 4 / 6 WMQ28N03T1 Mechanical Dimensions for PDFN3030-8L COMMON DIMENSIONS MM SYMBOL MIN MAX A 0.70 0.85 A1 0.10 0.25 D 2.90 3.25 D1 2.25 2.65 E 2.90 3.20 E1 3.10 3.45 E2 1.54 1.98 b 0.20 0.40 e 0.60 0.70 L 0.30 0.50 L1 Rev.6.0, 2019 www.way-on.com 0.13BSC L2 0.00 0.15 H 0.20 0.65 θ 0° 14° 5 / 6 WMQ28N03T1 Ordering Information Part Package Marking Packing method WMQ28N03T1 PDFN3030-8L Q28N03 Tape and Reel Marking Information Q28N03 WWXX XXX Q28N03 = Device code WWXX XXX= Date code Contact Information No.1001, Shiwan(7) Road, Pudong District, Shanghai, P.R.China.201207 Tel: 86-21-50310888 Fax: 86-21-50757680 Email: market@way-on.com WAYON website: http://www.way-on.com For additional information, please contact your local Sales Representative. ® is registered trademarks of Wayon Corporation. Disclaimer WAYON reserves the right to make changes without further notice to any Products herein to improve reliability, function, or design. The Products are not designed for use in hostile environments, including, without limitation, aircraft, nuclear power generation, medical appliances, and devices or systems in which malfunction of any Product can reasonably be expected to result in a personal injury. The information given in this document shall in no event be regarded as a guarantee of conditions or characteristics. WAYON does not assume any liability for infringement of patents, copyrights, or other intellectual property rights of third parties by or arising from the use of Products or technical information described in this document. Rev.6.0, 2019 www.way-on.com 6 / 6
WMQ28N03T1 价格&库存
很抱歉,暂时无法提供与“WMQ28N03T1”相匹配的价格&库存,您可以联系我们找货
