APSDM008GB2AN-CT
APSDM008GB2AN-CT
    APACERMEMORYAMERICA(宇瞻科技)
    SATA3 DISK MODULE 7-PIN/180 DEGR
APSDM008GB2AN-CT 数据手册
SQF-SDM 630 SATA III (6.0Gb) Disk Module NEW SQF-SDM 530 SATA III (6.0Gb) Disk Module NEW Flash Life Flash Lock Emergency Security ID Monitoring Erase Features Features ƒ Compliant with SATA III and SATA v3.0 standard ƒ Vertical type SATA DOM with housing ƒ Supports 72 bit ECC correct per 1K Byte data ƒ Compliant with SATA III and SATA v3.0 standard ƒ Universal Wear-leveling and Bad Block Management ƒ Supports 40 bit ECC correct per 1K Byte data ƒ Shock resistance, anti-vibration and Low power consumption ƒ Universal wear-leveling and bad block management ƒ GUI Management Tool & Software API Package ƒ Shock resistance, anti-vibration and low power consumption ƒ Supports hardware write protect Specifications ƒ GUI management tool & software API package Specifications Connector Type Flash type Standard 7-pin SATA connector SLC / Ultra MLC / MLC SLC: 1 to 32GB Ultra MLC: 4 to 32GB MLC: 4 to 64GB SATA III (6.0 Gbps) SLC: up to 500/150 MB/sec MLC: up to 250/100 MB/sec Commercial grade: 0 to +70° C Industrial grade: -40 to +85° C 1,500 G, peak / 0.5 ms 20 G, peak / 80 ~ 2000 Hz 2,000,000 program/erase cycles 44.7 x 11.2 x 4.2 Capacity Transfer Mode Sustained R/W Performance (*) Operating Temperature Shock Resistance Vibration Resistance Endurance Dimensions (mm) Connector Type Flash Type Capacity Transfer Mode Sustained R/W Performance (*) Operating Temperature Shock Resistance Vibration Resistance Endurance Dimensions (mm) Standard 7-pin SATA connector SLC / MLC SLC: 2 to 32GB MLC: 8 to 128GB SATA III (6.0 Gbps) SLC: up to 120/100 MB/sec MLC: up to 450/150 MB/sec Commercial grade: 0 to +70° C Industrial grade: -40 to +85° C 1500, peak / 0.5 ms 20 G, peak / 80 ~ 2000 Hz 2,000,000 program/erase cycles 39.4 (L) x 25 (W) x 6.5 (H) (*)These values are for reference only; they may change according to the flash memory used. (*) These values are for reference only; they may change according to the flash memory used. Ordering Information PN SQF-SDMS1-1G-S9C(T/B) SQF-SDMS1-1G-S9E(T/B) SQF-SDMS2-XG-S9C(T/B) SQF-SDMS2-XG-S9E(T/B) SQF-SDMU2-XG-S9C(T/B) SQF-SDMU2-XG-S9E(T/B) SQF-SDMM1-4G-S9C(T/B) SQF-SDMM1-4G-S9E(T/B) SQF-SDMM2-XG-S9C(T/B) SQF-SDMM2-XG-S9E(T/B) Description SQFlash 630 series SATA DOM V (Top/Bottom) SLC, DMA, 1 GB (0 ~ 70° C) SQFlash 630 series SATA DOM V (Top/Bottom) SLC, DMA, 1 GB (-40 ~ 85° C) SQFlash 630 series SATA DOM V (Top/Bottom) SLC, DMA, 2/4/8/16/32 GB (0 ~ 70° C) SQFlash 630 series SATA DOM V (Top/Bottom) SLC, DMA, 2/4/8/16/32 GB (-40 ~ 85° C) SQFlash 630 series SATA DOM V (Top/Bottom) Ultra MLC, DMA, 4/8/16/32 GB (0 ~ 70° C) SQFlash 630 series SATA DOM V (Top/Bottom) Ultra MLC, DMA, 4/8/16/32 GB (-40 ~ 85° C) SQFlash 630 series SATA DOM V (Top/Bottom) MLC, DMA, 4 GB (0 ~ 70° C) SQFlash 630 series SATA DOM V (Top/Bottom) MLC, DMA, 4 GB (-40 ~ 85° C) SQFlash 630 series SATA DOM V (Top/Bottom) MLC, DMA, 8/16/32/64 GB (0 ~ 70° C) SQFlash 630 series SATA DOM V (Top/Bottom) MLC, DMA, 8/16/32/64 GB (-40 ~ 85° C) Ordering Information PN SQF-SDMS2-2G-J6C SQF-SDMS2-2G-J6E SQF-SDMS4-XG-J6C SQF-SDMS4-XG-J6E SQF-SDMM1-8G-J6C SQF-SDMM1-8G-J6E SQF-SDMM2-16G-J6C SQF-SDMM2-16G-J6E SQF-SDMM4-XG-J6C SQF-SDMM4-XG-J6E Description SQFlash 530 series SATA DOM V 2 GB SLC 2-CH (0 ~ 70° C) SQFlash 530 series SATA DOM V 2 GB SLC 2-CH (-40 ~ 85° C) SQFlash 530 series SATA DOM V 4/8/16/32/64 GB SLC 4-CH (0 ~ 70° C) SQFlash 530 series SATA DOM V 4/8/16/32/64 GB SLC 4-CH (-40 ~ 85° C) SQFlash 530 series SATA DOM V 8 GB MLC 1-CH (0 ~ 70° C) SQFlash 530 series SATA DOM V 8 GB MLC 1-CH (-40 ~ 85° C) SQFlash 530 series SATA DOM V 16 GB MLC 2-CH (0 ~ 70° C) SQFlash 530 series SATA DOM V 16 GB MLC 2-CH (-40 ~ 85° C) SQFlash 530 series SATA DOM V 32/64/128 GB MLC 4-CH (0 ~ 70° C) SQFlash 530 series SATA DOM V 32/64/128 GB MLC 4-CH (-40 ~ 85° C) Note: X stands for different capacities Note: X stands for different capacities Embedded M2M/IoT Modules All product specifications are subject to change without notice Last updated : 7-May-2015
APSDM008GB2AN-CT 价格&库存
很抱歉,暂时无法提供与“APSDM008GB2AN-CT”相匹配的价格&库存,您可以联系我们找货
