WNSC2D16650CJQ
WNSC2D16650CJQ
    WEEN(瑞能)
    TO-3P-3,SC-65-3
    二极管阵列 1 对共阴极 650 V 16A 通孔 TO-3P-3,SC-65-3
WNSC2D16650CJQ 数据手册
VS-C5PX3012L-N3 www.vishay.com Vishay Semiconductors Hyperfast Rectifier, 2 x 15 A FRED Pt® G5 FEATURES Base common cathode 2 • Hyperfast and optimized Qrr • Best in class forward voltage drop and switching losses trade off • Optimized for high speed operation 1 2 Anode 3 TO-247AD 3L • 175 °C maximum operating junction temperature Anode 2 1 Common 3 cathode • Polyimide passivation • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 LINKS TO ADDITIONAL RESOURCES 3D 3D DESCRIPTION / APPLICATIONS 3D Models Application Notes Featuring a unique combination of low conduction and switching losses, this rectifier is the right choice for high frequency converters, both soft switched / resonant. Specifically designed to improve efficiency of PFC and output rectification stages of EV / HEV battery charging stations, booster stage of solar inverters and UPS applications, these devices are perfectly matched to operate with MOSFETs or high speed IGBTs. PRIMARY CHARACTERISTICS IF(AV), per leg 15 A VR 1200 V VF at IF at 125 °C 2.1 V trr 29 ns TJ max. 175 °C Package TO-247AD 3L Circuit configuration Common cathode MECHANICAL DATA Case: TO-247AD 3L Molding compound meets UL 94 V-0 flammability rating Terminals: J-STD-002 matte tin plated leads, solderable per Polarity: as per marking device details ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL TEST CONDITIONS VALUES UNITS 1200 V Repetitive peak reverse voltage, per leg VRRM Average rectified forward current, per leg IF(AV) TC = 111 °C, D = 0.50 Repetitive peak forward current, per leg IFRM TC = 111 °C, D = 0.50, f = 20 kHz 30 Non-repetitive peak surge current, per leg IFSM TC = 45 °C, tp = 10 ms, sine wave 110 Operating junction and storage temperature TJ, TStg 15 A -55 to +175 °C ELECTRICAL SPECIFICATIONS (TJ = 25 °C unless otherwise specified) PARAMETER Breakdown voltage, blocking voltage, per leg Forward voltage, per leg SYMBOL VBR, VR VF TEST CONDITIONS MIN. TYP. MAX. 1200 - - IF = 15 A - 2.5 3.3 IR = 100 μA IF = 15 A, TJ = 125 °C - 2.1 - VR = VR rated - - 50 TJ = 125 °C, VR = VR rated - - 500 UNITS V Reverse leakage current, per leg IR Junction capacitance, per leg CT VR = 200 V - 10 - pF Series inductance, per leg LS Measured to lead 5 mm from package body - 8 - nH μA Revision: 16-May-2022 Document Number: 96616 1 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 VS-C5PX3012L-N3 www.vishay.com Vishay Semiconductors DYNAMIC RECOVERY CHARACTERISTICS (TJ = 25 °C unless otherwise specified) PARAMETER SYMBOL Reverse recovery time, per leg trr Peak recovery current, per leg Qrr Reverse recovery time, per leg trr Peak recovery current, per leg IRRM Reverse recovery charge, per leg MIN. TYP. MAX. - 29 44 TJ = 25 °C - 96 - TJ = 125 °C - 137 - TJ = 25 °C IRRM Reverse recovery charge, per leg TEST CONDITIONS IF = 1.0 A, dIF/dt = 100 A/μs, VR = 30 V TJ = 125 °C - 11.5 - - 16 - TJ = 25 °C - 375 - TJ = 125 °C - 900 - TJ = 25 °C - 77.5 - TJ = 125 °C - 106 - - 21 - - 29 - TJ = 25 °C TJ = 125 °C Qrr IF = 10 A dIF/dt = 600 A/μs VR = 400 V IF = 15 A dIF/dt = 1000 A/μs VR = 800 V UNITS ns A nC ns A TJ = 25 °C - 680 - TJ = 125 °C - 1600 - MIN. TYP. MAX. UNITS - - 1.4 °C/W - 6.0 - g 6.0 (5.0) - 12 (10) kgf · cm (lbf · in) -55 - 175 °C nC THERMAL - MECHANICAL SPECIFICATIONS PARAMETER SYMBOL Thermal resistance, junction-to-case, per leg TEST CONDITIONS RthJC Weight Mounting torque Maximum junction and storage temperature range TJ, TStg Case style TO-247AD 3L 100 C5PX3012L 1000 TJ = 175 °C IR - Reverse Current (µA) IF - Instantaneous Forward Current (A) Marking device TJ = 175 °C 10 TJ = 125 °C 1 TJ = 25 °C TJ = -40 °C 0.1 TJ = 150 °C 100 TJ = 125 °C 10 1 TJ = 25 °C 0.1 0.01 0 1.0 2.0 3.0 4.0 5.0 VF - Forward Voltage Drop (V) Fig. 1 - Forward Voltage Drop Characteristics, Per Leg 0 200 400 600 800 1000 1200 VR - Reverse Voltage (V) Fig. 2 - Typical Values of Reverse Current vs. Reverse Voltage, Per Leg Revision: 16-May-2022 Document Number: 96616 2 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 VS-C5PX3012L-N3 www.vishay.com Allowable Solder Pad Temperature (°C) Vishay Semiconductors CT - Junction Capacitance (pF) 100 10 1 0 200 400 600 800 1000 1200 180 170 160 150 DC 140 130 120 110 Square wave (D = 0.50) rated VR applied 100 90 80 0 VR - Reverse Voltage (V) 2 4 6 8 10 12 14 16 IF(AV) - Average Forward Current (A) Fig. 3 - Typical Junction Capacitance vs. Reverse Voltage, Per Leg Fig. 4 - Maximum Allowable Case Temperature vs. Average Forward Current, Per Leg 60 Average Power Loss (W) RMS limit 50 40 D = 0.10 D = 0.20 D = 0.25 D = 0.33 D = 0.50 D = 0.75 DC 30 20 10 0 0 5 10 15 20 25 IF(AV) - Average Forward Current (A) Fig. 5 - Forward Power Loss Characteristics, Per Leg ZthJC - Thermal Impedance Junction to Case (°C/W) 10 1 0.1 0.01 0.001 0.00001 0.50 0.20 0.10 0.05 0.02 0.01 DC 0.0001 0.001 0.01 0.1 t1 - Rectangular Pulse Duration (s) Fig. 6 - Transient Thermal Impedance, Junction to Case, Per Leg Revision: 16-May-2022 Document Number: 96616 3 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 VS-C5PX3012L-N3 www.vishay.com Vishay Semiconductors 250 1800 1600 10 A, 400 V 200 15 A, 800 V 1400 100 Qrr (nC) trr (ns) 1200 150 15 A, 800 V 10 A, 400 V 1000 800 600 400 50 TJ = 125 °C TJ = 125 °C 200 0 0 100 1000 100 1000 dIF/dt (A/µs) dIF/dt (A/µs) Fig. 7 - Typical Reverse Recovery Time vs. dIF/dt, Per Leg Fig. 8 - Typical Stored Charge vs. dIF/dt, Per Leg 35 30 TJ = 125 °C Irr (A) 25 20 15 A, 800 V 15 10 10 A, 400 V 5 0 100 1000 dIF/dt (A/µs) Fig. 9 - Typical Stored Charge vs. dIF/dt, Per Leg Revision: 16-May-2022 Document Number: 96616 4 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 VS-C5PX3012L-N3 www.vishay.com Vishay Semiconductors (3) trr ta IF tb t0 t10 % 0 0.1 IRRM (2) Qrr (4) IRRM di(rec)M/dt (5) (1) diF/dt Fig. 10 - Reverse Recovery Waveform and Definitions Notes (1) di /dt - rate of change of current through zero crossing F (2) I RRM - peak reverse recovery current (3) t - reverse recovery time measured from t , crossing point of negative going I , to point t rr 0 F 10%, 0.1 IRRM (4) Q - area under curve defined by t and t rr 0 10 % t 10 % Q rr =  I ( t ) dt t0 (5) di(rec)M/dt - peak rate of change of current during tb portion of trr ORDERING INFORMATION TABLE Device code VS- C 5 P X 30 12 L -N3 1 2 3 4 5 6 7 8 9 1 - Vishay Semiconductors product 2 - C = common cathode 3 - 5 = FRED generation 5 4 - Package: P = TO-247AD 3L 5 - X = hyperfast recovery 6 - Current rating (30 = 30 A) 7 - Voltage rating (12 = 1200 V) 8 - L = long lead 9 - Environmental digit: -N3 = halogen-free, RoHS-compliant, and totally lead (Pb)-free ORDERING INFORMATION (Example) PREFERRED P/N QUANTITY PER TUBE MINIMUM ORDER QUANTITY PACKAGING DESCRIPTION VS-CPX3012L-N3 25 500 Antistatic plastic tube LINKS TO RELATED DOCUMENTS Dimensions www.vishay.com/doc?95626 Part marking information www.vishay.com/doc?95007 Revision: 16-May-2022 Document Number: 96616 5 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 Outline Dimensions www.vishay.com Vishay Semiconductors TO-247AD 3L DIMENSIONS in millimeters and inches A A (3) (6) Φ P E B (2) R/2 A2 S (Datum B) Ø K M DBM Φ P1 A D2 Q 2xR (2) D1 (4) D 1 4 D 3 2 Thermal pad (5) L1 C L (4) E1 A 0.01 M D B M View A - A See view B 2 x b2 3xb C 2x e b4 A1 0.10 M C A M (b1, b3, b5) Plating Base metal D DE (c) c1 E C C (b, b2, b4) (4) Section C - C, D - D, E - E SYMBOL A A1 A2 b b1 b2 b3 b4 b5 c c1 D D1 MILLIMETERS MIN. MAX. 4.65 5.31 2.21 2.59 1.50 2.49 0.99 1.40 0.99 1.35 1.65 2.39 1.65 2.34 2.59 3.43 2.59 3.38 0.38 0.89 0.38 0.84 19.71 20.70 13.08 - INCHES MIN. MAX. 0.183 0.209 0.087 0.102 0.059 0.098 0.039 0.055 0.039 0.053 0.065 0.094 0.065 0.092 0.102 0.135 0.102 0.133 0.015 0.035 0.015 0.033 0.776 0.815 0.515 - View B NOTES 3 4 SYMBOL D2 E E1 e ØK L L1 ØP Ø P1 Q R S MILLIMETERS MIN. MAX. 0.51 1.30 15.29 15.87 13.46 5.46 BSC 0.254 19.81 20.32 3.71 4.29 3.56 3.66 6.98 5.31 5.69 4.52 5.49 5.51 BSC INCHES MIN. MAX. 0.020 0.051 0.602 0.625 0.53 0.215 BSC 0.010 0.780 0.800 0.146 0.169 0.14 0.144 0.275 0.209 0.224 0.178 0.216 0.217 BSC NOTES 3 Notes (1) Dimensioning and tolerancing per ASME Y14.5M-1994 (2) Contour of slot optional (3) Dimension D and E do not include mold flash. These dimensions are measured at the outermost extremes of the plastic body (4) Thermal pad contour optional with dimensions D1 and E1 (5) Lead finish uncontrolled in L1 (6) Ø P to have a maximum draft angle of 1.5 to the top of the part with a maximum hole diameter of 3.91 mm (0.154") (7) Outline conforms to JEDEC® outline TO-247 with exception of dimension A min., D, E min., Q min., S, and note 4 Revision: 06-Mar-2020 Document Number: 95626 1 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 Legal Disclaimer Notice www.vishay.com Vishay Disclaimer ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. Vishay Intertechnology, Inc., its affiliates, agents, and employees, and all persons acting on its or their behalf (collectively, “Vishay”), disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. Vishay makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, Vishay disclaims (i) any and all liability arising out of the application or use of any product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Statements regarding the suitability of products for certain types of applications are based on Vishay's knowledge of typical requirements that are often placed on Vishay products in generic applications. Such statements are not binding statements about the suitability of products for a particular application. It is the customer's responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Parameters provided in datasheets and / or specifications may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated for each customer application by the customer's technical experts. Product specifications do not expand or otherwise modify Vishay's terms and conditions of purchase, including but not limited to the warranty expressed therein. Hyperlinks included in this datasheet may direct users to third-party websites. These links are provided as a convenience and for informational purposes only. Inclusion of these hyperlinks does not constitute an endorsement or an approval by Vishay of any of the products, services or opinions of the corporation, organization or individual associated with the third-party website. Vishay disclaims any and all liability and bears no responsibility for the accuracy, legality or content of the third-party website or for that of subsequent links. Except as expressly indicated in writing, Vishay products are not designed for use in medical, life-saving, or life-sustaining applications or for any other application in which the failure of the Vishay product could result in personal injury or death. Customers using or selling Vishay products not expressly indicated for use in such applications do so at their own risk. Please contact authorized Vishay personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of Vishay. Product names and markings noted herein may be trademarks of their respective owners. © 2023 VISHAY INTERTECHNOLOGY, INC. ALL RIGHTS RESERVED Revision: 01-Jan-2023 1 Document Number: 91000
WNSC2D16650CJQ 价格&库存
很抱歉,暂时无法提供与“WNSC2D16650CJQ”相匹配的价格&库存,您可以联系我们找货
