1000 Eaton Boulevard
Cleveland, OH 44122
United States
200–240V 6000VA 6000W On-Line DoubleConversion UPS, Unity Power Factor, Hardwire
In, HW/C19/C13 Out, 3U
Highlights
Unity (1.0) power factor
equalizes VA and wattage to
safely support more equipment
Zero transfer time between online and battery modes for
uninterrupted operation
Optional external battery packs
provide additional runtime for
applications requiring it
Pre-installed WEBCARDLXMINI
network interface supports Auto
Probe feature
ENERGY STAR-certified to
save electricity, lower costs and
protect the environment
MODEL NUMBER: SU6KRT3UG
Applications
On-line double-conversion UPS provides pure sine wave AC output to server and network equipment in
data centers and computer rooms.
Delivering perfectly regulated
sine wave output to missioncritical equipment
Protecting connected
components from dangerous
surges, spikes and line noise
Keeping equipment operational
through short power failures
Allowing time to save data and
safely shut down components in
case of a prolonged blackout
Features
Protects Mission-Critical Rack-Mounted Equipment against Damage, Downtime and Data
LossSmartOnline® SU6KRT3UG Unity Power Factor UPS system protects connected equipment against
damage, downtime and data loss due to power outages, voltage fluctuations and transient surges. Unity
Power Factor design enables full 6000VA / 6000W output capacity. In double-conversion mode, this UPS
system maintains perfect output by continuously converting AC input to DC, then reconverting UPS output
to fully regulated sine wave AC with ±1% voltage regulation and zero transfer time between online and
battery modes. Featuring true on-line, double-conversion operation, SU6KRT3UG provides the highest
level of UPS power protection for critical server, network and telecom equipment.
Reliable, Expandable Battery BackupUPS battery backup keeps connected equipment operational
through short power failures, and provides time to save data and perform an orderly system shutdown in
case of a prolonged blackout. The internal battery set provides 8.5 minutes of support at half load and 3
minutes at full load. During normal operation, incoming utility power keeps the battery fully charged so
backup power will be available when needed. Advanced temperature-controlled battery charge
management system provides efficient recharge and enhanced battery lifespan. For mission-critical
applications demanding continuous uptime, the 6kVA UPS can provide expandable runtime with optional
BP192V12RT3US external battery pack (sold separately). Battery-independent restart ensures automatic
UPS power-up after lengthy power outages, even with expired batteries.
Economy Mode Helps the Environment and Your Cash FlowOperates with >98% full-load efficiency in
optional economy mode significantly reducing BTU heat output and operating energy costs.
Intuitive Front-Panel Interface offers Convenient MonitoringFront-panel LEDs indicate line power, AC
output, On-battery mode, and Fault conditions. The LCD readout with scroll controls supports visual
monitoring of a variety of control options to support advanced UPS settings and configurations. The panel
rotates for comfortable viewing in rack-mount or tower configuration.
Pre-installed WEBCARDLXMINI Network Interface Offers 24/7 AccessPre-installed Java-free HTML5based WEBCARDLXMINI interface enables full remote access for site power and UPS status monitoring,
configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports
10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Automated alerts help
1/6
Package Includes
network management card
(2) Hardwire strain reliefs
USB cable
RS-232 cable
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
prevent accidental overloads, power loss and downtime. Advanced Communications Ports USB and DB9
ports with included cabling enable data-saving unattended shutdown of connected systems when used
with free downloadable PowerAlert® software. Capabilities include detailed monitoring of load levels, selftest data and utility power conditions. DB9 ports also support basic contact-closure monitoring to report
On-battery and Low-battery status for legacy systems.
Versatile Installation OptionsHardware is included for mounting the complete 6kVA UPS system with
internal batteries in 3U of space in an EIA-standard 19-inch 4-post rack. Use the optional
2POSTRMKITHD for 2-post rack mounting or the optional 2-9USTAND for mounting in an upright tower
position.
2-Year Warranty, $250K Ultimate Lifetime Insurance and Environmentally Responsible DesignThe
SU6KRT3UG comes with a 2-year warranty and $250,000 of Ultimate Lifetime Insurance for any
connected components damaged by a power surge (U.S., Canada and Puerto Rico only). It’s
manufactured in compliance with strict RoHS specifications, reflecting commitment to environmental
responsibility.
Specifications
OVERVIEW
UPC Code
037332223319
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
Hardwire AC input: 32A (200V), 30.7A (208V), 29A (220V), 27.8A (230V), 26.6A (240V) maximum; Max inrush
current: 100A
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Nominal Input Voltage Description
208V factory default
UPS Input Connection Type
Hardwire
UPS Input Connection Description
Hardwire input supports 3 wire L1, L2/N, PE(GND) input configurations
Input Current
50 / 60 Hz
Power Factor (Input)
0.98 minimum (full load, nominal input voltage)
THDi
很抱歉,暂时无法提供与“SU6KRT3UG”相匹配的价格&库存,您可以联系我们找货
