东莞铭普光磁股份有限公司
Dongguan Mentech Optical & Magnetic Co., Ltd.
Product Specification for Approval
WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL.
CUSTOMER
DESCRIPTION
10/100 BASE-T TRANSFORMER
MNC P/N
H2002DG
VERSION
A0
CUSTOMER P/N
ISSUED DATE
PHOTO OF PRODUCT
WEIGHT
1.83g
MADE IN
CHINA
2020/04/27
APPROVED BY MNC
PREPARED
BY
CHECKED
BY
APPROVED
BY
研发部
研发部
研发部
2020-04-27
2020-04-27
2020-04-27
符晶晶
肖明华
何校民
APPROVED BY CUSTOMER
SIGNATURE OR STAMP
1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE
ONCE THE SAMPLES APPROVED.
2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK.
东莞铭普光磁股份有限公司
TEL: +86-769-86921000
Add:Shipai Town, Dongguan City,Guangdong Province,China
FAX: +86-769-81701563
----------------------------------------------------------------------FORM-MT-0135REV.04
www.mnc-tek.com
东莞铭普光磁股份有限公司
HISTORY FOR REVISED SPECIFICATION
Part No.
H2002DG
INDEX
1. INDEX---------------------------------------------------------------------------------------------------------1
2. CHANGE RECORD---------------------------------------------------------------------------------------- 1
3. MECHANICAL----------------------------------------------------------------------------------------------2
4. SCHEMATIC-------------------------------------------------------------------------------------------------3
5. PACKING-----------------------------------------------------------------------------------------------------4
6. MATERIAL LIST------------------------------------------------------------------------------------------- 5
7. RECOMMENDED SOLDERING PROFILE------------------------------------------------------------6
CHANGE RECORD
REV.
A0
DESCRIPTION
(Content or Reason For Change)
INITIAL RELEASE
DATE
REVISOR
2020-04-27
Jingjing Fu
www.mnc-tek.com
1/6
东莞铭普光磁股份有限公司
SPECIFICATION
Part No.
H2002DG
A. MECHANICAL :
A
1
1
J
H2002DG
YYWWX
1
B
K
SUGGESTED PAD LAYOUT
C
E
F
G
H
D
Note:White ink marking
YY WW X
1.UNITS:mm/inch.
2.UNLESS OTHERWISE SPECIFIED ALL
TOLERANCES ARE: TYPICAL
3.PIN LENGTH DON'T INCLUDE SOLDER POINT
Production line code
( A to Z)
Week
Year
MILLIMETERS
INCHES
DIM
MIN
NOM
MAX
MIN
NOM
MAX
A
20.70
21.20
21.70
0.815
0.835
0.854
B
9.50
10.00
10.50
0.374
0.394
0.413
C
6.75
0.266
D
17.50
18.00
18.50
0.689
0.709
0.728
E
2.90
3.20
3.50
0.114
0.126
0.138
F
2.00
0.079
G
0.50
0.020
H
7.12
7.62
8.12
0.280
0.300
0.320
I
0.80
0.031
J
7.62
0.300
K
18.00
0.709
www.mnc-tek.com
2/6
东莞铭普光磁股份有限公司
SPECIFICATION
Part No.
H2002DG
B. SCHEMATIC :
1CT:1CT
1
19
TX
TD1
3
4
18
17
5
16
1CT:1CT
RX
RD1
1CT:1CT
6
15
RX
RD2
14
7
8
9
13
12
10
11
1CT:1CT
TD2
TX
C. ELECTRICAL SPECIFICATION @25℃
ITEM
SPECIFICATION TEST CONDITION TEST EQUIPMENT
INDUCTANCE :
350uH MIN.
100KHz 0.2V 8mA
TH2819XB OR EQU.
DC Bias
LEAKAGE INDUCTANCE :
0.50uH MAX.
100KHz 0.2V
TH2819XB OR EQU.
INTERWINDING CAPACITANCE :
50pF TYP.
100KHz 0.2V
TH2819XB OR EQU.
DC RESISTANCE :
1.2Ω MAX.
AT 25 ℃
TH2819XB OR EQU.
TURNS RATIO :
1CT:1CT±2%
POLARITY :
1-20,4-17,6-15,9-12
IN-PHASE
INSERTION LOSS :
-1.1dB MAX.
0.5-100 MHz
-18dB MIN.
0.5-30 MHz
-18+20*log(f/30)dB MIN.
30.1-60MHz
-12dB MIN.
60.1-80MHz
-35dB MIN.
0.5-40 MHz
-33+20*log(f/50)dB MIN.
40.1-100 MHz
-30dB MIN.
0.5-100 MHz
1500VAC
1mA,60S
1650VAC
1mA,6S
RETURN LOSS :
CROSS TALK :
CMRR :
ISOLATION HI-POT :PRI TO SEC
OPERATING TEMPERATURE
TH2819XB OR EQU.
E5061A OR EQU.
E5061A OR EQU.
E5061A OR EQU.
E5061A OR EQU.
7152AB OR EQU.
0℃ TO 70℃
www.mnc-tek.com
3/6
东莞铭普光磁股份有限公司
PACKAGE
Part No.
H2002DG
D. PACKING:
a. PACKAGING AS BELOW (ONLY FOR A REFERENCE):
530±2
0.5±0.1
E 4.5
B 7.8
A 12.3
C 11.6
D 4.3±0.3
PLUG
PLUG
SEAL
5g DESICCANT
PUT SMALL CARTON
3
4
PUT BIG CARTON
2
2
1
1
b. Q'TY:
c. LABEL:
24 PCS PER TUBE
5 TUBES PER BUNDLE (120 PCS)
10 BUNDLES PER BAG (1200 PCS)
1 BAG PER SMALL CARTON
4 SMALL CARTON PER BIG CARTON(4800 PCS)
REMARK:
ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE.
www.mnc-tek.com
4/6
东莞铭普光磁股份有限公司
MATERIAL LIST
Part No.
H2002DG
E.BOM
MATERIAL LIST
NO.
ITEM
MATERIAL
RATING
SUPPLIER OF MATERIAL
UL
YEAN SHING
N/A
ZHONGSHAN CRC
ELECTRONICS FACTORY
N/A
YEAN SHING
N/A
ZHONGSHAN CRC
ELECTRONICS FACTORY
N/A
QPN180
180℃
ZHUHAI SUNTEK
WIRE CO.,LTD
E234867
Polysol 180
180℃
ELEKTRISOLA(MALAYSIA)
SDN.BHD.
E258243
PF2A5-151J(b)
V-0
CHANGSHU SOUTH-EAST
PLASTIC CO.,LTD
E136137
T378J
V-0
CHANG CHUN
CHEMICAL(ZHANGZHOU)
CO.,LTD.
E59481
CP WIRE
HIFAM
N/A
DONGGUAN EATTO
ELECTRONIC MATERIAL
CO.,LTD
E218090
Mn-Zn
1
CORE
Ni-Zn
2
3
4
5
COPPER
WIRE
CASE
PIN
EPOXY
3300A/B
www.mnc-tek.com
5/6
东莞铭普光磁股份有限公司
Part No.
H2002DG
a. RECOMMENDED WAVE SOLDERING PROFILE:
CONDITION:
a.1. AVAILABLE FOR ALL THE THROUGH HOLE PARTS
a.2. SOLDERING METHOD: WAVE SOLDERING
a.3. SOLDER: Sn-0.7Cu
a.4. THE RECOMMENDED WAVE SOLDERING CURVE IS AS BELOW
b. MOISTURE SENSITIVE LEVEL:
b.1. LEVEL: 1
b.2. SHELF LIFE: UNLIMITED
b.3. STORAGE CONDITION: ≦30℃/85% RH
www.mnc-tek.com
6/6
很抱歉,暂时无法提供与“H2002DG”相匹配的价格&库存,您可以联系我们找货
